    Not going in Position mode
    4178
    • G
      gauravshukla914
      We are working on indoor navigation.
      Currently we are facing some strange issues. When we run "voxl-vision-px4 -o", we are able to see the odometry properly on our terminal.
      But in QgroundControl, when we are connected via usb cable, we only see "z" value in odometry and (x&y are zero). Also, the local position ned x and y are zero as well.
      Now when we connect over IP address of VOXL board to QgroundControl, we are able to see the complete odometry readings (i.e values of x,y&z). However, the local position ned x and y are still zero.
      Ultimately, we are trying to put the drone on the position flight mode, but its continously rejecting the position mode. We have made sure that our PX4 params are correct.
      Here's the voxl-vision-px4.conf file that we have set. And this exact configuration has worked for us in the past.
      "qgc_ip": "NULL",
      "en_localhost_mavlink_udp": true,
      "en_secondary_qgc": false,
      "secondary_qgc_ip": "NULL",
      "offboard_mode": "off",
      "en_vio": true,
      "en_voa": false,
      "en_send_vio_to_qgc": true,
      "en_send_voa_to_qgc": false,
      "en_adsb": false,
      "adsb_uart_bus": 7,
      "adsb_uart_baudrate": 57600,
      "px4_uart_bus": 5,
      "px4_uart_baudrate": 921600,
      "R_imu_to_body": [[0, 1, 0], [1, 0, 0], [0, 0, -1]],
      "T_imu_wrt_body": [0.068, -0.015, -0.008],
      "height_body_above_ground_m": 0.05,
      "T_stereo_wrt_body": [0.10, -0.04, 0.0],
      "land_on_tag_id": 0,
      "follow_tag_id": 0,
      "en_apriltag_fixed_frame": false,
      "fixed_apriltags": [{
      "tag_id": 0,
      "R_tag_to_fixed": [[0, -1, 0], [1, 0, 0], [0, 0, 1]],
      "T_tag_wrt_fixed": [0, 0, 0]
      "en_transform_mavlink_pos_setpoints_from_fixed_frame": true,
      "en_fixed_frame_pipe": false,
      "fixed_frame_filter_len": 5
      • G
        gauravshukla914
        With respect to the above post, I would also like to add this issue as well. I have attached a screenshot for the same.qgc_issue.png
        @Chad-Sweet @modaltb @ModalAI-Updates
        • Jeremy SchmidtJ
          Jeremy Schmidt ModalAI Team
          Good morning,
          Would you be able to attach a px4 parameter file for us to look at? Thanks.
          • G
            gauravshukla914
            @Jeremy-Schmidt Thanks for your reply. I was not able to upload the params here directly, so I have uploaded on a drive and shared a link. Let me know if you're not able to access it.
            https://infovisioninc-my.sharepoint.com/:u:/g/personal/gaurav_shukla_infovision_net/Eej6U97SlelArXddbazY31sBJcEZ8xu3EHdWfFwhigDNoA?e=CcAa5G
            • Jeremy SchmidtJ
              Yes thank you, I did get the file. I will go over it shortly and get back to you.
              • Jeremy SchmidtJ
                @gauravshukla914 I see you have sys_has_mag =0. Which px4 firmware version are you running?
                • G
                  gauravshukla914
                  The firmware we are using that 1.11.3.
                  Since we are trying to work on indoor navigation and not rely on gps, so we use two of your helper scripts. One is "sensors_disable_gps_mag.param" and other is "ekf2_indoor_vio.params"
                  • modaltbM
                    modaltb ModalAI Team
                    That FW version looks good to go, but the screen shot above looks like it's not showing all the typical data.
                    What about the MAVLink serial setup? https://gitlab.com/voxl-public/flight-core-px4/px4-parameters/-/blob/master/helpers/mavlink_serial_ports.params#L18
                    This would affect the communications between FlightCore (PX4) and VOXL and then ultimately what comes over WiFI to QGC
                    • G
                      gauravshukla914
                      @modaltb no data is missing. I had just cropped the image to show you the just the important part. Here's the full image.
