  3. Broken Parts
Broken Parts
voxl-2
52 Posts 4 Posters 29.6k Views 1 Watching
    wrote on last edited by tom
    #11
    @Bright-Nnadi nnadibright33@gmail.com
      Bright NnadiB Offline
      Bright Nnadi
      @tom okay haven't anything yet
        @Bright-Nnadi I will try your other email
          Bright Nnadi
          @tom Okay thanks
          • Bright NnadiB Offline
            Bright Nnadi
            Hey Tom,
            Please i have been looking at y'alls documentation for a while now. I still haven't found the pinout of the VOXL 2 flight deck yet. Please can you send me a image with labelled pinouts of the VOXL Flight Deck.
            • ? Offline
              The connectors and pinouts for them can be found here
              • ? A Former User
                Bright Nnadi
                @Alex-Gardner Thanks Alex, so my VOXL 2 is already assembled so its hard for me to find where each pinout are located. The labels aren't showing because the 3D model is covering it. Is it possible to set up a meeting with you sometime or you can send a video where you are plugging in stuffs to the assembled VOXL 2. (I could also take out the 3D model but I prefer not too since its fragile)
                  @Bright-Nnadi the photos you sent me were of a VOXL CAM not a VOXL2, is that what you are referencing? Or is this different hardware that you’re talking about now
                  Bright NnadiB 3 Replies Last reply
                    Bright Nnadi
                    @tom yes the VOXL CAM
                      Bright Nnadi
                      @tom My bad I have been mixing up the VOXL CAM with the VOXL 2 all this time.
                        Bright Nnadi
                        @tom Do y'all have sell the VOXL ESC USB interface
                          @Bright-Nnadi Is this what you're referencing? https://www.modalai.com/products/voxl-esc
                          Bright NnadiB 2 Replies Last reply
                            Bright Nnadi
                            @tom I am talking about this https://docs.modalai.com/modal-esc-v2-manual/
                              @Bright-Nnadi Yes, that is the same as what I linked above.
                                Bright Nnadi
                                @tom Okay thanks Tom
                                  Bright Nnadi
                                  Hey Tom , So i am trying to set up the VOXL CAM now. I have turned it on using the power module and the USB and the LED is solid green but I am not seeing the VOXL wifi.
                                    @Bright-Nnadi When you say you aren't seeing the VOXL WiFi, are you saying you want VOXL to be in SoftAP and are trying to connect to it with a computer? Or are you trying to put it in station mode and have it connect to an external network?
                                      Bright Nnadi
                                      @tom I am following the VOXL CAM Start guide and it says to connect to the VOXL wifi after powering it on. I am trying to connect it to my computer
                                        @Bright-Nnadi Are you using ADB in order to access the VOXL's shell? If so, what is the output of ifconfig ?
                                          Bright Nnadi
                                          @tom 0e324744-66bb-42f8-b599-e4df4cb37dec-image.png output
