  2. VOXL Dev Drones
  3. VOXL m500 Reference Drone
  4. voxl-tag-detector fails to start on V3.3 "Missing lens_cal_file"
Scheduled Pinned Locked Moved VOXL m500 Reference Drone
13 Posts 3 Posters 3.0k Views 2 Watching
  • PawelJP Offline
    PawelJP Offline
    PawelJ
    I recently reflashed the image for my voxl-m500 to 3.3 and reinstalled the voxl-suite during the process. I've run the voxl-configure-tag-detector service and set it up to run on boot, however I am unable to get it to run. When I try voxl-tag-detector -d I get an error about the lens calibration file missing. Is there something I am missing in the setup process? I have not updated the tag locations to my own yet, and am just trying to get the service running with the default settings. Note that I did change the size of the april tag to match mine.
    enabling debug mode
    loading tag-detector config file
    loading apriltag config file
    detector #0
        enable:          1
        input_pipe:      tracking
        en_fast_mode:    1
        n_threads:       1
        en_undistortion: 1
        undistort_scale: 0.60
        overlay_name:    tracking_tag_overlay
        lens_cal_file:   /data/modalai/opencv_tracking_intrinsics.yml
        skip_n_frames:   5
    detector #1
        enable:          0
        input_pipe:      stereo
        en_fast_mode:    1
        n_threads:       1
        en_undistortion: 1
        undistort_scale: 0.90
        overlay_name:    stereo_tag_overlay
        lens_cal_file:   /data/modalai/opencv_stereo_intrinsics.yml
        skip_n_frames:   5
    detector #2
        enable:          0
        input_pipe:      extra
        en_fast_mode:    1
        n_threads:       1
        en_undistortion: 0
        undistort_scale: 1.00
        overlay_name:    extra_tag_overlay
        lens_cal_file:   /data/modalai/opencv_extra_intrinsics.yml
        skip_n_frames:   5
    default_size_m:        0.173
    #0:
        loc_type:        unknown
        size_m:            0.173
        T_tag_wrt_fixed: 0.0  0.0  0.0
        R_tag_to_fixed:  0.0 -1.0  0.0
                         1.0  0.0  0.0
                         0.0  0.0  1.0
    Failed to load lens cal file /data/modalai/opencv_tracking_intrinsics.yml
    I have also made a corresponding post on the gitlab issues. Any help is greatly appreciated.
    Cheers,
    Pawel
    • Eric KatzfeyE Offline
      @PawelJ When you run the install script to flash the system image there is a prompt that asks if you want to preserve the /data partition where the calibration files are stored. Normally you preserve those unless you want to calibrate the cameras yourself. If the calibration files have been deleted then you need to get them replaced. You can run the calibration procedure yourself. The documentation is here: https://docs.modalai.com/calibrate-cameras/
      • PawelJP PawelJ
        enabling debug mode
        detector #0
            enable:          1
            en_fast_mode:    1
            n_threads:       1
            en_undistortion: 1
            skip_n_frames:   5
        detector #1
            enable:          0
            input_pipe:      stereo
            en_fast_mode:    1
            n_threads:       1
            en_undistortion: 1
            skip_n_frames:   5
        detector #2
            enable:          0
            input_pipe:      extra
            en_fast_mode:    1
            n_threads:       1
            en_undistortion: 0
            skip_n_frames:   5
        #0:
            loc_type:        unknown
            size_m:            0.173
                             1.0  0.0  0.0
                             0.0  0.0  1.0
        Cheers,
        Pawel
        • PawelJP PawelJ
          enabling debug mode
          detector #0
              enable:          1
              en_fast_mode:    1
              n_threads:       1
              en_undistortion: 1
              skip_n_frames:   5
          detector #1
              enable:          0
              input_pipe:      stereo
              en_fast_mode:    1
              n_threads:       1
              en_undistortion: 1
              skip_n_frames:   5
          detector #2
              enable:          0
              input_pipe:      extra
              en_fast_mode:    1
              n_threads:       1
              en_undistortion: 0
              skip_n_frames:   5
          #0:
              loc_type:        unknown
              size_m:            0.173
                               1.0  0.0  0.0
                               0.0  0.0  1.0
          Cheers,
          Pawel
          @PawelJ ```%YAML:1.0
          M: !!opencv-matrix
          rows: 3
          cols: 3
          dt: d
          data: [ 2.7874039916528164e+02, 0., 3.3988271378331154e+02, 0.,
          2.7880227185614154e+02, 2.5258101356853410e+02, 0., 0., 1. ]
          😧 !!opencv-matrix
          rows: 4
          cols: 1
          dt: d
          data: [ -1.4185703635329491e-02, 2.1172901376532889e-02,
          -1.4431453715214168e-02, 3.4931558175981398e-03 ]
          width: 640.
