  3. Starling MAX
Starling MAX
6 Posts 3 Posters 4.1k Views 2 Watching
  • Thomas EiszlerT Offline
    Thomas Eiszler
    We had to replace the power/ESC module on our Starling MAX and now we cannot arm the drone. voxl-esc scan seems to detect the ESC, but perhaps we are missing some configuration. There are a number of setup_ commands for voxl-esc, but it is not clear which applies to the Starling Max. How can we set up the new ESC?
    Tom
    • Thomas EiszlerT Thomas Eiszler
      Tom
      @Thomas-Eiszler I would recommend just running voxl-configure-mpa which will ensure you have the correct services configured and running as well as check the ESCs firmware and params and will update them if necessary
      Thomas EiszlerT 1 Reply Last reply
        Thomas Eiszler
        Thanks @tom! That seems to have worked. After configuration, I ran voxl-esc spin and all 4 rotors spun up in turn. Just another quick question about the output.
        Finished!
        [4.992197] TX=504, RX=1000 packets, RX CRC ERRORS=0
        Average RPMs: 0.00 0.00 0.00 1998.98
        Average RPM deviation between ESCs : 1998.98
        disabling bridge
        Is this just a quirk in the way the average RPMs are reported or should I be concerned that 3 of the 4 have a 0 average? They definitely all spun up, and seemed to reach the same speed.
        Thomas EiszlerT Alex KushleyevA 2 Replies Last reply
          Finished!
          disabling bridge
          Thomas Eiszler
          wrote on last edited by Thomas Eiszler
          @tom There is also another anomaly: voxl-inspect-battery shows voltage and current, but charge is listed as 0%. Is there some service that needs to be restarted/configured, like voxl-px4, in order to get a reading of the battery charge?
          I also ran px4-listener battery_status which also doesn't seem right. The cells that came with the Starling MAX I believe are 7.2V (two 2s in series, so 4 cells total).
          voxl2:/$ px4-listener battery_status
          TOPIC: battery_status
           battery_status
              timestamp: 1051478873 (0.067609 seconds ago)
              voltage_v: 5.76600
              voltage_filtered_v: 5.76056
              current_a: 1.00800
              current_filtered_a: 0.96054
              current_average_a: 3.40000
              discharged_mah: 299.21326
              remaining: 0.00000
              scale: 1.30000
              time_remaining_s: 0.00000
              temperature: nan
              voltage_cell_v: [0.00000, 0.00000, 0.00000, 0.00000, 0.00000, 0.00000, 0.00000, 0.00000, 0.00000, 0.00000, 0.00000, 0.00000, 0.00000, 0.00000]
              max_cell_voltage_delta: 0.00000
              custom_faults: 0
              average_power: 0.00000
              available_energy: 0.00000
              full_charge_capacity_wh: 0.00000
              remaining_capacity_wh: 0.00000
              design_capacity: 0.00000
              nominal_voltage: 0.00000
              capacity: 3950
              cycle_count: 0
              average_time_to_empty: 0
              serial_number: 0
              manufacture_date: 0
              state_of_health: 0
              max_error: 0
              interface_error: 0
              faults: 0
              average_time_to_full: 0
              over_discharge_count: 0
              connected: True
              cell_count: 4
              source: 0
              priority: 0
              is_powering_off: False
              is_required: False
              warning: 3
              mode: 0
          Do I need to change the POWER_MANAGER in /etc/modalai/voxl-px4.conf from VOXLPM to NONE and restar the voxl-px4 service? The comments seem to indicate that we should be using NONE with the Mini-ESC 4 in1:
          # POWER_MANAGER:
          #     Tell PX4 which power manager to use.
          #     Use NONE for ModalAI Mini-ESC since the ESC driver handles PM.
          #     Use EXTERNAL when not using the ModalAI APM power manager to power the board
          #       This also just disables the voxlpm driver, same as the NONE option
          #     Options include: [VOXLPM, EXTERNAL, NONE]
            Finished!
            disabling bridge
            @Thomas-Eiszler , what test command did you use for the case where 4 motors spun up but the only ID3 reported feedback?
            Finished!
            disabling bridge
            The number of TX and RX packets indicate to me that you most likely only spun ID3 of ESC in this test because you have double RX packets than TX (ID3 seconds out normal feedback packet and another one with current measurment for the whole board).
            voxl-esc spin probably only spun one motor at a time, in which case this is the expected behavior, and we should probably update the script to not report the deviation if only one motor was actually spinning in the particular test.
               battery_status
                  voltage_v: 5.76600
                  current_a: 1.00800
                  remaining: 0.00000
                  scale: 1.30000
                  temperature: nan
                  custom_faults: 0
                  capacity: 3950
                  cycle_count: 0
                  serial_number: 0
                  manufacture_date: 0
                  state_of_health: 0
                  max_error: 0
                  interface_error: 0
                  faults: 0
                  connected: True
                  cell_count: 4
                  source: 0
                  priority: 0
                  is_required: False
                  warning: 3
                  mode: 0
              # POWER_MANAGER:
              @Thomas-Eiszler , As long as you dont actually have the APM connected, having the power manager driver enabled in PX4 will not conflict with the mini ESC also reporting battery_status. This is because even though the APM driver in PX4 will attempt to start, it will fail to find the actual hardware device (via i2c probe) and will exit the driver. However, it is best to disable the power manager (APM) driver.
              Starling 2 MAX uses two 2-cell packs in series, so it is a 4-cell pack.
              when you run voxl-esc spin test, it should report voltage reported by each ESC. Does that match the actual battery voltage or is it also wrong (as is reported in your battery_status ?
