  3. GPS not connecting
GPS not connecting
starling
6 Posts 3 Posters 1.3k Views 3 Watching
  • R Offline
    R Offline
    roy.crosthwaite
    Hello ModalAI Support,
    We recently purchased qty 2 Starling 2 Max with the 5G add-on modem. Both units initially were working but one now has an apparent GPS module failure as I cannot connect to it. Also, after reading through several posts, it appears that we're not the only ones having this problem.
    As for the configuration of our units, here's what we have:
    system-image: 1.8.04-M0054-14.1a-perf
    kernel: #1 SMP PREEMPT Mon Mar 24 22:31:58 UTC 2025 4.19.125
    hw platform: M0054
    mach.var: 1.0.1
    SKU: MRB-D0012-4-V2-C29-T9-M24-X0
    voxl-suite: 1.5.0
    I read through and performed all the suggested troubleshooting steps that I found in several previous posts for GPS problems. The most revealing test is when I disable voxl-px4 from loading at startup and started it manually. There are a few errors thrown as it executes but when it tried to connect to the GPS it goes into an infinite loop trying all defined GPS UART baudrates and never connects. All cables and connectors have been checked and everything looks good physically. I also checked the power going into the GPS module and it is at the required 5VDC. I noticed a couple of things on the circuit side of the GPS board - a 3.3VDC test point and what appears to be a button cell soldered to the board. The voltage at the test point measured 2.57 VDC and with the power off I measured .25 volts on the assumed button cell. Of course, I go out to the 3DR website to track down information only to discover that the "Documentation is coming soon". 2.57VDC is definitely too low for something requiring 3.3VDC to operate.
    Before we bought these, we were told that there was an interference issue with the 5G modems and the GPS. I read through post https://forum.modalai.com/topic/4226/starling-2-max-no-gps-data?_=1756238568725 and gather that this problem might be an underlying issue with the VOXL 2 (and other boards plugged into it). Has any progress been made on this?
    Anyway, with all that said, it appears that the GPS is DOA. Below is the output from the voxl-px4 script when I run it manually.
    I appreciate any help you can give.
    hw platform: M0054
    mach.var: 1.0.1
    voxl-suite: 1.5.0
    current IP: wlan0: 192.168.8.1
    starling2-max (D0012):/$ voxl-px4
    Found DSP signature file
    [INFO] Daemon mode enabled
    AIRFRAME=MULTICOPTER
    GPS=AUTODETECT
    RC=GHST
    ESC=VOXL_ESC
    POWER MANAGER=NONE
    AIRSPEED SENSOR=NONE
    DISTANCE SENSOR=NONE
    OSD=DISABLE
    DAEMON_MODE=ENABLE
    SENSOR_CAL=ACTUAL
    ARTIFACT_MODE=DISABLE
    EXTRA STEPS:
    INFO [px4] mlockall() enabled. PX4's virtual address space is locked into RAM.
    INFO [px4] assuming working directory is rootfs, no symlinks needed.
    INFO [muorb] Got muorb init command
    INFO [muorb] [modules__muorb__slpi] muorb aggregator thread running
    INFO [muorb] muorb protobuf initalize method succeeded
    INFO [muorb] succesfully did ADVERTISE_TEST_TYPE
    INFO [muorb] [tasks] Creating pthread test_MUORB
    INFO [muorb] [tasks] Successfully created px4 task PX4_test_MUORB with tid 2097656
    INFO [muorb] succesfully did SUBSCRIBE_TEST_TYPE
    INFO [muorb] [tasks] Successfully created px4 task PX4_test_MUORB with tid 2097655
    INFO [muorb] succesfully did TOPIC_TEST_TYPE
    INFO [muorb] [tasks] Successfully created px4 task PX4_test_MUORB with tid 2097654
    INFO [muorb] succesfully did UNSUBSCRIBE_TEST_TYPE
    INFO [muorb] [tasks] Successfully created px4 task PX4_test_MUORB with tid 2097653
    INFO [muorb] muorb test passed
    | ___ \ \ \ / / / |
    | |/ / \ V / / /| |
    | __/ / \ / /
    | | / /^\ \ ___ |
    _| / / |_/
    px4 starting.
