  3. cam does not seem to be alive issue
image-sensor
26 Posts 3 Posters 7.1k Views 2 Watching
  • G Offline
    G Offline
    giladWDS
    I have the following setup:
    I have configured it with the following file in: /data/modalai/custom_camera_config.txt
    #!/bin/bash
    # This file allows setting of custom camera configurations by defining what
    # sensors are plugged into which port.
    # There is no guarantee that any arbitrary configuration will work. Only the
    # predefined camera configs at https://docs.modalai.com/voxl2-camera-configs/
    # are supported.
    # each slot can be one of the following sensors:
    # pmd-tof
    # pmd-tof-liow2
    # ov7251
    # ov7251-combo
    # ov9782
    # ov9782-combo
    # ar0144
    # ar0144-fsin (for use with m0173 and Starling 2 only)
    # ar0144-fsin-combo (for use with m0173 and Starling 2 only)
    # imx214
    # imx412
    # imx412-fpv (low latency mode)
    # imx678
    # When using a combo mode pair, you must also add a JX_COMBO_MODE field which
    # specifies is the pair is to be set up as either a stereo pair ordered
    # left-right, right-left, or treated as two independent cameras. If you are
    # using a combo-mode flex but only physically connect one of the two cameras
    # then select "single" it does not matter which one you connect.
    # For example:
    # J6_LOWER_COMBO_MODE="left-right"
    # J6_LOWER_COMBO_MODE="right-left"
    # J6_LOWER_COMBO_MODE="independent"
    # J6_LOWER_COMBO_MODE="single"
    # when running "independent" combo mode, also add a NAME2 field for the second cam
    # e.g J6_LOWER_NAME2="tracking_rear"
    # for all sensors except TOF, you can specify a "rotate" flag to
    # rotate the image 180 degrees e.g. J6_LOWER_ROTATE="true" or "false"
    # for stereo pairs (e.g. ov7251 combo or ar0144-slave-strereo) you can specify
    # "rotate-first-only" or "rotate-second-only" to only rotate one, other wise
    # when setting the rotate option to "true" both will be rotated.
    # Once configured, this file should live in /data/modalai/custom_camera-config.txt
    # then run voxl-configure-cameras custom to load it in
    # cp /usr/share/modalai/voxl-camera-server/custom_camera_config.txt /data/modalai/
    # We also suggest changing your /data/modalai/sku.txt file to have a camera
    # config term "CC" such as MRB-D0005-4-V2-CC
    J6_LOWER_SENSOR="imx412"
    J6_LOWER_NAME="hires"
    J6_LOWER_ROTATE="false"
    J6_UPPER_SENSOR=""
    J6_UPPER_NAME=""
    J6_UPPER_ROTATE="false"
    J7_LOWER_SENSOR="imx412"
    J7_LOWER_NAME="hires2"
    J7_LOWER_ROTATE="false"
    J7_UPPER_SENSOR="ar0144"
    J7_UPPER_NAME="tracking"
    J7_UPPER_ROTATE="false"
    J8_LOWER_SENSOR=""
    J8_LOWER_NAME=""
    J8_LOWER_ROTATE="false"
    J8_UPPER_SENSOR=""
    J8_UPPER_NAME=""
    J8_UPPER_ROTATE="false"
    And chose the C option int the voxl-configure-cameras script.
    Then after reset I don’t see J7_UPPER sensor (tracking)
    even when I am trying to switch between j7 lower and upper, J7_UPPER is missing.
