    voxl-tag-detector fails to start on V3.3 "Missing lens_cal_file"
    VOXL m500 Reference Drone
    836
    • PawelJP
      PawelJ
      I recently reflashed the image for my voxl-m500 to 3.3 and reinstalled the voxl-suite during the process. I've run the voxl-configure-tag-detector service and set it up to run on boot, however I am unable to get it to run. When I try voxl-tag-detector -d I get an error about the lens calibration file missing. Is there something I am missing in the setup process? I have not updated the tag locations to my own yet, and am just trying to get the service running with the default settings. Note that I did change the size of the april tag to match mine.
      enabling debug mode
      loading tag-detector config file
      loading apriltag config file
      detector #0
          enable:          1
          input_pipe:      tracking
          en_fast_mode:    1
          n_threads:       1
          en_undistortion: 1
          undistort_scale: 0.60
          overlay_name:    tracking_tag_overlay
          lens_cal_file:   /data/modalai/opencv_tracking_intrinsics.yml
          skip_n_frames:   5
      detector #1
          enable:          0
          input_pipe:      stereo
          en_fast_mode:    1
          n_threads:       1
          en_undistortion: 1
          undistort_scale: 0.90
          overlay_name:    stereo_tag_overlay
          lens_cal_file:   /data/modalai/opencv_stereo_intrinsics.yml
          skip_n_frames:   5
      detector #2
          enable:          0
          input_pipe:      extra
          en_fast_mode:    1
          n_threads:       1
          en_undistortion: 0
          undistort_scale: 1.00
          overlay_name:    extra_tag_overlay
          lens_cal_file:   /data/modalai/opencv_extra_intrinsics.yml
          skip_n_frames:   5
      default_size_m:        0.173
      #0:
          loc_type:        unknown
          size_m:            0.173
          T_tag_wrt_fixed: 0.0  0.0  0.0
          R_tag_to_fixed:  0.0 -1.0  0.0
                           1.0  0.0  0.0
                           0.0  0.0  1.0
      Failed to load lens cal file /data/modalai/opencv_tracking_intrinsics.yml
      I have also made a corresponding post on the gitlab issues. Any help is greatly appreciated.
      Cheers,
      Pawel
        Eric Katzfey ModalAI Team
        @PawelJ When you run the install script to flash the system image there is a prompt that asks if you want to preserve the /data partition where the calibration files are stored. Normally you preserve those unless you want to calibrate the cameras yourself. If the calibration files have been deleted then you need to get them replaced. You can run the calibration procedure yourself. The documentation is here: https://docs.modalai.com/calibrate-cameras/
          Eric Katzfey ModalAI Team @PawelJ
            @PawelJ ```%YAML:1.0
            M: !!opencv-matrix
            rows: 3
            cols: 3
            dt: d
            data: [ 2.7874039916528164e+02, 0., 3.3988271378331154e+02, 0.,
            2.7880227185614154e+02, 2.5258101356853410e+02, 0., 0., 1. ]
            😧 !!opencv-matrix
            rows: 4
            cols: 1
            dt: d
            data: [ -1.4185703635329491e-02, 2.1172901376532889e-02,
            -1.4431453715214168e-02, 3.4931558175981398e-03 ]
            width: 640.
            height: 480.
            distortion_model: fisheye
            • PawelJP
              PawelJ
              @Eric-Katzfey said in voxl-tag-detector fails to start on V3.3 "Missing lens_cal_file":
              %YAML:1.0
              M: !!opencv-matrix
              rows: 3
              cols: 3
              dt: d
              !!opencv-matrix
              rows: 4
              cols: 1
              dt: d
              width: 640.
              height: 480.
              Hello @Eric-Katzfey I have scp'd that file over to the voxl, but the voxl-tag-detector still fails to start running. I try to restart it with systemctl restart voxl-tag-detector, but it comes up as Not Running in voxl-inspect-services. When I try running it in debug mode I get this printout.
              yocto:~$ voxl-tag-detector -d
              enabling debug mode
              detector #0
                  enable:          1
                  en_fast_mode:    1
                  n_threads:       1
                  en_undistortion: 1
                  skip_n_frames:   5
              detector #1
                  enable:          0
                  input_pipe:      stereo
                  en_fast_mode:    1
                  n_threads:       1
                  en_undistortion: 1
                  skip_n_frames:   5
              detector #2
                  enable:          0
                  input_pipe:      extra
                  en_fast_mode:    1
                  n_threads:       1
                  en_undistortion: 0
                  skip_n_frames:   5
              #0:
                  loc_type:        unknown
                  size_m:            0.173
                                   1.0  0.0  0.0
                                   0.0  0.0  1.0
              Aborted
              I recall having to reset the calibration files for the px4 when debugging an earlier problem with your team. I have gone through and recalibrated those sensors already. Unless they are linked ot the px4 parameters, I have not removed any camera calibration files.