    INFO [muorb] [uORB] Advertising remote topic log_message
    INFO [px4] startup script: /bin/sh /usr/bin/voxl-px4-start 0
    INFO [parameters] Starting param sync THREAD
    AIRFRAME: MULTICOPTER
    GPS: AUTODETECT
    RC: GHST
    ESC: VOXL_ESC
    POWER MANAGER: NONE
    AIRSPEED SENSOR: NONE
    DISTANCE SENSOR: NONE
    OSD: DISABLE
    ARTIFACT_MODE: DISABLE
    EXTRA STEPS:
    Running on M0054
    INFO [muorb] [parameters] Starting param sync THREAD
    INFO [muorb] [qshell] before starting the qshell_entry task
    INFO [muorb] [tasks] Creating pthread qshell
    INFO [muorb] [qshell] qshell entry.....
    INFO [muorb] [tasks] Successfully created px4 task PX4_qshell with tid 2097652
    INFO [muorb] [qshell] Init app map initialized
    INFO [muorb] [qshell] after starting the qshell_entry task
    INFO [param] selected parameter default file /data/px4/param/parameters
    INFO [muorb] [uORB] Marking DeviceNode(parameter_client_reset_request) as advertised in process_remote_topic
    INFO [uORB] Marking DeviceNode(parameter_client_reset_response) as advertised in process_remote_topic
    INFO [muorb] [uORB] Advertising remote topic parameter_update
    INFO [muorb] [uORB] Marking DeviceNode(parameter_client_set_value_request) as advertised in process_remote_t
    INFO [uORB] Marking DeviceNode(parameter_server_set_used_request) as advertised in process_remote_topic
    INFO [muorb] [uORB] Marking DeviceNode(parameter_server_set_used_response) as advertised in process_remote_t
    INFO [uORB] Marking DeviceNode(parameter_client_set_value_response) as advertised in process_remote_topic
    INFO [parameters] BSON document size 3367 bytes, decoded 3367 bytes (INT32:47, FLOAT:109)
    INFO [qshell] Send cmd: 'icm42688p start -s'
    INFO [muorb] [uORB] Marking DeviceNode(qshell_req) as advertised in process_remote_topic
    INFO [muorb] [qshell] qshell gotten: icm42688p start -s
    INFO [muorb] [qshell] arg0 = 'icm42688p'
    INFO [muorb] [qshell] arg1 = 'start'
    INFO [muorb] [qshell] arg2 = '-s'
    INFO [muorb] [drivers__device] *** SPI Device ID 0x26000a 2490378
    INFO [uORB] Advertising remote topic sensor_accel
    INFO [uORB] Advertising remote topic sensor_gyro
    INFO [muorb] [icm42688p] ICM42688P::probe successful!
    INFO [muorb] [drivers__device] on SPI bus 1
    INFO [muorb] icm42688p #0 on SPI bus 1
    INFO [muorb]
    INFO [muorb] [icm42688p] >>> ICM42688P this: b2601168
    INFO [muorb] [qshell] Ok executing command: icm42688p start -s
    INFO [uORB] Advertising remote topic qshell_retval
    INFO [qshell] qshell return value timestamp: 399407608, local time: 399410543
    INFO [muorb] [drivers__device] Register interrupt b214ec48 e61ebf5c b2601168
    INFO [uORB] Advertising remote topic sensor_gyro_fifo
    INFO [uORB] Advertising remote topic sensor_accel_fifo
    INFO [qshell] Send cmd: 'icp101xx start -I -b 5'
    INFO [muorb] [qshell] qshell gotten: icp101xx start -I -b 5
    INFO [muorb] [qshell] arg0 = 'icp101xx'
