    GPS not connecting
    Starling & Starling 2
    • R
      roy.crosthwaite
      Hello ModalAI Support,
      We recently purchased qty 2 Starling 2 Max with the 5G add-on modem. Both units initially were working but one now has an apparent GPS module failure as I cannot connect to it. Also, after reading through several posts, it appears that we're not the only ones having this problem.
      As for the configuration of our units, here's what we have:
      system-image: 1.8.04-M0054-14.1a-perf
      kernel: #1 SMP PREEMPT Mon Mar 24 22:31:58 UTC 2025 4.19.125
      hw platform: M0054
      mach.var: 1.0.1
      SKU: MRB-D0012-4-V2-C29-T9-M24-X0
      voxl-suite: 1.5.0
      I read through and performed all the suggested troubleshooting steps that I found in several previous posts for GPS problems. The most revealing test is when I disable voxl-px4 from loading at startup and started it manually. There are a few errors thrown as it executes but when it tried to connect to the GPS it goes into an infinite loop trying all defined GPS UART baudrates and never connects. All cables and connectors have been checked and everything looks good physically. I also checked the power going into the GPS module and it is at the required 5VDC. I noticed a couple of things on the circuit side of the GPS board - a 3.3VDC test point and what appears to be a button cell soldered to the board. The voltage at the test point measured 2.57 VDC and with the power off I measured .25 volts on the assumed button cell. Of course, I go out to the 3DR website to track down information only to discover that the "Documentation is coming soon". 2.57VDC is definitely too low for something requiring 3.3VDC to operate.
      Before we bought these, we were told that there was an interference issue with the 5G modems and the GPS. I read through post https://forum.modalai.com/topic/4226/starling-2-max-no-gps-data?_=1756238568725 and gather that this problem might be an underlying issue with the VOXL 2 (and other boards plugged into it). Has any progress been made on this?
      Anyway, with all that said, it appears that the GPS is DOA. Below is the output from the voxl-px4 script when I run it manually.
      I appreciate any help you can give.
      hw platform: M0054
      mach.var: 1.0.1
      voxl-suite: 1.5.0
      current IP: wlan0: 192.168.8.1
      starling2-max (D0012):/$ voxl-px4
      Found DSP signature file
      [INFO] Daemon mode enabled
      AIRFRAME=MULTICOPTER
      GPS=AUTODETECT
      RC=GHST
      ESC=VOXL_ESC
      POWER MANAGER=NONE
      AIRSPEED SENSOR=NONE
      DISTANCE SENSOR=NONE
      OSD=DISABLE
      DAEMON_MODE=ENABLE
      SENSOR_CAL=ACTUAL
      ARTIFACT_MODE=DISABLE
      EXTRA STEPS:
      INFO [px4] mlockall() enabled. PX4's virtual address space is locked into RAM.
      INFO [px4] assuming working directory is rootfs, no symlinks needed.
      INFO [muorb] Got muorb init command
      INFO [muorb] [modules__muorb__slpi] muorb aggregator thread running
      INFO [muorb] muorb protobuf initalize method succeeded
      INFO [muorb] succesfully did ADVERTISE_TEST_TYPE
      INFO [muorb] [tasks] Creating pthread test_MUORB
      INFO [muorb] [tasks] Successfully created px4 task PX4_test_MUORB with tid 2097656
      INFO [muorb] succesfully did SUBSCRIBE_TEST_TYPE
      INFO [muorb] [tasks] Successfully created px4 task PX4_test_MUORB with tid 2097655
      INFO [muorb] succesfully did TOPIC_TEST_TYPE
      INFO [muorb] [tasks] Successfully created px4 task PX4_test_MUORB with tid 2097654
      INFO [muorb] succesfully did UNSUBSCRIBE_TEST_TYPE
      INFO [muorb] [tasks] Successfully created px4 task PX4_test_MUORB with tid 2097653
      INFO [muorb] muorb test passed
      | ___ \ \ \ / / / |
      | |/ / \ V / / /| |
      | __/ / \ / /
      | | / /^\ \ ___ |
      _| / / |_/
      px4 starting.
