  3. cam does not seem to be alive issue
image-sensor
26 Posts 3 Posters 7.3k Views 2 Watching
  • G giladWDS
    it seems to be there.
    I also check with the latest drivers found in here:
    https://gitlab.com/voxl-public/voxl-sdk/services/voxl-camera-server/-/tree/master/misc_files/usr/share/modalai/voxl-camera-server/drivers/ar0144
    and it did not changed the behavior.
    @giladWDS ,
    Everything looks correct. Is this the first time you are trying this configuration (and it has never worked)? Has this AR0144 camera worked before? And you also tried to put AR0144 camera on J7L and use sensormodule 2 for it? Do you have another AR0144 camera to try?
    I will try this configuration today to double check.
    G 1 Reply Last reply
    • G giladWDS
      @Vinny said in cam does not seem to be alive issue:
      Hi, thank you for your comment,
      I haven't cascaded the two cables.
      I am using MSU-M0084 to connect ar0144 and imx412 to J7, this is why it is probably looking longer then usual
      OK, @giladWDS I am trusting you, but to me that still looks like an impossibly long flex without doubling them or cascading an M0036 with an M0074/M0036 🙂
      Please remove the electronics from that cardboard box though and work on an ESD safe mat 🙂 That will help ensure long-term reliability.
        @giladWDS ,
        G Offline
        G Offline
        giladWDS
        I can confirm that the ar0144 module works.
        it works if i switch to J7L and then the imx connected to J7L wont work when it is connected to J7U.
        I know the setup works because i am currently running it with the same hardware on another voxl2
        @Vinny
        thank you for the comment, I will bring an ESD mat.
        • G giladWDS
          @Vinny
          G Offline
          G Offline
          giladWDS
          EDIT:
          If it helps this is my voxl-version
          system-image: 1.7.6-M0054-14.1a-perf
          kernel:       #1 SMP PREEMPT Wed Mar 20 19:48:52 UTC 2024 4.19.125
          hw platform:  M0054
          mach.var:     1.0
          voxl-suite:   1.2.0
          Packages:
          Repo:  http://voxl-packages.modalai.com/ ./dists/qrb5165/sdk-1.2/binary-arm64/
          Last Updated: 2023-03-02 13:19:12
          List:
          libfc-sensor                              1.0.5
          libmodal-cv                               0.4.0
          libmodal-exposure                         0.1.0
          libmodal-pipe                             2.10.0
          libqrb5165-io                             0.4.5
          libvoxl-cci-direct                        0.2.1
          modalai-slpi                              1.1.12
          qrb5165-dfs-server                        0.2.0
          qrb5165-imu-server                        1.0.1
          qrb5165-rangefinder-server                0.1.1
          qrb5165-system-tweaks                     0.2.6
          voxl-bind-spektrum                        0.1.1
          voxl-camera-calibration                   0.5.4
          voxl-camera-server                        1.9.1
          voxl-configurator                         0.5.6
          voxl-cpu-monitor                          0.4.8
          voxl-docker-support                       1.3.1
          voxl-elrs                                 0.1.3
          voxl-esc                                  1.4.0
          voxl-feature-tracker                      0.3.2
          voxl-flow-server                          0.3.3
          voxl-lepton-server                        1.2.0
          voxl-logger                               0.4.0
          voxl-mavcam-manager                       0.5.3
          voxl-mavlink-server                       1.4.0
          voxl-microdds-agent                       2.4.1-0
          voxl-modem                                1.0.9
          voxl-mpa-to-ros                           0.3.7
          voxl-mpa-to-ros2                          0.0.3
          voxl-mpa-tools                            1.1.5
          voxl-neopixel-manager                     0.0.3
          voxl-open-vins                            0.4.4
          voxl-open-vins-server                     0.2.18
          voxl-opencv                               4.5.5-2
          voxl-portal                               0.6.5
          voxl-px4                                  1.14.0-2.0.68
          voxl-px4-params                           0.3.8
          voxl-qvio-server                          1.0.2
          voxl-remote-id                            0.0.9
          voxl-ros2-foxy                            0.0.1
          voxl-streamer                             0.7.4
          voxl-suite                                1.2.0
          voxl-tflite-server                        0.3.2
          voxl-utils                                1.3.9
          voxl-uvc-server                           0.1.6
          voxl-vision-hub                           1.7.4
          voxl2-system-image                        1.7.6-r0
          • G giladWDS
            EDIT:
            hw platform:  M0054
            mach.var:     1.0
            voxl-suite:   1.2.0
            Packages:
            List:
            libfc-sensor                              1.0.5
            libmodal-cv                               0.4.0
            libqrb5165-io                             0.4.5
            modalai-slpi                              1.1.12
            voxl-elrs                                 0.1.3
            voxl-esc                                  1.4.0
            voxl-logger                               0.4.0
            voxl-modem                                1.0.9
            voxl-opencv                               4.5.5-2
            voxl-portal                               0.6.5
            voxl-streamer                             0.7.4
            voxl-suite                                1.2.0
            voxl-utils                                1.3.9
            #10
            @giladWDS , What you are describing sounds like a HW issue with J7U path, since either AR0144 or IMX412 is not functioning. Can you please inspect the Flex that you have connected to J7 for any damage? One more test would be connecting the whole flex to J6 and seeing if you can get J6U to work with either AR0144 or IMX412. If it works on J6U, then the issue may be on the voxl2 side of the hardware (in J7U connector path).
