    Stereo cameras not working with 14.5cm extension cable
    2546
    • Gary HolmgrenG
      Gary Holmgren
      Alex KushleyevA VinnyV 2 Replies Last reply Reply Quote 0
        Alex Kushleyev ModalAI Team @Gary Holmgren
        @Gary-Holmgren ,
        Can you please check using the following command whether the cameras are detected. The detection part only uses the I2C connection to the cameras, which should be just fine over the longer extension flex.
        voxl-camera-server -l
        the output of this command should tell you which "slots" the cameras have been detected (at the beginning). You can compare the output between running this command when all commands are working and not working.
        If the cameras cannot be detected when using the longer flex, please double check the flex connection orientation (to make sure pin1 goes to pin1 in all connectors).
        If the camera server can detect all the cameras, but not stream the images, then most likely the long flex is affecting the high speed image transmission.
        Also, can you check if the result is the same if you insert the long flex into the front stereo pair instead of rear?
        I can test this configuration as well, but you may find some results sooner.
        • VinnyV
          Vinny ModalAI Team @Gary Holmgren
          Hi @Gary-Holmgren
          We wrote this up some time ago to help explain the "why" of these longer flexes not always working.
          Link here
          You can read in the report that not every configuration is readily supported, and may take some custom tweaks to make it work, such as slowing down the MIPI rates.
          Alex has you covered otherwise!
          • R
            robertociuch @Vinny
            @Vinny @Gary-Holmgren
            I'm running into the same problem, unfortunally using the longer extension cables the camera server fail to start,
            I have read the article about MIPI CSI protocols, is it possible to lower the speed to use the cameras with the longer extension cable? In case how can I do it?
            thank you!
            • VinnyV
              Vinny ModalAI Team @robertociuch
              HI @robertociuch
              I'm sure @Alex-Kushleyev has a few config files ready to go for lower clock speeds. But, these are not broadly supported as far as I know, so you will need to be sure you apply them after every SDK update and retest.
              Can you confirm your image sensor setup you have now and which one is the problem child?
              Alex, correct me if I am wrong on any thing I just wrote 🙂
              R Riccardo BenedettiR 2 Replies Last reply Reply Quote 0
              • R
                robertociuch @Vinny
                @Vinny
                I am using the Sentinel configuration:
                stereo front - Omnivision OV7251
                stereo rear - Omnivision OV7251
                tracking - Omnivision OV7251
                hi-res - Sony IMX214 (eventually I will use the IMX412, but I still need to try it)
                • Riccardo BenedettiR
                  Riccardo Benedetti @Vinny
                  Hi @Vinny and @Alex-Kushleyev,
                  any update about the config files?
                  Thank you
                    Alex Kushleyev ModalAI Team @Riccardo Benedetti
                    @Riccardo-Benedetti and @robertociuch (and anyone else), can you please clarify which specific cameras in which position (slot / connector) you are looking to use with longer extension cables?
                    I am looking into how we could make the modified drivers available.
                    • R
                      robertociuch @Alex Kushleyev
                      Hi @Alex-Kushleyev ,
                      I use a configuration like the photo below, I still need to test the IMX412 hi-res with a custom extension cable,
                      do you think it would be better to lower the bitrate also for that camera?
                        Alex Kushleyev ModalAI Team @robertociuch
                        @robertociuch , ok, got it, so basically two stereo pairs is what we can address first.
                        For stereo pairs, i think there is some issues due to additional length of stereo splitter and the flex connected to the ov7251 cameras. So that is why lowering the mipi rate is needed.
                        Regarding IMX412, we have some flexibility in modifying the MIPI transfer rate as well, but lowering it may affect maximum resolution / fps (depending on what resolution / fps you need). IMX412 does work with our M0036 extension flex (14.5cm). We can discuss what you need after sorting out the stereo pairs. However, please try your new flex as well to see if it just works out of the box.
                        Lets do the following: i can share modified camera drivers for the stereo pairs, so you can test and confirm that it works and then I will discuss internally how to make them available in our standard release. I'll follow up later today or tomorrow morning.
                        voxltesterV 2 Replies Last reply Reply Quote 0
                        • voxltesterV
                          voxltester @Alex Kushleyev
                          I have replaced the built-in hires camera with IMX412 camera (https://www.modalai.com/collections/all/products/msu-m0107?variant=45747768557872).
                          I used M0036 cable as well, and it worked.
