  3. QGC sensors - compass remains red
19 Posts 4 Posters 3.0k Views 2 Watching
  • S suvasis
    hi Eric,
    I connected using wifi. /usr/bin/voxl-px4 is the command I am using.
    Can you point me to the documentation? Also should I use usbc only and not wifi?
    Thanks.
    suvasis
    @suvasis For magnetometer rotation it is specified as the -R option on the start line in /etc/modalai/voxl-px4.config. For example: qshell ist8310 start -R 10 -X -b 1 has a rotation specified by the -R option. This is from the standard PX4 documentation.
    Abdullah01A 1 Reply Last reply
    • S Offline
      S Offline
      suvasis
      hi Eric
      IS it the magnetometer not an inherent part of the VOXL2 board? Is it part of GPS? I have not attached GPS to my drone yet, For compass do I need GPS?
      Thanks.
      suvasis
      • S Offline
        S Offline
        suvasis
        hi Eric,
        I have not hooked up the GPS to my vehicle.
        I run the following commands:
        (do't see magnetometer anywhere)
        voxl2:~$ sudo journalctl -u voxl-px4 -f
        -- Logs begin at Tue 2022-09-06 03:18:07 UTC. --
        Mar 21 17:49:39 m0054 bash[1748]: INFO [muorb] SLPI: Advertising remote topic vehicle_command
        Mar 21 17:49:39 m0054 bash[1748]: INFO [commander] Handling Commander command 176
        Mar 21 17:49:39 m0054 bash[1748]: INFO [muorb] SLPI: Advertising remote topic vehicle_command_ack
        Mar 21 17:49:39 m0054 bash[1748]: INFO [mavlink] mode: Onboard, data rate: 100000 B/s on udp port 14556 remote port 14557
        Mar 21 17:49:39 m0054 bash[1748]: INFO [muorb] SLPI: Marking DeviceNode(vehicle_command) as advertised in process_remote_topic
        Mar 21 17:49:39 m0054 bash[1748]: INFO [px4] Startup script returned successfully
        Mar 21 17:49:39 m0054 bash[1748]: INFO [mavlink] partner IP: 127.0.0.1
        Mar 21 17:49:39 m0054 bash[1748]: INFO [muorb] SLPI: Advertising remote topic telemetry_status
        Mar 21 17:49:39 m0054 bash[1748]: INFO [PreFlightCheck] Failed EKF health preflight check while waiting for filter to settle
        Mar 21 17:49:39 m0054 bash[1748]: INFO [muorb] SLPI: Advertising remote topic timesync_status
        and
        (also don't see any address)
        voxl2:~$ sudo i2cdetect -y -r 1
        0 1 2 3 4 5 6 7 8 9 a b c d e f
        00: -- -- -- -- -- -- -- -- -- -- -- -- --
        10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
        20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
        30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
        40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
        50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
        60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
        70: -- -- -- -- -- -- -- --
          There is no magnetometer on VOXL 2, you need to connect the GPS unit that includes the magnetometer
          • S Offline
            S Offline
            suvasis
            Thankyou Chris, looks like QGC estimated heading information derived from other sensors, like the gyroscope and accelerometer, rather than a magnetometer. I got false idea from QGC.
              Abdullah01A Offline
              Abdullah01A Offline
              Abdullah01
              @Eric-Katzfey said in QGC sensors - compass remains red:
              Thank you.
              So, if my GPS is in the opposite orientation of the voxl imu by Yaw 180 deg, so I need to change it form 10 to (4), right?
              • Abdullah01A Abdullah01
                Thank you.
                @Abdullah01 The IMU rotation is handled separately. For the magnetometer in a Holybro GPS unit the rotation is specified as 10 (roll 180, yaw 90) when the unit is mounted on the drone with the arrow pointing towards to front of the drone. If you reverse this and the arrow points to the rear of the drone then you would specify 14 (roll 180, yaw 270).
                  Abdullah01A Offline
                  Abdullah01A Offline
                  Abdullah01
                  wrote on last edited by Abdullah01
                  #17
                  Ok, that means our config file is correct.
                  During the sensor calibration for the accelerometer shows an error in the orientation error pic showsWhatsApp Image 2023-06-13 at 2.19.53 PM.jpeg here
                  Also, for the compass calibration, once I restart the drone after finishing the calibration it goes away and I need to calibrate it again.
                  BTW, the voxl orientation is different than the GPS., and changed the config file to rotate the voxl orientation. Do think this might be the issue?
                  You can see this in the drone setup below, where the original orientation of the voxl is opposite to the drone's front
                  So, what do you think is the issue? Also, we are using I/O Board do think it needs a different setup?
                  Thank you for your support
                    @Abdullah01 Looks like it is the IMU rotation that isn't being specified correctly. It's kind of hard to tell in the picture but, at a minimum, the board is rotated 180 degrees. So it's the IMU rotation that needs to be set.
                      Abdullah01A Offline
                      Abdullah01A Offline
                      Abdullah01
                      yes, the board is rotated 180 degrees. So, how do I set the rotation of the IMU to 180 degrees? is it in the same config file?
                      I rotate it 180 degrees as shown below
