Raza RizviR
Raza Rizvi
@Raza Rizvi
  • Using SIYI Gimbal and Smart RC Controller with VOXL2
    Raza RizviR Raza Rizvi
    @Eric-Katzfey said in Using SIYI Gimbal and Smart RC Controller with VOXL2:
    J9
    Best.
    One more thing, the control input to the gimbal comes from a telem from the flight controller, as can be seen in the image attached.
    Which port should I use from the VOXL2 for that purpose?
    @Eric-Katzfey Awesome, thanks.
    I'm also buying the VOXL 2 Ethernet and USB Hub Add-on to integrate a Livox Mid 360 lidar on VOXL2. In this case, I wont need to buy an additional Add on board with UART right, since the VOXL 2 Ethernet and USB Hub Add-on also has a UART expansion?
    M0065 IO boards
    Hey Eric,
    Thanks a lot for a super quick response.
    Can you like me to the add-on board and the IO boards you are mentioning?
  • Clarification on Livox Mid 360 LiDAR Compatibility with VOXL 2 on Starling 2 Max Outdoor Drone
    @Thasindu-Wickrama Hey man, I am planning to do the same on a VOXL2 powered custom build drone.
    Did you have any success?
    ESCs, Sensors and Accessories
    I am developing a drone with VOXL2 and I wanted to know if the SIYI A8 mini Gimbal and the SIYI MK32 Smart Controller are compatible with the VOXL2 for drone control, gimbal control, and visualizing the live gimbal camera stream on the SIYI controller?
    If it's not directly supported, are there any work arounds?
  • Mavlink-Server Verification
    @McMason Can you please guide me on how to solve this issue?
    I am having a similar problem with the Sentinel drone, when I run the voxl-mavlink-server -r command, there is no main loop being triggered.
    Hence, I am also unable to see the drone connected to the QGround controller.
  • QGC Not Connecting to the Sentinel
    @tom
    @Adrian-Hidalgo
    I am connected over station. And Yes, I can SSH to the drone.
    @Adrian-Hidalgo
    Yes, the firewall is disabled.
    Here's the output to the mentioned command:
    The mavlink server is also running
  • Mavlink Server Not Receiving any messages
    The main issue is this.
    In order to debug this, I am trying to see if my mavlink server is working fine.
    The send works fine (apparently)
    voxl-mavlink-server --debug_send
    But, the recv is not working
    voxl-mavlink-server --debug_recv
    Can it be related to the ports mentioned inside the mavlink configuration?
    My mavlink conf is:
    And the vision-px4 conf. is:
    Please help.
    Hello, I am following this QuickStart Guide, but my QGC is unable to connect to the Sentinel drone.
    1. The drone is successfully connected to the WiFi
    ifconfig # On the Drone
    ifconfig # On the Host Laptop
    1. I can Ping from the drone to my Host laptop, and vice-versa
    1. I mentioned the Host IP Address inside the voxl-vision-px4.conf
    Still, when running the QGC on Host, it shows disconnected
  • R/C Transmitter Selection for VOXL2 AI Sentinel Drone
    Are there any other receivers onboard the Sentinel drone which can be used with Transmitters other than the Spektrum ones?
    I've recently ordered the VOXL 2 AI & 5G Development Drone - Sentinel and I am unsure about the R/C control of this drone.
    The webpage suggests buying an R/C Transmitter and mentions the Spektrum RC transmitter (e.g. DX6e, SPM8000 or SPMR8000) as a compatible one.
    My question is, does the drone comes already with a Spektrum Receiver, which is why we need to buy a Spektrum Transmitter?
    If not, are we open to buying any receivers or transmitters?
