  3. Issues about ssh RB5
rb5
19 Posts 4 Posters 2.8k Views 2 Watching
    @Qin-Yang You aren't using the correct IP when SSH'ing. You're trying to SSH using the WiFi network which you aren't connected to.
    What is the full output of ifconfig? That should show you the correct IP
    Qin YangQ Offline
    Qin YangQ Offline
    Qin Yang
    @tom Thank you for your reply.
    I list the full output of ifconfig, can you help me figure out which IP I need to use in the ssh? I tried 127.0.0.1, it also did not work.
    Thank you very much for your help and support.
      Qin YangQ Offline
      Qin YangQ Offline
      Qin Yang
      @tom My host PC system is ubuntu 22.04, is that an issue? since I looked at the instruction which suggest 18.04.
        Qin YangQ Offline
        Qin YangQ Offline
        Qin Yang
        @tom Sorry, I want to update something.
        I can ping 127.0.0.1, but I can not ssh it. please check the picture:
        Thanks.
        • Qin YangQ Qin Yang
          Thanks.
          @Qin-Yang Oh it looks like you're just doing wifi for all of this, no 5G involved.
          Qin YangQ 1 Reply Last reply
            Qin YangQ Offline
            Qin YangQ Offline
            Qin Yang
            @tom So, what should I do for the next?
            How to setup it?
            The network I used is TModile 5G in the Ipad and I turn on the hotspot to connect the rb5 and the host PC.
              How to setup it?
              @Qin-Yang Are both your macbook and rb5 connected to the hostpot?
              Did you use voxl-wifi station SSID PASS on the rb5?
                Qin YangQ Offline
                Qin YangQ Offline
                Qin Yang
                @tom Yes, the macbook and rb5 both connected to the hostpot. By the way, I installed the macbook with Ubuntu 22.04 not MAC OS.
                I did not use the voxl-wifi station SSID PASS on the rb5. I just follow the link text.
                Can you guide me how to do that?
                Thanks.
                  Thanks.
                  @Qin-Yang You'll want the RB5 to be connected to the same WiFi network that you connected your macbook to.
                  You can do this on RB5 by running voxl-wifi station SSID PASSWORD where SSID is the name of the WiFi network you'd like to connect to and PASSWORD is the password to that network
                    Qin YangQ Offline
                    Qin YangQ Offline
                    Qin Yang
                    @tom Thank you very much for your guiding. It works.
                    However, I got another issues about the camera. I follow the instruction How to Connect VOXL to QGroundControl over WiFi
                    , but my rb5 did not have any video showing in the QGC. And I run the voxl-inspect-services and found voxl-streamer did not run. Moreover, my rb5 software might be an old version since I can not find the command like: voxl-inspect-mavlink. Can you give me some suggestions?
                    please check the below picture:
                    ModeratorM 1 Reply Last reply
                      @Qin-Yang your software is too old for that feature. Please update to the latest, see the guide here: https://docs.modalai.com/Qualcomm-Flight-RB5-voxl-sdk-upgrade-guide/
                      • ModeratorM Moderator
                        Qin YangQ Offline
                        Qin YangQ Offline
                        Qin Yang
                        @Moderator Thank you very much for your suggestions. Currently, I install the latest version 1.1.2. And everything looks back in normal.
                        However, in the process of installation, I met some errors and I did not know whether it is a big issue.
                        Also, I found my original file miss some file : "opencv_stereo_intrinsics.yml" and "opencv_stereo_extrinsics.yml", can you send them to me.
                        Please check the pictures for more details:
                          @Qin-Yang What is the serial number of your RB5 drone? There should be a sticker on the drone with a serial number in the form MXX00000XXX
                            Qin YangQ Offline
                            Qin YangQ Offline
                            Qin Yang
                            @tom The serial number is M22000006H2, please check the picture for more details. By the way, this rb5 bought in Sep. 29, 2023.
                            Alex KushleyevA tomT 2 Replies Last reply
                              @Qin-Yang , I saw you also had some issues with ESC params not being updated correctly. Sorry about that, this sometimes happens when transitioning form older ESC firmware (which automatically happened during the SDK update)
                              You should be able to bring the ESC to the latest firmware / params using the following procedure : https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-esc/-/blob/dev/voxl-esc-tools/recovery.md
                              Thank you
                                @Qin-Yang I will send your cal files to the email associated to your forum account
                                  Qin YangQ Offline
                                  Qin YangQ Offline
                                  Qin Yang
                                  @tom Thank you very much, I got it.
                                    Thank you
                                    Qin YangQ Offline
                                    Qin YangQ Offline
                                    Qin Yang
                                    @Alex-Kushleyev Thank you very much for the solution, I fix it and it works. : )