      INFO [muorb] [uORB] Advertising remote topic log_message
      INFO [px4] startup script: /bin/sh /usr/bin/voxl-px4-start 0
      INFO [parameters] Starting param sync THREAD
      AIRFRAME: MULTICOPTER
      GPS: AUTODETECT
      RC: GHST
      ESC: VOXL_ESC
      POWER MANAGER: NONE
      AIRSPEED SENSOR: NONE
      DISTANCE SENSOR: NONE
      OSD: DISABLE
      ARTIFACT_MODE: DISABLE
      EXTRA STEPS:
      Running on M0054
      INFO [muorb] [parameters] Starting param sync THREAD
      INFO [muorb] [qshell] before starting the qshell_entry task
      INFO [muorb] [tasks] Creating pthread qshell
      INFO [muorb] [qshell] qshell entry.....
      INFO [muorb] [tasks] Successfully created px4 task PX4_qshell with tid 2097652
      INFO [muorb] [qshell] Init app map initialized
      INFO [muorb] [qshell] after starting the qshell_entry task
      INFO [param] selected parameter default file /data/px4/param/parameters
      INFO [muorb] [uORB] Marking DeviceNode(parameter_client_reset_request) as advertised in process_remote_topic
      INFO [uORB] Marking DeviceNode(parameter_client_reset_response) as advertised in process_remote_topic
      INFO [muorb] [uORB] Advertising remote topic parameter_update
      INFO [muorb] [uORB] Marking DeviceNode(parameter_client_set_value_request) as advertised in process_remote_t
      INFO [uORB] Marking DeviceNode(parameter_server_set_used_request) as advertised in process_remote_topic
      INFO [muorb] [uORB] Marking DeviceNode(parameter_server_set_used_response) as advertised in process_remote_t
      INFO [uORB] Marking DeviceNode(parameter_client_set_value_response) as advertised in process_remote_topic
      INFO [parameters] BSON document size 3367 bytes, decoded 3367 bytes (INT32:47, FLOAT:109)
      INFO [qshell] Send cmd: 'icm42688p start -s'
      INFO [muorb] [uORB] Marking DeviceNode(qshell_req) as advertised in process_remote_topic
      INFO [muorb] [qshell] qshell gotten: icm42688p start -s
      INFO [muorb] [qshell] arg0 = 'icm42688p'
      INFO [muorb] [qshell] arg1 = 'start'
      INFO [muorb] [qshell] arg2 = '-s'
      INFO [muorb] [drivers__device] *** SPI Device ID 0x26000a 2490378
      INFO [uORB] Advertising remote topic sensor_accel
      INFO [uORB] Advertising remote topic sensor_gyro
      INFO [muorb] [icm42688p] ICM42688P::probe successful!