    INFO [muorb] [qshell] arg2 = '-I'
    INFO [muorb] [qshell] arg3 = '-b'
    INFO [muorb] [qshell] arg4 = '5'
    INFO [uORB] Advertising remote topic imu_server
    INFO [muorb] [drivers__device] *** I2C Device ID 0xb76329 12018473
    INFO [muorb] [drivers__device] Set up I2C bus mutex for bus 5
    INFO [muorb] icp101xx #0 on I2C bus 5
    INFO [muorb] address 0x63
    INFO [muorb]
    INFO [muorb] [qshell] Ok executing command: icp101xx start -I -b 5
    INFO [qshell] qshell return value timestamp: 399439219, local time: 399440018
    INFO [qshell] Send cmd: 'temperature_compensation start'
    INFO [muorb] [qshell] qshell gotten: temperature_compensation start
    INFO [muorb] [qshell] arg0 = 'temperature_compensation'
    INFO [uORB] Advertising remote topic sensor_correction
    INFO [muorb] [qshell] Ok executing command: temperature_compensation start
    INFO [qshell] qshell return value timestamp: 399593065, local time: 399595876
    INFO [qshell] Send cmd: 'qmc5883l start -R 10 -X -b 1'
    INFO [muorb] [qshell] qshell gotten: qmc5883l start -R 10 -X -b 1
    INFO [muorb] [qshell] arg0 = 'qmc5883l'
    INFO [muorb] [qshell] arg2 = '-R'
    INFO [muorb] [qshell] arg3 = '10'
    INFO [muorb] [qshell] arg4 = '-X'
    INFO [muorb] [qshell] arg5 = '-b'
    INFO [muorb] [qshell] arg6 = '1'
    INFO [muorb] [drivers__device] *** I2C Device ID 0x80d09 527625
    INFO [muorb] [drivers__device] Set up I2C bus mutex for bus 1
    INFO [muorb] qmc5883l #0 on I2C bus 1
    INFO [muorb] (external)
    INFO [muorb] address 0xD
    INFO [muorb] rotation 10
    INFO [muorb]
    INFO [muorb] [qshell] Ok executing command: qmc5883l start -R 10 -X -b 1
    INFO [qshell] qshell return value timestamp: 399641432, local time: 399643756
    INFO [uORB] Advertising remote topic sensor_baro
    INFO [qshell] Send cmd: 'ist8310 start -R 10 -X -b 1'
    INFO [muorb] [qshell] qshell gotten: ist8310 start -R 10 -X -b 1
    INFO [muorb] [qshell] arg0 = 'ist8310'
    INFO [muorb] [drivers__device] *** I2C Device ID 0x60e09 396809
    ERROR [muorb] [drivers__device] i2c probe failed
    INFO [muorb] [SPI_I2C] PX4_qshell: no instance started (no device on bus?)
    ERROR [muorb] [qshell] Failed to execute command: ist8310 start -R 10 -X -b 1
    INFO [qshell] cmd returned with: -1
    INFO [qshell] qshell return value timestamp: 399679721, local time: 399683151
    ERROR [qshell] Command failed
    Looking for ist8308 magnetometer
    INFO [qshell] Send cmd: 'ist8308 start -R 12 -X -b 1'
    INFO [muorb] [qshell] qshell gotten: ist8308 start -R 12 -X -b 1
    INFO [muorb] [qshell] arg0 = 'ist8308'
    INFO [muorb] [qshell] arg3 = '12'
    INFO [muorb] [drivers__device] *** I2C Device ID 0xb0c09 723977
    ERROR [muorb] [qshell] Failed to execute command: ist8308 start -R 12 -X -b 1
    INFO [qshell] qshell return value timestamp: 399724506, local time: 399725746
    INFO [qshell] Send cmd: 'gps start'
    INFO [muorb] [qshell] qshell gotten: gps start
