  3. Re-configure VOXL2 1.4 for GHOST Receiver/Transmitter?
Scheduled Pinned Locked Moved Solved Development Drones
sentinel
14 Posts 3 Posters 993 Views 2 Watching
    Looks like the px4- version of the command isn't printing anything. You'll need to stop px4 running as a service with systemctl stop voxl-px4. Then wait a few seconds. Then start voxl-px4 from the command line in non-daemon mode with voxl-px4 -d. Once the startup script completes and you get a px4 prompt enter qshell ghst_rc status.
    P Offline
    P Offline
    pthomason
    Here's the results of that set of commands...
    voxl2:/$ systemctl stop voxl-px4
    voxl2:/$ voxl-px4 -d
    Found DSP signature file
    [INFO] Disabling daemon mode
    AIRFRAME=MULTICOPTER
    GPS=AUTODETECT
    RC=GHST
    ESC=VOXL_ESC
    POWER MANAGER=VOXLPM
    AIRSPEED SENSOR=NONE
    DISTANCE SENSOR=NONE
    OSD=DISABLE
    DAEMON_MODE=DISABLE
    SENSOR_CAL=ACTUAL
    ARTIFACT_MODE=DISABLE
    EXTRA STEPS:
    ______  __   __    ___
    | ___ \ \ \ / /   /   |
    | |_/ /  \ V /   / /| |
    |  __/   /   \  / /_| |
    | |     / /^\ \ \___  |
    \_|     \/   \/     |_/
    px4 starting.
    AIRFRAME: MULTICOPTER
    GPS: AUTODETECT
    RC: GHST
    ESC: VOXL_ESC
    POWER MANAGER: VOXLPM
    AIRSPEED SENSOR: NONE
    DISTANCE SENSOR: NONE
    OSD: DISABLE
    ARTIFACT_MODE: DISABLE
    EXTRA STEPS:
    Running on M0054
    INFO  [parameters] BSON document size 2664 bytes, decoded 2664 bytes (INT32:37, FLOAT:86)
    INFO  [muorb] SLPI:
    INFO  [muorb] SLPI: >>> ICM42688P this: b25fff68
    INFO  [qshell] qshell return value timestamp: 70192095, local time: 70194772
    INFO  [muorb] SLPI: Register interrupt b214ec48 e61f670c b25fff68
    INFO  [muorb] SLPI: Set up I2C bus mutex for bus 5
    INFO  [muorb] SLPI:
    INFO  [qshell] qshell return value timestamp: 70221943, local time: 70224937
    INFO  [muorb] SLPI: Set up I2C bus mutex for bus 1
    INFO  [muorb] SLPI: qmc5883l #0 on I2C bus 1
    INFO  [muorb] SLPI:  address 0xD
    INFO  [muorb] SLPI:
    INFO  [muorb] SLPI: Ok executing command: qmc5883l start -R 10 -X -b 1
    INFO  [qshell] qshell return value timestamp: 70254774, local time: 70258408
    ERROR [muorb] SLPI: Failed to execute command: ist8310 start -R 10 -X -b 1
    INFO  [qshell] qshell return value timestamp: 70289802, local time: 70292586
    ERROR [qshell] Command failed
    INFO  [muorb] SLPI: Successfully created px4 task PX4_gps with tid 2097648
    INFO  [qshell] qshell return value timestamp: 70319527, local time: 70322599
    Looking for ncp5623c RGB LED
    INFO  [muorb] SLPI: GPS UART baudrate set to 115200
    INFO  [muorb] SLPI: Set i2c address 0x38, fd 3
    ERROR [muorb] SLPI: Failed to execute command: rgbled_ncp5623c start -X -b 1 -f 400 -a 56
    INFO  [qshell] qshell return value timestamp: 70362363, local time: 70366032
    Starting VOXL ESC driver
    INFO  [qshell] Send cmd: 'voxl_esc start'
    INFO  [muorb] SLPI: qshell gotten: voxl_esc start
    INFO  [muorb] SLPI:   arg0 = 'voxl_esc'
    INFO  [muorb] SLPI: VOXL_ESC: Starting VOXL ESC driver
    INFO  [muorb] SLPI: Params: VOXL_ESC_CONFIG: 1
    INFO  [muorb] SLPI: Params: VOXL_ESC_MODE: 0
    INFO  [muorb] SLPI: Params: VOXL_ESC_BAUD: 2000000
    INFO  [muorb] SLPI: Params: VOXL_ESC_FUNC1: 103