      INFO [muorb] [drivers__device] on SPI bus 1
      INFO [muorb] icm42688p #0 on SPI bus 1
      INFO [muorb]
      INFO [muorb] [icm42688p] >>> ICM42688P this: b2601168
      INFO [muorb] [qshell] Ok executing command: icm42688p start -s
      INFO [uORB] Advertising remote topic qshell_retval
      INFO [qshell] qshell return value timestamp: 399407608, local time: 399410543
      INFO [muorb] [drivers__device] Register interrupt b214ec48 e61ebf5c b2601168
      INFO [uORB] Advertising remote topic sensor_gyro_fifo
      INFO [uORB] Advertising remote topic sensor_accel_fifo
      INFO [qshell] Send cmd: 'icp101xx start -I -b 5'
      INFO [muorb] [qshell] qshell gotten: icp101xx start -I -b 5
      INFO [muorb] [qshell] arg0 = 'icp101xx'
      INFO [muorb] [qshell] arg2 = '-I'
      INFO [muorb] [qshell] arg3 = '-b'
      INFO [muorb] [qshell] arg4 = '5'
      INFO [uORB] Advertising remote topic imu_server
      INFO [muorb] [drivers__device] *** I2C Device ID 0xb76329 12018473
      INFO [muorb] [drivers__device] Set up I2C bus mutex for bus 5
      INFO [muorb] icp101xx #0 on I2C bus 5
      INFO [muorb] address 0x63
      INFO [muorb]
      INFO [muorb] [qshell] Ok executing command: icp101xx start -I -b 5
      INFO [qshell] qshell return value timestamp: 399439219, local time: 399440018
      INFO [qshell] Send cmd: 'temperature_compensation start'
      INFO [muorb] [qshell] qshell gotten: temperature_compensation start
      INFO [muorb] [qshell] arg0 = 'temperature_compensation'
      INFO [uORB] Advertising remote topic sensor_correction
      INFO [muorb] [qshell] Ok executing command: temperature_compensation start
      INFO [qshell] qshell return value timestamp: 399593065, local time: 399595876
      INFO [qshell] Send cmd: 'qmc5883l start -R 10 -X -b 1'
      INFO [muorb] [qshell] qshell gotten: qmc5883l start -R 10 -X -b 1
      INFO [muorb] [qshell] arg0 = 'qmc5883l'
      INFO [muorb] [qshell] arg2 = '-R'
      INFO [muorb] [qshell] arg3 = '10'
      INFO [muorb] [qshell] arg4 = '-X'
      INFO [muorb] [qshell] arg5 = '-b'
      INFO [muorb] [qshell] arg6 = '1'
      INFO [muorb] [drivers__device] *** I2C Device ID 0x80d09 527625
      INFO [muorb] [drivers__device] Set up I2C bus mutex for bus 1
      INFO [muorb] qmc5883l #0 on I2C bus 1
      INFO [muorb] (external)
      INFO [muorb] address 0xD
      INFO [muorb] rotation 10
      INFO [muorb]
      INFO [muorb] [qshell] Ok executing command: qmc5883l start -R 10 -X -b 1
      INFO [qshell] qshell return value timestamp: 399641432, local time: 399643756
      INFO [uORB] Advertising remote topic sensor_baro
      INFO [muorb] [qshell] qshell gotten: ist8310 start -R 10 -X -b 1
      INFO [muorb] [qshell] arg0 = 'ist8310'
      INFO [muorb] [drivers__device] *** I2C Device ID 0x60e09 396809
      ERROR [muorb] [drivers__device] i2c probe failed
      INFO [muorb] [SPI_I2C] PX4_qshell: no instance started (no device on bus?)
      ERROR [muorb] [qshell] Failed to execute command: ist8310 start -R 10 -X -b 1
      INFO [qshell] cmd returned with: -1
      INFO [qshell] qshell return value timestamp: 399679721, local time: 399683151
      ERROR [qshell] Command failed
      Looking for ist8308 magnetometer
      INFO [qshell] Send cmd: 'ist8308 start -R 12 -X -b 1'
      INFO [muorb] [qshell] qshell gotten: ist8308 start -R 12 -X -b 1
      INFO [muorb] [qshell] arg0 = 'ist8308'
      INFO [muorb] [qshell] arg3 = '12'
