  3. Broken Parts
Broken Parts
voxl-2
52 Posts 4 Posters 29.6k Views 1 Watching
    @Bright-Nnadi I sent it at 10:18 PST
    Bright NnadiB Offline
    Bright Nnadi
    @tom which email address? Nnadibright33@gmail.com or bnnadi@islander.tamucc.edu?
      wrote on last edited by tom
      #11
      @Bright-Nnadi nnadibright33@gmail.com
        Bright Nnadi
        @tom okay haven't anything yet
          @Bright-Nnadi I will try your other email
            Bright Nnadi
            @tom Okay thanks
            • Bright NnadiB Offline
              Bright Nnadi
              Hey Tom,
              Please i have been looking at y'alls documentation for a while now. I still haven't found the pinout of the VOXL 2 flight deck yet. Please can you send me a image with labelled pinouts of the VOXL Flight Deck.
              • ? Offline
                The connectors and pinouts for them can be found here
                • ? A Former User
                  Bright Nnadi
                  @Alex-Gardner Thanks Alex, so my VOXL 2 is already assembled so its hard for me to find where each pinout are located. The labels aren't showing because the 3D model is covering it. Is it possible to set up a meeting with you sometime or you can send a video where you are plugging in stuffs to the assembled VOXL 2. (I could also take out the 3D model but I prefer not too since its fragile)
                    @Bright-Nnadi the photos you sent me were of a VOXL CAM not a VOXL2, is that what you are referencing? Or is this different hardware that you’re talking about now
                    Bright NnadiB 3 Replies Last reply
                      Bright Nnadi
                      @tom yes the VOXL CAM
                        Bright Nnadi
                        @tom My bad I have been mixing up the VOXL CAM with the VOXL 2 all this time.
                          Bright Nnadi
                          @tom Do y'all have sell the VOXL ESC USB interface
                            @Bright-Nnadi Is this what you're referencing? https://www.modalai.com/products/voxl-esc
                            Bright NnadiB 2 Replies Last reply
                              Bright Nnadi
                              @tom I am talking about this https://docs.modalai.com/modal-esc-v2-manual/
                                @Bright-Nnadi Yes, that is the same as what I linked above.
                                  Bright Nnadi
                                  @tom Okay thanks Tom
                                    Bright Nnadi
                                    Hey Tom , So i am trying to set up the VOXL CAM now. I have turned it on using the power module and the USB and the LED is solid green but I am not seeing the VOXL wifi.
                                      @Bright-Nnadi When you say you aren't seeing the VOXL WiFi, are you saying you want VOXL to be in SoftAP and are trying to connect to it with a computer? Or are you trying to put it in station mode and have it connect to an external network?
                                        Bright Nnadi
                                        @tom I am following the VOXL CAM Start guide and it says to connect to the VOXL wifi after powering it on. I am trying to connect it to my computer
                                          @Bright-Nnadi Are you using ADB in order to access the VOXL's shell? If so, what is the output of ifconfig ?