                      • modaltbM
                        Sorry, I meant the Serial/MAVLink setup, which may affect this:
                        Then in MAVLink inspector, you see more data:
                        • modaltbM
                          Actually, you want to select LOCAL_POSITION_NED to see the VIO data, I didn't have this until I loaded the https://gitlab.com/voxl-public/flight-core-px4/px4-parameters/-/blob/master/helpers/ekf2_indoor_vio.params
                          • G
                            gauravshukla914
                            @modaltb We have already loaded the ekf2_indoor_vio.params.
                            Also I'm getting all these data that you just shared. I'm getting the local position ned, but the x and y are zero. Again the point to be noted here is that (also mentioned in the original post), tha I'm connected via USB cable to qgc. When I'm just over the wifi, I get the right odometry but the x and y of local position ned is still 0 one.png two.png three.png
                            • modaltbM
                              @gauravshukla914 said in Not going in Position mode:
                              "qgc_ip": "NULL",
                              Looking at your config file in first post above, I'm not sure how you are getting a connection over WiFi without the IP address configured?
                              If you run voxl-version, can you paste the output here?
                              And also, can you run voxl-vision-px4 manually from command line and paste output here?
                              Thanks, sorry for missing the first data points.
                              • G
                                gauravshukla914
                                ~ # voxl-vision-px4
                                loading config file
                                qgc_ip:                     NULL
                                en_localhost_mavlink_udp    1
                                en_secondary_qgc:           0
                                en_vio:                     1
                                en_voa:                     0
                                en_send_vio_to_qgc:         1
                                en_send_voa_to_qgc:         0
                                en_adsb:                    0
                                adsb_uart_bus:              7
                                adsb_uart_baudrate:         57600
                                px4_uart_bus:               5
                                px4_uart_baudrate:          921600
                                R_imu_to_body:
                                 0.0000   1.0000   0.0000
                                 1.0000   0.0000   0.0000
                                 0.0000   0.0000  -1.0000
                                T_imu_wrt_body:
                                 0.0680  -0.0150  -0.0080
                                height_body_above_ground_m:  0.200
                                land_on_tag_id:             0
                                follow_tag_id:              0
                                en_apriltag_fixed_frame:    0
                                en_transform_mavlink_pos_setpoints_from_fixed_frame:1
                                n_fixed_apriltags:          1
                                Fixed apriltag #0:
                                    tag id: 0
                                    R_tag_to_fixed:
                                 0.0000  -1.0000   0.0000
                                 0.0000   0.0000   1.0000
                                    T_tag_wrt_fixed:
                                 0.0000   0.0000   0.0000
                                T_stereo_wrt_body:
                                 0.1000  -0.0400   0.0000
                                en_fixed_frame_pipe:        0
                                fixed_frame_filter_len:     5
                                WARNING, exising instance of voxl-vision-px4 found, attempting to stop it
                                starting geometry module
                                starting uart mavlink
                                starting udp mavlink
                                Adding manual QGC IP address to udp connection list: NULL
                                WARNING: invalid qgc_ip, this is fine if you don't want to use it
                                starting px4 shell
                                Detected PX4 Mavlink SYSID 1
                                [293.934196] SNAV INFO: Loading Tracking camera parameters
                                [293.935673] SNAV INFO: Successfully opened file /etc/modalai/vio_apriltag_app.xml [12]
                                [293.937330] SNAV INFO: Read: 4273 characters
                                [293.938443] SNAV INFO: XML parser successfully parsed document.
                                [293.938784] SNAV INFO: Returning pointer to SnavAppParams XML element
                                [293.939035] SNAV INFO: Begin parsing SnavVisionParams...
                                [293.939349] SNAV INFO: Successfully opened file /etc/snav/camera.downward.xml [12]
                                [293.940807] SNAV INFO: Read: 3037 characters
                                [293.941461] SNAV INFO: XML parser successfully parsed document.
