  2. VOXL Accessories
  3. Microhard Modems
  4. Flight Deck with Microhard Radio not connecting to QGC
Scheduled Pinned Locked Moved Microhard Modems
13 Posts 3 Posters 2.8k Views 2 Watching
    This is pretty broadly used, so maybe some configuration has gotten wonky. Can you please share which version of software you are using? https://docs.modalai.com/voxl-utils/#voxl-version
    • Daniel RyuD Offline
      Daniel RyuD Offline
      Daniel Ryu
        Daniel RyuD Offline
        Daniel Ryu
        If it helps, when connected to the flight deck via wifi following the quickstart on m500, my laptop QGC can connect to the flight deck
          Hi @Daniel-Ryu,
          Can you post the output from ifconfig on both your PC and VOXL when everything is powered on.
            And could I also see the status of voxl-vision-px4 using systemctl status -l voxl-vision-px4
            Daniel RyuD 1 Reply Last reply
              Daniel RyuD Offline
              Daniel Ryu
              Screenshot from 2020-12-28 18-29-17.png Screenshot from 2020-12-28 18-29-45.png Screenshot from 2020-12-28 18-30-47.png
                Daniel RyuD Offline
                Daniel RyuD Offline
                Daniel Ryu
                @tom forgot to tag your name
                  Hi @Daniel-Ryu ,
                  From the screenshots you provided it looks as though your ground control station has the IP address of 192.168.168.108 while in voxl-vision-px4.conf you have it set to 192.168.168.109. It is possible that the IP address of your ground control station changed after a reboot and voxl-vision-px4 is still looking for the old IP.
                  To prevent this problem in the future you should be able to set a static IP for your wired connection on your Ubuntu ground station.
                    Daniel RyuD Offline
                    Daniel Ryu
                    @tom That was the problem! Thank you
                    • Daniel RyuD Daniel Ryu
                      @Daniel-Ryu Great to hear! I appreciate your patience with this.
