  3. RB5 unable to connect to hotspot
rb5
11 Posts 4 Posters 2.2k Views 2 Watching
  • Francesco JacomelF Offline
    Francesco Jacomel
    wrote on last edited by Francesco Jacomel
    I've been trying to connect to different wifi networks and I'm unable to succeed on that.
    WPA supplicant file is being updated as below:
    ctrl_interface=/var/run/wpa_supplicant
    update_config=1
    network={
    #WPA-PSK
            ssid="Test1"
            key_mgmt=WPA-PSK
            psk="abcdefgh"
    And I just can't see any error but the connection is not established. Test1 is a hotspot on my cellphone, should I use WPA2-PSK instead?
    Hotspot settings are as follows:
    SSID:	Test1
    Protocol:	Wi-Fi 4 (802.11n)
    Security type:	WPA2-Personal
    Network band:	2.4 GHz
    Network channel:	1
      Hi @Francesco-Jacomel ,
      This is an example of our WPA supplicant used at the factory during setup:
      # Only WPA-PSK is used. Any valid cipher combination is accepted.
      update_config=1
      network={
      	ssid="Foo"
      	key_mgmt=WPA-PSK
      	pairwise=TKIP CCMP
      	group=TKIP CCMP
      	psk="Bar"
      wowlan_triggers=magic_pkt
      These got things connected on our network. I've not dug into the params myself though so 'use at own security risk' 😉
      Francesco JacomelF 1 Reply Last reply
      • tomT Offline
        @Francesco-Jacomel Are you rebooting your RB5 Flight after modifying the wpa_supplicant file?
        • modaltbM modaltb
          update_config=1
          network={
          	ssid="Foo"
          	key_mgmt=WPA-PSK
          	pairwise=TKIP CCMP
          	group=TKIP CCMP
          	psk="Bar"
          Francesco Jacomel
          @modaltb It's the pretty same as I have here. 😞 I've tried keeping the pairwise and group for some attempts but also didn't work.
            Francesco Jacomel
            @tom Yep, after any change on the file I'm rebooting.
            • tomT Offline
              @Francesco-Jacomel Are you able to connect to any WiFi network? i.e. your home / office network?
                Francesco Jacomel
                @tom I've tried two different networks so far, one from my company so a firewall might be affecting the connection attempt through WPA, other using my iPhone Hotspot which is WPA2 so I'm unsure whether this might be an issue. I'm setting up a new one with no restrictions (no firewall, no wpa2).
                I'll update here accordingly.
                  Francesco Jacomel
                  I've set up a new network with very few restrictions and now it is connected to the network! Thank you very much for your support!
                  • tomT Offline
                    @Francesco-Jacomel Great! Thanks for investigating that, our test network is fairly open security-wise so we hadn't run into that issue.
                    • J Offline
                      justinGE
                      Not to necro a thread, but if you're using WPA2 you need to supply a country code at the top of the wpa_supplicant such as
                      country=US
                      update_config=1
                      network={
                      	ssid="Foo"
                      	psk="Bar"
                      I was having trouble connecting to our local internet until I did this.
                      • J justinGE
                        country=US
                        update_config=1
                        network={
                        	ssid="Foo"
                        	psk="Bar"
                        @justinGE This is good information, thanks for sharing!
