    RB5 unable to connect to hotspot
    Qualcomm Flight RB5 5G Drone
    1199
    • Francesco JacomelF
      Francesco Jacomel
      I've been trying to connect to different wifi networks and I'm unable to succeed on that.
      WPA supplicant file is being updated as below:
      ctrl_interface=/var/run/wpa_supplicant
      update_config=1
      network={
      #WPA-PSK
              ssid="Test1"
              key_mgmt=WPA-PSK
              psk="abcdefgh"
      And I just can't see any error but the connection is not established. Test1 is a hotspot on my cellphone, should I use WPA2-PSK instead?
      Hotspot settings are as follows:
      SSID:	Test1
      Protocol:	Wi-Fi 4 (802.11n)
      Security type:	WPA2-Personal
      Network band:	2.4 GHz
      Network channel:	1
      • modaltbM
        modaltb ModalAI Team
        Hi @Francesco-Jacomel ,
        This is an example of our WPA supplicant used at the factory during setup:
        # Only WPA-PSK is used. Any valid cipher combination is accepted.
        update_config=1
        network={
        	ssid="Foo"
        	key_mgmt=WPA-PSK
        	pairwise=TKIP CCMP
        	group=TKIP CCMP
        	psk="Bar"
        wowlan_triggers=magic_pkt
        These got things connected on our network. I've not dug into the params myself though so 'use at own security risk' 😉
        Francesco JacomelF 1 Reply Last reply Reply Quote 0
          tom admin
          @Francesco-Jacomel Are you rebooting your RB5 Flight after modifying the wpa_supplicant file?
            Francesco Jacomel @modaltb
            @modaltb It's the pretty same as I have here. 😞 I've tried keeping the pairwise and group for some attempts but also didn't work.
              Francesco Jacomel @tom
              @tom Yep, after any change on the file I'm rebooting.
                tom admin
                @Francesco-Jacomel Are you able to connect to any WiFi network? i.e. your home / office network?
                  @tom I've tried two different networks so far, one from my company so a firewall might be affecting the connection attempt through WPA, other using my iPhone Hotspot which is WPA2 so I'm unsure whether this might be an issue. I'm setting up a new one with no restrictions (no firewall, no wpa2).
                  I'll update here accordingly.
                    Francesco Jacomel
                    I've set up a new network with very few restrictions and now it is connected to the network! Thank you very much for your support!
                      tom admin
                      @Francesco-Jacomel Great! Thanks for investigating that, our test network is fairly open security-wise so we hadn't run into that issue.
                      • J
                        justinGE
                        Not to necro a thread, but if you're using WPA2 you need to supply a country code at the top of the wpa_supplicant such as
                        country=US
                        update_config=1
                        network={
                        	ssid="Foo"
                        	psk="Bar"
                        I was having trouble connecting to our local internet until I did this.
                        tomT 1 Reply Last reply Reply Quote 1
                          tom admin @justinGE
                          @justinGE This is good information, thanks for sharing!
