  3. How to Build mavsdk_server from new source
13 Posts 5 Posters 2.6k Views 2 Watching
  • PIRON PIP Offline
    PIRON PIP Offline
    PIRON PI
    Hi, I download a new version of mavsdk.
    But New mavsdk needs cmake version 3.13 or later.
    I try to use voxl-emulator or gcr.io/modalai-public/voxl-mavsdk-cpp:v1.0, but their cmake are too old.
    Is there a way to build new version of mavsdk?
    • PIRON PIP PIRON PI
      @PIRON-PI You can get release binaries, for example: https://github.com/mavlink/MAVSDK/releases/download/v0.43.0/mavsdk_server_linux-arm64-musl
      • PIRON PIP Offline
        PIRON PIP Offline
        PIRON PI
        Hi Eric, the demo code of python can work with mavsdk_server,
        but C++ demo code can't connect with mavsdk_server.
        I read source code of python that assigns udp port for mavsdk_server.
        C++ demo code doesn't assign udp port for mavsdk_server.
        Does this cause C++ demo code doesn't work?
          @PIRON-PI I have only worked with the python code.
          • C Offline
            C Offline
            CY-1992
            @PIRON-PI You don't need mavsdk-server if you use C++.
            PIRON PIP 3 Replies Last reply
            • C CY-1992
              PIRON PIP Offline
              PIRON PIP Offline
              PIRON PI
              • C CY-1992
                PIRON PIP Offline
                PIRON PIP Offline
                PIRON PI
                @CY-1992 You give me confidence .
                I did it.
                Thanks a lot.
                • C CY-1992
                  PIRON PIP Offline
                  PIRON PIP Offline
                  PIRON PI
                  @CY-1992 I generate libmavsdk.so from instruction of mavsdk.mavlink.io,
                  but it can't be compatible with VOXL.
                  Do you know where I can get source to generate libmavsdk.so for VOXL flight Deck?
                    I assume you have seen this tutorial since you mention the docker image
                    Have you tried to upgrade cmake inside the voxl-mavsdk-cpp:v1.0 docker? If cmake version is the only blocker, you should be able to upgrade it to keep moving
                    PIRON PIP 2 Replies Last reply
                    • Chad SweetC Chad Sweet
                      PIRON PIP Offline
                      PIRON PIP Offline
                      PIRON PI
                      @Chad-Sweet I try to upgrade cmake in docker, but it doesn't work.
                        PIRON PIP Offline
                        PIRON PIP Offline
                        PIRON PI
                        @Chad-Sweet Maybe you can offer the right version of mavsdk source. Because I use "git clone https://github.com/mavlink/MAVSDK.git". It's too new to be compatible with VOXL flight Deck.
                          @PIRON-PI You don't need to build mavsdk from the source if you are using it in docker on voxl. Just download the arm64 deb package and install it in the docker as shown below in Dockerfile. Try to use base image arm64v8/ubuntu:20.04. It has the latest cmake version.
                          FROM arm64v8/ubuntu:20.04
                          ENV DEBIAN_FRONTEND noninteractive
                          RUN apt-get -y update && \
                              apt-get install -y build-essential cmake git wget
                          WORKDIR /home
                          RUN wget https://github.com/mavlink/MAVSDK/releases/download/v1.4.0/libmavsdk-dev_1.4.0_debian11_arm64.deb && \
                              dpkg -i libmavsdk-dev_1.4.0_debian11_arm64.deb
                          WORKDIR /home
                          #copy all your c++ files and CMakeLists.txt to home directory
                          COPY . .
                          RUN cmake -Bbuild -DCMAKE_BUILD_TYPE=Debug -H. && \
                              cmake --build build -j4
                          PIRON PIP 1 Reply Last reply
                          • ? A Former User
                            WORKDIR /home
                            WORKDIR /home
                            COPY . .
                            PIRON PIP Offline
                            PIRON PIP Offline
                            PIRON PI
                            @chaitanya Sorry. My goal is that cell phone can control VOXL flight deck.
                            Therefore, I need a MAVSDK library( e.g. libmavsdk.so) at Android. Then I can use the library to send command to control VOXL flight deck.
