  3. Unable to bind controllers with starling 2
fpv
15 Posts 2 Posters 3.3k Views 1 Watching
  • T Offline
    T Offline
    taiwohazeez
    Hello, I have a four starling 2 drones, but I’ve not been able to fly any simply because I’ve not been able to bind my controllers to them. I initially got an orqa FPV controller, now I have a commando 8 elrs transmitter, I still can’t bind it. Can you kindly assist. Also my elrs LED on my drone keeps blinking between blue and pink, i think it’s not going into binding mode, despite using the command voxl-elrs —bind.
    Thank you for your help.
    Best,
    Taiwo
    • T taiwohazeez
      Best,
      Taiwo
      wrote on last edited by tom
      @taiwohazeez What is the SKU of your drone? voxl-inspect-sku
      Do you know what receiver is on your drone? Ghost and ELRS would require different receivers
        T Offline
        T Offline
        taiwohazeez
        @tom SKU : MRB-D0014-4-V1-C27-T9-M0-X0
        From the invoice, I can see Ghost Atto 2.4Ghz
        • T taiwohazeez
          @taiwohazeez Have you reviewed this doc?
          https://docs.modalai.com/orqa-ghost/
          You'll have to use the Orqa FPV controller, an ELRS commando will be incompatible with this receiver
          T 2 Replies Last reply
            T Offline
            T Offline
            taiwohazeez
            @tom thanks. I’ve been able to bind two of them.
              T Offline
              T Offline
              taiwohazeez
              @tom thank you for your help, I was able to bind two of my drones, but the other two keep saying unknown RX. Can you assist me with that ?
              • T taiwohazeez
                @taiwohazeez Are they also equipped with Ghost receivers?
                  T Offline
                  T Offline
                  taiwohazeez
                  @tom yes, they were purchased together
                  • T taiwohazeez
                    @taiwohazeez I unfortunately don't have any knowledge that isn't on our public docs link that I shared
                      T Offline
                      T Offline
                      taiwohazeez
                      @tom alright. Thank you! I will look into it again, hopefully it binds
                        T Offline
                        T Offline
                        taiwohazeez
                        @tom sorry to bother you once more, i got one more drone binded, but it refuses to get armed. I noticed that the ESC led (blue) isn't coming on. Do you have any suggestions?
                        Thanks.
                        • T taiwohazeez
                          Thanks.
                          T Offline
                          T Offline
                          taiwohazeez
                          @tom when i power up the drone, the led flashes, but after that, it stops
                          • T taiwohazeez
                            @taiwohazeez I recommend connecting the drone to QGroundControl via WiFi and then seeing what PX4 pre-arm checks are failing
                              T Offline
                              T Offline
                              taiwohazeez
                              @tom alright. Thank you for your time, I will do just that!
                              • T taiwohazeez
                                @taiwohazeez No problem, it would also be helpful to know what SDK version is loaded on your drone. You can check this with voxl-version