    when I reset voxl-camera-server system service and check it's status i get:
    voxl-camera-server.service - voxl-camera-server
       Loaded: loaded (/usr/bin/voxl-camera-server; enabled; vendor preset: enabled)
       Active: active (running) since Mon 2024-08-26 14:42:34 UTC; 6s ago
     Main PID: 17591 (voxl-camera-ser)
        Tasks: 112 (limit: 4915)
       CGroup: /system.slice/voxl-camera-server.service
               └─17591 /usr/bin/voxl-camera-server
    Aug 26 14:42:34 m0054 voxl-camera-server[17591]: =================================================================
    Aug 26 14:42:34 m0054 voxl-camera-server[17591]: connected to mavlink pipe
    Aug 26 14:42:34 m0054 voxl-camera-server[17591]: Starting Camera: hires (id #0)
    Aug 26 14:42:34 m0054 voxl-camera-server[17591]: Connected to cpu-monitor
    Aug 26 14:42:34 m0054 voxl-camera-server[17591]: gbm_create_device(156): Info: backend name is: msm_drm
    Aug 26 14:42:34 m0054 voxl-camera-server[17591]: Starting Camera: hires2 (id #1)
    Aug 26 14:42:34 m0054 voxl-camera-server[17591]: Starting Camera: tracking (id #2)
    Aug 26 14:42:34 m0054 voxl-camera-server[17591]: WARNING: cam tracking (id 2) does not seem to be alive
    Aug 26 14:42:34 m0054 voxl-camera-server[17591]: ------ voxl-camera-server: Started 2 of 3 cameras
    Aug 26 14:42:34 m0054 voxl-camera-server[17591]: ------ voxl-camera-server: Camera server is now running
    Furthermore, voxel-camera-server -l command prints:
    DEBUG:   Cam idx: 0, Cam slot: 0, Slave Address: 0x0034, Sensor Id: 0x0577
    DEBUG:   Cam idx: 1, Cam slot: 2, Slave Address: 0x0034, Sensor Id: 0x0577
    DEBUG:   Number of cameras: 2
    Stats for camera: 0
    4056 x 3040
    4056 x 2288
    3040 x 3040
    3040 x 3040
    3040 x 3040
    3040 x 3040
    4056 x 3040
    4056 x 3040
    4056 x 2288
    4056 x 2288
    4056 x 2288
    4056 x 2288
    2028 x 1112
    1920 x 1080
    1280 x  960 HAL_PIXEL_FORMAT_YCbCr_420_888
    1280 x  960 HAL_PIXEL_FORMAT_BLOB
    1280 x  800 HAL_PIXEL_FORMAT_YCbCr_420_888
    1280 x  800 HAL_PIXEL_FORMAT_BLOB
    1280 x  768 HAL_PIXEL_FORMAT_YCbCr_420_888
    1280 x  768 HAL_PIXEL_FORMAT_BLOB
    1280 x  720 HAL_PIXEL_FORMAT_YCbCr_420_888
    1280 x  720 HAL_PIXEL_FORMAT_BLOB
    1024 x  738 HAL_PIXEL_FORMAT_YCbCr_420_888
    1024 x  738 HAL_PIXEL_FORMAT_BLOB
    1024 x  768 HAL_PIXEL_FORMAT_YCbCr_420_888
    1024 x  768 HAL_PIXEL_FORMAT_BLOB
     864 x  480 HAL_PIXEL_FORMAT_YCbCr_420_888
     864 x  480 HAL_PIXEL_FORMAT_BLOB
     800 x  600 HAL_PIXEL_FORMAT_YCbCr_420_888
     800 x  600 HAL_PIXEL_FORMAT_BLOB
     800 x  480 HAL_PIXEL_FORMAT_YCbCr_420_888
     800 x  480 HAL_PIXEL_FORMAT_BLOB
     720 x  480 HAL_PIXEL_FORMAT_YCbCr_420_888
     720 x  480 HAL_PIXEL_FORMAT_BLOB
    4056 x 3040 HAL_PIXEL_FORMAT_RAW10
    4056 x 3040 HAL_PIXEL_FORMAT_RAW12
    4056 x 3040 HAL_PIXEL_FORMAT_RAW16
    4056 x 3040 HAL_PIXEL_FORMAT_RAW_OPAQUE
    	min = 100
    	max = 1600
    	1600
    	min = 0ns
    	max = 232155075ns
    Stats for camera: 1
    4056 x 3040
    4056 x 2288
    3040 x 3040
    3040 x 3040
    3040 x 3040
    3040 x 3040
    4056 x 3040
    4056 x 3040
    4056 x 2288
    4056 x 2288
    4056 x 2288
    4056 x 2288
    2028 x 1112
    1920 x 1080
    	min = 100
    	max = 1600
    	1600
    	min = 0ns
    	max = 232155075ns
    Number of cameras detected: 2
    And, vocel-inspect-cam doesn’t give me the option to inspect tracking so when I try `voxl-inspect-cam -a’ I get:
    I would love any help with this.
