    Request Support: VOXL 2 Mini No USB Power / Dim LED Issue
    419
    • Ashish KumarA
      Ashish Kumar
      Hi ModalAI Support,
      I am experiencing an issue with my VOXL 2 Mini.
      I had the VOXL 2 Mini running from the 12 V power module and simultaneously connected to my laptop over USB-C. Everything had been working normally, but suddenly my laptop shut down. After that event, the USB-C port on the VOXL 2 Mini stopped functioning.
      Current behavior:
      When connected through USB-C only, the board does not power on (no LED, no ADB connection).
      When powered using the 12 V adapter, I only see a dim green LED. The board does not fully boot and does not appear over USB when connected to a laptop.
      It seems that either the USB-C port or part of the power/USB circuitry may have been damaged.
      Could you please advise on next steps or whether this board needs repair or replacement?
      Thank you,
      Ashish Kumar
        tom admin @Ashish Kumar
        @Ashish-Kumar Can you post a picture of your hardware setup so I can verify all looks normal?
        Ashish KumarA 1 Reply Last reply Reply Quote 0
        • Ashish KumarA
          Ashish Kumar @tom
          @tom Thank you for your response. I’ve attached the pictures of your hardware setup for your review.
          • Ashish KumarA
            Ashish Kumar @Ashish Kumar
              @Ashish-Kumar What OS are you running on your host machine? If linux can you provide the output of lsusb with the board powered and plugged in?
              • VinnyV
                Vinny ModalAI Team @tom
                @Ashish-Kumar
                With ONLY USB-C, the board will not boot, so that is normal behavior.
                VBAT is always required.
                D1 (Green LED) says the VBAT is present and our local 3.3V is ON.
                With just that LED on, it tells me your board is likely stuck in QDL mode and needs reflashing, so the steps Tom provided will help confirm that.
                • Ashish KumarA
                  Ashish Kumar @Vinny
                  @Vinny @tom Thank you for the support. I’m using Linux, and here is the output of lsusb with the board powered and connected.
                  Bus 001 Device 002: ID 0bda:5522 Realtek Semiconductor Corp. Integrated_Webcam_HD
                  Bus 001 Device 004: ID 8087:0026 Intel Corp. AX201 Bluetooth
                  There is no Qualcomm/QDL device listed.
                  The board was functioning correctly before an unexpected laptop shutdown, but after that it stopped responding. With only USB-C there is no LED, and with VBAT I only see a dim green D1 LED and the board does not boot. Please advise on next steps.
                  Thank you.
                  • VinnyV
                    Vinny ModalAI Team @Ashish Kumar
                    @Ashish-Kumar
                    Few things:
                    1. Please stop trying with only USB-C, that is invalid. Think of this as your smartphone... there is always a battery present (our power module) before you insert a USB-C cable.
                    2. Please remove USB-C, Plug in the power module when it is OFF, then turn the power module ON.., then insert the USB-C cable. Our Hardware is not hot-swappable. Only USB ports can tolerate an active host connection, but all power supplies must be OFF when plugged in, then turned ON.
                    3. Your power module was delivered with clear heatshrink. What happened to it? That would not be a covered RMA since the HW of the power module is now compromised.
                    4. Can you confirm if you have tried multiple USB cables and multiple ports on your PC? (or even another PC?). We often see that fix some folks issues, either a lose cable or bad port... happens more than you would think.
                    After those steps are confirmed, then I think @tom can guide you further.
                    • Ashish KumarA
                      Ashish Kumar @Vinny
                      @Vinny Thank you for your support.
                      Regarding the power module: I did not modify it. I received it exactly in this condition. I have not opened or altered the module.
                      I have tried all the recommended steps including powering with the module off -> then ON -> then inserting USB-C, as well as using different laptops, different USB cables, and different ports on both Windows and Ubuntu, but the issue still remains the same.
                        @Ashish-Kumar Can you run the following and then plug in the board to your host machine after powering it on?
                        dmesg -wH
                        and then copy any relevant enumeration info here
                        • Ashish KumarA
                          Ashish Kumar @tom
                          @tom I ran dmesg -wH and monitored the output while powering the VOXL 2 Mini with VBAT and then plugging in the USB-C cable. There were many existing system messages, but when I connected the VOXL 2 Mini, no new lines appeared at all in the dmesg log.
                          Thank you.
                            @Ashish-Kumar Are you using the same USB-C cable and port on your host machine that worked before? Also are you running linux natively on your machine or in a VM?
                            • Ashish KumarA
                              Ashish Kumar @tom
                              @tom Yes, I tried different USB-C cables, different USB ports, and even different laptops (Windows and Ubuntu 22.04, both running natively - not a VM).
                              The result is the same in all cases.
                              When the VOXL 2 Mini is powered with VBAT and I plug in USB-C, nothing appears in dmesg and ADB does not detect the board.
                                @Ashish-Kumar This is very abnormal, I'd recommend submitting an RMA: https://www.modalai.com/pages/rma
                                • Ashish KumarA
                                  Ashish Kumar @tom
                                  @tom Thank you. I will submit an RMA request.
