  3. voxl-docker-mavsdk-python build issues
voxl
48 Posts 6 Posters 32.2k Views 4 Watching
    @Alexander-Saunders Not sure why that is happening. That does not happen when I try it. I'm guessing that you have a networking issue of some sort or perhaps all this messing with Docker on the target has somehow corrupted it and it needs to be reinstalled.
    Alexander SaundersA Offline
    Alexander Saunders
    @Eric-Katzfey So I deleted and re cloned voxl-docker-mavsdk-python branch ascend/docker. The build image failed halfway in. Is there any work that needs to be done on the VOXL2 or host computer that I am not aware of? Screenshot from 2024-05-28 10-15-10.png Screenshot from 2024-05-28 10-14-45.png
      Alexander Saunders
      @Eric-Katzfey Also in the environment, the SDK is 1.2, python 3.10.12, Ubuntu 22.04.4 LTS
        @Alexander-Saunders Okay, we're looking into it, thanks!
        Alexander SaundersA 1 Reply Last reply
          Alexander Saunders
          @Eric-Katzfey Thank you! What kind of timeline should I expect to hear back from you?
          B 2 Replies Last reply
            B Offline
            B Offline
            brahim
            @Alexander-Saunders I am testing a fix for this issue as we speak. I've sourced the problem to a Mavsdk dependency that had a recent upstream change which is causing issues on the voxl2 build image script.
              B Offline
              B Offline
              brahim
              @Alexander-Saunders can you try the following patch to the Dockerfile?
              I noticed that the mavsdk 3rd party package updated their header files to include a filesystem header that is incompatible with standard cpp libraries on ubuntu 18.04, hence switching the dockerfile to focal instead of bionic. You can save the text in a *.patch file (e.g. "filesystem.patch") and then run
              git apply filesystem.patch
              Alternatively just switch the docker base image from "bionic" to "focal"
              diff --git a/Dockerfile b/Dockerfile
              index c38a5c7..08e668b 100644
              --- a/Dockerfile
              +++ b/Dockerfile
              @@ -1,4 +1,4 @@
              -FROM arm64v8/ubuntu:bionic
              +FROM arm64v8/ubuntu:focal
               WORKDIR /home
              @@ -8,7 +8,7 @@ RUN wget -O - https://apt.kitware.com/keys/kitware-archive-latest.asc 2>/dev/nul
               RUN apt-add-repository 'deb https://apt.kitware.com/ubuntu/ bionic main'
               RUN apt-get update
               RUN apt-get install -y cmake build-essential colordiff git doxygen -y
              -RUN apt-get install -y python3 python3-pip -y
              +RUN apt-get install -y python3 python3-pip -y
               RUN apt-get install -y git libxml2-dev libxslt-dev curl
               RUN git clone https://github.com/mavlink/MAVSDK.git
              Alexander SaundersA 2 Replies Last reply
              • B brahim
                --- a/Dockerfile
                +++ b/Dockerfile
                @@ -1,4 +1,4 @@
                 WORKDIR /home
                 RUN apt-get update
                Alexander Saunders
                @brahim Thank you for getting back to me! I do not have access to the VOXL at this moment, but will be able to test first thing in the morning.
                • B brahim
                  --- a/Dockerfile
                  +++ b/Dockerfile
                  @@ -1,4 +1,4 @@
                   WORKDIR /home
                   RUN apt-get update
                  Alexander Saunders
                  wrote on last edited by Alexander Saunders
                  #29
                  @brahim Changing from bionic to focal lead to Docker being installed successfully. I am currently following this documentation: https://docs.modalai.com/voxl2-PX4-hitl/ .
                  The commands were ran fine:
                  1. wget https://storage.googleapis.com/modalai_public/modal_dockers/voxl-gazebo-docker_v1_2.tgz
                  2. docker load < voxl-gazebo-docker_v1_2.tgz
                  3. docker tag voxl-gazebo-docker:v1.2 voxl-gazebo-docker:latest
                  I am not using QGC because I am troubleshooting why only heartbeat packages are being sent and not GPS, Odometry, etc. voxl-px4 and qvio-server have been disabled.
