  3. voxl-tag-detector fails to start on V3.3 "Missing lens_cal_file"
m500
13 Posts 3 Posters 3.3k Views 2 Watching
  • PawelJP PawelJ
    I recently reflashed the image for my voxl-m500 to 3.3 and reinstalled the voxl-suite during the process. I've run the voxl-configure-tag-detector service and set it up to run on boot, however I am unable to get it to run. When I try voxl-tag-detector -d I get an error about the lens calibration file missing. Is there something I am missing in the setup process? I have not updated the tag locations to my own yet, and am just trying to get the service running with the default settings. Note that I did change the size of the april tag to match mine.
    enabling debug mode
    loading tag-detector config file
    loading apriltag config file
    detector #0
        enable:          1
        input_pipe:      tracking
        en_fast_mode:    1
        n_threads:       1
        en_undistortion: 1
        undistort_scale: 0.60
        overlay_name:    tracking_tag_overlay
        lens_cal_file:   /data/modalai/opencv_tracking_intrinsics.yml
        skip_n_frames:   5
    detector #1
        enable:          0
        input_pipe:      stereo
        en_fast_mode:    1
        n_threads:       1
        en_undistortion: 1
        undistort_scale: 0.90
        overlay_name:    stereo_tag_overlay
        lens_cal_file:   /data/modalai/opencv_stereo_intrinsics.yml
        skip_n_frames:   5
    detector #2
        enable:          0
        input_pipe:      extra
        en_fast_mode:    1
        n_threads:       1
        en_undistortion: 0
        undistort_scale: 1.00
        overlay_name:    extra_tag_overlay
        lens_cal_file:   /data/modalai/opencv_extra_intrinsics.yml
        skip_n_frames:   5
    default_size_m:        0.173
    #0:
        loc_type:        unknown
        size_m:            0.173
        T_tag_wrt_fixed: 0.0  0.0  0.0
        R_tag_to_fixed:  0.0 -1.0  0.0
                         1.0  0.0  0.0
                         0.0  0.0  1.0
    Failed to load lens cal file /data/modalai/opencv_tracking_intrinsics.yml
    I have also made a corresponding post on the gitlab issues. Any help is greatly appreciated.
    Cheers,
    Pawel
    @PawelJ ```%YAML:1.0
    M: !!opencv-matrix
    rows: 3
    cols: 3
    dt: d
    data: [ 2.7874039916528164e+02, 0., 3.3988271378331154e+02, 0.,
    2.7880227185614154e+02, 2.5258101356853410e+02, 0., 0., 1. ]
    😧 !!opencv-matrix
    rows: 4
    cols: 1
    dt: d
    data: [ -1.4185703635329491e-02, 2.1172901376532889e-02,
    -1.4431453715214168e-02, 3.4931558175981398e-03 ]
    width: 640.
    height: 480.
    distortion_model: fisheye
    • PawelJP Offline
      PawelJP Offline
      PawelJ
      wrote on last edited by PawelJ
      @Eric-Katzfey said in voxl-tag-detector fails to start on V3.3 "Missing lens_cal_file":
      %YAML:1.0
      M: !!opencv-matrix
      rows: 3
      cols: 3
      dt: d
      !!opencv-matrix
      rows: 4
      cols: 1
      dt: d
      width: 640.
      height: 480.
      Hello @Eric-Katzfey I have scp'd that file over to the voxl, but the voxl-tag-detector still fails to start running. I try to restart it with systemctl restart voxl-tag-detector, but it comes up as Not Running in voxl-inspect-services. When I try running it in debug mode I get this printout.
      yocto:~$ voxl-tag-detector -d
      enabling debug mode
      detector #0
          enable:          1
          en_fast_mode:    1
          n_threads:       1
          en_undistortion: 1
          skip_n_frames:   5
      detector #1
          enable:          0
          input_pipe:      stereo
          en_fast_mode:    1
          n_threads:       1
          en_undistortion: 1
          skip_n_frames:   5
      detector #2
          enable:          0
          input_pipe:      extra
          en_fast_mode:    1
          n_threads:       1
          en_undistortion: 0
          skip_n_frames:   5
      #0:
          loc_type:        unknown
          size_m:            0.173
                           1.0  0.0  0.0
                           0.0  0.0  1.0
      Aborted
      I recall having to reset the calibration files for the px4 when debugging an earlier problem with your team. I have gone through and recalibrated those sensors already. Unless they are linked ot the px4 parameters, I have not removed any camera calibration files.