      INFO [muorb] [drivers__device] *** I2C Device ID 0xb0c09 723977
      ERROR [muorb] [qshell] Failed to execute command: ist8308 start -R 12 -X -b 1
      INFO [qshell] qshell return value timestamp: 399724506, local time: 399725746
      INFO [qshell] Send cmd: 'gps start'
      INFO [muorb] [qshell] qshell gotten: gps start
      INFO [muorb] [qshell] arg0 = 'gps'
      INFO [muorb] [tasks] Creating pthread gps
      INFO [muorb] [tasks] Successfully created px4 task PX4_gps with tid 2097647
      INFO [muorb] [qshell] Ok executing command: gps start
      INFO [qshell] qshell return value timestamp: 399763498, local time: 399764414
      Looking for ncp5623c RGB LED
      INFO [muorb] [gps] GPS UART baudrate set to 115200
      INFO [qshell] Send cmd: 'rgbled_ncp5623c start -X -b 1 -f 400 -a 56'
      INFO [muorb] [qshell] qshell gotten: rgbled_ncp5623c start -X -b 1 -f 400 -a 56
      INFO [muorb] [qshell] arg0 = 'rgbled_ncp5623c'
      INFO [muorb] [qshell] arg2 = '-X'
      INFO [muorb] [qshell] arg4 = '1'
      INFO [muorb] [qshell] arg5 = '-f'
      INFO [muorb] [qshell] arg6 = '400'
      INFO [muorb] [qshell] arg7 = '-a'
      INFO [muorb] [qshell] arg8 = '56'
      INFO [muorb] [drivers__device] *** I2C Device ID 0x7b3809 8075273
      INFO [muorb] [drivers__device] Set i2c address 0x38, fd 4
      ERROR [muorb] [qshell] Failed to execute command: rgbled_ncp5623c start -X -b 1 -f 400 -a 56
      INFO [qshell] qshell return value timestamp: 399803230, local time: 399805491
      Starting VOXL ESC driver
      INFO [uORB] Advertising remote topic sensor_mag
      INFO [qshell] Send cmd: 'voxl_esc start'
      INFO [muorb] [qshell] qshell gotten: voxl_esc start
      INFO [muorb] [qshell] arg0 = 'voxl_esc'
      INFO [uORB] Advertising remote topic actuator_outputs
      INFO [muorb] [voxl_esc] Starting VOXL ESC driver
      INFO [muorb] [voxl_esc] Params: VOXL_ESC_CONFIG: 1
      INFO [muorb] [voxl_esc] Params: VOXL_ESC_MODE: 0
      INFO [muorb] [voxl_esc] Params: VOXL_ESC_BAUD: 2000000
      INFO [muorb] [voxl_esc] Params: VOXL_ESC_FUNC1: 102
      INFO [muorb] [voxl_esc] Params: VOXL_ESC_FUNC2: 103
      INFO [muorb] [voxl_esc] Params: VOXL_ESC_FUNC3: 101
      INFO [muorb] [voxl_esc] Params: VOXL_ESC_FUNC4: 104
      INFO [muorb] [voxl_esc] Params: VOXL_ESC_SDIR1: 0
      INFO [muorb] [voxl_esc] Params: VOXL_ESC_SDIR2: 0
      INFO [muorb] [voxl_esc] Params: VOXL_ESC_SDIR3: 0
      INFO [muorb] [voxl_esc] Params: VOXL_ESC_SDIR4: 0
      INFO [muorb] [voxl_esc] Params: VOXL_ESC_RPM_MIN: 2000
      INFO [muorb] [voxl_esc] Params: VOXL_ESC_RPM_MAX: 12000
      INFO [muorb] [voxl_esc] Params: VOXL_ESC_T_PERC: 90
      INFO [muorb] [voxl_esc] Params: VOXL_ESC_T_DEAD: 20
      INFO [muorb] [voxl_esc] Params: VOXL_ESC_T_EXPO: 35
      INFO [muorb] [voxl_esc] Params: VOXL_ESC_T_MINF: 0.150000
      INFO [muorb] [voxl_esc] Params: VOXL_ESC_T_COSP: 0.990000
      INFO [muorb] [voxl_esc] Params: VOXL_ESC_VLOG: 1
      INFO [muorb] [voxl_esc] Params: VOXL_ESC_PUB_BST: 1
      INFO [muorb] [voxl_esc] Params: VOXL_ESC_T_WARN: 0
      INFO [muorb] [voxl_esc] Params: VOXL_ESC_T_OVER: 0
      INFO [muorb] [voxl_esc] Params: GPIO_CTL_CH: 0
      INFO [muorb] [qshell] Ok executing command: voxl_esc start
      INFO [muorb] [voxl_esc] Opening UART ESC device 2, baud rate 2000000
      INFO [muorb] [voxl_esc] Successfully opened UART ESC device
      INFO [muorb] [voxl_esc] Detecting ESCs...