                                [293.941740] SNAV INFO: Returning pointer to first child element: SnavCamera
                                [293.941997] SNAV INFO: Parse camera IncludeFile...
                                [293.942216] SNAV INFO: Found "SnavCameraDownward" attribute in xml file.
                                [293.942744] SNAV INFO: Setting override_cam_id to 1
                                [293.943070] SNAV INFO: Setting pixel_width to 640
                                [293.943314] SNAV INFO: Setting pixel_height to 480
                                [293.943849] SNAV INFO: Setting memory_stride to 640
                                [293.943978] SNAV INFO: Setting image_format to raw10
                                [293.944094] SNAV INFO: Setting fps to 30
                                [293.944227] SNAV INFO: Setting default_exposure to 0.125
                                [293.944341] SNAV INFO: Setting default_gain to 0.5
                                [293.944464] SNAV INFO: Setting frame_queue_size to 5
                                [293.944572] SNAV INFO: Setting enable_cpa to 1
                                [293.944693] SNAV INFO: Setting mv_cpa_type to 1
                                [293.944850] SNAV INFO: Setting mv_cpa_filter_size to 2
                                [293.944985] SNAV INFO: Setting mv_cpa_exposure_cost to 0.75
                                [293.945123] SNAV INFO: Setting mv_cpa_gain_cost to 0.25
                                [293.945259] SNAV INFO: Setting mv_cpa_hist_exposure_min to 0.001
                                [293.945388] SNAV INFO: Setting mv_cpa_hist_exposure_soft_max to 0.2
                                [293.945518] SNAV INFO: Setting mv_cpa_hist_exposure_max to 0.2
                                [293.945650] SNAV INFO: Setting mv_cpa_hist_gain_min to 0.001
                                [293.945780] SNAV INFO: Setting mv_cpa_hist_gain_soft_max to 0.3
                                [293.945916] SNAV INFO: Setting mv_cpa_hist_gain_max to 1.0
                                [293.946048] SNAV INFO: Setting mv_cpa_hist_log_egp_step_size_min to 0.001
                                [293.946184] SNAV INFO: Setting mv_cpa_hist_log_egp_step_size_max to 1.0
                                [293.947018] SNAV INFO: Successfully opened file /etc/snav/mount.snav_dft_vio_app.xml [12]
                                [293.947326] SNAV INFO: Read: 1491 characters
                                [293.947555] SNAV INFO: XML parser successfully parsed document.
                                [293.947675] SNAV INFO: Returning pointer to first child element: SnavMount
                                [293.947776] SNAV INFO: Parse mount IncludeFile...
                                [293.947889] SNAV INFO: Found "SnavMountDownward" attribute in xml file.
                                [293.948031] SNAV INFO: Setting mv_vislam_tbc_1 to 0.019768f
                                [293.948161] SNAV INFO: Setting mv_vislam_tbc_2 to 0.016882f
                                [293.948292] SNAV INFO: Setting mv_vislam_tbc_3 to -0.012101f
                                [293.948422] SNAV INFO: Setting mv_vislam_ombc_1 to -2.313745f
                                [293.948553] SNAV INFO: Setting mv_vislam_ombc_2 to -0.000521f
                                [293.948680] SNAV INFO: Setting mv_vislam_ombc_3 to -0.053149f
                                [293.948816] SNAV INFO: Setting mv_vislam_std0_tbc_1 to 0.005
                                [293.948945] SNAV INFO: Setting mv_vislam_std0_tbc_2 to 0.005
                                [293.949061] SNAV INFO: Setting mv_vislam_std0_tbc_3 to 0.005
                                [293.949186] SNAV INFO: Setting mv_vislam_std0_ombc_1 to 0.04
                                [293.949323] SNAV INFO: Setting mv_vislam_std0_ombc_2 to 0.04
                                [293.949450] SNAV INFO: Setting mv_vislam_std0_ombc_3 to 0.04
                                [293.949631] SNAV INFO: Successfully opened file /etc/snav/calibration.downward.xml [12]
                                [293.949896] SNAV INFO: Read: 2491 characters
                                [293.950272] SNAV INFO: XML parser successfully parsed document.
