  3. No able to update the time using time-sync
27 Posts 2 Posters 8.3k Views 1 Watching
    Was your previous test in the same location as well?
    Aldo Castro FreireA 1 Reply Last reply
    • Aldo Castro FreireA Offline
      Aldo Castro Freire
      this is what I get
        Aldo Castro Freire
        @tom same location.
          @Aldo-Castro-Freire And pinging google.com fails the same as 8.8.8.8?
            Aldo Castro Freire
            it just hangs there, it does not even try I believe!!
              @Aldo-Castro-Freire Interesting, form what I can see, everything looks like it's running correctly on the software side since you're able to get an IP just fine but the internet connection itself doesn't work...
              What does your antenna situation look like?
                Aldo Castro Freire
                wrote on last edited by Aldo Castro Freire
                #17
                it was power-off at the moment of the photo
                  @Aldo-Castro-Freire Okay that looks normal. Can you try testing the SIM card in another device such as a cellphone to verify it can establish a valid network connection at your location?
                    Aldo Castro Freire
                    it is working fine on my phone
                      Aldo Castro Freire
                      I saw the wlan has a number for some odd reason
                        @Aldo-Castro-Freire Looks like wlan0 is in softap mode, try doing ifconfig wlan0 down and then pinging. I wonder if the routing is getting confused
                          Aldo Castro Freire
                          #22
                          after that ping just hangs there
                            @Aldo-Castro-Freire Next thing to try
                            Disable the voxl-modem service from running automatically with:
                            systemctl disable voxl-modem
                            Then reboot your VOXL with:
                            reboot
                            (or power cycle)
                            Then ADB back in and run:
                            voxl-modem-start.sh
                            and paste that output here as well as open a new shell and see if you're able to ping
                              This would be running through what the voxl-modem service does in the background but gives us better visibility
                                Aldo Castro Freire
                                this is my output
                                but it does not update time and no access to internet
                                  @Aldo-Castro-Freire From what I can see, everything looks good on both the hardware and the software side. It's possible it's an issue with the carrier.
                                  We use GoogleFi for all of our testing so I unfortunately can't provide any guidance on anything related to your carrier.
                                    Aldo Castro Freire
                                    Today I tried using another provider for the SIM and it connected to the internet. Not sure where to start debugging this cause it is getting an IP, but I figure it needs internet access to get the time ?
