    Starling MAX
    VOXL Dev Drones
    • Thomas EiszlerT
      Thomas Eiszler
      We had to replace the power/ESC module on our Starling MAX and now we cannot arm the drone. voxl-esc scan seems to detect the ESC, but perhaps we are missing some configuration. There are a number of setup_ commands for voxl-esc, but it is not clear which applies to the Starling Max. How can we set up the new ESC?
      Tom
        tom admin @Thomas Eiszler
        @Thomas-Eiszler I would recommend just running voxl-configure-mpa which will ensure you have the correct services configured and running as well as check the ESCs firmware and params and will update them if necessary
        Thomas EiszlerT 1 Reply Last reply Reply Quote 0
        • Thomas EiszlerT
          Thomas Eiszler @tom
          Thanks @tom! That seems to have worked. After configuration, I ran voxl-esc spin and all 4 rotors spun up in turn. Just another quick question about the output.
          Finished!
          [4.992197] TX=504, RX=1000 packets, RX CRC ERRORS=0
          Average RPMs: 0.00 0.00 0.00 1998.98
          Average RPM deviation between ESCs : 1998.98
          disabling bridge
          Is this just a quirk in the way the average RPMs are reported or should I be concerned that 3 of the 4 have a 0 average? They definitely all spun up, and seemed to reach the same speed.
          Thomas EiszlerT Alex KushleyevA 2 Replies Last reply Reply Quote 0
          • Thomas EiszlerT
            Thomas Eiszler @Thomas Eiszler
            @tom There is also another anomaly: voxl-inspect-battery shows voltage and current, but charge is listed as 0%. Is there some service that needs to be restarted/configured, like voxl-px4, in order to get a reading of the battery charge?
            I also ran px4-listener battery_status which also doesn't seem right. The cells that came with the Starling MAX I believe are 7.2V (two 2s in series, so 4 cells total).
            voxl2:/$ px4-listener battery_status
            TOPIC: battery_status
             battery_status
                timestamp: 1051478873 (0.067609 seconds ago)
                voltage_v: 5.76600
                voltage_filtered_v: 5.76056
                current_a: 1.00800
                current_filtered_a: 0.96054
                current_average_a: 3.40000
                discharged_mah: 299.21326
                remaining: 0.00000
                scale: 1.30000
                time_remaining_s: 0.00000
                temperature: nan
                voltage_cell_v: [0.00000, 0.00000, 0.00000, 0.00000, 0.00000, 0.00000, 0.00000, 0.00000, 0.00000, 0.00000, 0.00000, 0.00000, 0.00000, 0.00000]
                max_cell_voltage_delta: 0.00000
                custom_faults: 0
                average_power: 0.00000
                available_energy: 0.00000
                full_charge_capacity_wh: 0.00000
                remaining_capacity_wh: 0.00000
                design_capacity: 0.00000
                nominal_voltage: 0.00000
                capacity: 3950
                cycle_count: 0
                average_time_to_empty: 0
                serial_number: 0
                manufacture_date: 0
                state_of_health: 0
                max_error: 0
                interface_error: 0
                faults: 0
                average_time_to_full: 0
                over_discharge_count: 0
                connected: True
                cell_count: 4
                source: 0
                priority: 0
                is_powering_off: False
                is_required: False
                warning: 3
                mode: 0
            Do I need to change the POWER_MANAGER in /etc/modalai/voxl-px4.conf from VOXLPM to NONE and restar the voxl-px4 service? The comments seem to indicate that we should be using NONE with the Mini-ESC 4 in1:
            # POWER_MANAGER:
            #     Tell PX4 which power manager to use.
            #     Use NONE for ModalAI Mini-ESC since the ESC driver handles PM.
            #     Use EXTERNAL when not using the ModalAI APM power manager to power the board
            #       This also just disables the voxlpm driver, same as the NONE option
            #     Options include: [VOXLPM, EXTERNAL, NONE]
              Alex Kushleyev ModalAI Team @Thomas Eiszler
              @Thomas-Eiszler , what test command did you use for the case where 4 motors spun up but the only ID3 reported feedback?
              Finished!
              disabling bridge
              The number of TX and RX packets indicate to me that you most likely only spun ID3 of ESC in this test because you have double RX packets than TX (ID3 seconds out normal feedback packet and another one with current measurment for the whole board).
              voxl-esc spin probably only spun one motor at a time, in which case this is the expected behavior, and we should probably update the script to not report the deviation if only one motor was actually spinning in the particular test.
                @Thomas-Eiszler , As long as you dont actually have the APM connected, having the power manager driver enabled in PX4 will not conflict with the mini ESC also reporting battery_status. This is because even though the APM driver in PX4 will attempt to start, it will fail to find the actual hardware device (via i2c probe) and will exit the driver. However, it is best to disable the power manager (APM) driver.
                Starling 2 MAX uses two 2-cell packs in series, so it is a 4-cell pack.
                when you run voxl-esc spin test, it should report voltage reported by each ESC. Does that match the actual battery voltage or is it also wrong (as is reported in your battery_status ?