    VinnyV 1 Reply Last reply
    • G giladWDS
      #!/bin/bash
      # are supported.
      # pmd-tof
      # pmd-tof-liow2
      # ov7251
      # ov7251-combo
      # ov9782
      # ov9782-combo
      # ar0144
      # imx214
      # imx412
      # imx678
      # For example:
      J6_UPPER_SENSOR=""
      J6_UPPER_NAME=""
      J8_LOWER_SENSOR=""
      J8_LOWER_NAME=""
      J8_UPPER_SENSOR=""
      J8_UPPER_NAME=""
      Stats for camera: 0
      4056 x 3040
      4056 x 2288
      3040 x 3040
      3040 x 3040
      3040 x 3040
      3040 x 3040
      4056 x 3040
      4056 x 3040
      4056 x 2288
      4056 x 2288
      4056 x 2288
      4056 x 2288
      2028 x 1112
      1920 x 1080
      	min = 100
      	max = 1600
      	1600
      	min = 0ns
      	max = 232155075ns
      Stats for camera: 1
      4056 x 3040
      4056 x 2288
      3040 x 3040
      3040 x 3040
      3040 x 3040
      3040 x 3040
      4056 x 3040
      4056 x 3040
      4056 x 2288
      4056 x 2288
      4056 x 2288
      4056 x 2288
      2028 x 1112
      1920 x 1080
      	min = 100
      	max = 1600
      	1600
      	min = 0ns
      	max = 232155075ns
      Hi @giladWDS
      I am from hardware and noticed you have an extra long flex for the Hires..
      cf4dc137-d477-4bfd-babf-9ebd542cb008-image.png Did you cascade two M0036 extension flexes back to back?
      You will most likely have failures in this config and we do not recommend it if that is what I am observing.
      https://docs.modalai.com/image-sensor-flexes-adapters/#extending-mipi-image-sensor-cable-lengths
      Not sure if it is related to your issue or not, but I would at least start by using a well supported hardware config before digging too deep into the SW configuration concerns you have.
      Hope this helps!
      Alex KushleyevA G 2 Replies Last reply
      • VinnyV Vinny
        Hi @giladWDS
        Hope this helps!
        @giladWDS , can you please provide the list of camera files that you currently have in /usr/lib/camera:
        ls /usr/lib/camera/
        I just want to double check that AR0144 camera driver files are there.
        G 1 Reply Last reply
        • VinnyV Vinny
          Hi @giladWDS
          Hope this helps!
          G Offline
          G Offline
          giladWDS
          @Vinny said in cam does not seem to be alive issue:
          Hi, thank you for your comment,
          I haven't cascaded the two cables.
          I am using MSU-M0084 to connect ar0144 and imx412 to J7, this is why it is probably looking longer then usual
            ls /usr/lib/camera/
            G Offline
            G Offline
            giladWDS
            it seems to be there.
            I also check with the latest drivers found in here:
            https://gitlab.com/voxl-public/voxl-sdk/services/voxl-camera-server/-/tree/master/misc_files/usr/share/modalai/voxl-camera-server/drivers/ar0144
            and it did not changed the behavior.
