    Flight Deck with Microhard Radio not connecting to QGC
    Microhard Modems
    2169
    • Daniel RyuD
      Daniel Ryu
      Following this guide here, I was able to connect one microhard radio from my PC to one wired to the flight deck. With VOXL shell, I was able to ping the PC's ip address. As per the guide, I updated the qgc_ip field in voxl-vision-px4.conf to my PC's ip address and reset the px4 service. However, QGC is still unable to find the drone. Any tips on what I am missing to have QGC find the drone?
      As a further note, when the Flight Deck is connected by wire to the PC (USB to QGC), my PC locates and connects to the drone.
      volx-vision-px4.conf
      Pinging computer IP:
      PC Microhard radio IP: 192.168.168.1
      VOXL Microhard radio IP: 192.168.168.2
        tom admin
        Hi @Daniel-Ryu ,
        One thing I would recommend doing is setting up the voxl-vision-px4 service using voxl-configure-vision-px4. It's possible that voxl-vision-px4 is in a weird state and this can help reset it and flush out any issues.
        Another thing to check is to turn off all other networks on your PC side of things, i.e. WiFi and any other ethernet connections you may have connected. They can sometimes interfere with things depending on their settings.
        Let me know if this solution helps.
        Daniel RyuD 1 Reply Last reply Reply Quote 0
        • Daniel RyuD
          Daniel Ryu @tom
          @tom ran voxl-configure-vision-px4 as per the instructions here and disabled all other networks. No change in situation. Since I can ping from the Flight Deck (using adb shell) to my laptop running QGC, I'm wondering whether the QGC connection service on the Flight Deck can even find the Microhard radio its connected to. Does this sound plausible? Let me know if there are any pictures/screenshots I can upload that would help diagnose this issue.
          • Chad SweetC
            Chad Sweet ModalAI Team
            This is pretty broadly used, so maybe some configuration has gotten wonky. Can you please share which version of software you are using? https://docs.modalai.com/voxl-utils/#voxl-version
            • Daniel RyuD
              Daniel Ryu
              • Daniel RyuD
                Daniel Ryu
                If it helps, when connected to the flight deck via wifi following the quickstart on m500, my laptop QGC can connect to the flight deck
                  tom admin
                  Hi @Daniel-Ryu,
                  Can you post the output from ifconfig on both your PC and VOXL when everything is powered on.
                    tom admin
                    And could I also see the status of voxl-vision-px4 using systemctl status -l voxl-vision-px4
                    • Daniel RyuD
                      Daniel Ryu
                      Screenshot from 2020-12-28 18-29-17.png Screenshot from 2020-12-28 18-29-45.png Screenshot from 2020-12-28 18-30-47.png
                      • Daniel RyuD
                        Daniel Ryu @tom
                        @tom forgot to tag your name
                          tom admin
                          Hi @Daniel-Ryu ,
                          From the screenshots you provided it looks as though your ground control station has the IP address of 192.168.168.108 while in voxl-vision-px4.conf you have it set to 192.168.168.109. It is possible that the IP address of your ground control station changed after a reboot and voxl-vision-px4 is still looking for the old IP.
                          To prevent this problem in the future you should be able to set a static IP for your wired connection on your Ubuntu ground station.
                          • Daniel RyuD
                            Daniel Ryu
                            @tom That was the problem! Thank you
                            tomT 1 Reply Last reply Reply Quote 1
                              tom admin @Daniel Ryu
                              @Daniel-Ryu Great to hear! I appreciate your patience with this.