      • PawelJP PawelJ
        %YAML:1.0
        M: !!opencv-matrix
        rows: 3
        cols: 3
        dt: d
        !!opencv-matrix
        rows: 4
        cols: 1
        dt: d
        width: 640.
        height: 480.
        enabling debug mode
        detector #0
            enable:          1
            en_fast_mode:    1
            n_threads:       1
            en_undistortion: 1
            skip_n_frames:   5
        detector #1
            enable:          0
            input_pipe:      stereo
            en_fast_mode:    1
            n_threads:       1
            en_undistortion: 1
            skip_n_frames:   5
        detector #2
            enable:          0
            input_pipe:      extra
            en_fast_mode:    1
            n_threads:       1
            en_undistortion: 0
            skip_n_frames:   5
        #0:
            loc_type:        unknown
            size_m:            0.173
                             1.0  0.0  0.0
                             0.0  0.0  1.0
        Aborted
        @PawelJ Yes, I think it is related to the system image flash procedure https://docs.modalai.com/flash-system-image/ It will wipe the /data partition where the calibration files exist unless you tell it not to do that.
        PawelJP 1 Reply Last reply
          PawelJP Offline
          PawelJP Offline
          PawelJ
          @Eric-Katzfey I did not wipe the /data partition during the reinstall
          • PawelJP PawelJ
            @PawelJ We will investigate this and see why you lost the calibration files when flashing 3.3.0 system image.
              PawelJP Offline
              PawelJP Offline
              PawelJ
              @Eric-Katzfey do you have any suggestions to get this up and running? I am just trying to get the default system features working at the moment. I have added the missing calibration file, but it still appears to be failing.
              • PawelJP PawelJ
                @PawelJ Bear with us. Our subject matter experts are out on summer vacation this week.
                • PawelJP Offline
                  PawelJP Offline
                  PawelJ
                  Yes of course, it's the time of year for a vacation :). Just an update....as I was working on some tflite portions of my project I noticed that the qvio-server was down now, but was not prior to adding the calibration file. If I run it in debug mode it provides a more helpful printout and shows that there is an error in loading the calibration file.
                  yocto:~$ voxl-qvio-server
                  loading qvio config file
                  imu_name:                         imu1
                  cam_name:                         tracking
                  odr_hz:                           30.000
                  use_camera_height_bootstrap:      1
                  camera_height_off_ground_m:        0.100
                  enable_init_while_moving:         1
                  cam_imu_timeshift_s:               0.002
                  cam_imu_timeshift_s_uncertainty:   0.001
                  T_cam_wrt_imu_uncertainty:         0.005  0.005  0.005
                  R_cam_to_imu_uncertainty:          0.040  0.040  0.040
                  accl_fsr_ms2:                     156.000
                  gyro_fsr_rad:                     34.000
                  accl_noise_std_dev:                0.316
                  gyro_noise_std_dev:                0.010
                  cam_noise_std_dev:                100.000
                  min_std_pixel_noise:               0.500
                  fail_high_pixel_noise_points:      1.665
                  limited_imu_bw_trigger:           35.000
                  gps_imu_time_alignment_s:          0.000
                  T_gps_wrt_imu:                    -0.115  0.450  0.100
                  enable_mapping:                   1
                  enable_gps_vel:                   0
                  setting scheduler
                  WARNING Failed to set priority, errno = 1
                  This seems to be a problem with ADB, the scheduler
                  should work properly when this is a background process
                  ERROR failed to set scheduler
                  #0:
                      parent:                imu1
                      child:                 tracking
                      T_child_wrt_parent:    0.017   0.015   0.013
                      RPY_parent_to_child:   0.0    45.0    90.0
                      R_child_to_parent:     0.000  -0.707   0.707
                                             1.000   0.000  -0.000
                                            -0.000   0.707   0.707
                  tbc:   0.017  0.015  0.013
                  ombc:  0.614  0.614  1.482 (axis angle)
                  ombc:  0.000 45.000 90.000 (RPY deg)
                  loading /data/modalai/opencv_tracking_intrinsics.yml
                  terminate called after throwing an instance of 'YAML::BadSubscript'
                    what():  operator[] call on a scalar
                  Aborted
                  Here is the what the file looks like
                  %YAML:1.0
                  M: !!opencv-matrix
                  rows: 3
                  cols: 3
                  dt: d
                  D: !!opencv-matrix
                  rows: 4
                  cols: 1
                  dt: d
                  width: 640.
                  height: 480.
                  Cheers
                  • PawelJP Offline
                    PawelJP Offline
                    PawelJ
                    Got the problem sorted out.
                    %YAML:1.0
                    M: !!opencv-matrix
                       rows: 3
                       cols: 3
                       dt: d
                    D: !!opencv-matrix
                       rows: 4
                       cols: 1
                       dt: d
                       width: 640.
                       height: 480.
                    Cheers
                    wilkinsafW 1 Reply Last reply
                    • PawelJP PawelJ
                      %YAML:1.0
                      M: !!opencv-matrix
                         rows: 3
                         cols: 3
                         dt: d
                      D: !!opencv-matrix
                         rows: 4
                         cols: 1
                         dt: d
                         width: 640.
                         height: 480.
                      Cheers
                      wilkinsafW Offline
                      wilkinsafW Offline
                      wilkinsaf
                      If anyone has run into this again,
                      ensure you update your /etc/modalai/voxl-tag-detector.conf to the tracking camera pipe you would like to do the april tag detection on.
                      the "tracking" has gotten update to "tracking_down" or "tracking_front"