            • G giladWDS
              @giladWDS ,
              Everything looks correct. Is this the first time you are trying this configuration (and it has never worked)? Has this AR0144 camera worked before? And you also tried to put AR0144 camera on J7L and use sensormodule 2 for it? Do you have another AR0144 camera to try?
              I will try this configuration today to double check.
              • G giladWDS
                OK, @giladWDS I am trusting you, but to me that still looks like an impossibly long flex without doubling them or cascading an M0036 with an M0074/M0036 🙂
                Please remove the electronics from that cardboard box though and work on an ESD safe mat 🙂 That will help ensure long-term reliability.
                  @giladWDS ,
                  G Offline
                  G Offline
                  giladWDS
                  I can confirm that the ar0144 module works.
                  it works if i switch to J7L and then the imx connected to J7L wont work when it is connected to J7U.
                  I know the setup works because i am currently running it with the same hardware on another voxl2
                  @Vinny
                  thank you for the comment, I will bring an ESD mat.
                  • G giladWDS
                    @Vinny
                    G Offline
                    G Offline
                    giladWDS
                    EDIT:
                    If it helps this is my voxl-version
                    system-image: 1.7.6-M0054-14.1a-perf
                    kernel:       #1 SMP PREEMPT Wed Mar 20 19:48:52 UTC 2024 4.19.125
                    hw platform:  M0054
                    mach.var:     1.0
                    voxl-suite:   1.2.0
                    Packages:
                    Repo:  http://voxl-packages.modalai.com/ ./dists/qrb5165/sdk-1.2/binary-arm64/
                    Last Updated: 2023-03-02 13:19:12
                    List:
                    libfc-sensor                              1.0.5
                    libmodal-cv                               0.4.0
                    libmodal-exposure                         0.1.0
                    libmodal-pipe                             2.10.0
                    libqrb5165-io                             0.4.5
                    libvoxl-cci-direct                        0.2.1
                    modalai-slpi                              1.1.12
                    qrb5165-dfs-server                        0.2.0
                    qrb5165-imu-server                        1.0.1
                    qrb5165-rangefinder-server                0.1.1
                    qrb5165-system-tweaks                     0.2.6
                    voxl-bind-spektrum                        0.1.1
                    voxl-camera-calibration                   0.5.4
                    voxl-camera-server                        1.9.1
                    voxl-configurator                         0.5.6
                    voxl-cpu-monitor                          0.4.8
                    voxl-docker-support                       1.3.1
                    voxl-elrs                                 0.1.3
                    voxl-esc                                  1.4.0
                    voxl-feature-tracker                      0.3.2
                    voxl-flow-server                          0.3.3
                    voxl-lepton-server                        1.2.0
                    voxl-logger                               0.4.0
                    voxl-mavcam-manager                       0.5.3
                    voxl-mavlink-server                       1.4.0
                    voxl-microdds-agent                       2.4.1-0
                    voxl-modem                                1.0.9
                    voxl-mpa-to-ros                           0.3.7
                    voxl-mpa-to-ros2                          0.0.3
                    voxl-mpa-tools                            1.1.5
                    voxl-neopixel-manager                     0.0.3
                    voxl-open-vins                            0.4.4
                    voxl-open-vins-server                     0.2.18
                    voxl-opencv                               4.5.5-2
                    voxl-portal                               0.6.5
                    voxl-px4                                  1.14.0-2.0.68
                    voxl-px4-params                           0.3.8
                    voxl-qvio-server                          1.0.2
                    voxl-remote-id                            0.0.9
                    voxl-ros2-foxy                            0.0.1
                    voxl-streamer                             0.7.4
                    voxl-suite                                1.2.0
                    voxl-tflite-server                        0.3.2
                    voxl-utils                                1.3.9
                    voxl-uvc-server                           0.1.6
                    voxl-vision-hub                           1.7.4
                    voxl2-system-image                        1.7.6-r0
                    • G giladWDS
                      EDIT:
                      hw platform:  M0054
                      mach.var:     1.0
                      voxl-suite:   1.2.0
                      Packages:
                      List:
                      libfc-sensor                              1.0.5
                      libmodal-cv                               0.4.0
                      libqrb5165-io                             0.4.5
                      modalai-slpi                              1.1.12
                      voxl-elrs                                 0.1.3
                      voxl-esc                                  1.4.0
                      voxl-logger                               0.4.0
                      voxl-modem                                1.0.9
                      voxl-opencv                               4.5.5-2
                      voxl-portal                               0.6.5
                      voxl-streamer                             0.7.4
                      voxl-suite                                1.2.0
                      voxl-utils                                1.3.9
                      #10
                      @giladWDS , What you are describing sounds like a HW issue with J7U path, since either AR0144 or IMX412 is not functioning. Can you please inspect the Flex that you have connected to J7 for any damage? One more test would be connecting the whole flex to J6 and seeing if you can get J6U to work with either AR0144 or IMX412. If it works on J6U, then the issue may be on the voxl2 side of the hardware (in J7U connector path).