    INFO  [muorb] SLPI: Params: VOXL_ESC_FUNC2: 102
    INFO  [muorb] SLPI: Params: VOXL_ESC_FUNC3: 104
    INFO  [muorb] SLPI: Params: VOXL_ESC_FUNC4: 101
    INFO  [muorb] SLPI: Params: VOXL_ESC_SDIR1: 0
    INFO  [muorb] SLPI: Params: VOXL_ESC_SDIR2: 0
    INFO  [muorb] SLPI: Params: VOXL_ESC_SDIR3: 0
    INFO  [muorb] SLPI: Params: VOXL_ESC_SDIR4: 0
    INFO  [muorb] SLPI: Params: VOXL_ESC_RPM_MIN: 1000
    INFO  [muorb] SLPI: Params: VOXL_ESC_RPM_MAX: 7000
    INFO  [muorb] SLPI: Params: VOXL_ESC_T_PERC: 90
    INFO  [muorb] SLPI: Params: VOXL_ESC_T_DEAD: 20
    INFO  [muorb] SLPI: Params: VOXL_ESC_T_EXPO: 35
    INFO  [muorb] SLPI: Params: VOXL_ESC_T_MINF: 0.150000
    INFO  [muorb] SLPI: Params: VOXL_ESC_T_COSP: 0.990000
    INFO  [muorb] SLPI: Params: VOXL_ESC_VLOG: 1
    INFO  [muorb] SLPI: Params: VOXL_ESC_PUB_BST: 1
    INFO  [muorb] SLPI: Params: VOXL_ESC_T_WARN: 0
    INFO  [muorb] SLPI: Params: VOXL_ESC_T_OVER: 0
    INFO  [muorb] SLPI: Params: GPIO_CTL_CH: 0
    INFO  [muorb] SLPI: Ok executing command: voxl_esc start
    INFO  [muorb] SLPI: VOXL_ESC: Opening UART ESC device 2, baud rate 2000000
    INFO  [muorb] SLPI: VOXL_ESC: Successfully opened UART ESC device
    INFO  [muorb] SLPI: VOXL_ESC: Detecting ESCs...
    INFO  [muorb] SLPI: VOXL_ESC:   ESC ID     : 0
    INFO  [muorb] SLPI: VOXL_ESC:   Board Type : 37: ModalAi 4-in-1 ESC (M0134-1)
    INFO  [muorb] SLPI: VOXL_ESC:   Unique ID  : 0x203330385246571800200038
    INFO  [muorb] SLPI: VOXL_ESC:   Firmware   : version   39, hash 9c6233d6
    INFO  [muorb] SLPI: VOXL_ESC:   Bootloader : version  183, hash b4fa2cf8
    INFO  [muorb] SLPI: VOXL_ESC:   Reply time : 111us
    INFO  [qshell] qshell return value timestamp: 70512857, local time: 70515915
    INFO  [muorb] SLPI: VOXL_ESC:   ESC ID     : 1
    INFO  [muorb] SLPI: VOXL_ESC:   Unique ID  : 0x2033303852465719003D004B
    INFO  [muorb] SLPI: VOXL_ESC:   Reply time : 799us
    INFO  [muorb] SLPI: VOXL_ESC:   ESC ID     : 2
    INFO  [muorb] SLPI: VOXL_ESC:   Unique ID  : 0x203330385246571800200048
    INFO  [muorb] SLPI: VOXL_ESC:   Reply time : 104us
    INFO  [muorb] SLPI: VOXL_ESC:   ESC ID     : 3
    INFO  [muorb] SLPI: VOXL_ESC:   Unique ID  : 0x203330385246571800200045
    INFO  [muorb] SLPI: VOXL_ESC:   Reply time : 705us
    INFO  [muorb] SLPI: VOXL_ESC: Use extened rpm packet : 1
    INFO  [muorb] SLPI: VOXL_ESC: All ESCs successfully detected
    Starting GHST RC driver
    INFO  [qshell] Send cmd: 'ghst_rc start -d 7'
    INFO  [muorb] SLPI: qshell gotten: ghst_rc start -d 7
    INFO  [muorb] SLPI:   arg0 = 'ghst_rc'
    INFO  [muorb] SLPI:   arg2 = '-d'
    INFO  [muorb] SLPI:   arg3 = '7'
    INFO  [muorb] SLPI: Ok executing command: ghst_rc start -d 7
    INFO  [uORB] Advertising remote topic input_rc
    INFO  [qshell] qshell return value timestamp: 70549244, local time: 70551299
    INFO  [uORB] Advertising remote topic actuator_outputs_debug
    INFO  [uORB] Advertising remote topic esc_status
    INFO  [qshell] Send cmd: 'voxlpm start -X -b 2'
    INFO  [muorb] SLPI: qshell gotten: voxlpm start -X -b 2
    INFO  [muorb] SLPI:   arg0 = 'voxlpm'
    INFO  [muorb] SLPI:   arg4 = '2'
    INFO  [muorb] SLPI: *** I2C Device ID 0xd24411 13779985
    INFO  [muorb] SLPI: Set up I2C bus mutex for bus 2