                  In a separate terminal, voxl-px4-hitl is being ran as called for in the documentation. The main issues are gazebo seems to not give expected outputs with some of the commands and the lack of status data from dsp_hitl. I've also looked through the forum to see if anyone else had a similar problem. If you or anyone could point me in the correct direction, I would greatly appreciate that!
                  -Alexander
                  Screenshot from 2024-05-29 13-27-31.png Screenshot from 2024-05-29 13-28-05.png Screenshot from 2024-05-29 13-32-45.png
                  Stefan AmundarainS 1 Reply Last reply
                    -Alexander
                    Stefan AmundarainS Offline
                    Stefan Amundarain
                    wrote on last edited by Stefan Amundarain
                    #30
                    @Alexander-Saunders @brahim to add on a follow up, what is the correct pin out of the FTDI cable we plug into the j18 port? Documentation says no power, just RX, TX, and Gnd; but YouTube instruction by Ascend Engineering uses Power as well. YouTube video by ModalAI matches instructions but the information doesn’t seem to be read, just heartbeat packets.
                    VinnyV 1 Reply Last reply
                    • Stefan AmundarainS Stefan Amundarain
                      Hi @Stefan-Amundarain
                      Not all FTDI cables are the same. There are literally over a dozen variations out there.
                      If the specific FTDI cable requires a "VTREF" to set the logic levels, then a VCC is needed as on Ascend's example. If you use one that is USB powered and TTL levles, then likely it is already set for 3.3V, and no power is required.
                      So, please double check your specific FTDI cable before following any tutorials you may see and make appropriate mods as needed.
                      • VinnyV Vinny
                        Alexander Saunders
                        #32
                        @Vinny @brahim @Eric-Katzfey We're still running into the issue of no meaningful data being sent to gazebo. The only data is still the heartbeat packets.
                        We're referencing: https://docs.modalai.com/voxl2-PX4-hitl/
                        We've done the steps up to: docker run --rm -it --net=host --privileged -e DISPLAY=$DISPLAY -v /dev/input:/dev/input:rw -v /tmp/.X11-unix:/tmp/.X11-unix:ro voxl-gazebo-docker ./run_gazebo.bash
                        and
                        qshell dsp_hitl status which is telling us about the heartbeat only.
                        Also, we tried the archived instructions to see if we would get a different output.
                        The FTDI cable used is the same, but the serial port closed issue has stopped. Don't know why.
                        The warning for SDF I feel like is the source of the problem.
                        The warning when running docker run --rm:
                        Status output:
                          and
                          Status output:
                          @Alexander-Saunders Are you doing xhost + before running docker?
                            Alexander Saunders
                            @Eric-Katzfey The latest attempts, yes. After running that and
                            gazebo will open up. The issue is connect gazebo with VOXL2 to run in HITL mode. I've followed two of the video from Modalai and Ascend exactly with no luck. Also went through the documentation again.
                            All instances are being ran on the host computer. When comparing the image from above to docs, we are only getting heartbeat packets.
                              @Alexander-Saunders The heartbeat counter is the amount of heartbeat messages being sent out, not received. So you are not getting anything on the serial port.
                                @Alexander-Saunders Also, take a look at this: https://www.reddit.com/r/linux4noobs/comments/lu1plx/hi_i_get_this_authorization_required_but_no/
                                  @Alexander-Saunders Definitely looks like a permissions issue of some sort in your system.
                                    Alexander Saunders
                                    @Eric-Katzfey Are you suggesting giving the file/repo permissions with
                                    xhost si:localuser:root
                                    Also we are using the FDTI cable provided with the ESC AND USB C to A to connect to host.
                                      @Alexander-Saunders I'm only suggesting that there is a permissions problem of some sort. I don't see that on my machine so just trying to figure out what is different in your environment.
                                      Alexander SaundersA 3 Replies Last reply
                                        Alexander Saunders
                                        @Eric-Katzfey I tried giving permission to user with no change.
                                          Alexander Saunders
                                          @Eric-Katzfey Is it possible to see a picture of your terminal of the commands you sent?