                                [293.950393] SNAV INFO: Returning pointer to first child element: SnavCalibration
                                [293.950495] SNAV INFO: Parse calibration IncludeFile...
                                [293.950617] SNAV INFO: Found "SnavCalibrationDownward" attribute in xml file.
                                [293.950748] SNAV INFO: Setting calib_pixel_width to 640
                                [293.950872] SNAV INFO: Setting calib_pixel_height to 480
                                [293.950992] SNAV INFO: Setting calib_memory_stride to 640
                                [293.951121] SNAV INFO: Setting principal_point_x to 304.78164
                                [293.951250] SNAV INFO: Setting principal_point_y to 226.549706
                                [293.951385] SNAV INFO: Setting focal_length_x to 277.688987
                                [293.951515] SNAV INFO: Setting focal_length_y to 277.418541
                                [293.951632] SNAV INFO: Setting distortion_0 to -0.012669
                                [293.951758] SNAV INFO: Setting distortion_1 to 0.013676
                                [293.951894] SNAV INFO: Setting distortion_2 to -0.011134
                                [293.952024] SNAV INFO: Setting distortion_3 to 0.003616
                                [293.952186] SNAV INFO: Setting distortion_4 to 0
                                [293.952313] SNAV INFO: Setting distortion_5 to 0
                                [293.952422] SNAV INFO: Setting distortion_6 to 0
                                [293.952547] SNAV INFO: Setting distortion_7 to 0
                                [293.952660] SNAV INFO: Setting distortion_model to 10
                                [293.952796] SNAV INFO: Attempting to update calibration to match resolution: downward camera...
                                [293.952916] SNAV INFO: Calibration scaled by 1.000000 to match resolution.
                                [293.953028] SNAV INFO: Attempting to update calibration to match resolution: hires camera...
                                [293.953143] SNAV INFO: Calibration scaled by inf to match resolution.
                                [293.953240] SNAV INFO: Attempting to update calibration to match resolution: right stereo camera...
                                [293.953353] SNAV INFO: Calibration scaled by inf to match resolution.
                                [293.953449] SNAV INFO: Attempting to update calibration to match resolution: stereo camera (1/2)...
                                [293.953563] SNAV INFO: Calibration scaled by inf to match resolution.
                                [293.953659] SNAV INFO: Attempting to update calibration to match resolution: stereo camera (2/2)...
                                [293.953769] SNAV INFO: Calibration scaled by inf to match resolution.
                                [293.953865] SNAV INFO: Parse individual parameters...