              G Offline
              G Offline
              giladWDS
              Thank you for the help, I have tried a different cable and it didn't work either, plus this flex is working when I am using it on a different voxl2
              • G giladWDS
                @giladWDS , it seems that there is a HW issue on the VOXL2 side with J7U. Specifically, any camera connected to it is not detected, which could be either i2c or power issue.
                Is it an option for you to connect the AR0144 camera to J8L ?
                In order to figure the problem the board would most likely need to be sent back to us for inspection.
                  G Offline
                  G Offline
                  giladWDS
                  Hi, after I had to work on other projects I have finally come back to this and I managed to make the voxl read all cameras when I moved the tracking camera to j8-lower.
                  now the issue I'm facing is with a frame rate reduction.
                  it seems that whenever I try to change the frame rate of one of the high-res cameras the server crashes.
                  this is the server log:
                  Oct 27 12:35:13 root systemd[1]: Started voxl-camera-server.
                  Oct 27 12:35:13 root voxl-camera-server[14170]: detected system image 1.7.6
                  Oct 27 12:35:13 root voxl-camera-server[14170]: using new imx412 defaults
                  Oct 27 12:35:14 root voxl-camera-server[14170]: using new imx412 defaults
                  Oct 27 12:35:14 root voxl-camera-server[14170]: =================================================================
                  Oct 27 12:35:14 root voxl-camera-server[14170]: configuration for 3 cameras:
                  Oct 27 12:35:14 root voxl-camera-server[14170]: cam #0
                  Oct 27 12:35:14 root voxl-camera-server[14170]:     name:                hires2
                  Oct 27 12:35:14 root voxl-camera-server[14170]:     sensor type:         imx412
                  Oct 27 12:35:14 root voxl-camera-server[14170]:     isEnabled:           1
                  Oct 27 12:35:14 root voxl-camera-server[14170]:     camId:               0
                  Oct 27 12:35:14 root voxl-camera-server[14170]:     camId2:              -1
                  Oct 27 12:35:14 root voxl-camera-server[14170]:     fps:                 10
                  Oct 27 12:35:14 root voxl-camera-server[14170]:     en_rotate:           0
                  Oct 27 12:35:14 root voxl-camera-server[14170]:     en_rotate2:          0
                  Oct 27 12:35:14 root voxl-camera-server[14170]:     en_preview:          1
                  Oct 27 12:35:14 root voxl-camera-server[14170]:     pre_width:           4056
                  Oct 27 12:35:14 root voxl-camera-server[14170]:     pre_height:          3040
                  Oct 27 12:35:14 root voxl-camera-server[14170]:     en_raw_preview:      0
                  Oct 27 12:35:14 root voxl-camera-server[14170]:     en_small_video:      0
                  Oct 27 12:35:14 root voxl-camera-server[14170]:     small_video_width:   1024
                  Oct 27 12:35:14 root voxl-camera-server[14170]:     small_video_height:  768
                  Oct 27 12:35:14 root voxl-camera-server[14170]:     en_large_video:      0
                  Oct 27 12:35:14 root voxl-camera-server[14170]:     large_video_width:   4056
                  Oct 27 12:35:14 root voxl-camera-server[14170]:     large_video_height:  3040
                  Oct 27 12:35:14 root voxl-camera-server[14170]:     en_snapshot:         0
                  Oct 27 12:35:14 root voxl-camera-server[14170]:     snap_width:          4056
                  Oct 27 12:35:14 root voxl-camera-server[14170]:     snap_height:         3040
                  Oct 27 12:35:14 root voxl-camera-server[14170]:     ae_mode:             isp
                  Oct 27 12:35:14 root voxl-camera-server[14170]:     standby_enabled:     0
