Maxwell SchaeferM
Maxwell Schaefer
@Maxwell Schaefer
  • Cannot bind my stinger to my radiomaster gx12
    Maxwell SchaeferM Maxwell Schaefer
    Assuming your Stinger SKU contains an ExpressLRS modem (ModalAI M0184 Gemini RX), you will want to follow the ExpressLRS Binding procedures. Firstly, to put the receiver into "binding" mode, you'll want to either press the bind button for at least 1.5 seconds, and you must do this at least a few seconds after the battery has been inserted (or anytime later). You can also put the receiver into binding mode by powering on and off the Stinger 3 times quickly, though this can be unreliable.
    You will also need to make sure your transmitter is compatible with the receiver, and in a compatible mode. The M0184 by default comes with firmware based on ELRS 3, so you will need to verify that your GX12's internal ExpressLRS firmware is also on major version 3, otherwise you will need to downgrade to V3. Furthermore, the GX12 comes with a dual-band transmitter which supports 2.4GHz and 915MHz operation. To work with the M0184 you must make sure the selected "RF Band" parameter is "915 MHz", and the packet rate is 50 Hz 100 Hz, or 200 Hz. Other packet rates are not supported on the older modem in the M0184.
  • Zorro Blue Audio
    @Nick-Stroumtsos The Zorro Blue does not have any audio capabilities. It is built with custom electronics which do not include support for a speaker so no firmware can enable audio features.
  • Re-configure VOXL2 1.4 for GHOST Receiver/Transmitter?
    The ExpressLRS receiver requires* one additional wire. The ghost atto only connects one wire to the VOXL RC RX pin, but the ELRS receiver will also require a connection to the VOXL RC TX pin, otherwise the wiring is identical. Pre-crimped wires can be found easily for the JST GH connectors (J19) to make adding connections simple.
    *You could leave the receiver's RX line (the VOXL's RC TX) disconnected; this would make updates and other control using the voxl-elrs application impossible but basic RC functionality would work.
    Development Drones sentinel
    Our recommended and most well-supported RC system would be ExpressLRS. We have our own receiver available here, and a transmitter pre-programmed to work with many of our drones available here.
    Beyond these options, nearly any commercially available ExpressLRS transmitters and receivers would work and can be found cheaply. Follow the guidance here to make sure your chosen devices are compatible if you choose to look elsewhere.
    If you would like to continue using your current controller and transmitter module, you will need to find a replacement ghst atto receiver which unfortunately don't seem to be available anymore.
  • Questions on Starling 2 Max
    That red light is for the M0184 ELRS receiver. A constant slow blink from the light means it is disconnected. It will turn solid with a connection. Other LED states are documented here.
  • Lost the original Zorro Blue model
    @Omri-Eival The Zorro Blue User Manual should answer most of your questions, with a shell script to copy all of the latest data to a handset in the provided zip file. While you are there, if your firmware is out of date it may be worth going through the update process.
  • Need Info for Starling 2 Max That Shipped With New Wifi & ELRS Receiver
    The M0184 ELRS receiver is able to be flashed with the ExpressLRS Configurator; however, it requires you to use our forked firmware repository. The instructions for using ELRS Configurator with our receivers are here: https://docs.modalai.com/elrs-configurator.
    Development Drones starling
  • Requesting the factory original calibration files for ADK Ser#M2500000185
    @latif You should be able to disable the model match feature on the same screen which displayed the "Model Mismatch" error. By setting the model match id to 0, it will ignore the model match id set on the receiver and connect. The ExpressLRS documentation has more detail about how to set up the RC connection here.
    Flight Core and Legacy VOXL
  • elrs fw compatibility
    @wifa799 @Viktor-Gal You can use any CRSF (ELRS) receiver with the VOXL 2 and it will work. While we don't support flashing upstream builds of ELRS from the VOXL, if you update it yourself it will work without requiring any additional modification or patches. The patches from ModalAI just include some extra utilities for managing the receiver with the voxl-elrs tool such as the "unbind" command and pwm configuration from the VOXL. I'll see if I can provide a build for the betafpv receiver which matches the 3.5.3 version provided for our in-house M0184 receivers, but in the meantime you can definitely use firmware from the upstream ELRS repo.
    @Viktor-Gal ELRS maintains compatibility between all versions with the same major version number, so a 3.x.x receiver is compatible with any 3.x.x transmitter; however, a 3.x.x receiver is not compatible with a 2.x transmitter. Because of this, you will need to update the transmitter in your handset. You can use the upstream ELRS firmware for this since we don't make any modifications to the firmware for the iFlight Commando, instructions are here. I suggest using the latest firmware version available, you can flash older firmware later if necessary. All customization and ModalAI provided models on the handset will persist through this process.
  • VOXL2 RC uart failure
    Hi @tkddnjs825,
    In addition to Alex's question above, could you also please share which version of voxl-elrs is being used on each voxl2? The voxl-version command should list the versions of each installed package.
    Can you also please confirm that in the voxl-px4 configuration file on the voxl2 that is not able to communicate with the ELRS receiver that the RC type is set to CRSF_RAW, like this: RC=CRSF_RAW.
    Furthermore, if you could share the output of voxl-elrs --scan from the voxl which is unsuccessful that would be helpful.
    Thanks,
    Max
