<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Re-configure VOXL2 1.4 for GHOST Receiver&#x2F;Transmitter?]]></title><description><![CDATA[<p dir="auto">Hello, we recently had to get our VOXL2 board replaced and the returned unit doesn't appear to have the correct configuration for our original transmitter and receiver. Our transmitter is an ORQA FPV.Ctrl with a Ghost UberLite-24 module. The receiver on our Sentnel is a small white board, with one antenna port, and the word 'GHOST' printed on it. The new VOXL2 is running voxl-suite 1.4.0.</p>
<p dir="auto">Out of the box the system appears to be using RC=CRSF_RAW in the /etc/modalai/voxl-px4.conf file. This results in 'px4-listener input_rc' returning all zeros for stick inputs, 16 channels, and rssi of 0, and rssi_dbm as 'nan'. QGroundControl shows the channel monitor, but the sliders do not respond to stick inputs.</p>
<p dir="auto">When I change to RC=GHST 'px4-listener input_rc' shows the same as CRSF_RAW above, QGroundControl shows no channel-monitor section at all.</p>
<pre><code>voxl2:/$ voxl-inspect-sku
family code:   MRB-D0006 (sentinel)
compute board: 4 (voxl2)
hw version:    2
cam config:    11
modem config:  24 (M0090-3-2 Sierra EM9291))
tx config:     7 (elrs_beta_fpv)
extras config: 0 (none)
SKU:           MRB-D0006-4-V2-C11-T7-M24-X0
<pre><code>voxl2:/$ voxl-version
kernel:       #1 SMP PREEMPT Mon Nov 11 22:08:01 UTC 2024 4.19.125
hw platform:  M0054
mach.var:     1.0.0
voxl-suite:   1.4.0
Packages:
Repo:  http://voxl-packages.modalai.com/ ./dists/qrb5165/sdk-1.4/binary-arm64/
Last Updated: 2023-03-02 12:58:49
List:
libmodal-cv                               0.5.16
libmodal-exposure                         0.1.3
libmodal-pipe                             2.10.4
libqrb5165-io                             0.4.7
libvoxl-cci-direct                        0.2.3
modalai-slpi                              1.1.19
qrb5165-imu-server                        1.1.0
qrb5165-rangefinder-server                0.1.4
qrb5165-system-tweaks                     0.3.2
voxl-camera-calibration                   0.5.9
voxl-camera-server                        2.0.8
voxl-configurator                         0.9.4
voxl-cpu-monitor                          0.5.1
voxl-elrs                                 0.3.4
voxl-esc                                  1.4.8
voxl-feature-tracker                      0.5.2
voxl-io-server                            0.0.4
voxl-lepton-server                        1.3.3
voxl-lepton-tracker                       0.0.4
voxl-logger                               0.4.9
voxl-mavcam-manager                       0.5.7
voxl-mavlink-server                       1.4.4
voxl-modem                                1.1.3
voxl-mpa-tools                            1.3.4
voxl-open-vins                            0.4.14
voxl-open-vins-server                     0.2.83
voxl-opencv                               4.5.5-2
voxl-osd                                  0.0.2
voxl-portal                               0.7.2
voxl-px4                                  1.14.0-2.0.85
voxl-px4-params                           0.5.8
voxl-qvio-server                          1.1.1
voxl-reset-slpi                           0.0.1
voxl-state-estimator                      0.0.3
voxl-streamer                             0.7.5
voxl-suite                                1.4.0
voxl-tflite-server                        0.3.7
voxl-utils                                1.4.4
voxl-vision-hub                           1.8.17
voxl-vtx                                  1.1.3
voxl2-system-image                        1.8.02-r0
<pre><code>voxl2:/$ voxl-inspect-services
Scanning services...
 voxl-auto-logger         | Disabled  | Not Running |
 voxl-camera-server       |  Enabled  |   Running   |    30.1%
 voxl-cpu-monitor         |  Enabled  |   Running   |     0.3%
 voxl-elrs-startup        | Disabled  | Not Running |
 voxl-imu-server          |  Enabled  |   Running   |     2.0%
 voxl-io-server           | Disabled  | Not Running |
 voxl-lepton-tracker      | Disabled  | Not Running |
 voxl-logger              | Disabled  | Not Running |
 voxl-mavlink-server      |  Enabled  |   Running   |     2.1%
 voxl-modem               |  Enabled  |   Running   |     0.1%
 voxl-open-vins-server    | Disabled  | Not Running |
 voxl-osd                 | Disabled  | Not Running |
 voxl-portal              |  Enabled  |   Running   |     0.1%
 voxl-px4-imu-server      | Disabled  | Not Running |
 voxl-px4                 |  Enabled  |   Running   |    15.9%
 voxl-qvio-server         |  Enabled  |   Running   |     1.2%
 voxl-softap              |  Enabled  |  Completed  |
 voxl-state-estimator     | Disabled  | Not Running |
 voxl-streamer            |  Enabled  |   Running   |     1.1%
 voxl-vision-hub          |  Enabled  |   Running   |     1.2%
 voxl-vrx                 | Disabled  | Not Running |
 voxl-vtx                 | Disabled  | Not Running |
]]></description><link>https://forum.modalai.com/topic/5387/re-configure-voxl2-1.4-for-ghost-receiver-transmitter</link><generator>RSS for Node</generator><lastBuildDate>Thu, 20 Aug 2026 11:38:49 GMT</lastBuildDate><atom:link href="https://forum.modalai.com/topic/5387.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 19 Aug 2026 17:12:09 GMT</pubDate><ttl>60</ttl></channel></rss>
