voxl-tag-detector fails to start on V3.3 "Missing lens_cal_file"
I recently reflashed the image for my voxl-m500 to 3.3 and reinstalled the voxl-suite during the process. I've run the voxl-configure-tag-detector service and set it up to run on boot, however I am unable to get it to run. When I try voxl-tag-detector -d I get an error about the lens calibration file missing. Is there something I am missing in the setup process? I have not updated the tag locations to my own yet, and am just trying to get the service running with the default settings. Note that I did change the size of the april tag to match mine.
enabling debug mode loading tag-detector config file loading apriltag config file ================================================================= detector #0 enable: 1 input_pipe: tracking en_fast_mode: 1 n_threads: 1 en_undistortion: 1 undistort_scale: 0.60 overlay_name: tracking_tag_overlay lens_cal_file: /data/modalai/opencv_tracking_intrinsics.yml skip_n_frames: 5 detector #1 enable: 0 input_pipe: stereo en_fast_mode: 1 n_threads: 1 en_undistortion: 1 undistort_scale: 0.90 overlay_name: stereo_tag_overlay lens_cal_file: /data/modalai/opencv_stereo_intrinsics.yml skip_n_frames: 5 detector #2 enable: 0 input_pipe: extra en_fast_mode: 1 n_threads: 1 en_undistortion: 0 undistort_scale: 1.00 overlay_name: extra_tag_overlay lens_cal_file: /data/modalai/opencv_extra_intrinsics.yml skip_n_frames: 5 ================================================================= default_size_m: 0.173 #0: id: 0 name: default_name loc_type: unknown size_m: 0.173 T_tag_wrt_fixed: 0.0 0.0 0.0 R_tag_to_fixed: 0.0 -1.0 0.0 1.0 0.0 0.0 0.0 0.0 1.0 Failed to load lens cal file /data/modalai/opencv_tracking_intrinsics.ymlI have also made a corresponding post on the gitlab issues. Any help is greatly appreciated.
Cheers,
Pawel -
@PawelJ When you run the install script to flash the system image there is a prompt that asks if you want to preserve the /data partition where the calibration files are stored. Normally you preserve those unless you want to calibrate the cameras yourself. If the calibration files have been deleted then you need to get them replaced. You can run the calibration procedure yourself. The documentation is here: https://docs.modalai.com/calibrate-cameras/
Cheers,
Pawel -
Cheers,
Pawel@PawelJ ```%YAML:1.0
M: !!opencv-matrix
rows: 3
cols: 3
dt: d
data: [ 2.7874039916528164e+02, 0., 3.3988271378331154e+02, 0.,
2.7880227185614154e+02, 2.5258101356853410e+02, 0., 0., 1. ]
!!opencv-matrix
rows: 4
cols: 1
dt: d
data: [ -1.4185703635329491e-02, 2.1172901376532889e-02,
-1.4431453715214168e-02, 3.4931558175981398e-03 ]
width: 640.
height: 480.
distortion_model: fisheye -
@Eric-Katzfey said in voxl-tag-detector fails to start on V3.3 "Missing lens_cal_file":
%YAML:1.0
M: !!opencv-matrix
rows: 3
cols: 3
dt: d
!!opencv-matrix
rows: 4
cols: 1
dt: d
width: 640.
height: 480.
distortion_model: fisheyeHello @Eric-Katzfey I have scp'd that file over to the voxl, but the voxl-tag-detector still fails to start running. I try to restart it with
systemctl restart voxl-tag-detector, but it comes up asNot Runninginvoxl-inspect-services. When I try running it in debug mode I get this printout.yocto:~$ voxl-tag-detector -d enabling debug mode loading tag-detector config file loading apriltag config file ================================================================= detector #0 enable: 1 input_pipe: tracking en_fast_mode: 1 n_threads: 1 en_undistortion: 1 undistort_scale: 0.60 overlay_name: tracking_tag_overlay lens_cal_file: /data/modalai/opencv_tracking_intrinsics.yml skip_n_frames: 5 detector #1 enable: 0 input_pipe: stereo en_fast_mode: 1 n_threads: 1 en_undistortion: 1 undistort_scale: 0.90 overlay_name: stereo_tag_overlay lens_cal_file: /data/modalai/opencv_stereo_intrinsics.yml skip_n_frames: 5 detector #2 enable: 0 input_pipe: extra en_fast_mode: 1 n_threads: 1 en_undistortion: 0 undistort_scale: 1.00 overlay_name: extra_tag_overlay lens_cal_file: /data/modalai/opencv_extra_intrinsics.yml skip_n_frames: 5 ================================================================= default_size_m: 0.173 #0: id: 0 name: default_name loc_type: unknown size_m: 0.173 T_tag_wrt_fixed: 0.0 0.0 0.0 R_tag_to_fixed: 0.0 -1.0 0.0 1.0 0.0 0.0 0.0 0.0 1.0 AbortedI recall having to reset the calibration files for the px4 when debugging an earlier problem with your team. I have gone through and recalibrated those sensors already. Unless they are linked ot the px4 parameters, I have not removed any camera calibration files.