          height: 480.
          distortion_model: fisheye
          • PawelJP Offline
            PawelJP Offline
            PawelJ
            wrote on last edited by PawelJ
            @Eric-Katzfey said in voxl-tag-detector fails to start on V3.3 "Missing lens_cal_file":
            %YAML:1.0
            M: !!opencv-matrix
            rows: 3
            cols: 3
            dt: d
            !!opencv-matrix
            rows: 4
            cols: 1
            dt: d
            width: 640.
            height: 480.
            Hello @Eric-Katzfey I have scp'd that file over to the voxl, but the voxl-tag-detector still fails to start running. I try to restart it with systemctl restart voxl-tag-detector, but it comes up as Not Running in voxl-inspect-services. When I try running it in debug mode I get this printout.
            yocto:~$ voxl-tag-detector -d
            enabling debug mode
            detector #0
                enable:          1
                en_fast_mode:    1
                n_threads:       1
                en_undistortion: 1
                skip_n_frames:   5
            detector #1
                enable:          0
                input_pipe:      stereo
                en_fast_mode:    1
                n_threads:       1
                en_undistortion: 1
                skip_n_frames:   5
            detector #2
                enable:          0
                input_pipe:      extra
                en_fast_mode:    1
                n_threads:       1
                en_undistortion: 0
                skip_n_frames:   5
            #0:
                loc_type:        unknown
                size_m:            0.173
                                 1.0  0.0  0.0
                                 0.0  0.0  1.0
            Aborted
            I recall having to reset the calibration files for the px4 when debugging an earlier problem with your team. I have gone through and recalibrated those sensors already. Unless they are linked ot the px4 parameters, I have not removed any camera calibration files.
            • PawelJP PawelJ
              %YAML:1.0
              M: !!opencv-matrix
              rows: 3
              cols: 3
              dt: d
              !!opencv-matrix
              rows: 4
              cols: 1
              dt: d
              width: 640.
              height: 480.
              enabling debug mode
              detector #0
                  enable:          1
                  en_fast_mode:    1
                  n_threads:       1
                  en_undistortion: 1
                  skip_n_frames:   5
              detector #1
                  enable:          0
                  input_pipe:      stereo
                  en_fast_mode:    1
                  n_threads:       1
                  en_undistortion: 1
                  skip_n_frames:   5
              detector #2
                  enable:          0
                  input_pipe:      extra
                  en_fast_mode:    1
                  n_threads:       1
                  en_undistortion: 0
                  skip_n_frames:   5
              #0:
                  loc_type:        unknown
                  size_m:            0.173
                                   1.0  0.0  0.0
                                   0.0  0.0  1.0
              Aborted
              @PawelJ Yes, I think it is related to the system image flash procedure https://docs.modalai.com/flash-system-image/ It will wipe the /data partition where the calibration files exist unless you tell it not to do that.
              PawelJP 1 Reply Last reply
                PawelJP Offline
                PawelJP Offline
                PawelJ
                @Eric-Katzfey I did not wipe the /data partition during the reinstall
                • PawelJP PawelJ
                  @PawelJ We will investigate this and see why you lost the calibration files when flashing 3.3.0 system image.
                    PawelJP Offline
                    PawelJP Offline
                    PawelJ
                    @Eric-Katzfey do you have any suggestions to get this up and running? I am just trying to get the default system features working at the moment. I have added the missing calibration file, but it still appears to be failing.