    INFO  [muorb] SLPI: Set i2c address 0x6a, fd 4
    INFO  [muorb] SLPI: Set i2c address 0x44, fd 4
    INFO  [uORB] Advertising remote topic battery_status
    INFO  [muorb] SLPI: voxlpm #0 on I2C bus 2
    INFO  [muorb] SLPI:  address 0x44
    INFO  [muorb] SLPI:
    INFO  [muorb] SLPI: Ok executing command: voxlpm start -X -b 2
    INFO  [uORB] Advertising remote topic power_monitor
    INFO  [qshell] qshell return value timestamp: 70586095, local time: 70588109
    INFO  [uORB] Advertising remote topic sensors_status_mag
    INFO  [qshell] qshell return value timestamp: 70809096, local time: 70811296
    INFO  [qshell] qshell return value timestamp: 71198944, local time: 71201108
    INFO  [uORB] Advertising remote topic estimator_aid_src_mag_heading
    INFO  [qshell] qshell return value timestamp: 71313275, local time: 71316082
    INFO  [qshell] qshell return value timestamp: 71359435, local time: 71361812
    INFO  [muorb] SLPI: u-blox firmware version: SPG 5.10
    INFO  [muorb] SLPI: u-blox protocol version: 34.10
    INFO  [muorb] SLPI: u-blox module: MAX-M10S
    INFO  [qshell] qshell return value timestamp: 71483137, local time: 71484877
    INFO  [qshell] qshell return value timestamp: 71533437, local time: 71535280
    INFO  [qshell] qshell return value timestamp: 71573161, local time: 71576568
    INFO  [muorb] SLPI:   arg0 = 'land_detector'
    INFO  [muorb] SLPI:   arg2 = 'multicopter'
    INFO  [qshell] qshell return value timestamp: 71617286, local time: 71619917
    INFO  [uORB] Advertising remote topic vehicle_land_detected
    INFO  [qshell] Send cmd: 'manual_control start'
    INFO  [muorb] SLPI: qshell gotten: manual_control start
    INFO  [muorb] SLPI:   arg0 = 'manual_control'
    INFO  [muorb] SLPI: Ok executing command: manual_control start
    INFO  [qshell] qshell return value timestamp: 71667009, local time: 71668829
    INFO  [uORB] Advertising remote topic manual_control_setpoint
    INFO  [qshell] Send cmd: 'control_allocator start'
    INFO  [muorb] SLPI: qshell gotten: control_allocator start
    INFO  [muorb] SLPI:   arg0 = 'control_allocator'
    INFO  [uORB] Advertising remote topic control_allocator_status
    INFO  [uORB] Marking DeviceNode(control_allocator_status) as advertised in process_remote_topic
    INFO  [uORB] Advertising remote topic actuator_motors
    INFO  [uORB] Advertising remote topic actuator_servos
    INFO  [uORB] Advertising remote topic actuator_servos_trim
    INFO  [muorb] SLPI: Ok executing command: control_allocator start
    INFO  [qshell] qshell return value timestamp: 72042152, local time: 72044686
    INFO  [qshell] Send cmd: 'load_mon start'
    INFO  [muorb] SLPI: qshell gotten: load_mon start
    INFO  [muorb] SLPI:   arg0 = 'load_mon'
    INFO  [muorb] SLPI: Ok executing command: load_mon start
    INFO  [uORB] Advertising remote topic cpuload
    INFO  [qshell] qshell return value timestamp: 72078955, local time: 72080979
    INFO  [qshell] Send cmd: 'rc_update start'
    INFO  [muorb] SLPI: qshell gotten: rc_update start
    INFO  [muorb] SLPI:   arg0 = 'rc_update'
    INFO  [muorb] SLPI: Ok executing command: rc_update start
    INFO  [uORB] Advertising remote topic rc_channels
    INFO  [qshell] qshell return value timestamp: 72453167, local time: 72456118