                          This is my voxl-camera-server.conf for the setting
                          	"version":	0.1,
                          	"cameras":	[{
                          			"type":	"ov7251",
                          			"name":	"tracking",
                          			"enabled":	true,
                          			"camera_id":	0,
                          			"fps":	30,
                          			"en_rotate":	false,
                          			"en_preview":	true,
                          			"preview_width":	640,
                          			"preview_height":	480,
                          			"en_raw_preview":	true,
                          			"ae_mode":	"lme_msv",
                          			"ae_desired_msv":	60,
                          			"exposure_min_us":	20,
                          			"exposure_max_us":	33000,
                          			"gain_min":	54,
                          			"gain_max":	8000,
                          			"exposure_soft_min_us":	5000,
                          			"ae_filter_alpha":	0.600000023841858,
                          			"ae_ignore_fraction":	0.20000000298023224,
                          			"ae_slope":	0.05000000074505806,
                          			"ae_exposure_period":	1,
                          			"ae_gain_period":	1
                          			"type":	"imx412",
                          			"name":	"hires",
                          			"enabled":	true,
                          			"camera_id":	1,
                          			"fps":	30,
                          			"en_preview":	false,
                          			"en_raw_preview":	false,
                          			"en_small_video":	true,
                          			"small_video_width":	1024,
                          			"small_video_height":	768,
                          			"small_venc_mode":	"h265",
                          			"small_venc_br_ctrl":	"cqp",
                          			"small_venc_Qfixed":	30,
                          			"small_venc_Qmin":	15,
                          			"small_venc_Qmax":	40,
                          			"small_venc_nPframes":	9,
                          			"small_venc_mbps":	2,
                          			"en_large_video":	true,
                          			"large_video_width":	4056,
                          			"large_video_height":	3040,
                          			"large_venc_mode":	"h265",
                          			"large_venc_br_ctrl":	"cqp",
                          			"large_venc_Qfixed":	38,
                          			"large_venc_Qmin":	15,
                          			"large_venc_Qmax":	50,
                          			"large_venc_nPframes":	29,
                          			"large_venc_mbps":	30,
                          			"en_snapshot":	true,
                          			"en_snapshot_width":	4056,
                          			"en_snapshot_height":	3040,
                          			"ae_mode":	"isp"
                          By the way, I have a question regarding "camera_id" in /etc/modalai/voxl-camera-server.conf.
                          I set up the camera with 04 - ov7251 tracking imx214 hires and can see the "camera_id" 0 for the ov7251. For imx214, "camera_id" is set as 1.
                          The camera connection is exactly same in the above photo (J7)
                          Isn't J7 port's "camera_id" 2 and 3 as described in https://docs.modalai.com/voxl2-image-sensors/#sdk-110-system-image-17x?
                          I would like to know what is the correct "camera_id" for the (ov7251+imx214) and (ov7251+imx412).
                          Also, I was wondering if the photo posted on the website was correct.
                          • voxltesterV
                            One more question.
                            I found imx214 with M0036 cable is not working.
                            I thought it is just a cable.
                            I do not have any knowledge, could you please why it is not working with a cable?
                            Thanks in advance.
                              Alex Kushleyev ModalAI Team @voxltester
                              @voxltester , the hardware sensor IDs (also known as camera slot IDs) are described correctly in our documentation. However, the camera server is not aware of the hardware IDs because the camera framework remaps the HW sensor ids (camera slot ids) to what we call camera_id.
                              camera_id for voxl-camera-server are derived from the HW sensor ids. The camera_ids will be in the same order as HW sensor IDs but camera_ids will start from 0 and will be consecutive.
                              So that if you have CameraX plugged in to J6 Upper (HW sensor ID1) and CameraY plugged in to J7 Lower (HW sensor ID2), for voxl-camera-server, the CameraX will have camera_id=0, the CameraY will have camera_id=1
                                @voxltester , is your IMX214 camera working without the M0036 cable? Do you have another M0036 cable to try?
                                When you say it is not working, is it detected when you run voxl-camera-server -l or not? The two possibilities are:
                                • the camera is not detected using voxl-camera-server -l
                                • the camera IS detected using voxl-camera-server -l but does not stream any images
                                Alex KushleyevA voxltesterV 2 Replies Last reply Reply Quote 0
                                  @robertociuch
                                  I started testing a single stereo pair (front), plugged in to J6 and it works with a single M0036 extension (14.5cm). I tried two different M0036 cables. I am using SDK 1.3.0.
                                  In the original post of this thread, i mistakenly thought that the user was trying to connect TWO M0036 extenders back to back and that does not work unless the mipi rate is lowered. But the single M0036 seems to work fine.
                                  Can you please provide some more details about your test:
                                  • SDK version that you are using
                                  • what camera configuration option do you select when setting up camera configs
                                  • does the same configuration work with shorter flexes? (M0074)
                                  • can you try to enable only one stereo pair at a time (disable all the other cameras in voxl-camera-server.conf) and see if front stereo works and (separately) rear stereo works?
                                  • does voxl-camera-server -l detect all the cameras that are physically connected to the board?
                                  • voxltesterV
                                    Thank you for the information. Now I understood about the parameters and numbers.