    INFO [muorb] [qshell] arg0 = 'gps'
    INFO [muorb] [tasks] Creating pthread gps
    INFO [muorb] [tasks] Successfully created px4 task PX4_gps with tid 2097647
    INFO [muorb] [qshell] Ok executing command: gps start
    INFO [qshell] qshell return value timestamp: 399763498, local time: 399764414
    Looking for ncp5623c RGB LED
    INFO [muorb] [gps] GPS UART baudrate set to 115200
    INFO [qshell] Send cmd: 'rgbled_ncp5623c start -X -b 1 -f 400 -a 56'
    INFO [muorb] [qshell] qshell gotten: rgbled_ncp5623c start -X -b 1 -f 400 -a 56
    INFO [muorb] [qshell] arg0 = 'rgbled_ncp5623c'
    INFO [muorb] [qshell] arg2 = '-X'
    INFO [muorb] [qshell] arg4 = '1'
    INFO [muorb] [qshell] arg5 = '-f'
    INFO [muorb] [qshell] arg6 = '400'
    INFO [muorb] [qshell] arg7 = '-a'
    INFO [muorb] [qshell] arg8 = '56'
    INFO [muorb] [drivers__device] *** I2C Device ID 0x7b3809 8075273
    INFO [muorb] [drivers__device] Set i2c address 0x38, fd 4
    ERROR [muorb] [qshell] Failed to execute command: rgbled_ncp5623c start -X -b 1 -f 400 -a 56
    INFO [qshell] qshell return value timestamp: 399803230, local time: 399805491
    Starting VOXL ESC driver
    INFO [uORB] Advertising remote topic sensor_mag
    INFO [qshell] Send cmd: 'voxl_esc start'
    INFO [muorb] [qshell] qshell gotten: voxl_esc start
    INFO [muorb] [qshell] arg0 = 'voxl_esc'
    INFO [uORB] Advertising remote topic actuator_outputs
    INFO [muorb] [voxl_esc] Starting VOXL ESC driver
    INFO [muorb] [voxl_esc] Params: VOXL_ESC_CONFIG: 1
    INFO [muorb] [voxl_esc] Params: VOXL_ESC_MODE: 0
    INFO [muorb] [voxl_esc] Params: VOXL_ESC_BAUD: 2000000
    INFO [muorb] [voxl_esc] Params: VOXL_ESC_FUNC1: 102
    INFO [muorb] [voxl_esc] Params: VOXL_ESC_FUNC2: 103
    INFO [muorb] [voxl_esc] Params: VOXL_ESC_FUNC3: 101
    INFO [muorb] [voxl_esc] Params: VOXL_ESC_FUNC4: 104
    INFO [muorb] [voxl_esc] Params: VOXL_ESC_SDIR1: 0
    INFO [muorb] [voxl_esc] Params: VOXL_ESC_SDIR2: 0
    INFO [muorb] [voxl_esc] Params: VOXL_ESC_SDIR3: 0
    INFO [muorb] [voxl_esc] Params: VOXL_ESC_SDIR4: 0
    INFO [muorb] [voxl_esc] Params: VOXL_ESC_RPM_MIN: 2000
    INFO [muorb] [voxl_esc] Params: VOXL_ESC_RPM_MAX: 12000
    INFO [muorb] [voxl_esc] Params: VOXL_ESC_T_PERC: 90
    INFO [muorb] [voxl_esc] Params: VOXL_ESC_T_DEAD: 20
    INFO [muorb] [voxl_esc] Params: VOXL_ESC_T_EXPO: 35
    INFO [muorb] [voxl_esc] Params: VOXL_ESC_T_MINF: 0.150000
    INFO [muorb] [voxl_esc] Params: VOXL_ESC_T_COSP: 0.990000
    INFO [muorb] [voxl_esc] Params: VOXL_ESC_VLOG: 1
    INFO [muorb] [voxl_esc] Params: VOXL_ESC_PUB_BST: 1
    INFO [muorb] [voxl_esc] Params: VOXL_ESC_T_WARN: 0
    INFO [muorb] [voxl_esc] Params: VOXL_ESC_T_OVER: 0
    INFO [muorb] [voxl_esc] Params: GPIO_CTL_CH: 0
    INFO [muorb] [qshell] Ok executing command: voxl_esc start
    INFO [muorb] [voxl_esc] Opening UART ESC device 2, baud rate 2000000
    INFO [muorb] [voxl_esc] Successfully opened UART ESC device
    INFO [muorb] [voxl_esc] Detecting ESCs...