                                [293.953997] SNAV INFO: Setting tag_size to 0.267
                                [293.954123] SNAV INFO: Setting enable_apriltag to 1
                                [293.954247] SNAV INFO: Setting enable_undistortion to 1
                                [293.954354] SNAV INFO: Setting num_detection_threads to 4
                                [293.954480] SNAV INFO: Setting quad_decimate to 1.0
                                [293.954614] SNAV INFO: Setting quad_sigma to 0.0
                                [293.954734] SNAV INFO: Setting refine_edges to 1
                                [293.954837] SNAV INFO: Setting refine_decode to 1
                                [293.954955] SNAV INFO: Setting refine_pose to 1
                                [293.955061] SNAV INFO: Setting debug to 0
                                [293.955181] SNAV INFO: Setting enable_vio to 1
                                [293.955284] SNAV INFO: Setting enable_vio_gps to 0
                                [293.955402] SNAV INFO: Setting enable_dft to 0
                                [293.955510] SNAV INFO: Setting enable_dft_idle to 1
                                [293.955632] SNAV INFO: Setting enable_srw_writer to 0
                                [293.955742] SNAV INFO: Setting verbose to 0
                                [293.955867] SNAV INFO: Setting mv_version_strict_checking to 0
                                [293.956001] SNAV INFO: Setting sensor_imu_api_version_strict_checking to 1
                                [293.956121] SNAV INFO: Setting log_level to LOG_NOTICE
                                [293.956225] SNAV INFO: Setting imu_raw_sample_rate to 500
                                [293.956344] SNAV INFO: Setting imu_vio_sample_rate to 500
                                [293.956450] SNAV INFO: Setting gps_device_num to 0
                                [293.956573] SNAV INFO: Setting mv_vislam_readout_time to 0
                                [293.956694] SNAV INFO: Setting mv_vislam_delta to -0.008
                                [293.956821] SNAV INFO: Setting mv_vislam_std0_delta to 0.001
                                [293.956954] SNAV INFO: Setting mv_vislam_accel_meas_range to 156
                                [293.957079] SNAV INFO: Setting mv_vislam_gyro_meas_range to 34
                                [293.957194] SNAV INFO: Setting mv_vislam_std_accel_meas_noise to 0.316227766016838
                                [293.957349] SNAV INFO: Setting mv_vislam_std_gyro_meas_noise to 1e-2
                                [293.957476] SNAV INFO: Setting mv_vislam_std_cam_noise to 100
                                [293.957613] SNAV INFO: Setting mv_vislam_min_std_pixel_noise to 0.5
                                [293.957740] SNAV INFO: Setting mv_vislam_fail_high_pixel_noise_points to 0
                                [293.957850] SNAV INFO: Setting mv_vislam_log_depth_bootstrap to 0
                                [293.957972] SNAV INFO: Setting mv_vislam_use_log_camera_height to 1
                                [293.958081] SNAV INFO: Setting mv_vislam_log_camera_height_bootstrap to −1.66
                                [293.958205] SNAV INFO: Setting mv_vislam_no_init_when_moving to 1
                                [293.958343] SNAV INFO: Setting mv_vislam_limited_imu_bw_trigger to 35
                                [293.958473] SNAV INFO: Setting mv_vislam_gps_imu_time_alignment to 0.100
                                [293.958603] SNAV INFO: Setting mv_vislam_tba_1 to 0
                                [293.958726] SNAV INFO: Setting mv_vislam_tba_2 to 0
                                [293.958837] SNAV INFO: Setting mv_vislam_tba_3 to 0
                                [293.958942] SNAV INFO: Setting mapping to 1
                                [293.959045] SNAV INFO: Setting mv_dft_max_nr to 150
                                [293.959148] SNAV INFO: Setting mv_dft_min_nr to 30
                                [293.959243] SNAV INFO: Finished parsing SnavVisionParams.
                                [293.959388] SNAV INFO: Starting tracking camera manager
                                [293.959561] SNAV INFO: using tracking cam id 1
                                libcam.enable.publish  1
                                libcam.enable.publish.dump 0
                                libcam.publish.buffer.policy max
                                libcam.publish.buffer.max 3
                                libcam.debug.level info
                                libcam.dump.dir /data/misc/camera/dumps
                                [294.417122] SNAV INFO: Opened camera 1
                                [294.418634] SNAV INFO: Set preview size: 640x480
                                [294.419452] SNAV INFO: Using RAW format
                                FASTCV: fcvAvailableHardware Linux
                                MachineVision is licensed as community user
                                LNX_8074 supported? 1
                                LNX_8096 supported? 1
                                LNX_IA64 supported? 1
                                WINDOWS supported? 0
                                [294.449171] SNAV INFO: CameraManager is finished initializing.
                                [294.449468] SNAV INFO: Starting camera image streaming...