%YAML:1.0
M: !!opencv-matrix
rows: 3
cols: 3
dt: d
!!opencv-matrix
rows: 4
cols: 1
dt: d
width: 640.
height: 480.
@PawelJ Yes, I think it is related to the system image flash procedure https://docs.modalai.com/flash-system-image/ It will wipe the /data partition where the calibration files exist unless you tell it not to do that.
@Eric-Katzfey I did not wipe the /data partition during the reinstall
@PawelJ We will investigate this and see why you lost the calibration files when flashing 3.3.0 system image.
@Eric-Katzfey do you have any suggestions to get this up and running? I am just trying to get the default system features working at the moment. I have added the missing calibration file, but it still appears to be failing.
@PawelJ Bear with us. Our subject matter experts are out on summer vacation this week.
Yes of course, it's the time of year for a vacation :). Just an update....as I was working on some tflite portions of my project I noticed that the
qvio-serverwas down now, but was not prior to adding the calibration file. If I run it in debug mode it provides a more helpful printout and shows that there is an error in loading the calibration file.yocto:~$ voxl-qvio-server loading qvio config file ================================================================= imu_name: imu1 cam_name: tracking odr_hz: 30.000 use_camera_height_bootstrap: 1 camera_height_off_ground_m: 0.100 enable_init_while_moving: 1 cam_imu_timeshift_s: 0.002 cam_imu_timeshift_s_uncertainty: 0.001 T_cam_wrt_imu_uncertainty: 0.005 0.005 0.005 R_cam_to_imu_uncertainty: 0.040 0.040 0.040 accl_fsr_ms2: 156.000 gyro_fsr_rad: 34.000 accl_noise_std_dev: 0.316 gyro_noise_std_dev: 0.010 cam_noise_std_dev: 100.000 min_std_pixel_noise: 0.500 fail_high_pixel_noise_points: 1.665 limited_imu_bw_trigger: 35.000 gps_imu_time_alignment_s: 0.000 T_gps_wrt_imu: -0.115 0.450 0.100 enable_mapping: 1 enable_gps_vel: 0 ================================================================= setting scheduler WARNING Failed to set priority, errno = 1 This seems to be a problem with ADB, the scheduler should work properly when this is a background process ERROR failed to set scheduler loading extrinsics config file #0: parent: imu1 child: tracking T_child_wrt_parent: 0.017 0.015 0.013 RPY_parent_to_child: 0.0 45.0 90.0 R_child_to_parent: 0.000 -0.707 0.707 1.000 0.000 -0.000 -0.000 0.707 0.707 tbc: 0.017 0.015 0.013 ombc: 0.614 0.614 1.482 (axis angle) ombc: 0.000 45.000 90.000 (RPY deg) loading /data/modalai/opencv_tracking_intrinsics.yml terminate called after throwing an instance of 'YAML::BadSubscript' what(): operator[] call on a scalar AbortedHere is the what the file looks like
%YAML:1.0 M: !!opencv-matrix rows: 3 cols: 3 dt: d data: [ 2.7874039916528164e+02, 0., 3.3988271378331154e+02, 0., 2.7880227185614154e+02, 2.5258101356853410e+02, 0., 0., 1. ] D: !!opencv-matrix rows: 4 cols: 1 dt: d data: [ -1.4185703635329491e-02, 2.1172901376532889e-02, -1.4431453715214168e-02, 3.4931558175981398e-03 ] width: 640. height: 480. distortion_model: fisheyeCheers
Got the problem sorted out.
If anyone has run into this again,
ensure you update your
/etc/modalai/voxl-tag-detector.confto the tracking camera pipe you would like to do the april tag detection on.the "tracking" has gotten update to "tracking_down" or "tracking_front"