    INFO [muorb] [voxl_esc] ESC ID : 0
    INFO [muorb] [voxl_esc] Board Type : 40: ModalAi 4-in-1 ESC (M0129-3)
    INFO [muorb] [voxl_esc] Unique ID : 0x2039333557555311000E001D
    INFO [qshell] qshell return value timestamp: 399982295, local time: 399985088
    INFO [muorb] [voxl_esc] Firmware : version 39, hash 9c6233d6
    INFO [muorb] [voxl_esc] Bootloader : version 184, hash 10bf24c8
    INFO [muorb] [voxl_esc] Reply time : 715us
    INFO [muorb] [voxl_esc] VOXL_ESC:
    INFO [muorb] [voxl_esc] ESC ID : 1
    INFO [muorb] [voxl_esc] Unique ID : 0x2039333557555311000E0018
    INFO [muorb] [voxl_esc] Reply time : 705us
    INFO [muorb] [voxl_esc] ESC ID : 2
    INFO [muorb] [voxl_esc] Unique ID : 0x2039333557555311000E001F
    INFO [muorb] [voxl_esc] Reply time : 105us
    INFO [muorb] [voxl_esc] ESC ID : 3
    INFO [muorb] [voxl_esc] Unique ID : 0x2039333557555311000E0020
    INFO [muorb] [voxl_esc] Reply time : 723us
    INFO [muorb] [voxl_esc] Use extened rpm packet : 1
    INFO [muorb] [voxl_esc] All ESCs successfully detected
    Starting GHST RC driver
    INFO [qshell] Send cmd: 'ghst_rc start -d 7'
    INFO [muorb] [qshell] qshell gotten: ghst_rc start -d 7
    INFO [muorb] [qshell] arg0 = 'ghst_rc'
    INFO [muorb] [qshell] arg2 = '-d'
    INFO [muorb] [qshell] arg3 = '7'
    INFO [muorb] [qshell] Ok executing command: ghst_rc start -d 7
    INFO [uORB] Advertising remote topic input_rc
    INFO [qshell] qshell return value timestamp: 400026444, local time: 400029741
    INFO [uORB] Advertising remote topic actuator_outputs_debug
    INFO [uORB] Advertising remote topic esc_status
    INFO [muorb] [qshell] qshell gotten: sensors start
    INFO [muorb] [qshell] arg0 = 'sensors'
    INFO [qshell] Send cmd: 'sensors start'
    INFO [uORB] Advertising remote topic sensor_selection
    INFO [uORB] Advertising remote topic sensors_status_imu
    INFO [uORB] Advertising remote topic vehicle_acceleration
    INFO [uORB] Advertising remote topic vehicle_angular_velocity
    INFO [uORB] Advertising remote topic sensor_combined
    INFO [uORB] Advertising remote topic vehicle_air_data
    INFO [uORB] Advertising remote topic vehicle_gps_position
    INFO [uORB] Advertising remote topic vehicle_magnetometer
    INFO [uORB] Advertising remote topic sensor_preflight_mag
    INFO [uORB] Advertising remote topic sensors_status_mag
    INFO [uORB] Advertising remote topic vehicle_imu
    INFO [uORB] Advertising remote topic vehicle_imu_status
    INFO [muorb] [qshell] Ok executing command: sensors start
    INFO [qshell] qshell return value timestamp: 400201636, local time: 400204844
    INFO [uORB] Advertising remote topic battery_status
    INFO [uORB] Advertising remote topic sensors_status_baro
    INFO [qshell] Send cmd: 'ekf2 start'
    INFO [muorb] [qshell] qshell gotten: ekf2 start
    INFO [muorb] [qshell] arg0 = 'ekf2'
    INFO [uORB] Advertising remote topic vehicle_attitude
    INFO [uORB] Advertising remote topic vehicle_local_position
    INFO [uORB] Advertising remote topic estimator_event_flags
    INFO [uORB] Advertising remote topic estimator_innovation_test_ratios
    INFO [uORB] Advertising remote topic estimator_innovation_variances
    INFO [uORB] Advertising remote topic estimator_innovations
    INFO [uORB] Advertising remote topic estimator_sensor_bias
    INFO [uORB] Advertising remote topic estimator_states
    INFO [uORB] Advertising remote topic estimator_status_flags
    INFO [muorb] [qshell] Ok executing command: ekf2 start
    INFO [uORB] Advertising remote topic ekf2_timestamps