                                AR ERROR: arFileOpen(): Failed to open file: /home/root/vislam/Configuration.SF.xml
                                PX4 Connected over UART with sysid 1
                                mempool cur block size 307200, new block size 307200
                                AR ERROR: arFileOpen(): Failed to open file: /home/root/na
                                [sensor_imu_api_impl.cpp, 126] Creating handle for imu_id: 0 function: 2 description: [SECONDARY-mpu9x50@/dev/spi-1-@500Hz-STANDALONE-00]
                                [SensorImuUtil.cpp, 107] ComputeOffset iteration 0 apps time 1622058299964619355  - dsp time 296415509583 = 1622058003549109772
                                [SensorImuUtil.cpp, 108] ComputeOffset The apps - dsp offset = [1622058003549109772]ns, Apps ClockType[CLOCK_REALTIME]
                                [SensorImuUtil.cpp, 107] ComputeOffset iteration 1 apps time 1622058299964853991  - dsp time 296415755625 = 1622058003549098366
                                [SensorImuUtil.cpp, 108] ComputeOffset The apps - dsp offset = [1622058003549098366]ns, Apps ClockType[CLOCK_REALTIME]
                                [SensorImuUtil.cpp, 107] ComputeOffset iteration 2 apps time 1622058299965010971  - dsp time 296415913229 = 1622058003549097742
                                [SensorImuUtil.cpp, 108] ComputeOffset The apps - dsp offset = [1622058003549097742]ns, Apps ClockType[CLOCK_REALTIME]
                                [SensorImuUtil.cpp, 107] ComputeOffset iteration 3 apps time 1622058299965426702  - dsp time 296416328229 = 1622058003549098473
                                [SensorImuUtil.cpp, 107] ComputeOffset iteration 4 apps time 1622058299965746287  - dsp time 296416648489 = 1622058003549097798
                                [SensorImuUtil.cpp, 107] ComputeOffset iteration 5 apps time 1622058299965929048  - dsp time 296416831145 = 1622058003549097903
                                [SensorImuUtil.cpp, 107] ComputeOffset iteration 6 apps time 1622058299966075559  - dsp time 296416977812 = 1622058003549097747
                                [SensorImuUtil.cpp, 107] ComputeOffset iteration 7 apps time 1622058299966282643  - dsp time 296417185156 = 1622058003549097487
                                [SensorImuUtil.cpp, 108] ComputeOffset The apps - dsp offset = [1622058003549097487]ns, Apps ClockType[CLOCK_REALTIME]
                                [SensorImuUtil.cpp, 107] ComputeOffset iteration 8 apps time 1622058299966439779  - dsp time 296417341770 = 1622058003549098009
                                [SensorImuUtil.cpp, 107] ComputeOffset iteration 9 apps time 1622058299966613582  - dsp time 296417515729 = 1622058003549097853
                                [294.523253] SNAV INFO: Initializing IMU sensor...
                                [SensorIMU_v2.cpp, 84] Initialize Now calling rpcmem_init...
                                [SensorIMU_v2.cpp, 358] AllocateRpcBuffers Allocating buffers using rpcmem_alloc...