                        G Offline
                        G Offline
                        giladWDS
                        Thank you for the help, I have tried a different cable and it didn't work either, plus this flex is working when I am using it on a different voxl2
                        • G giladWDS
                          @giladWDS , it seems that there is a HW issue on the VOXL2 side with J7U. Specifically, any camera connected to it is not detected, which could be either i2c or power issue.
                          Is it an option for you to connect the AR0144 camera to J8L ?
                          In order to figure the problem the board would most likely need to be sent back to us for inspection.
                            G Offline
                            G Offline
                            giladWDS
                            Hi, after I had to work on other projects I have finally come back to this and I managed to make the voxl read all cameras when I moved the tracking camera to j8-lower.
                            now the issue I'm facing is with a frame rate reduction.
                            it seems that whenever I try to change the frame rate of one of the high-res cameras the server crashes.
                            this is the server log:
                            Oct 27 12:35:13 root systemd[1]: Started voxl-camera-server.
                            Oct 27 12:35:13 root voxl-camera-server[14170]: detected system image 1.7.6
                            Oct 27 12:35:13 root voxl-camera-server[14170]: using new imx412 defaults
                            Oct 27 12:35:14 root voxl-camera-server[14170]: using new imx412 defaults
                            Oct 27 12:35:14 root voxl-camera-server[14170]: =================================================================
                            Oct 27 12:35:14 root voxl-camera-server[14170]: configuration for 3 cameras:
                            Oct 27 12:35:14 root voxl-camera-server[14170]: cam #0
                            Oct 27 12:35:14 root voxl-camera-server[14170]:     name:                hires2
                            Oct 27 12:35:14 root voxl-camera-server[14170]:     sensor type:         imx412
                            Oct 27 12:35:14 root voxl-camera-server[14170]:     isEnabled:           1
                            Oct 27 12:35:14 root voxl-camera-server[14170]:     camId:               0
                            Oct 27 12:35:14 root voxl-camera-server[14170]:     camId2:              -1
                            Oct 27 12:35:14 root voxl-camera-server[14170]:     fps:                 10
                            Oct 27 12:35:14 root voxl-camera-server[14170]:     en_rotate:           0
                            Oct 27 12:35:14 root voxl-camera-server[14170]:     en_rotate2:          0
                            Oct 27 12:35:14 root voxl-camera-server[14170]:     en_preview:          1
                            Oct 27 12:35:14 root voxl-camera-server[14170]:     pre_width:           4056
                            Oct 27 12:35:14 root voxl-camera-server[14170]:     pre_height:          3040
                            Oct 27 12:35:14 root voxl-camera-server[14170]:     en_raw_preview:      0
                            Oct 27 12:35:14 root voxl-camera-server[14170]:     en_small_video:      0
                            Oct 27 12:35:14 root voxl-camera-server[14170]:     small_video_width:   1024
                            Oct 27 12:35:14 root voxl-camera-server[14170]:     small_video_height:  768
                            Oct 27 12:35:14 root voxl-camera-server[14170]:     en_large_video:      0
                            Oct 27 12:35:14 root voxl-camera-server[14170]:     large_video_width:   4056
                            Oct 27 12:35:14 root voxl-camera-server[14170]:     large_video_height:  3040
