  3. How to Build mavsdk_server from new source
13 Posts 5 Posters 2.5k Views 2 Watching
  • PIRON PIP PIRON PI
    Hi Eric, the demo code of python can work with mavsdk_server,
    but C++ demo code can't connect with mavsdk_server.
    I read source code of python that assigns udp port for mavsdk_server.
    C++ demo code doesn't assign udp port for mavsdk_server.
    Does this cause C++ demo code doesn't work?
    @PIRON-PI I have only worked with the python code.
    • C Offline
      C Offline
      CY-1992
      @PIRON-PI You don't need mavsdk-server if you use C++.
      PIRON PIP 3 Replies Last reply
      • C CY-1992
        PIRON PIP Offline
        PIRON PIP Offline
        PIRON PI
        • C CY-1992
          PIRON PIP Offline
          PIRON PIP Offline
          PIRON PI
          @CY-1992 You give me confidence .
          I did it.
          Thanks a lot.
          • C CY-1992
            PIRON PIP Offline
            PIRON PIP Offline
            PIRON PI
            @CY-1992 I generate libmavsdk.so from instruction of mavsdk.mavlink.io,
            but it can't be compatible with VOXL.
            Do you know where I can get source to generate libmavsdk.so for VOXL flight Deck?
              I assume you have seen this tutorial since you mention the docker image
              Have you tried to upgrade cmake inside the voxl-mavsdk-cpp:v1.0 docker? If cmake version is the only blocker, you should be able to upgrade it to keep moving
              PIRON PIP 2 Replies Last reply
              • Chad SweetC Chad Sweet
                PIRON PIP Offline
                PIRON PIP Offline
                PIRON PI
                @Chad-Sweet I try to upgrade cmake in docker, but it doesn't work.
                  PIRON PIP Offline
                  PIRON PIP Offline
                  PIRON PI
                  @Chad-Sweet Maybe you can offer the right version of mavsdk source. Because I use "git clone https://github.com/mavlink/MAVSDK.git". It's too new to be compatible with VOXL flight Deck.
                  • ? Offline
                    @PIRON-PI You don't need to build mavsdk from the source if you are using it in docker on voxl. Just download the arm64 deb package and install it in the docker as shown below in Dockerfile. Try to use base image arm64v8/ubuntu:20.04. It has the latest cmake version.
                    FROM arm64v8/ubuntu:20.04
                    ENV DEBIAN_FRONTEND noninteractive
                    RUN apt-get -y update && \
                        apt-get install -y build-essential cmake git wget
                    WORKDIR /home
                    RUN wget https://github.com/mavlink/MAVSDK/releases/download/v1.4.0/libmavsdk-dev_1.4.0_debian11_arm64.deb && \
                        dpkg -i libmavsdk-dev_1.4.0_debian11_arm64.deb
                    WORKDIR /home
                    #copy all your c++ files and CMakeLists.txt to home directory
                    COPY . .
                    RUN cmake -Bbuild -DCMAKE_BUILD_TYPE=Debug -H. && \
                        cmake --build build -j4
                    PIRON PIP 1 Reply Last reply
                    • ? A Former User
                      WORKDIR /home
                      WORKDIR /home
                      COPY . .
                      PIRON PIP Offline
                      PIRON PIP Offline
                      PIRON PI
                      @chaitanya Sorry. My goal is that cell phone can control VOXL flight deck.
                      Therefore, I need a MAVSDK library( e.g. libmavsdk.so) at Android. Then I can use the library to send command to control VOXL flight deck.