                  Oct 27 12:35:14 root voxl-camera-server[14170]:     decimator:           1
                  Oct 27 12:35:14 root voxl-camera-server[14170]:     independent_exposure:0
                  Oct 27 12:35:14 root voxl-camera-server[14170]: cam #1
                  Oct 27 12:35:14 root voxl-camera-server[14170]:     camId:               1
                  Oct 27 12:35:14 root voxl-camera-server[14170]: cam #2
                  Oct 27 12:35:14 root voxl-camera-server[14170]:     name:                tracking
                  Oct 27 12:35:14 root voxl-camera-server[14170]:     sensor type:         ar0144
                  Oct 27 12:35:14 root voxl-camera-server[14170]:     camId:               2
                  Oct 27 12:35:14 root voxl-camera-server[14170]:     fps:                 30
                  Oct 27 12:35:14 root voxl-camera-server[14170]:     pre_width:           1280
                  Oct 27 12:35:14 root voxl-camera-server[14170]:     pre_height:          800
                  Oct 27 12:35:14 root voxl-camera-server[14170]:     en_raw_preview:      1
                  Oct 27 12:35:14 root voxl-camera-server[14170]:     small_video_width:   -1
                  Oct 27 12:35:14 root voxl-camera-server[14170]:     small_video_height:  -1
                  Oct 27 12:35:14 root voxl-camera-server[14170]:     large_video_width:   -1
                  Oct 27 12:35:14 root voxl-camera-server[14170]:     large_video_height:  -1
                  Oct 27 12:35:14 root voxl-camera-server[14170]:     snap_width:          -1
                  Oct 27 12:35:14 root voxl-camera-server[14170]:     snap_height:         -1
                  Oct 27 12:35:14 root voxl-camera-server[14170]:     ae_mode:             lme_msv
                  Oct 27 12:35:14 root voxl-camera-server[14170]: fsync_en:            0
                  Oct 27 12:35:14 root voxl-camera-server[14170]: fsync_gpio:          111
                  Oct 27 12:35:14 root voxl-camera-server[14170]: connected to GPS mavlink pipe
                  Oct 27 12:35:14 root voxl-camera-server[14170]: Starting Camera: hires2 (id #0)
                  Oct 27 12:35:14 root voxl-camera-server[14170]: Connected to cpu-monitor
                  Oct 27 12:35:14 root voxl-camera-server[14170]: Using gain limits min: 100 max: 1600
                  Oct 27 12:35:14 root voxl-camera-server[14170]: gbm_create_device(156): Info: backend name is: msm_drm
                  Oct 27 12:35:14 root voxl-camera-server[14170]: Starting Camera: hires (id #1)
                  Oct 27 12:35:14 root voxl-camera-server[14170]: ERROR:   Received "Result" error from camera: hires2
                  Oct 27 12:35:14 root systemd[1]: voxl-camera-server.service: Main process exited, code=killed, status=6/ABRT
                  Oct 27 12:35:14 root systemd[1]: voxl-camera-server.service: Failed with result 'signal'.
                  Oct 27 12:35:16 root systemd[1]: voxl-camera-server.service: Service hold-off time over, scheduling restart.
                  Oct 27 12:35:16 root systemd[1]: voxl-camera-server.service: Scheduled restart job, restart counter is at 1.
                  and this is the config file:
                  cat /etc/modalai/voxl-camera-server.conf
                   * voxl-camera-server Configuration File
                   * Each camera has configurations for up to 4 HAL3 streams:
                   *    - `preview` stream for raw unprocessed images from CV cameras
                   *    - `small_video` 720p (ish) h264/h265 compressed for fpv video streaming
                   *    - `large_video` 4k (ish) h264/h265 for onboard video recording to disk
                   *    - `snapshot` ISP-processed JPG snapshots that get saved to disk
                   * on QRB5165 platforms (VOXL2 and VOXL2 mini) you can only have 3 of the 4 enabled
                   * This file is generated from default values by voxl-configure-cameras.
