    UVC-Server to QGC Stream Activation
    VOXL Flight
    1024
    • Caleb RievleyC
      Caleb Rievley
      The voxl-uvc-server is recognizing our camera. How can we initiate the stream and view it on QGC?
        Eric Katzfey ModalAI Team @Caleb Rievley
        @Caleb-Rievley The documentation for voxl-uvc-server is here: https://docs.modalai.com/voxl-uvc-server/. To get the stream to show on QGC you use it in conjunction with voxl-streamer. The documentation for voxl-streamer is here: https://docs.modalai.com/voxl-streamer/. Specifically, take a look at this section: https://docs.modalai.com/voxl-streamer/#streaming-uvc-cameras-from-voxl-uvc-server
        Caleb RievleyC 1 Reply Last reply Reply Quote 0
        • Caleb RievleyC
          Caleb Rievley
          After using command, voxl-streamer , the prompt says Using configuration file /etc/modai/voxl-streamer.conf and does nothing else. The documentation says that it should output that the stream is available @rtsp..... Is this normal?
          • Caleb RievleyC
            Caleb Rievley @Caleb Rievley
            • Caleb RievleyC
              Caleb Rievley @Eric Katzfey
              @Eric-Katzfey By the way, we are using a USB camera. It shows up as a UVC Camera so I believe that it is compatible.
                @Caleb-Rievley Use voxl-streamer -d to get more verbose output.
                • Caleb RievleyC
                    @Caleb-Rievley If voxl-uvc-server found it then it should be a valid USB UVC camera.
                      @Caleb-Rievley Were you able to access https://docs.modalai.com/voxl-streamer/? That documentation explains how to configure and choose the desired camera. In the output above it shows that you did not choose a configuration which means that it is defaulting to the hires camera configuration.
                      Caleb RievleyC 2 Replies Last reply Reply Quote 0
                      • Caleb RievleyC
                        Caleb Rievley
                        What configuration do we use for a USB UVC camera?
                        • Caleb RievleyC
                          @Eric-Katzfey I also tried this
                          • Caleb RievleyC
                              @Caleb-Rievley Once voxl-uvc-server has started successfully you can use voxl-streamer to stream the video. As per the instructions at: https://docs.modalai.com/voxl-streamer/#streaming-uvc-cameras-from-voxl-uvc-server you need to use configuration uvc-generic, not uvc-video. And don't use the -u option.
                              • Caleb RievleyC
                                Today we did a system flash and went through steps to reconnect our microhard and have control through microhard. We Installed and configured our voxl-vision-px4. We are now trying to update the opkg package and it is not finding the server. We checked to make sure that the internet is connected as you can see in the top part of the window. What could be causing this issue? Our goal is to install the uvc-server.
                                  @Caleb-Rievley You probably don't have connectivity to the internet. It would be best to get everything setup without Microhard and then setup Microhard last. Having both Microhard running and wlan can cause problems connecting to the internet.
                                  • Caleb RievleyC
                                    @Eric-Katzfey Thank you that worked. We did have to remove the microhard. We think that we remember that the connectivity worked with the microhard before we flashed it? Is that a possibility?
                                      @Caleb-Rievley Generally, that won't work.