                    • PawelJP PawelJ
                      @PawelJ Bear with us. Our subject matter experts are out on summer vacation this week.
                      • PawelJP Offline
                        PawelJP Offline
                        PawelJ
                        Yes of course, it's the time of year for a vacation :). Just an update....as I was working on some tflite portions of my project I noticed that the qvio-server was down now, but was not prior to adding the calibration file. If I run it in debug mode it provides a more helpful printout and shows that there is an error in loading the calibration file.
                        yocto:~$ voxl-qvio-server
                        loading qvio config file
                        imu_name:                         imu1
                        cam_name:                         tracking
                        odr_hz:                           30.000
                        use_camera_height_bootstrap:      1
                        camera_height_off_ground_m:        0.100
                        enable_init_while_moving:         1
                        cam_imu_timeshift_s:               0.002
                        cam_imu_timeshift_s_uncertainty:   0.001
                        T_cam_wrt_imu_uncertainty:         0.005  0.005  0.005
                        R_cam_to_imu_uncertainty:          0.040  0.040  0.040
                        accl_fsr_ms2:                     156.000
                        gyro_fsr_rad:                     34.000
                        accl_noise_std_dev:                0.316
                        gyro_noise_std_dev:                0.010
                        cam_noise_std_dev:                100.000
                        min_std_pixel_noise:               0.500
                        fail_high_pixel_noise_points:      1.665
                        limited_imu_bw_trigger:           35.000
                        gps_imu_time_alignment_s:          0.000
                        T_gps_wrt_imu:                    -0.115  0.450  0.100
                        enable_mapping:                   1
                        enable_gps_vel:                   0
                        setting scheduler
                        WARNING Failed to set priority, errno = 1
                        This seems to be a problem with ADB, the scheduler
                        should work properly when this is a background process
                        ERROR failed to set scheduler
                        #0:
                            parent:                imu1
                            child:                 tracking
                            T_child_wrt_parent:    0.017   0.015   0.013
                            RPY_parent_to_child:   0.0    45.0    90.0
                            R_child_to_parent:     0.000  -0.707   0.707
                                                   1.000   0.000  -0.000
                                                  -0.000   0.707   0.707
                        tbc:   0.017  0.015  0.013
                        ombc:  0.614  0.614  1.482 (axis angle)
                        ombc:  0.000 45.000 90.000 (RPY deg)
                        loading /data/modalai/opencv_tracking_intrinsics.yml
                        terminate called after throwing an instance of 'YAML::BadSubscript'
                          what():  operator[] call on a scalar
                        Aborted
                        Here is the what the file looks like
                        %YAML:1.0
                        M: !!opencv-matrix
                        rows: 3
                        cols: 3
                        dt: d
                        D: !!opencv-matrix
                        rows: 4
                        cols: 1
                        dt: d
                        width: 640.
                        height: 480.
                        Cheers
                        • PawelJP Offline
                          PawelJP Offline
                          PawelJ
                          Got the problem sorted out.
                          %YAML:1.0
                          M: !!opencv-matrix
                             rows: 3
                             cols: 3
                             dt: d
                          D: !!opencv-matrix
                             rows: 4
                             cols: 1
                             dt: d
                             width: 640.
                             height: 480.
                          Cheers
                          wilkinsafW 1 Reply Last reply
                          • PawelJP PawelJ
                            %YAML:1.0
                            M: !!opencv-matrix
                               rows: 3
                               cols: 3
                               dt: d
                            D: !!opencv-matrix
                               rows: 4
                               cols: 1
                               dt: d
                               width: 640.
                               height: 480.
                            Cheers
                            wilkinsafW Offline
                            wilkinsafW Offline
                            wilkinsaf
                            If anyone has run into this again,
                            ensure you update your /etc/modalai/voxl-tag-detector.conf to the tracking camera pipe you would like to do the april tag detection on.
                            the "tracking" has gotten update to "tracking_down" or "tracking_front"