    INFO [qshell] qshell return value timestamp: 400372199, local time: 400374149
    INFO [uORB] Advertising remote topic vehicle_odometry
    INFO [uORB] Advertising remote topic estimator_aid_src_baro_hgt
    INFO [uORB] Advertising remote topic estimator_aid_src_fake_pos
    INFO [uORB] Advertising remote topic estimator_aid_src_fake_hgt
    INFO [uORB] Advertising remote topic estimator_aid_src_mag_heading
    INFO [uORB] Advertising remote topic estimator_aid_src_gravity
    INFO [qshell] Send cmd: 'mc_pos_control start'
    INFO [muorb] [qshell] qshell gotten: mc_pos_control start
    INFO [muorb] [qshell] arg0 = 'mc_pos_control'
    INFO [uORB] Advertising remote topic takeoff_status
    INFO [muorb] [qshell] Ok executing command: mc_pos_control start
    INFO [qshell] qshell return value timestamp: 400439639, local time: 400441121
    INFO [qshell] Send cmd: 'mc_att_control start'
    INFO [muorb] [qshell] qshell gotten: mc_att_control start
    INFO [muorb] [qshell] arg0 = 'mc_att_control'
    INFO [muorb] [qshell] Ok executing command: mc_att_control start
    INFO [qshell] qshell return value timestamp: 400483669, local time: 400486499
    INFO [qshell] Send cmd: 'mc_rate_control start'
    INFO [muorb] [qshell] qshell gotten: mc_rate_control start
    INFO [muorb] [qshell] arg0 = 'mc_rate_control'
    INFO [uORB] Advertising remote topic rate_ctrl_status
    INFO [muorb] [qshell] Ok executing command: mc_rate_control start
    INFO [qshell] qshell return value timestamp: 400555835, local time: 400557571
    INFO [qshell] Send cmd: 'mc_hover_thrust_estimator start'
    INFO [muorb] [qshell] qshell gotten: mc_hover_thrust_estimator start
    INFO [muorb] [qshell] arg0 = 'mc_hover_thrust_estimator'
    INFO [muorb] [qshell] Ok executing command: mc_hover_thrust_estimator start
    INFO [qshell] qshell return value timestamp: 400607194, local time: 400608430
    INFO [qshell] Send cmd: 'mc_autotune_attitude_control start'
    INFO [muorb] [qshell] qshell gotten: mc_autotune_attitude_control start
    INFO [muorb] [qshell] arg0 = 'mc_autotune_attitude_control'
    INFO [uORB] Advertising remote topic autotune_attitude_control_status
    INFO [muorb] [qshell] Ok executing command: mc_autotune_attitude_control start
    INFO [qshell] qshell return value timestamp: 400652695, local time: 400654662
    INFO [qshell] Send cmd: 'land_detector start multicopter'
    INFO [muorb] [qshell] qshell gotten: land_detector start multicopter
    INFO [muorb] [qshell] arg0 = 'land_detector'
    INFO [muorb] [qshell] arg2 = 'multicopter'
    INFO [muorb] [qshell] Ok executing command: land_detector start multicopter
    INFO [uORB] Advertising remote topic vehicle_land_detected
    INFO [qshell] qshell return value timestamp: 400691706, local time: 400693863
    INFO [qshell] Send cmd: 'manual_control start'
    INFO [muorb] [qshell] qshell gotten: manual_control start
    INFO [muorb] [qshell] arg0 = 'manual_control'
    INFO [muorb] [qshell] Ok executing command: manual_control start
    INFO [qshell] qshell return value timestamp: 400729166, local time: 400730650
    INFO [uORB] Advertising remote topic manual_control_setpoint
    INFO [qshell] Send cmd: 'control_allocator start'
    INFO [muorb] [qshell] qshell gotten: control_allocator start
    INFO [muorb] [qshell] arg0 = 'control_allocator'
    INFO [uORB] Advertising remote topic control_allocator_status
    INFO [uORB] Marking DeviceNode(control_allocator_status) as advertised in process_remote_topic
    INFO [uORB] Advertising remote topic actuator_motors
    INFO [uORB] Advertising remote topic actuator_servos