      INFO [muorb] [voxl_esc] ESC ID : 0
      INFO [muorb] [voxl_esc] Board Type : 40: ModalAi 4-in-1 ESC (M0129-3)
      INFO [muorb] [voxl_esc] Unique ID : 0x2039333557555311000E001D
      INFO [qshell] qshell return value timestamp: 399982295, local time: 399985088
      INFO [muorb] [voxl_esc] Firmware : version 39, hash 9c6233d6
      INFO [muorb] [voxl_esc] Bootloader : version 184, hash 10bf24c8
      INFO [muorb] [voxl_esc] Reply time : 715us
      INFO [muorb] [voxl_esc] VOXL_ESC:
      INFO [muorb] [voxl_esc] ESC ID : 1
      INFO [muorb] [voxl_esc] Unique ID : 0x2039333557555311000E0018
      INFO [muorb] [voxl_esc] Reply time : 705us
      INFO [muorb] [voxl_esc] ESC ID : 2
      INFO [muorb] [voxl_esc] Unique ID : 0x2039333557555311000E001F
      INFO [muorb] [voxl_esc] Reply time : 105us
      INFO [muorb] [voxl_esc] ESC ID : 3
      INFO [muorb] [voxl_esc] Unique ID : 0x2039333557555311000E0020
      INFO [muorb] [voxl_esc] Reply time : 723us
      INFO [muorb] [voxl_esc] Use extened rpm packet : 1
      INFO [muorb] [voxl_esc] All ESCs successfully detected
      Starting GHST RC driver
      INFO [qshell] Send cmd: 'ghst_rc start -d 7'
      INFO [muorb] [qshell] qshell gotten: ghst_rc start -d 7
      INFO [muorb] [qshell] arg0 = 'ghst_rc'
      INFO [muorb] [qshell] arg2 = '-d'
      INFO [muorb] [qshell] arg3 = '7'
      INFO [muorb] [qshell] Ok executing command: ghst_rc start -d 7
      INFO [uORB] Advertising remote topic input_rc
      INFO [qshell] qshell return value timestamp: 400026444, local time: 400029741
      INFO [uORB] Advertising remote topic actuator_outputs_debug
      INFO [uORB] Advertising remote topic esc_status
      INFO [muorb] [qshell] qshell gotten: sensors start
      INFO [muorb] [qshell] arg0 = 'sensors'
      INFO [qshell] Send cmd: 'sensors start'
      INFO [uORB] Advertising remote topic sensor_selection
      INFO [uORB] Advertising remote topic sensors_status_imu
      INFO [uORB] Advertising remote topic vehicle_acceleration
      INFO [uORB] Advertising remote topic vehicle_angular_velocity
      INFO [uORB] Advertising remote topic sensor_combined
      INFO [uORB] Advertising remote topic vehicle_air_data
      INFO [uORB] Advertising remote topic vehicle_gps_position
      INFO [uORB] Advertising remote topic vehicle_magnetometer
      INFO [uORB] Advertising remote topic sensor_preflight_mag
      INFO [uORB] Advertising remote topic sensors_status_mag
      INFO [uORB] Advertising remote topic vehicle_imu
      INFO [uORB] Advertising remote topic vehicle_imu_status
      INFO [muorb] [qshell] Ok executing command: sensors start
      INFO [qshell] qshell return value timestamp: 400201636, local time: 400204844
      INFO [uORB] Advertising remote topic battery_status
      INFO [uORB] Advertising remote topic sensors_status_baro
      INFO [qshell] Send cmd: 'ekf2 start'
      INFO [muorb] [qshell] qshell gotten: ekf2 start
      INFO [muorb] [qshell] arg0 = 'ekf2'
      INFO [uORB] Advertising remote topic vehicle_attitude
      INFO [uORB] Advertising remote topic vehicle_local_position
      INFO [uORB] Advertising remote topic estimator_event_flags
      INFO [uORB] Advertising remote topic estimator_innovation_test_ratios
      INFO [uORB] Advertising remote topic estimator_innovation_variances
      INFO [uORB] Advertising remote topic estimator_innovations
      INFO [uORB] Advertising remote topic estimator_sensor_bias
      INFO [uORB] Advertising remote topic estimator_states
