  3. Sendor suit getting stalled
vio
5 Posts 2 Posters 957 Views 1 Watching
  • Jetson NanoJ Offline
    Jetson Nano
    Veteran
    Re: CAM_MISSING_STALLED
    @Alex-Kushleyev @tom @modaltb @Eric-Katzfey
    I would like to reopen the query , which i was never able to solve .
    I am still facing the same error. this time i am using the new PMD TOF LIOW , with old tracking camer and old hires.
    The TOF is working perfect but tracking camera is getting stalled. Also this time hires is not at all starting.
    Starting Camera: hires (id #1)
    ERROR:   Camera 1 failed to find supported stream config: 1024x768
    WARNING: Failed to start cam hires due to invalid resolution
    WARNING: assuming cam is missing and trying to compensate
    Starting Camera: tracking (originally id #2) with id offset: 1
    setting ov7251 BLC register for cam id 1
    ------ voxl-camera-server: Started 2 of 3 cameras
    WARNING: [ROYALE_WARNING] {ROYALE_FRAME_DROP}: Dropped 5561 frame(s).
    WARNING: [ROYALE_WARNING] {ROYALE_RAW_FRAME_STATS}: Raw frame drop stats: Bridge 5561 frames dropped, FC 0 frames dropped, 9 frames delivered.
    WARNING: [ROYALE_WARNING] {ROYALE_FRAME_DROP}: Dropped 9 frame(s).
    WARNING: [ROYALE_WARNING] {ROYALE_RAW_FRAME_STATS}: Raw frame drop stats: Bridge 9 frames dropped, FC 0 frames dropped, 81 frames delivered.
    voxl2:/$ voxl-camera-server
    existing instance of voxl-camera-server found, attempting to stop it
    detected system image 1.7.10
    using new imx214 defaults
    configuration for 3 cameras:
    cam #0
        sensor type:         pmd-tof-liow2
        isEnabled:           1
        camId:               0
        camId2:              -1
        fps:                 10
        en_rotate:           1
        en_rotate2:          0
        en_preview:          1
        pre_width:           240
        pre_height:          1629
        en_raw_preview:      1
        en_small_video:      0
        small_video_width:   -1
        small_video_height:  -1
        en_large_video:      0
        large_video_width:   -1
        large_video_height:  -1
        en_snapshot:         0
        snap_width:          -1
        snap_height:         -1
        exif_focal_length:   0.000000
        exif_focal_len_35mm_format:0
        exif_fnumber:        0.000000
        ae_mode:             off
        msv_exposure_min_us: 0
        msv_exposure_max_us: 6000
        standby_enabled:     0
        decimator:           5
        independent_exposure:0
    cam #1
        sensor type:         imx214
        isEnabled:           1
        camId:               1
        camId2:              -1
        fps:                 30
        en_rotate:           0
        en_rotate2:          0
        en_preview:          0
        pre_width:           640
        pre_height:          480
        en_raw_preview:      0
        en_small_video:      1
        small_video_width:   1920
        small_video_height:  1080
        en_large_video:      1
        large_video_width:   4208
        large_video_height:  3120
        en_snapshot:         1
        snap_width:          4208
        snap_height:         3120
        ae_mode:             isp
        msv_exposure_min_us: 20
        msv_exposure_max_us: 33000
        standby_enabled:     0
        decimator:           1
    cam #2
        sensor type:         ov7251
        isEnabled:           1
        camId:               2
        camId2:              -1
        fps:                 30
        en_rotate:           0
        en_rotate2:          0
        en_preview:          1
        pre_width:           640
        pre_height:          480
        en_raw_preview:      1
        en_small_video:      0
        en_large_video:      0
        en_snapshot:         0
        snap_width:          -1
        snap_height:         -1
        ae_mode:             lme_msv
        standby_enabled:     0
        decimator:           1
    fsync_en:            0
    fsync_gpio:          109
    connected to mavlink pipe
    Starting Camera: tof (id #0)
    Connected to cpu-monitor
    ERROR:   Camera 1 failed to find supported stream config: 1920x1080
    WARNING: [ROYALE_WARNING] {ROYALE_FRAME_DROP}: Dropped 44792 frame(s).
    WARNING: [ROYALE_WARNING] {ROYALE_RAW_FRAME_STATS}: Raw frame drop stats: Bridge 44792 frames dropped, FC 0 frames dropped, 9 frames delivered.
    ^C
    received SIGINT Ctrl-C
    ------ voxl-camera-server: Camera server is now stopping
    WARNING: Deleting buffers: 6 of 16 still in use
    ------ voxl-camera-server: Camera server exited gracefully, returning 0
    Help me to solve this error .