                @PawelJ Yes, I think it is related to the system image flash procedure https://docs.modalai.com/flash-system-image/ It will wipe the /data partition where the calibration files exist unless you tell it not to do that.
                PawelJP 1 Reply Last reply Reply Quote 0
                • PawelJP
                  PawelJ @Eric Katzfey
                  @Eric-Katzfey I did not wipe the /data partition during the reinstall
                    @PawelJ We will investigate this and see why you lost the calibration files when flashing 3.3.0 system image.
                    • PawelJP
                      @Eric-Katzfey do you have any suggestions to get this up and running? I am just trying to get the default system features working at the moment. I have added the missing calibration file, but it still appears to be failing.
                        @PawelJ Bear with us. Our subject matter experts are out on summer vacation this week.
                        • PawelJP
                          PawelJ
                          Yes of course, it's the time of year for a vacation :). Just an update....as I was working on some tflite portions of my project I noticed that the qvio-server was down now, but was not prior to adding the calibration file. If I run it in debug mode it provides a more helpful printout and shows that there is an error in loading the calibration file.
                          yocto:~$ voxl-qvio-server
                          loading qvio config file
                          imu_name:                         imu1
                          cam_name:                         tracking
                          odr_hz:                           30.000
                          use_camera_height_bootstrap:      1
                          camera_height_off_ground_m:        0.100
                          enable_init_while_moving:         1
                          cam_imu_timeshift_s:               0.002
                          cam_imu_timeshift_s_uncertainty:   0.001
                          T_cam_wrt_imu_uncertainty:         0.005  0.005  0.005
                          R_cam_to_imu_uncertainty:          0.040  0.040  0.040
                          accl_fsr_ms2:                     156.000
                          gyro_fsr_rad:                     34.000
                          accl_noise_std_dev:                0.316
                          gyro_noise_std_dev:                0.010
                          cam_noise_std_dev:                100.000
                          min_std_pixel_noise:               0.500
                          fail_high_pixel_noise_points:      1.665
                          limited_imu_bw_trigger:           35.000
                          gps_imu_time_alignment_s:          0.000
                          T_gps_wrt_imu:                    -0.115  0.450  0.100
                          enable_mapping:                   1
                          enable_gps_vel:                   0
                          setting scheduler
                          WARNING Failed to set priority, errno = 1
                          This seems to be a problem with ADB, the scheduler
                          should work properly when this is a background process
                          ERROR failed to set scheduler
                          #0:
                              parent:                imu1
                              child:                 tracking
                              T_child_wrt_parent:    0.017   0.015   0.013
                              RPY_parent_to_child:   0.0    45.0    90.0
                              R_child_to_parent:     0.000  -0.707   0.707
                                                     1.000   0.000  -0.000
                                                    -0.000   0.707   0.707
                          tbc:   0.017  0.015  0.013
                          ombc:  0.614  0.614  1.482 (axis angle)
                          ombc:  0.000 45.000 90.000 (RPY deg)
                          loading /data/modalai/opencv_tracking_intrinsics.yml
                          terminate called after throwing an instance of 'YAML::BadSubscript'
                            what():  operator[] call on a scalar
                          Aborted
                          Here is the what the file looks like
                          %YAML:1.0
                          M: !!opencv-matrix
                          rows: 3
                          cols: 3
                          dt: d
                          D: !!opencv-matrix
                          rows: 4
                          cols: 1
                          dt: d
                          width: 640.
                          height: 480.
                          Cheers
                          • PawelJP
                            PawelJ
                            Got the problem sorted out.
                            %YAML:1.0
                            M: !!opencv-matrix
                               rows: 3
                               cols: 3
                               dt: d
                            D: !!opencv-matrix
                               rows: 4
                               cols: 1
                               dt: d
                               width: 640.
                               height: 480.
                            Cheers