    INFO [uORB] Advertising remote topic actuator_servos_trim
    INFO [muorb] [qshell] Ok executing command: control_allocator start
    INFO [qshell] qshell return value timestamp: 400901362, local time: 400903812
    INFO [qshell] Send cmd: 'load_mon start'
    INFO [muorb] [qshell] qshell gotten: load_mon start
    INFO [muorb] [qshell] arg0 = 'load_mon'
    INFO [muorb] [qshell] Ok executing command: load_mon start
    INFO [uORB] Advertising remote topic cpuload
    INFO [qshell] qshell return value timestamp: 400944602, local time: 400945574
    INFO [muorb] [qshell] qshell gotten: rc_update start
    INFO [muorb] [qshell] arg0 = 'rc_update'
    INFO [qshell] Send cmd: 'rc_update start'
    INFO [muorb] [qshell] Ok executing command: rc_update start
    INFO [qshell] qshell return value timestamp: 401113628, local time: 401115288
    INFO [uORB] Advertising remote topic rc_channels
    INFO [qshell] Send cmd: 'commander start'
    INFO [muorb] [qshell] qshell gotten: commander start
    INFO [muorb] [qshell] arg0 = 'commander'
    INFO [muorb] [tasks] Creating pthread commander
    INFO [muorb] [tasks] Successfully created px4 task PX4_commander with tid 2097641
    INFO [uORB] Advertising remote topic led_control
    INFO [muorb] [commander] LED: open /dev/led0 failed (22)
    INFO [uORB] Advertising remote topic tune_control
    INFO [muorb] [qshell] Ok executing command: commander start
    INFO [qshell] qshell return value timestamp: 401250309, local time: 401251149
    INFO [uORB] Advertising remote topic event
    INFO [uORB] Advertising remote topic health_report
    INFO [uORB] Advertising remote topic failsafe_flags
    INFO [uORB] Advertising remote topic actuator_armed
    INFO [uORB] Advertising remote topic vehicle_control_mode
    INFO [uORB] Advertising remote topic vehicle_status
    INFO [uORB] Advertising remote topic failure_detector_status
    INFO [uORB] Advertising remote topic vehicle_thrust_setpoint
    INFO [uORB] Advertising remote topic vehicle_torque_setpoint
    INFO [uORB] Advertising remote topic vehicle_attitude_setpoint
    INFO [uORB] Advertising remote topic vehicle_rates_setpoint
    INFO [qshell] Send cmd: 'flight_mode_manager start'
    INFO [muorb] [qshell] qshell gotten: flight_mode_manager start
    INFO [muorb] [qshell] arg0 = 'flight_mode_manager'
    INFO [uORB] Advertising remote topic vehicle_command
    INFO [muorb] [qshell] Ok executing command: flight_mode_manager start
    INFO [qshell] qshell return value timestamp: 401328584, local time: 401330285
    INFO [dataman] data manager file '/data/px4/dataman' size is 7866640 bytes
    INFO [muorb] [uORB] Advertising remote topic transponder_report
    INFO [muorb] [uORB] Advertising remote topic rtl_time_estimate
    INFO [muorb] [uORB] Advertising remote topic position_setpoint_triplet
    INFO [mavlink] mode: Onboard, data rate: 100000 B/s on udp port 14556 remote port 14557
    INFO [muorb] [uORB] Advertising remote topic telemetry_status
    INFO [mavlink] partner IP: 127.0.0.1
    INFO [muorb] [uORB] Advertising remote topic vehicle_visual_odometry
    INFO [muorb] [uORB] Advertising remote topic offboard_control_mode
    INFO [muorb] [uORB] Advertising remote topic obstacle_distance
    INFO [muorb] [uORB] Advertising remote topic distance_sensor
    INFO [muorb] [uORB] Advertising remote topic timesync_status
    INFO [uORB] Advertising remote topic estimator_aid_src_rng_hgt
    INFO [muorb] [uORB] Marking DeviceNode(vehicle_command_ack) as advertised in process_remote_topic
    INFO [uORB] Advertising remote topic actuator_controls_status_0
