  3. Not able to flash using debug board
voxl
22 Posts 7 Posters 6.5k Views 4 Watching
  • modaltbM modaltb
    @Gaurav-Borade not sure why it didn't make it to youtube yet, but here's a link for now: https://drive.google.com/file/d/1lPK5ypVNkRDaCLJSWZa_J7Cx84tZ2Q_G/view?usp=sharing
    G Offline
    G Offline
    Gaurav Borade
    @modaltb Thank you for this
    • G Offline
      G Offline
      Gaurav Borade
      wrote on last edited by Gaurav Borade
      #11
      Hi, @modaltb I tried with it, but still have not succeeded 😐
      Two things I want to confirm
      1. Am I using the right system image? I am using VOXL Platform Release 3-3-0 0.4.6 b downloaded from https://developer.modalai.com/asset
      2. The cable, in the video I can see the cable like below cable in video.JPG
      Is this cable will work? or do I need the same cable shown in the video? please let me know if am doing something wrong here.
      • modaltbM Offline
        modaltbM Offline
        modaltb
        Hi @Gaurav-Borade ,
        You are correct, the USB cable you have is fine and the image is also OK.
        Question: are you using an Ubuntu VM on another host machine? This is something I'm not positive about, should be OK but just not something we've tested too much.
        G 1 Reply Last reply
        • modaltbM modaltb
          Hi @Gaurav-Borade ,
          G Offline
          G Offline
          Gaurav Borade
          @modaltb Thank you for the confirmation on the USB cable.
          Yes, I am using Ubuntu Virtual Box. The board was communicating fine with the Virtual Box previously (Before bricked) so unbricking on that only. I will try it on another machine as well.
          • Jae ParkJ Offline
            Jae ParkJ Offline
            Jae Park
            @tom Hi, I'm the op of this post (link) but thought I would ask my question here since it seems to belong here now.
            I am following the Unbricking VOXL instruction. More specifically, here's what I'm doing.
            • Before anything is plugged in, I left the FASTBOOT switch on and the Debug board is already attached.
            • Plug in the (1) cable for power
            • Plug in cable (3) -- just a micro-usb
            • Wait 5 sec, turn off the FASTBOOT switch.
            • sudo fastboot devices
              And this returns nothing. I've also tried adding cable (2) right after I plug in power which didn't work (I've tried many things..)
              Please advise if I'm doing anything wrong. Thank you!
            Jae
            • Jae ParkJ Jae Park
              Jae
              @Jae-Park if you do a watch fastboot devices do you ever see it come up? Another thing to check, what is your output of lsusb after about 30 seconds of having the Voxl-flight powered up and plugged in to your pc?
              Also cable “2” is unrelated to this process
              Jae ParkJ 1 Reply Last reply
                Jae ParkJ Offline
                Jae ParkJ Offline
                Jae Park
                wrote on last edited by Jae Park
                #16
                Here is the output from lsusb. (once before attaching the power&micro-usb and again but 30 seconds after attaching them)
                Also, I retried it again, following the exact steps I had described above, while watching on watch -n 1 fastboot devices. And, nothing had showed up.
                  @Jae-Park Can you do the same lsusb test without the debug board attached?
                    Jae ParkJ Offline
                    Jae ParkJ Offline
                    Jae Park
                    #18
                    This is after attaching cable (1) and (3), in the order, and running lsusb (waited some time before running the command).
                      @Jae-Park It appears to me as though the VOXL portion of your VOXL-Flight is in a "bricked" state that is not fixable without sending it in for inspection. Refer to this RMA page for more info: https://modalai.com/rma
                        Jae ParkJ Offline
                        Jae ParkJ Offline
                        Jae Park
                        #20
                        • Jae ParkJ Offline
                          Jae ParkJ Offline
                          Jae Park
                          @tom Would it be going in for RMA PCB or Drone? It seems like PCB is what I'd want to choose.
                          Also, if that is the case, can I ship out just the board, or would it have to be the entire drone itself? Thank you.
                            @Jae-Park You should ship out the entire drone so that the team can verify that all of the components are functional, fix anything else that you may not have seen, and do a final flight test before sending back.