                            Oct 27 12:35:14 root voxl-camera-server[14170]:     en_snapshot:         0
                            Oct 27 12:35:14 root voxl-camera-server[14170]:     snap_width:          4056
                            Oct 27 12:35:14 root voxl-camera-server[14170]:     snap_height:         3040
                            Oct 27 12:35:14 root voxl-camera-server[14170]:     ae_mode:             isp
                            Oct 27 12:35:14 root voxl-camera-server[14170]:     standby_enabled:     0
                            Oct 27 12:35:14 root voxl-camera-server[14170]:     decimator:           1
                            Oct 27 12:35:14 root voxl-camera-server[14170]:     independent_exposure:0
                            Oct 27 12:35:14 root voxl-camera-server[14170]: cam #1
                            Oct 27 12:35:14 root voxl-camera-server[14170]:     camId:               1
                            Oct 27 12:35:14 root voxl-camera-server[14170]: cam #2
                            Oct 27 12:35:14 root voxl-camera-server[14170]:     name:                tracking
                            Oct 27 12:35:14 root voxl-camera-server[14170]:     sensor type:         ar0144
                            Oct 27 12:35:14 root voxl-camera-server[14170]:     camId:               2
                            Oct 27 12:35:14 root voxl-camera-server[14170]:     fps:                 30
                            Oct 27 12:35:14 root voxl-camera-server[14170]:     pre_width:           1280
                            Oct 27 12:35:14 root voxl-camera-server[14170]:     pre_height:          800
                            Oct 27 12:35:14 root voxl-camera-server[14170]:     en_raw_preview:      1
                            Oct 27 12:35:14 root voxl-camera-server[14170]:     small_video_width:   -1
                            Oct 27 12:35:14 root voxl-camera-server[14170]:     small_video_height:  -1
                            Oct 27 12:35:14 root voxl-camera-server[14170]:     large_video_width:   -1
                            Oct 27 12:35:14 root voxl-camera-server[14170]:     large_video_height:  -1
                            Oct 27 12:35:14 root voxl-camera-server[14170]:     snap_width:          -1
                            Oct 27 12:35:14 root voxl-camera-server[14170]:     snap_height:         -1
                            Oct 27 12:35:14 root voxl-camera-server[14170]:     ae_mode:             lme_msv
                            Oct 27 12:35:14 root voxl-camera-server[14170]: fsync_en:            0
                            Oct 27 12:35:14 root voxl-camera-server[14170]: fsync_gpio:          111
                            Oct 27 12:35:14 root voxl-camera-server[14170]: connected to GPS mavlink pipe
                            Oct 27 12:35:14 root voxl-camera-server[14170]: Starting Camera: hires2 (id #0)
                            Oct 27 12:35:14 root voxl-camera-server[14170]: Connected to cpu-monitor
                            Oct 27 12:35:14 root voxl-camera-server[14170]: Using gain limits min: 100 max: 1600
                            Oct 27 12:35:14 root voxl-camera-server[14170]: gbm_create_device(156): Info: backend name is: msm_drm
                            Oct 27 12:35:14 root voxl-camera-server[14170]: Starting Camera: hires (id #1)
                            Oct 27 12:35:14 root voxl-camera-server[14170]: ERROR:   Received "Result" error from camera: hires2
                            Oct 27 12:35:14 root systemd[1]: voxl-camera-server.service: Main process exited, code=killed, status=6/ABRT
                            Oct 27 12:35:14 root systemd[1]: voxl-camera-server.service: Failed with result 'signal'.
                            Oct 27 12:35:16 root systemd[1]: voxl-camera-server.service: Service hold-off time over, scheduling restart.
