  3. Not able to flash using debug board
voxl
22 Posts 7 Posters 6.8k Views 4 Watching
  • modaltbM Offline
    modaltbM Offline
    modaltb
    Hi @Gaurav-Borade ,
    Not the "emergency boot" switch is for a production tool only, not used in the field.
    We've had some folks recently where changing PCs has "resolved" the issue, what host OS is on your PC?
    To double check, are you treating the 'fastboot' switch like a momentary button? The idea is that we boot up with the fastboot switch on but then turn the switch off....
    In many cases leaving it 'on' is OK, but there's times when that itself causes issues.
    • G Offline
      G Offline
      Gaurav Borade
      Hi @modaltb , Thank you for the reply.
      Thank you for the clarification on the emergency boot switch.
      I have Windows 10 OS on my PC. Thank you for the advice, Will try with another PC.
      Yes, I am following the same process mentioned on https://docs.modalai.com/unbrick-voxl/ (Force VOXL into fastboot)
      I will retry this again. Also, for reference do you have any video for these unbricking steps?
      • modaltbM Offline
        modaltbM Offline
        modaltb
        @Gaurav-Borade , we have one in the works that should be ready shortly, I'll send a link once we get it posted!
        • J Offline
          J Offline
          jonathan
          Any update on this? I've tried the same process as @Gaurav-Borade, including the instructions here:
          https://docs.modalai.com/usb-expander-and-debug-user-guide/
          and I also see nothing listed under sudo fastboot devices.
          Using the usb-expander-and-debug-user-guide I'm able to start a screen to /dev/ttyUSB0, but I can't get adb shell to work after the screen is started.
          I'm on Ubuntu Linux 18.04, I'll switch to another Ubuntu 18.04 machine and re-run the debricking procedure to see if anything changes.
          G 1 Reply Last reply
            If it was working before, and you can confidently get other boards into fastboot, it is likely the PCB has been damaged.
            Our RMA process can be found here: https://modalai.com/rma
            For reference, our safe handling instructions are found here: https://modalai.com/handling
            • J Offline
              J Offline
              james.wadsworth
              I am having the exact same problem but, running Ubuntu 18.04. My usb expansion board has EMERG boot.
              • J jonathan
                G Offline
                G Offline
                Gaurav Borade
                Hi Team, if anyone have the video link, please share so we can try to unbrick it.
                modaltbM 1 Reply Last reply
                • G Gaurav Borade
                  modaltbM Offline
                  modaltbM Offline
                  modaltb
                  @Gaurav-Borade not sure why it didn't make it to youtube yet, but here's a link for now: https://drive.google.com/file/d/1lPK5ypVNkRDaCLJSWZa_J7Cx84tZ2Q_G/view?usp=sharing
                  • modaltbM modaltb
                    G Offline
                    G Offline
                    Gaurav Borade
                    @modaltb Thank you for this
                    • G Offline
                      G Offline
                      Gaurav Borade
                      wrote on last edited by Gaurav Borade
                      #11
                      Hi, @modaltb I tried with it, but still have not succeeded 😐
                      Two things I want to confirm
                      1. Am I using the right system image? I am using VOXL Platform Release 3-3-0 0.4.6 b downloaded from https://developer.modalai.com/asset
                      2. The cable, in the video I can see the cable like below cable in video.JPG
                      Is this cable will work? or do I need the same cable shown in the video? please let me know if am doing something wrong here.
                      • modaltbM Offline
                        modaltbM Offline
                        modaltb
                        Hi @Gaurav-Borade ,
                        You are correct, the USB cable you have is fine and the image is also OK.
                        Question: are you using an Ubuntu VM on another host machine? This is something I'm not positive about, should be OK but just not something we've tested too much.
                        • modaltbM modaltb
                          Hi @Gaurav-Borade ,
                          G Offline
                          G Offline
                          Gaurav Borade
                          @modaltb Thank you for the confirmation on the USB cable.
                          Yes, I am using Ubuntu Virtual Box. The board was communicating fine with the Virtual Box previously (Before bricked) so unbricking on that only. I will try it on another machine as well.
                          • Jae ParkJ Offline
                            Jae ParkJ Offline
                            Jae Park
                            @tom Hi, I'm the op of this post (link) but thought I would ask my question here since it seems to belong here now.
                            I am following the Unbricking VOXL instruction. More specifically, here's what I'm doing.
                            • Before anything is plugged in, I left the FASTBOOT switch on and the Debug board is already attached.
                            • Plug in the (1) cable for power
                            • Plug in cable (3) -- just a micro-usb
                            • Wait 5 sec, turn off the FASTBOOT switch.
                            • sudo fastboot devices
                              And this returns nothing. I've also tried adding cable (2) right after I plug in power which didn't work (I've tried many things..)
                              Please advise if I'm doing anything wrong. Thank you!
                            Jae
                            • Jae ParkJ Jae Park
                              Jae
                              @Jae-Park if you do a watch fastboot devices do you ever see it come up? Another thing to check, what is your output of lsusb after about 30 seconds of having the Voxl-flight powered up and plugged in to your pc?
                              Also cable “2” is unrelated to this process
                              Jae ParkJ 1 Reply Last reply
                                Jae ParkJ Offline
                                Jae ParkJ Offline
                                Jae Park
                                wrote on last edited by Jae Park
                                #16
                                Here is the output from lsusb. (once before attaching the power&micro-usb and again but 30 seconds after attaching them)
                                Also, I retried it again, following the exact steps I had described above, while watching on watch -n 1 fastboot devices. And, nothing had showed up.
                                  @Jae-Park Can you do the same lsusb test without the debug board attached?
                                    Jae ParkJ Offline
                                    Jae ParkJ Offline
                                    Jae Park
                                    #18
                                    This is after attaching cable (1) and (3), in the order, and running lsusb (waited some time before running the command).
                                      @Jae-Park It appears to me as though the VOXL portion of your VOXL-Flight is in a "bricked" state that is not fixable without sending it in for inspection. Refer to this RMA page for more info: https://modalai.com/rma
                                        Jae ParkJ Offline
                                        Jae ParkJ Offline
                                        Jae Park
                                        #20
                                        • Jae ParkJ Offline
                                          Jae ParkJ Offline
                                          Jae Park
                                          @tom Would it be going in for RMA PCB or Drone? It seems like PCB is what I'd want to choose.
                                          Also, if that is the case, can I ship out just the board, or would it have to be the entire drone itself? Thank you.