      INFO [uORB] Advertising remote topic estimator_status_flags
      INFO [muorb] [qshell] Ok executing command: ekf2 start
      INFO [uORB] Advertising remote topic ekf2_timestamps
      INFO [qshell] qshell return value timestamp: 400372199, local time: 400374149
      INFO [uORB] Advertising remote topic vehicle_odometry
      INFO [uORB] Advertising remote topic estimator_aid_src_baro_hgt
      INFO [uORB] Advertising remote topic estimator_aid_src_fake_pos
      INFO [uORB] Advertising remote topic estimator_aid_src_fake_hgt
      INFO [uORB] Advertising remote topic estimator_aid_src_mag_heading
      INFO [uORB] Advertising remote topic estimator_aid_src_gravity
      INFO [qshell] Send cmd: 'mc_pos_control start'
      INFO [muorb] [qshell] qshell gotten: mc_pos_control start
      INFO [muorb] [qshell] arg0 = 'mc_pos_control'
      INFO [uORB] Advertising remote topic takeoff_status
      INFO [muorb] [qshell] Ok executing command: mc_pos_control start
      INFO [qshell] qshell return value timestamp: 400439639, local time: 400441121
      INFO [qshell] Send cmd: 'mc_att_control start'
      INFO [muorb] [qshell] qshell gotten: mc_att_control start
      INFO [muorb] [qshell] arg0 = 'mc_att_control'
      INFO [muorb] [qshell] Ok executing command: mc_att_control start
      INFO [qshell] qshell return value timestamp: 400483669, local time: 400486499
      INFO [qshell] Send cmd: 'mc_rate_control start'
      INFO [muorb] [qshell] qshell gotten: mc_rate_control start
      INFO [muorb] [qshell] arg0 = 'mc_rate_control'
      INFO [uORB] Advertising remote topic rate_ctrl_status
      INFO [muorb] [qshell] Ok executing command: mc_rate_control start
      INFO [qshell] qshell return value timestamp: 400555835, local time: 400557571
      INFO [qshell] Send cmd: 'mc_hover_thrust_estimator start'
      INFO [muorb] [qshell] qshell gotten: mc_hover_thrust_estimator start
      INFO [muorb] [qshell] arg0 = 'mc_hover_thrust_estimator'
      INFO [muorb] [qshell] Ok executing command: mc_hover_thrust_estimator start
      INFO [qshell] qshell return value timestamp: 400607194, local time: 400608430
      INFO [qshell] Send cmd: 'mc_autotune_attitude_control start'
      INFO [muorb] [qshell] qshell gotten: mc_autotune_attitude_control start
      INFO [muorb] [qshell] arg0 = 'mc_autotune_attitude_control'
      INFO [uORB] Advertising remote topic autotune_attitude_control_status
      INFO [muorb] [qshell] Ok executing command: mc_autotune_attitude_control start
      INFO [qshell] qshell return value timestamp: 400652695, local time: 400654662
      INFO [qshell] Send cmd: 'land_detector start multicopter'
      INFO [muorb] [qshell] qshell gotten: land_detector start multicopter
      INFO [muorb] [qshell] arg0 = 'land_detector'
      INFO [muorb] [qshell] arg2 = 'multicopter'
      INFO [muorb] [qshell] Ok executing command: land_detector start multicopter
      INFO [uORB] Advertising remote topic vehicle_land_detected
      INFO [qshell] qshell return value timestamp: 400691706, local time: 400693863
      INFO [qshell] Send cmd: 'manual_control start'
      INFO [muorb] [qshell] qshell gotten: manual_control start
      INFO [muorb] [qshell] arg0 = 'manual_control'
      INFO [muorb] [qshell] Ok executing command: manual_control start
      INFO [qshell] qshell return value timestamp: 400729166, local time: 400730650
      INFO [uORB] Advertising remote topic manual_control_setpoint
      INFO [qshell] Send cmd: 'control_allocator start'