                            Oct 27 12:35:16 root systemd[1]: voxl-camera-server.service: Scheduled restart job, restart counter is at 1.
                            and this is the config file:
                            cat /etc/modalai/voxl-camera-server.conf
                             * voxl-camera-server Configuration File
                             * Each camera has configurations for up to 4 HAL3 streams:
                             *    - `preview` stream for raw unprocessed images from CV cameras
                             *    - `small_video` 720p (ish) h264/h265 compressed for fpv video streaming
                             *    - `large_video` 4k (ish) h264/h265 for onboard video recording to disk
                             *    - `snapshot` ISP-processed JPG snapshots that get saved to disk
                             * on QRB5165 platforms (VOXL2 and VOXL2 mini) you can only have 3 of the 4 enabled
                             * This file is generated from default values by voxl-configure-cameras.
                             * Do not expect arbitrary resolutions to work, the ISP and video compression
                             * pipelines only support very specific resolutions.
                             * The default video compression mode is cqp or Constant Quantization Parameter
                            	"version":	0.1,
                            	"fsync_en":	false,
                            	"fsync_gpio":	111,
                            	"cameras":	[{
                            			"type":	"imx412",
                            			"name":	"hires2",
                            			"enabled":	true,
                            			"camera_id":	0,
                            			"fps":	10,
                            			"en_preview":	true,
                            			"preview_width":	4056,
                            			"preview_height":	3040,
                            			"en_raw_preview":	false,
                            			"en_small_video":	false,
                            			"small_video_width":	1024,
                            			"small_video_height":	768,
                            			"small_venc_mode":	"h265",
                            			"small_venc_br_ctrl":	"cqp",
                            			"small_venc_Qfixed":	30,
                            			"small_venc_Qmin":	15,
                            			"small_venc_Qmax":	40,
                            			"small_venc_nPframes":	9,
                            			"small_venc_mbps":	2,
                            			"en_large_video":	false,
                            			"large_video_width":	4056,
                            			"large_video_height":	3040,
                            			"large_venc_mode":	"h265",
                            			"large_venc_br_ctrl":	"cqp",
                            			"large_venc_Qfixed":	38,
                            			"large_venc_Qmin":	15,
                            			"large_venc_Qmax":	50,
                            			"large_venc_nPframes":	29,
                            			"large_venc_mbps":	30,
                            			"en_snapshot":	false,
                            			"en_snapshot_width":	4056,
                            			"en_snapshot_height":	3040,
                            			"ae_mode":	"isp"
                            			"type":	"imx412",
                            			"name":	"hires",
                            			"enabled":	true,
                            			"camera_id":	1,
                            			"fps":	10,
                            			"en_preview":	true,
                            			"ae_mode":	"isp"
                            			"type":	"ar0144",
                            			"name":	"tracking",
                            			"enabled":	true,
                            			"camera_id":	2,
                            			"fps":	30,
                            			"en_rotate":	false,
                            			"en_preview":	true,
                            			"preview_width":	1280,
                            			"preview_height":	800,
                            			"en_raw_preview":	true,
                            			"ae_mode":	"lme_msv",
                            			"ae_desired_msv":	60,
                            			"exposure_min_us":	20,
                            			"exposure_max_us":	33000,
                            			"gain_min":	54,
                            			"gain_max":	8000,
                            			"exposure_soft_min_us":	5000,
                            			"ae_filter_alpha":	0.600000023841858,
                            			"ae_ignore_fraction":	0.20000000298023224,
                            			"ae_slope":	0.05000000074505806,
                            			"ae_exposure_period":	1,
                            			"ae_gain_period":	1
                            And when I change it back to 30 fps it works. the problem is the CPU toll 30 takes.
