  2. VOXL Compute & Autopilot
  3. VOXL Flight
  4. UVC-Server to QGC Stream Activation
Scheduled Pinned Locked Moved VOXL Flight
17 Posts 2 Posters 2.5k Views 2 Watching
  • Caleb RievleyC Offline
    Caleb Rievley
    The voxl-uvc-server is recognizing our camera. How can we initiate the stream and view it on QGC?
    • Caleb RievleyC Caleb Rievley
      Eric KatzfeyE Online
      @Caleb-Rievley The documentation for voxl-uvc-server is here: https://docs.modalai.com/voxl-uvc-server/. To get the stream to show on QGC you use it in conjunction with voxl-streamer. The documentation for voxl-streamer is here: https://docs.modalai.com/voxl-streamer/. Specifically, take a look at this section: https://docs.modalai.com/voxl-streamer/#streaming-uvc-cameras-from-voxl-uvc-server
      Caleb RievleyC 1 Reply Last reply
        Caleb Rievley
        After using command, voxl-streamer , the prompt says Using configuration file /etc/modai/voxl-streamer.conf and does nothing else. The documentation says that it should output that the stream is available @rtsp..... Is this normal?
          Caleb Rievley
            Caleb Rievley
            @Eric-Katzfey By the way, we are using a USB camera. It shows up as a UVC Camera so I believe that it is compatible.
              @Caleb-Rievley Use voxl-streamer -d to get more verbose output.
                Caleb Rievley
                  @Caleb-Rievley If voxl-uvc-server found it then it should be a valid USB UVC camera.
                    @Caleb-Rievley Were you able to access https://docs.modalai.com/voxl-streamer/? That documentation explains how to configure and choose the desired camera. In the output above it shows that you did not choose a configuration which means that it is defaulting to the hires camera configuration.
                    Caleb RievleyC 2 Replies Last reply
                      Caleb Rievley
                      What configuration do we use for a USB UVC camera?
                        Caleb Rievley
                        @Eric-Katzfey I also tried this
                          Caleb Rievley
                            @Caleb-Rievley Once voxl-uvc-server has started successfully you can use voxl-streamer to stream the video. As per the instructions at: https://docs.modalai.com/voxl-streamer/#streaming-uvc-cameras-from-voxl-uvc-server you need to use configuration uvc-generic, not uvc-video. And don't use the -u option.
                              Caleb Rievley
                              Today we did a system flash and went through steps to reconnect our microhard and have control through microhard. We Installed and configured our voxl-vision-px4. We are now trying to update the opkg package and it is not finding the server. We checked to make sure that the internet is connected as you can see in the top part of the window. What could be causing this issue? Our goal is to install the uvc-server.
                                @Caleb-Rievley You probably don't have connectivity to the internet. It would be best to get everything setup without Microhard and then setup Microhard last. Having both Microhard running and wlan can cause problems connecting to the internet.
                                  Caleb Rievley
                                  @Eric-Katzfey Thank you that worked. We did have to remove the microhard. We think that we remember that the connectivity worked with the microhard before we flashed it? Is that a possibility?
                                    @Caleb-Rievley Generally, that won't work.
