  3. No able to update the time using time-sync
27 Posts 2 Posters 8.3k Views 1 Watching
    @Aldo-Castro-Freire Okay so that is a different issue and voxl-time-sync is not affecting that at all.
    What kind of LTE modem are you using and what carrier?
    • Aldo Castro FreireA Offline
      Aldo Castro Freire
      it is using the LTE modem https://www.modalai.com/collections/voxl-add-ons/products/voxl-lte?variant=32449203601459 WP7610.
      it is currently using the Telus carrier, apn is isp.telus.com
        @Aldo-Castro-Freire Where are you located? Depending on your location the modem / SIM may not be supported.
          @Aldo-Castro-Freire And has it worked in the past?
            Aldo Castro Freire
            the current location is Okotoks, Alberta, Canada. It was working fine a week ago but today it wasn't working. I have a 40Gbs plan. I got the sim in the same place and it was working fine
              @Aldo-Castro-Freire What does ifconfig wwan0 show ? And what if you just try pinging www.google.com
                Actually the full output of ifconfig may be more helpful
                  Was your previous test in the same location as well?
                  Aldo Castro FreireA 1 Reply Last reply
                    Aldo Castro Freire
                    this is what I get
                      Aldo Castro Freire
                      @tom same location.
                        @Aldo-Castro-Freire And pinging google.com fails the same as 8.8.8.8?
                          Aldo Castro Freire
                          it just hangs there, it does not even try I believe!!
                            @Aldo-Castro-Freire Interesting, form what I can see, everything looks like it's running correctly on the software side since you're able to get an IP just fine but the internet connection itself doesn't work...
                            What does your antenna situation look like?
                              Aldo Castro Freire
                              wrote on last edited by Aldo Castro Freire
                              #17
                              it was power-off at the moment of the photo
                                @Aldo-Castro-Freire Okay that looks normal. Can you try testing the SIM card in another device such as a cellphone to verify it can establish a valid network connection at your location?
                                  Aldo Castro Freire
                                  it is working fine on my phone
                                    Aldo Castro Freire
                                    I saw the wlan has a number for some odd reason
                                      @Aldo-Castro-Freire Looks like wlan0 is in softap mode, try doing ifconfig wlan0 down and then pinging. I wonder if the routing is getting confused
                                        Aldo Castro Freire
                                        #22
                                        after that ping just hangs there
                                          @Aldo-Castro-Freire Next thing to try
                                          Disable the voxl-modem service from running automatically with:
                                          systemctl disable voxl-modem
                                          Then reboot your VOXL with:
                                          reboot
                                          (or power cycle)
                                          Then ADB back in and run:
                                          voxl-modem-start.sh
                                          and paste that output here as well as open a new shell and see if you're able to ping