    INFO  [qshell] Send cmd: 'commander start'
    INFO  [muorb] SLPI: qshell gotten: commander start
    INFO  [muorb] SLPI:   arg0 = 'commander'
    INFO  [muorb] SLPI: Creating pthread commander
    INFO  [muorb] SLPI: Successfully created px4 task PX4_commander with tid 2097640
    INFO  [uORB] Advertising remote topic led_control
    INFO  [muorb] SLPI: LED: open /dev/led0 failed (22)
    INFO  [uORB] Advertising remote topic tune_control
    INFO  [muorb] SLPI: Ok executing command: commander start
    INFO  [qshell] qshell return value timestamp: 72721949, local time: 72724567
    INFO  [uORB] Advertising remote topic event
    INFO  [uORB] Advertising remote topic mavlink_log
    INFO  [muorb] SLPI: Preflight Fail: Accel 0 uncalibrated
    INFO  [muorb] SLPI: Preflight Fail: Compass 0 uncalibrated
    INFO  [uORB] Advertising remote topic health_report
    INFO  [uORB] Advertising remote topic failsafe_flags
    INFO  [uORB] Advertising remote topic actuator_armed
    INFO  [uORB] Advertising remote topic vehicle_control_mode
    INFO  [uORB] Advertising remote topic vehicle_status
    INFO  [uORB] Advertising remote topic failure_detector_status
    INFO  [uORB] Advertising remote topic vehicle_thrust_setpoint
    INFO  [uORB] Advertising remote topic vehicle_torque_setpoint
    INFO  [uORB] Advertising remote topic vehicle_attitude_setpoint
    INFO  [uORB] Advertising remote topic vehicle_rates_setpoint
    INFO  [qshell] Send cmd: 'flight_mode_manager start'
    INFO  [muorb] SLPI: qshell gotten: flight_mode_manager start
    INFO  [muorb] SLPI:   arg0 = 'flight_mode_manager'
    INFO  [uORB] Advertising remote topic vehicle_command
    INFO  [muorb] SLPI: Ok executing command: flight_mode_manager start
    INFO  [qshell] qshell return value timestamp: 72847484, local time: 72849829
    INFO  [dataman] data manager file '/data/px4/dataman' size is 7866640 bytes
    INFO  [muorb] SLPI: Advertising remote topic transponder_report
    INFO  [muorb] SLPI: Advertising remote topic rtl_time_estimate
    INFO  [modal_io_bridge] Modal IO Bridge driver starting
    INFO  [muorb] SLPI: Advertising remote topic telemetry_status
    INFO  [muorb] SLPI: Advertising remote topic offboard_control_mode
    INFO  [muorb] SLPI: Advertising remote topic vehicle_visual_odometry
    INFO  [muorb] SLPI: Advertising remote topic obstacle_distance
    INFO  [muorb] SLPI: Advertising remote topic timesync_status
    INFO  [uORB] Advertising remote topic estimator_aid_src_ev_hgt
    INFO  [uORB] Advertising remote topic estimator_aid_src_ev_pos
    INFO  [uORB] Advertising remote topic estimator_aid_src_ev_vel
    INFO  [uORB] Advertising remote topic estimator_aid_src_ev_yaw
    INFO  [uORB] Advertising remote topic actuator_controls_status_0
    INFO  [mavlink] mode: Normal, data rate: 100000 B/s on udp port 14558 remote port 14559
    INFO  [muorb] SLPI: Marking DeviceNode(telemetry_status) as advertised in process_remote_topic
    INFO  [mavlink] MAVLink only on localhost (set param MAV_{i}_BROADCAST = 1 to enable network)
    pxh> INFO  [muorb] SLPI: Preflight Fail: Accel 0 uncalibrated
    INFO  [muorb] SLPI: GPS UART baudrate set to 9600
    pxh> qshINFO  [muorb] SLPI: GPS UART baudrate set to 38400
    pxh> qsheINFO  [muorb] SLPI: Got ack to initial CFG_VALSET!