                                [SensorIMU_v2.cpp, 368] AllocateRpcBuffers rpcmem_alloc passed for SensorIMU buffer size(24000) bytes addr(0x4dc888)
                                [SensorIMU_v2.cpp, 381] AllocateRpcBuffers rpcmem_alloc passed for SensorIMU buffer(bias compensated) size(24000) bytes addr(0x4e2650)
                                [SensorIMU_v2.cpp, 396] AllocateRpcBuffers rpcmem_alloc passed for SensorIMU buffer(attitude rotation matrix) size(40000) bytes addr(0x4e8418)
                                [SensorIMU_v2.cpp, 108] Imu Initialization Successful.  rpcClientHandle: 2
                                [SensorImuUtil.cpp, 107] ComputeOffset iteration 0 apps time 294524215313  - dsp time 296418601197 = -1894385884
                                [SensorImuUtil.cpp, 108] ComputeOffset The apps - dsp offset = [-1894385884]ns, Apps ClockType[CLOCK_MONOTONIC]
                                [SensorImuUtil.cpp, 107] ComputeOffset iteration 1 apps time 294524571825  - dsp time 296418959062 = -1894387237
                                [SensorImuUtil.cpp, 108] ComputeOffset The apps - dsp offset = [-1894387237]ns, Apps ClockType[CLOCK_MONOTONIC]
                                [SensorImuUtil.cpp, 107] ComputeOffset iteration 2 apps time 294525223703  - dsp time 296419611822 = -1894388119
                                [SensorImuUtil.cpp, 108] ComputeOffset The apps - dsp offset = [-1894388119]ns, Apps ClockType[CLOCK_MONOTONIC]
                                [SensorImuUtil.cpp, 107] ComputeOffset iteration 3 apps time 294525361985  - dsp time 296419750208 = -1894388223
                                [SensorImuUtil.cpp, 108] ComputeOffset The apps - dsp offset = [-1894388223]ns, Apps ClockType[CLOCK_MONOTONIC]
                                [SensorImuUtil.cpp, 107] ComputeOffset iteration 4 apps time 294525591100  - dsp time 296419979687 = -1894388587
                                [SensorImuUtil.cpp, 108] ComputeOffset The apps - dsp offset = [-1894388587]ns, Apps ClockType[CLOCK_MONOTONIC]
                                [SensorImuUtil.cpp, 107] ComputeOffset iteration 5 apps time 294525700476  - dsp time 296420089687 = -1894389211
                                [SensorImuUtil.cpp, 108] ComputeOffset The apps - dsp offset = [-1894389211]ns, Apps ClockType[CLOCK_MONOTONIC]
                                [SensorImuUtil.cpp, 107] ComputeOffset iteration 6 apps time 294525794434  - dsp time 296420183645 = -1894389211
                                [SensorImuUtil.cpp, 107] ComputeOffset iteration 7 apps time 294525891310  - dsp time 296420280104 = -1894388794
                                [SensorImuUtil.cpp, 107] ComputeOffset iteration 8 apps time 294526120686  - dsp time 296420509270 = -1894388584
                                [SensorImuUtil.cpp, 107] ComputeOffset iteration 9 apps time 294526217717  - dsp time 296420606875 = -1894389158
                                [294.526534] SNAV INFO: IMU sensor finished initializing.
                                [294.527209] SNAV INFO: IMU sensor settings retrieved.
                                [294.527282] SNAV INFO: Creating IMU thread.
                                [294.527409] SNAV INFO: Creating VISLAM processing thread.
                                [294.527505] SNAV INFO: Creating VISLAM publishing thread.
                                [294.527786] SNAV INFO: ImuManager thread has tid = 3290, nice = -15
                                [294.527940] SNAV INFO: VISLAM processing thread has tid = 3291, nice = -5
                                [294.528103] SNAV INFO: VISLAM publishing thread has tid = 3292, nice = -5
                                  tom admin
                                  @gauravshukla914 Are you attempting to use VOA or just VIO?
                                  • G
                                    gauravshukla914
                                    @tom I'm just attemting to use VIO.
                                      tom admin
                                      @gauravshukla914 Okay, in that case we will want to get you updated to System Image 3.2.0 / voxl-suite 0.3.4.
                                      Before we do that though, I want to make sure you are able to backup your camera calibration files so that you won't need to re-calibrate.
                                      In order to do this you can use the voxl-backup utility which should currently be installed on your VOXL as it is included in the voxl-utils package.
                                      First you will use voxl-backup -b BACKUP_PATH in order to save your camera calibration files to the specified path. Then, I would recommend pulling these files off of your voxl using adb pull BACKUP_PATH HOST_PC_DIR so that you have them saved for the future.
                                      You can then go ahead and flash System Image 3.2.0, located here.
                                      After you finish flashing you can adb push your camera cal files back onto your VOXL and use voxl-backup -r BACKUP_ROOT in order to restore them to their correct locations.