    INFO [mavlink] mode: Normal, data rate: 100000 B/s on udp port 14558 remote port 14559
    INFO [muorb] [uORB] Marking DeviceNode(telemetry_status) as advertised in process_remote_topic
    INFO [mavlink] MAVLink only on localhost (set param MAV_{i}_BROADCAST = 1 to enable network)
    INFO [px4] Startup script returned successfully
    INFO [logger] logger started (mode=all)
    INFO [muorb] [gps] GPS UART baudrate set to 9600
    INFO [muorb] [ekf2] resetQuatStateYaw called: -0.081279 (0.000000)
    ERROR [muorb] [ekf2] ====> GLOBAL R to Earth: -4.657814 (42)
    INFO [uORB] Advertising remote topic estimator_aid_src_ev_hgt
    INFO [uORB] Advertising remote topic estimator_aid_src_ev_pos
    INFO [uORB] Advertising remote topic estimator_aid_src_ev_vel
    INFO [uORB] Advertising remote topic estimator_aid_src_ev_yaw
    INFO [muorb] [ekf2] resetQuatStateYaw called: -0.081279 (0.100000)
    INFO [uORB] Advertising remote topic estimator_baro_bias
    INFO [uORB] Advertising remote topic home_position
    INFO [muorb] [gps] GPS UART baudrate set to 38400
    INFO [muorb] [gps] GPS UART baudrate set to 57600
    INFO [muorb] [gps] GPS UART baudrate set to 230400
    INFO [muorb] [gps] GPS UART baudrate set to 460800
    INFO [muorb] [gps] GPS UART baudrate set to 921600
    ^CERROR [muorb] Sending kill command to SLPI!!!
    Sending kill slpi command!
    INFO [uORB] Advertising remote topic mavlink_log
    ERROR [muorb] [sensors] Accel #0 fail: TIMEOUT!
    PX4 Exiting in sig_int_handler
    Exiting in shutdown_main
    starling2-max (D0012):/$**
    • R roy.crosthwaite
      hw platform: M0054
      mach.var: 1.0.1
      voxl-suite: 1.5.0
      hw platform: M0054
      mach.var: 1.0.1
      voxl-suite: 1.5.0
      GPS=AUTODETECT
      RC=GHST
      ESC=VOXL_ESC
      POWER MANAGER=NONE
      OSD=DISABLE
      DAEMON_MODE=ENABLE
      SENSOR_CAL=ACTUAL
      EXTRA STEPS:
      | ___ \ \ \ / / / |
      | |/ / \ V / / /| |
      | __/ / \ / /
      | | / /^\ \ ___ |
      _| / / |_/
      px4 starting.
      GPS: AUTODETECT
      RC: GHST
      ESC: VOXL_ESC
      POWER MANAGER: NONE
      OSD: DISABLE
      EXTRA STEPS:
      Running on M0054
      INFO [muorb]
      INFO [muorb]
      INFO [muorb]
      Eric KatzfeyE Online
      @roy-crosthwaite Can you swap GPS units with the working one and verify that it fixes the issue?
      R 3 Replies Last reply
        R Offline
        R Offline
        roy.crosthwaite
        @Eric-Katzfey I would if I could. The 2nd unit went home with one of our guys 4 hours away (flying that is). I am having him ship it to me so I can swap it. In the mean time, I wanted to see if there is a work-around for the interference problem. I did see some creative ideas to mitigate the interference at least partially in one of the posts... Also, are cables with a connector on one end and flying leads available for the GPS modules? It would be nice to be able to pull the receiver off and test with the UBLOX software.
        Thanks.
          R Offline
          R Offline
          roy.crosthwaite
          @Eric-Katzfey never mind about the cable, I found them on Amazon...
            R Offline
            R Offline
            roy.crosthwaite
            @Eric-Katzfey Hello Eric, I was finally able to swap out the GPS for a known good unit and the one in question is definitely dead. I presume this can be returned on an RMA. The drone was purchased on Order Number 6839. Let me know the next steps.
            Thanks.
            • R roy.crosthwaite
              Thanks.
              @roy-crosthwaite see here: https://www.modalai.com/pages/rma
