  3. voxl-mapper/planner for a Seeker drone
25 Posts 2 Posters 5.7k Views 1 Watching
  • P Offline
    P Offline
    Pooyan
    wrote on last edited by Pooyan
    Hello all,
    I am doing the voxl-mapper/planner for a Seeker drone using the following repository:
    [https://gitlab.com/voxl-public/voxl-sdk/services/voxl-mapper/-/tree/master?ref_type=heads](link url)
    I am done with all of the steps provided there, but when I run the voxl-mapper I get the following error constantly:
    ERROR validating TOF2 data received through pipe: read partial packet
    read 693516 bytes, but it should be a multiple of 693516
    make sure you are using a recent voxl-camera-server that publishes a tof2_data_t type
    it's likely you are using an old voxl-camera-server
    I have done the following commands to update camera-server, and I got a massage about being updated to the final version:
    I would appreciate it if you could give me some hints.
    @tom, can you take a look please.
    • P Pooyan
      Hello all,
      tomT Online
      tomT Online
      @Pooyan What SDK are you using? You can see this with voxl-version
      P 1 Reply Last reply
        P Offline
        P Offline
        Pooyan
        @tom thank you for your reply.
        It is 0.9.5
        • P Pooyan
          It is 0.9.5
          tomT Online
          tomT Online
          @Pooyan Okay you can't mix and match packages like that. voxl-camera-server from dev can't be used with SDK 0.9.5.
          You need to use SDK 1.1.2 and use the packages as they come, not pull in others, it won't work
          P 2 Replies Last reply
            P Offline
            P Offline
            Pooyan
            @tom yes, thanks. But, is there any other version I could use to fit the Camera-Server on the SDK version that I have?
            • P Pooyan
              tomT Online
              tomT Online
              @Pooyan No, the only voxl-camera-server package compatible with that SDK would be the one installed with it.
              Why are you trying to change versions?
              P 3 Replies Last reply
                P Offline
                P Offline
                Pooyan
                @tom I don't want to change any versions, but as you said I need to update the SDK, I was wondering maybe I could solve the problem with no upgrading SDK, but using another version of Camera-server.
                The thing is that it used to work for sure when you were working on 0.9.5 version. That is why I was asking.
                  P Offline
                  P Offline
                  Pooyan
                  @tom is there any way to have voxl-mapper on the SDK 0.9.5?
                  I am trying to upgrade another Seeker, so in the mean time I was wondering if I could proceed with this one.
                    P Offline
                    P Offline
                    Pooyan
                    @tom I am just putting the versioning as well, in case there is anything you wanted to see:
                    • P Pooyan
                      tomT Online
                      tomT Online
                      @Pooyan We can really only offer support with the latest SDK, you can read through the SDK 0.9 docs here if you'd like to see our old docs: https://docs.modalai.com/voxl-sdk-0_9/
                      This is the voxl-mapper section based on SDK 0.9.5 https://docs.modalai.com/voxl-mapper-0_9/
                        P Offline
                        P Offline
                        Pooyan
                        @tom Thank you so much for the reply and information. I understand that for sure.
                          P Offline
                          P Offline
                          Pooyan
                          @tom Now I have upgrade SDK to 1.1.2, and did everything again through this link:
                          The thing is that the voxl-mapper is Enabled but not running and when I am trying the voxl-mapper command, I get the following error:
                          I would appreciate it if you could give me some hint on this.
                          Thank you so much.
                          • P Pooyan
                            Thank you so much.
                            P Offline
                            P Offline
                            Pooyan
                            @Pooyan there was an internet connection issue and after that I used "opkg update && opkg upgrade", and then "opkg install voxl-portal voxl-mapper " for installing mapper again and now this problem is solved.
                              P Offline
                              P Offline
                              Pooyan
                              #14
                              @tom Hello again,
                              The SDK was updated to 1.2.0 and it was because of putting the configure-opkg on dev as it was said in the GitLab voxl-mapper link. I went through every steps in the following link again. Do you have any idea about what I can do?
                              as you can see, when I run the "voxl-mapper", I get the following errors and it keeps repeating.
                              Thank you so much for your help.
                              • P Pooyan
                                @tom Hello again,
                                P Offline
                                P Offline
                                Pooyan
                                @tom Again I changed the version to 1.1.2 and got the same issue about loading shared libraries: libvoxblox.so. So I want to explain more what I do in case you could help me better.
                                I have included the screenshot as well.
                                When I push the built mapper to voxl I get the following error as well. I wanted to show that to you as well:
                                The codes I use to do that are as follow:
                                git clone https://gitlab.com/voxl-public/voxl-sdk/services/voxl-mapper.git
                                ./install_build_deps.sh APQ8096 dev
                                ./build.sh apq8096
                                ./make_package.sh ipk
                                ./deploy_to_voxl.sh
                                I would appreciate it if you could give me any hints on this.
                                • P Pooyan
                                  ./build.sh apq8096
                                  ./deploy_to_voxl.sh
                                  tomT Online
                                  tomT Online
                                  @Pooyan After a fresh flash using the release and ./install.sh if you adb on and run opkg install voxl-mapper and then run voxl-mapper what happens?
                                    P Offline
                                    P Offline
                                    Pooyan
                                    @tom I have just flashed it again and before anything else I did opkg install voxl-mapper and I got this:
                                    I did it when the seeker is connected to the internet and the adb cable is connected, and I got this:
                                    Still I didn't even install the FC2 through QGC or doing anything else.
                                    • P Pooyan
                                      tomT Online
                                      tomT Online
                                      @Pooyan Oh sorry, on voxl run opkg install /data/voxl-suite-offline-packages/voxl-mapper*.ipk
                                        P Offline
                                        P Offline
                                        Pooyan
                                        @tom thank you for the command. I get this now:
                                        • P Pooyan
                                          tomT Online
                                          tomT Online
                                          wrote on last edited by tom
                                          #20
                                          @Pooyan Okay you'll just have to install the dependencies in the same way. I just did this on my voxl1:
                                          cd /data/voxl-suite-offline-packages/
                                          opkg install voxl-ceres-solver_2\:1.14.0-10.ipk
                                          opkg install voxl-nlopt_2.5.0-4.ipk
                                          opkg install voxl-voxblox_1.1.5.ipk
                                          opkg install voxl-mapper_0.2.0.ipk