    pxh> qshellINFO  [muorb] SLPI: u-blox firmware version: SPG 5.10
    pxh> qshell INFO  [uORB] Advertising remote topic sensor_gps
    pxh> qshell ghst_rc status
    INFO  [qshell] Send cmd: 'ghst_rc status'
    INFO  [muorb] SLPI: qshell gotten: ghst_rc status
    INFO  [muorb] SLPI:   arg1 = 'status'
    INFO  [muorb] SLPI: UART device: 7
    INFO  [muorb] SLPI: UART RX bytes: 0
    INFO  [muorb] SLPI: Telemetry disabled: Singlewire RC port
    INFO  [muorb] SLPI: ghst_rc: cycle interval: 4909 events, 4602.09us avg, min 4517us max 5234us 60.313us rms
    INFO  [muorb] SLPI: ghst_rc: publish interval: 4909 events, 4602.08us avg, min 4519us max 5216us 60.657us rms
    INFO  [muorb] SLPI: Ok executing command: ghst_rc status
    INFO  [qshell] qshell return value timestamp: 93142469, local time: 93144181
    INFO  [muorb] SLPI: ghst_rc: cycle interval: 9465 events, 4604.74us avg, min 4517us max 5234us 62.283us rms
    INFO  [muorb] SLPI: ghst_rc: publish interval: 9465 events, 4604.73us avg, min 4519us max 5216us 61.851us rms
    INFO  [qshell] qshell return value timestamp: 114136059, local time: 114138421
    INFO  [muorb] SLPI: ghst_rc: cycle interval: 12405 events, 4605.51us avg, min 4517us max 5234us 62.184us rms
    INFO  [muorb] SLPI: ghst_rc: publish interval: 12404 events, 4605.50us avg, min 4519us max 5216us 62.220us rm
    INFO  [qshell] qshell return value timestamp: 127681055, local time: 127683879
    I hope this helps, I'm not sure what 'normal' output looks like in this case.
    • Eric KatzfeyE Offline
      It shows that no bytes have been received over the UART. So you need to see why there are no bytes coming across. Is the receiver generating any? You can attach a oscilloscope to the transmit line from the receiver and see if it is trying to send anything. Are you sure that the receiver and transmitter are properly bound?
      • P Offline
        P Offline
        pthomason
        I'm not sure it's a UART, I think it's a one-wire interface, there's only three wires connected to the GHOST board. The transmitter and receiver appear bound, and I've repeated the binding process a few times.
          Yes, there is ground, power, and the transmit line from the receiver. The receive line to the receiver is not connected. But this is a 4 wire UART.
          • P Offline
            P Offline
            pthomason
            Less than 1V peak-to-peak measured at the receiver on the transmit line. In searching online it seems ImmersionRC have gone out of business also?
              I think ImmersionRC was bought by Orqa.
              • P Offline
                P Offline
                pthomason
                Assuming the receiver is damaged, what is the recommended replacement? I still have an FPV.Ctrl controller with UberLite-24 transmitter module.
                • Maxwell SchaeferM Offline
                  Maxwell Schaefer
                  Our recommended and most well-supported RC system would be ExpressLRS. We have our own receiver available here, and a transmitter pre-programmed to work with many of our drones available here.
                  Beyond these options, nearly any commercially available ExpressLRS transmitters and receivers would work and can be found cheaply. Follow the guidance here to make sure your chosen devices are compatible if you choose to look elsewhere.
                  If you would like to continue using your current controller and transmitter module, you will need to find a replacement ghst atto receiver which unfortunately don't seem to be available anymore.
                  P 1 Reply Last reply
                  • Maxwell SchaeferM Maxwell Schaefer
                    P Offline
                    P Offline
                    pthomason
                    wrote on last edited by pthomason
                    #13
                    @Maxwell-Schaefer Does the ExpressLRS receiver require different wiring than our existing ghst atto? I can reconnect/patch the 3 wires for power, gnd and data, but I'm not sure I can add connections to the J19 plug easily. To be clear, we're using the Sentinel platform, J19 has GPS and the receiver connection. We're also still using SDK 1.4 that shipped on our replacement VOXL2.
                    Thank you.
                      Maxwell Schaefer
                      The ExpressLRS receiver requires* one additional wire. The ghost atto only connects one wire to the VOXL RC RX pin, but the ELRS receiver will also require a connection to the VOXL RC TX pin, otherwise the wiring is identical. Pre-crimped wires can be found easily for the JST GH connectors (J19) to make adding connections simple.
                      *You could leave the receiver's RX line (the VOXL's RC TX) disconnected; this would make updates and other control using the voxl-elrs application impossible but basic RC functionality would work.
                      • Maxwell SchaeferM Maxwell Schaefer has marked this topic as solved on