                   * Do not expect arbitrary resolutions to work, the ISP and video compression
                   * pipelines only support very specific resolutions.
                   * The default video compression mode is cqp or Constant Quantization Parameter
                  	"version":	0.1,
                  	"fsync_en":	false,
                  	"fsync_gpio":	111,
                  	"cameras":	[{
                  			"type":	"imx412",
                  			"name":	"hires2",
                  			"enabled":	true,
                  			"camera_id":	0,
                  			"fps":	10,
                  			"en_preview":	true,
                  			"preview_width":	4056,
                  			"preview_height":	3040,
                  			"en_raw_preview":	false,
                  			"en_small_video":	false,
                  			"small_video_width":	1024,
                  			"small_video_height":	768,
                  			"small_venc_mode":	"h265",
                  			"small_venc_br_ctrl":	"cqp",
                  			"small_venc_Qfixed":	30,
                  			"small_venc_Qmin":	15,
                  			"small_venc_Qmax":	40,
                  			"small_venc_nPframes":	9,
                  			"small_venc_mbps":	2,
                  			"en_large_video":	false,
                  			"large_video_width":	4056,
                  			"large_video_height":	3040,
                  			"large_venc_mode":	"h265",
                  			"large_venc_br_ctrl":	"cqp",
                  			"large_venc_Qfixed":	38,
                  			"large_venc_Qmin":	15,
                  			"large_venc_Qmax":	50,
                  			"large_venc_nPframes":	29,
                  			"large_venc_mbps":	30,
                  			"en_snapshot":	false,
                  			"en_snapshot_width":	4056,
                  			"en_snapshot_height":	3040,
                  			"ae_mode":	"isp"
                  			"type":	"imx412",
                  			"name":	"hires",
                  			"enabled":	true,
                  			"camera_id":	1,
                  			"fps":	10,
                  			"en_preview":	true,
                  			"ae_mode":	"isp"
                  			"type":	"ar0144",
                  			"name":	"tracking",
                  			"enabled":	true,
                  			"camera_id":	2,
                  			"fps":	30,
                  			"en_rotate":	false,
                  			"en_preview":	true,
                  			"preview_width":	1280,
                  			"preview_height":	800,
                  			"en_raw_preview":	true,
                  			"ae_mode":	"lme_msv",
                  			"ae_desired_msv":	60,
                  			"exposure_min_us":	20,
                  			"exposure_max_us":	33000,
                  			"gain_min":	54,
                  			"gain_max":	8000,
                  			"exposure_soft_min_us":	5000,
                  			"ae_filter_alpha":	0.600000023841858,
                  			"ae_ignore_fraction":	0.20000000298023224,
                  			"ae_slope":	0.05000000074505806,
                  			"ae_exposure_period":	1,
                  			"ae_gain_period":	1
                  And when I change it back to 30 fps it works. the problem is the CPU toll 30 takes.
                  • G giladWDS
                    	"version":	0.1,
                    	"fsync_en":	false,
                    	"fsync_gpio":	111,
                    	"cameras":	[{
                    			"type":	"imx412",
                    			"name":	"hires2",
                    			"enabled":	true,
                    			"camera_id":	0,
                    			"fps":	10,
                    			"en_preview":	true,
                    			"ae_mode":	"isp"
                    			"type":	"imx412",
                    			"name":	"hires",
                    			"enabled":	true,
                    			"camera_id":	1,
                    			"fps":	10,
                    			"en_preview":	true,
                    			"ae_mode":	"isp"
                    			"type":	"ar0144",
                    			"name":	"tracking",
                    			"enabled":	true,
                    			"camera_id":	2,
                    			"fps":	30,
                    			"en_rotate":	false,
                    			"en_preview":	true,
                    			"gain_min":	54,
                    			"gain_max":	8000,
                    			"ae_gain_period":	1
                    @giladWDS I did a quick test on my set up with IMX214 connected, and it has no issue with 5 or 10 fps with largest resolution 4208x3120 preview. I am pretty sure i tested slower (than 30) FPS on IMX412 before. Can you please try some other FPS (15, 20, 25) and see if you can find any pattern of cases that do not work? Also what if you disable one of the cameras. I am just trying to think what can cause this..
                    I will get a chance to test with two IMX412 tomorrow.