      INFO [muorb] [qshell] qshell gotten: control_allocator start
      INFO [muorb] [qshell] arg0 = 'control_allocator'
      INFO [uORB] Advertising remote topic control_allocator_status
      INFO [uORB] Marking DeviceNode(control_allocator_status) as advertised in process_remote_topic
      INFO [uORB] Advertising remote topic actuator_motors
      INFO [uORB] Advertising remote topic actuator_servos
      INFO [uORB] Advertising remote topic actuator_servos_trim
      INFO [muorb] [qshell] Ok executing command: control_allocator start
      INFO [qshell] qshell return value timestamp: 400901362, local time: 400903812
      INFO [qshell] Send cmd: 'load_mon start'
      INFO [muorb] [qshell] qshell gotten: load_mon start
      INFO [muorb] [qshell] arg0 = 'load_mon'
      INFO [muorb] [qshell] Ok executing command: load_mon start
      INFO [uORB] Advertising remote topic cpuload
      INFO [qshell] qshell return value timestamp: 400944602, local time: 400945574
      INFO [muorb] [qshell] qshell gotten: rc_update start
      INFO [muorb] [qshell] arg0 = 'rc_update'
      INFO [qshell] Send cmd: 'rc_update start'
      INFO [muorb] [qshell] Ok executing command: rc_update start
      INFO [qshell] qshell return value timestamp: 401113628, local time: 401115288
      INFO [uORB] Advertising remote topic rc_channels
      INFO [qshell] Send cmd: 'commander start'
      INFO [muorb] [qshell] qshell gotten: commander start
      INFO [muorb] [qshell] arg0 = 'commander'
      INFO [muorb] [tasks] Creating pthread commander
      INFO [muorb] [tasks] Successfully created px4 task PX4_commander with tid 2097641
      INFO [uORB] Advertising remote topic led_control
      INFO [muorb] [commander] LED: open /dev/led0 failed (22)
      INFO [uORB] Advertising remote topic tune_control
      INFO [muorb] [qshell] Ok executing command: commander start
      INFO [qshell] qshell return value timestamp: 401250309, local time: 401251149
      INFO [uORB] Advertising remote topic event
      INFO [uORB] Advertising remote topic health_report
      INFO [uORB] Advertising remote topic failsafe_flags
      INFO [uORB] Advertising remote topic actuator_armed
      INFO [uORB] Advertising remote topic vehicle_control_mode
      INFO [uORB] Advertising remote topic vehicle_status
      INFO [uORB] Advertising remote topic failure_detector_status
      INFO [uORB] Advertising remote topic vehicle_thrust_setpoint
      INFO [uORB] Advertising remote topic vehicle_torque_setpoint
      INFO [uORB] Advertising remote topic vehicle_attitude_setpoint
      INFO [uORB] Advertising remote topic vehicle_rates_setpoint
      INFO [qshell] Send cmd: 'flight_mode_manager start'
      INFO [muorb] [qshell] qshell gotten: flight_mode_manager start
      INFO [muorb] [qshell] arg0 = 'flight_mode_manager'
      INFO [uORB] Advertising remote topic vehicle_command
      INFO [muorb] [qshell] Ok executing command: flight_mode_manager start
      INFO [qshell] qshell return value timestamp: 401328584, local time: 401330285
      INFO [dataman] data manager file '/data/px4/dataman' size is 7866640 bytes
      INFO [muorb] [uORB] Advertising remote topic transponder_report
      INFO [muorb] [uORB] Advertising remote topic rtl_time_estimate
      INFO [muorb] [uORB] Advertising remote topic position_setpoint_triplet
      INFO [mavlink] mode: Onboard, data rate: 100000 B/s on udp port 14556 remote port 14557
      INFO [muorb] [uORB] Advertising remote topic telemetry_status
      INFO [mavlink] partner IP: 127.0.0.1