                                      • G
                                        gauravshukla914
                                        @tom I did that. I flashed with the image that you asked me to. Unfortunately the problem is still there. I'm able to see the odometry on my terminal once I do the "voxl-version-px4 -o". But no luck with the QgroundControl. Basically the same problem!
                                        adb shell
                                        / # voxl-version
                                        cat: /etc/modalai/voxl-software-bundle-version.txt: No such file or directory
                                        system-image:    ModalAI 3.2.0 BUILDER: ekatzfey BUILD_TIME: 2021-02-05_19:54
                                        kernel:          #1 SMP PREEMPT Fri Feb 5 20:03:22 UTC 2021 3.18.71-perf
                                        factory-bundle:  1.0.1 (Yocto installation)
                                        architecture:    aarch64
                                        processor:       apq8096
                                        os:              GNU/Linux
                                        voxl-suite:
                                        Package: voxl-suite
                                        Version: 0.3.4
                                        Depends: voxl-utils (>= 0.6.0), libmodal_json (>= 0.3.4), libmodal_pipe (>= 1.7.8), librc_math (>= 1.1.4), libvoxl_io (>= 0.5.4), mavlink-camera-manager (>= 0.0.1), opencv (>= 4.5.1), openmp (>= 10.0.1), voxl-camera-server (>= 0.5.6), voxl-dfs-server (>= 0.0.7), voxl-docker-support (>= 1.1.1), voxl-gphoto2 (>= 0.0.5), voxl-hal3-tof-cam-ros (>= 0.0.5), voxl-imu-server (>= 0.7.8), voxl-modem (>= 0.11.0), voxl-mpa-tflite-server (>= 0.0.2), voxl-mpa-tools (>= 0.1.6), voxl-nodes (>= 0.1.3), voxl-qvio-server (>= 0.2.1), voxl-rtsp (>= 1.0.3), voxl-streamer (>= 0.2.1), voxl-vision-px4 (>= 0.8.1), voxl-vpn (>= 0.0.3)
                                        Section: base
                                        Architecture: all
                                        Maintainer: james@modalai.com
                                        MD5Sum: e1e5bf1a125affe5036099f6ce895bed
                                        Filename: voxl-suite_0.3.4.ipk
                                        Description: meta-package for voxl-suite stable release
                                        Installed-Time: 1622142966
                                        Package: voxl-suite
                                        Version: 0.2.0
                                        Depends: docker, imu_app (= 0.0.6), libvoxl_io (= 0.5.2), voxl-cam-manager (= 0.2.2), voxl-docker-support (= 1.1.1), voxl-hal3-tof-cam-ros (= 0.0.2), voxl-modem (= 0.10.0), voxl-nodes (= 0.0.8), voxl-rtsp (= 1.0.2), voxl-utils (= 0.5.2), voxl-vision-px4 (= 0.6.8), voxl_imu (= 0.0.4), voxl-time-sync (= 0.0.1), voxl-vpn (= 0.0.2), librc_math (= 1.1.2), libmodal_pipe (= 1.2.2), modalai-vl (= 0.1.3)
                                        Section: base
                                        Architecture: armv7a
                                        MD5Sum: af706cd3c1ea59f274f2ed9b93141f1d
                                        Filename: voxl-suite_0.2.0.ipk
                                        Description: meta-package to install all of the voxl-suite
                                          tom admin
                                          @gauravshukla914 Can you post your voxl-vision-px4 conf file?
                                          cat /etc/modalai/voxl-vision-px4.conf
                                          • G
                                            gauravshukla914
                                            @tom said in Not going in Position mode:
                                            	"qgc_ip":	"192.168.100.174",
                                            	"secondary_qgc_ip":	"192.168.1.214",
                                            	"qgc_udp_port_number":	14550,
                                            	"en_vio":	true,
                                            	"en_voa":	false,
                                            	"en_adsb":	true,
                                            	"adsb_uart_bus":	7,
                                            	"px4_uart_bus":	5,
                                            	"follow_tag_id":	0,
                                            	"fixed_frame_filter_len":	5,