                      G Offline
                      G Offline
                      giladWDS
                      I have tested different layouts with different cameras disabled and it didn't work either.
                      for some reason, the voxl won't accept any other frame rate in the config file other than 30.
                      • G giladWDS
                        @giladWDS , this is strange. I can set IMX412 to any rate I want, however I am using different sensormodule files - can you please try to use ones from :
                        /usr/share/modalai/chi-cdk/imx412-fpv/com.qti.sensormodule.imx412_fpv_0.bin
                        /usr/share/modalai/chi-cdk/imx412-fpv/com.qti.sensormodule.imx412_fpv_2.bin
                        instead of com.qti.sensormodule.imx412_0.bin com.qti.sensormodule.imx412_2.bin (remove or rename these first).
                        please note that it is possible that the "fpv" version of the sensormodules may not have the full resolution in your older system image (latest ones do), which you can check using voxl-camera-server -l, but i think it should..
                        Edit: i also tried the modules you used, and works fine for me (i tested using a single camera)
                        One more thing to try is to lock camera server to faster cpu cores, which can be done in the following way from command line (you should stop the camera server service first):
                        taskset --cpu-list 4-7 voxl-camera-server
                        If this still does not work, please provide output of dmesg and logcat saved to separate files, so i can potentially see the reason for the crash. Thanks! (well, even if one of the solutions works, i would still be curious what error you were getting before!)
                          G Offline
                          G Offline
                          giladWDS
                          It would take some time to do this since I found a workaround compiling the camera server from source with a small fix:
                          I changed the hal3_camera_mgr.cpp
                          int32_t frame_rate_rate[] = {fps,fps};
                          into:
                          int32_t frame_rate_rate[] = {1,30};
                          I know this is hacky and will probably bite me if I try to put higher fps for low fps cameras like a tof or something but it works for now.
                          I will get back to it and update.
                          • G giladWDS
                            into:
                            @giladWDS , thanks for the udpate!
                            I believe we had to use the following line in order to enable fps higher than 30 (or higher than 60, i forget), otherwise the high fps was not working.
                            We will keep this in mind, however I am not able to reproduce your issues, so we'll just keep this conversation open.
                              G Offline
                              G Offline
                              giladWDS
                              @Alex-Kushleyev hi
                              I just stumbled upon the same bug with our voxl-flight-deck module that also refuses to downscale the fps.
                              • G giladWDS
                                @Alex-Kushleyev hi
                                @giladWDS , can you please provide minimal instructions to reproduce on voxl2? I can try it from sdk install, then configure cameras, modify config to lower fps and test.
                                Regarding flight deck, is it voxl2 flight deck or voxl1?
                                Alex KushleyevA G 2 Replies Last reply
                                  Perhaps the solution will be to check if desired fps is less than 30, then use the different fps range, but I would like to reproduce first, since i am able to set the fps correctly below 30 as is.
                                    G Offline
                                    G Offline
                                    giladWDS
                                    the flight-deck is a voxl2 unit (qrb chip)
                                    with voxl-camera-server 1.8.9 on 1.1.2 SDK
                                    other than that one imx412 is enough for the server to crash but let me know if you want the full config and/or driver list
                                    • G giladWDS
                                      @giladWDS ,
                                      Is it possible for you to try the same test on the latest SDK, at least 1.3.3 or 1.3.5 ?
                                      There have been many fixes and updates since 1.1.2 and 1.2.0.
                                      I just tested again on our latest camera server and no issue running 5 or 10hz preview at full resolution 4056x3040.
                                        @giladWDS ,
                                        G Offline
                                        G Offline
                                        giladWDS
                                        I will test it with the flight deck and let you know as soon as I can
                                        • G giladWDS
                                          @giladWDS , I believe i was able to reproduce the issue. It seems you cannot set the fps lower than 15fps only when you have raw preview enabled and no other streams that use ISP are running. Can you please confirm that this is the case?
                                          If you have non-raw preview or other streams enabled like small or large video, then what happens the pipeline will actually drop frames to achieve the desired fps. So it is not ideal, that is to say that the camera is still sending higher fps, but the frames are dropped. However, the overhead for receiving extra frames and dropping them at lowest level is not too big. I will investigate if we can actually set the camera to run at the desired lower fps.
                                          I am pretty sure that i can fix it, perhaps using the fix you already found, but can you please confirm that this is your camera configuration, if possible just paste your hires camera config here. Thanks!