                                    Regarding IMX214 (https://www.modalai.com/products/msu-m0025-2) + M0036 cable (https://www.modalai.com/products/m0036),
                                    it is working without M0036 cable. (hires and tracking cameras are connected only with M0084 (https://www.modalai.com/collections/accessories/products/msu-m0084)
                                    You are correct. The camera IS detected using voxl-camera-server -l but does not stream any images!!
                                    I can see the detected cameras with voxl-camera-server -l,
                                    DEBUG:   Cam idx: 0, Cam slot: 2, Slave Address: 0x00E2, Sensor Id: 0x7750
                                    DEBUG:   Cam idx: 1, Cam slot: 3, Slave Address: 0x0020, Sensor Id: 0x0214
                                    DEBUG:   Number of cameras: 2
                                    Cam idx: 0 is tracking, and Cam idx: 1 is IMX214
                                    But I cannot see the output of hires camera with M0036 cable.
                                    |           Pipe Name |  bytes  | wide |  hgt |exp(ms)| gain | frame id |latency(ms)|  fps |  mbps  | format
                                    |   hires_large_color |
                                    | hires_large_encoded |
                                    |    hires_large_grey |
                                    |   hires_small_color |
                                    | hires_small_encoded |
                                    |    hires_small_grey |
                                    |      hires_snapshot |
                                    |        qvio_overlay |  368640 |  640 |  576 |  4.75 |   51 |    15635 |     35.0  | 30.0 |   88.5 | RAW8
                                    |              tflite |
                                    |            tracking |  307200 |  640 |  480 |  4.75 |   51 |    15636 |     11.6  | 30.0 |   73.7 | RAW8
                                    Any thought?
                                    • R
                                      I tried with only one M0036 extension cable and it works, but as I connect the second pair of cameras with one more M0036 extension it starts to have some issues, the camera server sometimes starts but most of the times it doesn't, if it does I get a mixed preview of the cameras in the voxl portal, for example I want to see a preview of one pair of stereo and instead of seeing left and right cameras I see one of the front and one of the rear, and then it crashes,
                                      I already tried to replace the extensions, the cameras and even the voxl with brand new pieces but that configuration doesn't work, the only way is to use the shorter extension cables M0074 on one of the stereo pair (or both), with that extension I never got any type of problem.
                                      I am using the SDK 1.3.0
                                      The camera preset I am using is the 11 (sentinel)
                                      The camera server detects all the cameras, if I disable one of the two stereo pairs it seem to work
                                        @robertociuch , I understand. Please hang in there, i will test the dual stereo configuration, each with a single M0036 extension cable. I should get back to you later today.
                                          @robertociuch , I tested the dual stereo configuration with M0036 14.5cm extensions on each stereo. Stereo pairs plugged into J6 and J8, just like Camera Configuration 11 shows (link), I unplugged all other cameras. Seems to be working fine. I am attaching the voxl-camera-server.conf file with just stereo set up. Also, i am using SDK 1.3.2, however it should be working with older SDKs. If you find that installing the longer flex is an issue, it is possible that the flex itself is problematic. You can test the stereo pairs individually to find if there is a particular cable that is bad.
                                          Also, please double check that the following sensormodules (camera drivers) are present in the correct location:
                                          voxl2:/$ ls /usr/lib/camera/*combo*
                                          /usr/lib/camera/com.qti.sensormodule.ov7251_combo_0.bin  /usr/lib/camera/com.qti.sensormodule.ov7251_combo_4.bin
                                          /usr/lib/camera/com.qti.sensormodule.ov7251_combo_1.bin  /usr/lib/camera/com.qti.sensormodule.ov7251_combo_5.bin
                                          	"version":	0.1,
                                          	"fsync_en":	false,
                                          	"fsync_gpio":	109,
                                          	"cameras":	[{
                                          			"type":	"ov7251",
                                          			"name":	"stereo_front",
                                          			"enabled":	true,
                                          			"camera_id":	0,
                                          			"camera_id_second":	1,
                                          			"independent_exposure":	false,
                                          			"fps":	30,
                                          			"en_rotate":	true,
                                          			"en_rotate_second":	true,
                                          			"en_preview":	true,
                                          			"gain_min":	54,
                                          			"gain_max":	8000,
                                          			"ae_gain_period":	1
                                          			"type":	"ov7251",
                                          			"name":	"stereo_rear",
                                          			"enabled":	true,
                                          			"camera_id":	3,
                                          			"camera_id_second":	2,
                                          			"fps":	30,
                                          			"en_rotate":	false,
                                          			"en_rotate_second":	false,
                                          			"en_preview":	true,
                                          			"gain_min":	54,
                                          			"gain_max":	8000,
                                          			"ae_gain_period":	1
