@Moderator thank you for the recommendation. I will try out this.
Posts made by Ege Yüceel
RE: VIO drifting when using TFlite Serverposted in GPS-denied Navigation (VIO)
Hi ModalAI team
I’m working with a Starling 2 drone running SDK 1.4.0. In a recent project, I integrated a TFLite server to command the drone in certain directions using VIO (qvio).
Here’s the situation:
In Position mode, VIO works fine. It can handle mild to moderately agile maneuvers with good stability. However, once I start using the TFLite server to command the drone (via MAVSDK Python Docker, listening to TFLite outputs from a mounted pipe), VIO becomes unstable. The issues I observe: During slightly rapid motions, I get errors like “accelerometer fail” or “height estimate error”. Over time, VIO itself fails completely and I have to restart.
I am presuming this can happen because of overheating. When the neural network runs, the VOXL2 temperature often reaches 80–85°C, sometimes even above 90°C when I dont start the propellers quickly. This could:
-Directly harm the VOXL2 hardware.
-Disrupt IMU calibration at high temperatures.
I’m thinking about adding a cooling fan or redoing the IMU calibration (hot calibration in particular).
What would be your suggestions or other potential reasons for this case?
Best Strategy for Injecting Photorealistic Rendering Outputs into VOXL2 Camera Pipeline in Gazebo HITLposted in VOXL SDK
Hi ModalAI community,
I'm working on a Gazebo HITL setup with VOXL2 and need to inject photorealistic rendering (GSplat, NeRF) outputs into the camera pipeline. I'm trying to figure out the best approach and would appreciate your input. I have followed the guide https://docs.modalai.com/voxl2-PX4-hitl/#hitl. To modify the existing docker contents, I copy a part of the file directory (/usr/workspace/voxl2_hitl_gazebo) outside the container. I do the necessary file edits there and initialize the docker with that directory mounted to the container and also compile/build the code changes within the docker.
My Setup:
- VOXL2 running HITL with Gazebo
- Current world: modalai.world with iris_hitl model
- Photorealistic rendering environment where you give a pose and get an image back
Goal: VOXL2 should use these rendered images as its camera output for VIO and other services
Current Understanding:
-VOXL2 has built-in VIO that processes camera images
-Current modalai.world has no camera sensor
-I want to bypass camera rendering and inject photorealistic images directly
-Need images to be available for multiple services (VIO, voxl-tflite-service, etc.)My Questions:
- Should I add a camera sensor to the world and attach a custom plugin? Or is there a cleaner way to inject images directly into the camera pipeline?
- If I inject rendered images directly into a camera plugin (modifying or creating a custom plugin), will VOXL2 still perform proper VIO? Or does it need actual camera sensor data?
- What's the minimal change needed? I want to avoid dealing with camera intrinsics, distortion models, and rendering pipelines.
- How do I make the injected images available to multiple VOXL2 services? I need VIO, voxl-tflite-service, and potentially other services to access the same camera feed.
- What is the specific plugin at /usr/workspace/voxl2_hitl_gazebo/build/ I need to modify for this?
Deploying Neural Networks with Multi-Modal Inputs (Camera + Additional Sensor Data)posted in Modal Pipe Architecture (MPA)
Hi ModalAI team. I’ve been successfully using voxl-tflite-server to run custom neural networks that take image input from the mpa/hires camera. Now, I’d like to expand to more general neural networks that also incorporate other forms of input. For example, prior waypoint information stored in memory or additional sensory data (e.g., IMU, rangefinders, or temporal data from previous frames).
What would be the recommended roadmap to support this?
Specifically:
How should I modify or extend the current model helper pipeline to feed both image and non-image inputs?
Is there support in voxl-tflite-server for multiple input tensors (e.g., combining a camera frame other forms of information)?
Disabling PX4 autopilot and directly command 4x1 thrust and torque for low-level controlposted in VOXL Compute & Autopilot
Hi ModalAI team, I am working on a project that involves developing an end-to-end neural network-based control policy for a quadrotor. For this, I would like to bypass the PX4 autopilot and directly control the drone at the low level using a 4x1 vector of thrust and torque (roll, pitch, yaw) commands, similar to what is used in 12D system models.
My goal is to retain the VOXL infrastructure, especially for reading from onboard services like custom neural network outputs through the voxl-tflite-server pipes and using the existing sensor and system services. However, I would like to disable PX4's control stack and instead send raw actuator commands directly from my control policy.
Could you clarify whether this type of low-level control is supported through VOXL’s existing service architecture? If so, do I need to implement my control policy in C++, or is it also feasible to use Python for sending these thrust and torque commands at a low enough latency for closed-loop flight? Any guidance on how to interface with the motor outputs or appropriate service pipes to do this would be greatly appreciated. Thank you.
RE: Using MPA within voxl-docker-mavsdk-cppposted in Modal Pipe Architecture (MPA)
@Zachary-Lowell-0 Hi Zach and team, I have been using the voxl docker mavsdk python container successfully for MAVSDK based drone control, and now I would like to read from VOXL’s Modal Pipe Architecture (MPA) inside the same container. I saw your suggestion about either mounting header files like modal_start_stop.h or installing the full MPA package inside the container. Could you please clarify the best way to do this? Should I install the libmodal_pipe Debian package inside the Docker image using the Dockerfile, or manually copy the headers and libraries from the host? Also, is this setup compatible with the voxl docker mavsdk python container, or is it mainly meant for the C++ MAVSDK version?
I am trying to listen to a custom voxl tflite server service that gives inference output from my custom neural networks. I want to deploy some motion planning in Python based on the neural net output. I would really appreciate more specific setup instructions or an example Dockerfile that includes MPA support. Thank you.
RE: tensorflow lite dev setup failing on Ubuntu 22posted in Ask your questions right here!
@Alex-Kushleyev Thanks for the response.
@Alex-Kushleyev I was having the same problem and thanks to this answer I can build without an issue. But the only thing I am worried is when I deploy this to my Voxl 2 machine with SDK version 1.4.1 and voxl-tflite-server version 0.3.9, would it break anything? My aim is to develop some custom tflite application.
Inference performance and GPU customization on PX4 Autonomy Developer Kit and Starling 2posted in Ask your questions right here!
Hi, I have questions about the PX4 Autonomy Developer Kit and Starling 2.
How is the inference time for object detection and classification models, considering that other tasks like flight control are running? Can PyTorch be used for image-based tasks on these systems, or is TFLite the main option? Are there ways to customize compute power, especially GPU acceleration, beyond the built-in Adreno 650?
Warranty and Replacement Parts for PX4 Autonomy Development Kit & Starling 2 Dronesposted in Ask your questions right here!
I’m considering purchasing either the PX4 Autonomy Development Kit or the Starling 2 Drone and had a couple of questions about their durability and maintenance:
1- Do these drones come with any kind of warranty? If so, what does it cover?
2- Are potentially breakable parts like the chassis and propellers easily replaceable? I saw a general list of accessories on ModalAI’s website (https://www.modalai.com/collections/all?&sort_by=manual), but I didn’t find anything specific about chassis replacements.
3- Would the Sentinel replacement propellers (https://www.modalai.com/collections/all/products/mrp-d0006-1-01) be compatible with these drones?
I’d appreciate any insights from those who have experience with these models. Thanks!