      INFO [muorb] [uORB] Advertising remote topic vehicle_visual_odometry
      INFO [muorb] [uORB] Advertising remote topic offboard_control_mode
      INFO [muorb] [uORB] Advertising remote topic obstacle_distance
      INFO [muorb] [uORB] Advertising remote topic distance_sensor
      INFO [muorb] [uORB] Advertising remote topic timesync_status
      INFO [uORB] Advertising remote topic estimator_aid_src_rng_hgt
      INFO [muorb] [uORB] Marking DeviceNode(vehicle_command_ack) as advertised in process_remote_topic
      INFO [uORB] Advertising remote topic actuator_controls_status_0
      INFO [mavlink] mode: Normal, data rate: 100000 B/s on udp port 14558 remote port 14559
      INFO [muorb] [uORB] Marking DeviceNode(telemetry_status) as advertised in process_remote_topic
      INFO [mavlink] MAVLink only on localhost (set param MAV_{i}_BROADCAST = 1 to enable network)
      INFO [px4] Startup script returned successfully
      INFO [logger] logger started (mode=all)
      INFO [muorb] [gps] GPS UART baudrate set to 9600
      INFO [muorb] [ekf2] resetQuatStateYaw called: -0.081279 (0.000000)
      ERROR [muorb] [ekf2] ====> GLOBAL R to Earth: -4.657814 (42)
      INFO [uORB] Advertising remote topic estimator_aid_src_ev_hgt
      INFO [uORB] Advertising remote topic estimator_aid_src_ev_pos
      INFO [uORB] Advertising remote topic estimator_aid_src_ev_vel
      INFO [uORB] Advertising remote topic estimator_aid_src_ev_yaw
      INFO [muorb] [ekf2] resetQuatStateYaw called: -0.081279 (0.100000)
      INFO [uORB] Advertising remote topic estimator_baro_bias
      INFO [uORB] Advertising remote topic home_position
      INFO [muorb] [gps] GPS UART baudrate set to 38400
      INFO [muorb] [gps] GPS UART baudrate set to 57600
      INFO [muorb] [gps] GPS UART baudrate set to 230400
      INFO [muorb] [gps] GPS UART baudrate set to 460800
      INFO [muorb] [gps] GPS UART baudrate set to 921600
      ^CERROR [muorb] Sending kill command to SLPI!!!
      Sending kill slpi command!
      INFO [uORB] Advertising remote topic mavlink_log
      ERROR [muorb] [sensors] Accel #0 fail: TIMEOUT!
      PX4 Exiting in sig_int_handler
      Exiting in shutdown_main
      starling2-max (D0012):/$**
        Eric Katzfey ModalAI Team @roy.crosthwaite
        @roy-crosthwaite Can you swap GPS units with the working one and verify that it fixes the issue?
        R 3 Replies Last reply Reply Quote 0
        • R
          roy.crosthwaite @Eric Katzfey
          @Eric-Katzfey I would if I could. The 2nd unit went home with one of our guys 4 hours away (flying that is). I am having him ship it to me so I can swap it. In the mean time, I wanted to see if there is a work-around for the interference problem. I did see some creative ideas to mitigate the interference at least partially in one of the posts... Also, are cables with a connector on one end and flying leads available for the GPS modules? It would be nice to be able to pull the receiver off and test with the UBLOX software.
          Thanks.
          • R
            @Eric-Katzfey never mind about the cable, I found them on Amazon...
            • R
              @Eric-Katzfey Hello Eric, I was finally able to swap out the GPS for a known good unit and the one in question is definitely dead. I presume this can be returned on an RMA. The drone was purchased on Order Number 6839. Let me know the next steps.
              Thanks.
                tom admin @roy.crosthwaite
                @roy-crosthwaite see here: https://www.modalai.com/pages/rma