                            • G giladWDS
                              	"version":	0.1,
                              	"fsync_en":	false,
                              	"fsync_gpio":	111,
                              	"cameras":	[{
                              			"type":	"imx412",
                              			"name":	"hires2",
                              			"enabled":	true,
                              			"camera_id":	0,
                              			"fps":	10,
                              			"en_preview":	true,
                              			"ae_mode":	"isp"
                              			"type":	"imx412",
                              			"name":	"hires",
                              			"enabled":	true,
                              			"camera_id":	1,
                              			"fps":	10,
                              			"en_preview":	true,
                              			"ae_mode":	"isp"
                              			"type":	"ar0144",
                              			"name":	"tracking",
                              			"enabled":	true,
                              			"camera_id":	2,
                              			"fps":	30,
                              			"en_rotate":	false,
                              			"en_preview":	true,
                              			"gain_min":	54,
                              			"gain_max":	8000,
                              			"ae_gain_period":	1
                              @giladWDS I did a quick test on my set up with IMX214 connected, and it has no issue with 5 or 10 fps with largest resolution 4208x3120 preview. I am pretty sure i tested slower (than 30) FPS on IMX412 before. Can you please try some other FPS (15, 20, 25) and see if you can find any pattern of cases that do not work? Also what if you disable one of the cameras. I am just trying to think what can cause this..
                              I will get a chance to test with two IMX412 tomorrow.
                                G Offline
                                G Offline
                                giladWDS
                                I have tested different layouts with different cameras disabled and it didn't work either.
                                for some reason, the voxl won't accept any other frame rate in the config file other than 30.
                                • G giladWDS
                                  @giladWDS , this is strange. I can set IMX412 to any rate I want, however I am using different sensormodule files - can you please try to use ones from :
                                  /usr/share/modalai/chi-cdk/imx412-fpv/com.qti.sensormodule.imx412_fpv_0.bin
                                  /usr/share/modalai/chi-cdk/imx412-fpv/com.qti.sensormodule.imx412_fpv_2.bin
                                  instead of com.qti.sensormodule.imx412_0.bin com.qti.sensormodule.imx412_2.bin (remove or rename these first).
                                  please note that it is possible that the "fpv" version of the sensormodules may not have the full resolution in your older system image (latest ones do), which you can check using voxl-camera-server -l, but i think it should..
                                  Edit: i also tried the modules you used, and works fine for me (i tested using a single camera)
                                  One more thing to try is to lock camera server to faster cpu cores, which can be done in the following way from command line (you should stop the camera server service first):
                                  taskset --cpu-list 4-7 voxl-camera-server
                                  If this still does not work, please provide output of dmesg and logcat saved to separate files, so i can potentially see the reason for the crash. Thanks! (well, even if one of the solutions works, i would still be curious what error you were getting before!)
                                    G Offline
                                    G Offline
                                    giladWDS
                                    It would take some time to do this since I found a workaround compiling the camera server from source with a small fix:
                                    I changed the hal3_camera_mgr.cpp
                                    int32_t frame_rate_rate[] = {fps,fps};
                                    into:
                                    int32_t frame_rate_rate[] = {1,30};
                                    I know this is hacky and will probably bite me if I try to put higher fps for low fps cameras like a tof or something but it works for now.
                                    I will get back to it and update.
                                    • G giladWDS
                                      into:
                                      @giladWDS , thanks for the udpate!
                                      I believe we had to use the following line in order to enable fps higher than 30 (or higher than 60, i forget), otherwise the high fps was not working.
                                      We will keep this in mind, however I am not able to reproduce your issues, so we'll just keep this conversation open.
                                        G Offline
                                        G Offline
                                        giladWDS
                                        @Alex-Kushleyev hi
                                        I just stumbled upon the same bug with our voxl-flight-deck module that also refuses to downscale the fps.
                                        • G giladWDS
                                          @Alex-Kushleyev hi
                                          @giladWDS , can you please provide minimal instructions to reproduce on voxl2? I can try it from sdk install, then configure cameras, modify config to lower fps and test.
                                          Regarding flight deck, is it voxl2 flight deck or voxl1?