    • Jetson NanoJ Jetson Nano
      cam #0
          isEnabled:           1
          camId:               0
          camId2:              -1
          fps:                 10
          en_rotate:           1
          en_rotate2:          0
          en_preview:          1
          pre_width:           240
          pre_height:          1629
          en_raw_preview:      1
          en_small_video:      0
          en_large_video:      0
          en_snapshot:         0
          snap_width:          -1
          snap_height:         -1
          ae_mode:             off
          standby_enabled:     0
          decimator:           5
      cam #1
          sensor type:         imx214
          isEnabled:           1
          camId:               1
          camId2:              -1
          fps:                 30
          en_rotate:           0
          en_rotate2:          0
          en_preview:          0
          pre_width:           640
          pre_height:          480
          en_raw_preview:      0
          en_small_video:      1
          en_large_video:      1
          en_snapshot:         1
          snap_width:          4208
          snap_height:         3120
          ae_mode:             isp
          standby_enabled:     0
          decimator:           1
      cam #2
          sensor type:         ov7251
          isEnabled:           1
          camId:               2
          camId2:              -1
          fps:                 30
          en_rotate:           0
          en_rotate2:          0
          en_preview:          1
          pre_width:           640
          pre_height:          480
          en_raw_preview:      1
          en_small_video:      0
          en_large_video:      0
          en_snapshot:         0
          snap_width:          -1
          snap_height:         -1
          ae_mode:             lme_msv
          standby_enabled:     0
          decimator:           1
      fsync_en:            0
      fsync_gpio:          109
      ^C
      Alex KushleyevA Online
      @Jetson-Nano , you probably have incorrect camera IDs in your voxl-camera-server.conf. Please check which cameras are detected and note their camera IDs and make sure they correspond to the IDs specificed in voxl-camera-server.conf.
      https://docs.modalai.com/debugging-camera-issues/#checking-which-cameras-are-detected-by-camera-server
        Jetson Nano
        Veteran
        @Alex-Kushleyev I had checked the with the command and it did not recognize the hires camera at all and the tracking camera in certain and totally independent conditions. which makes me able to understand what is the cause of error.
        voxl2:~$ voxl-camera-server -l
        DEBUG:   ----------- Number of cameras: 1
        DEBUG:   Cam idx: 0, Cam slot: 4, Slave Address: 0x00E2, Sensor Id: 0x7750
        DEBUG:   Note: This list comes from the HAL module and may not be indicative
        DEBUG:   	of configurations that have full pipelines
        DEBUG:   Number of cameras: 1
        Stats for camera: 0
        ANDROID_SCALER_AVAILABLE_RAW_SIZES:
        These are likely supported by the sensor
         640 x  480
         640 x  480
         640 x  480
        ANDROID_SCALER_AVAILABLE_STREAM_CONFIGURATIONS:
        These are NOT necessarily supported by the sensor
         640 x  480 HAL_PIXEL_FORMAT_YCbCr_420_888
         640 x  480 HAL_PIXEL_FORMAT_BLOB
         640 x  400 HAL_PIXEL_FORMAT_YCbCr_420_888
         640 x  400 HAL_PIXEL_FORMAT_BLOB
         640 x  360 HAL_PIXEL_FORMAT_YCbCr_420_888
         640 x  360 HAL_PIXEL_FORMAT_BLOB
         352 x  288 HAL_PIXEL_FORMAT_YCbCr_420_888
         352 x  288 HAL_PIXEL_FORMAT_BLOB
         320 x  240 HAL_PIXEL_FORMAT_YCbCr_420_888
         320 x  240 HAL_PIXEL_FORMAT_BLOB
         240 x  320 HAL_PIXEL_FORMAT_YCbCr_420_888
         240 x  320 HAL_PIXEL_FORMAT_BLOB
         176 x  144 HAL_PIXEL_FORMAT_YCbCr_420_888
         176 x  144 HAL_PIXEL_FORMAT_BLOB
         640 x  480 HAL_PIXEL_FORMAT_RAW10
         640 x  480 HAL_PIXEL_FORMAT_RAW12
         640 x  480 HAL_PIXEL_FORMAT_RAW16
         640 x  480 HAL_PIXEL_FORMAT_RAW_OPAQUE
        ANDROID_SENSOR_INFO_SENSITIVITY_RANGE
        	min = 54
        	max = 3451
        ANDROID_SENSOR_MAX_ANALOG_SENSITIVITY
        	3451
        ANDROID_SENSOR_INFO_EXPOSURE_TIME_RANGE
        	min = 0ns
        	max = 1266732525ns
        Number of cameras detected: 1
          Stats for camera: 0
           640 x  480
           640 x  480
           640 x  480
          	min = 54
          	max = 3451
          	3451
          	min = 0ns
          	max = 1266732525ns
          @Jetson-Nano , please make sure that for every camera that you have connected, you have the correct sensormodule placed in /usr/lib/camera and corresponding entry in /etc/voxl-camera-server.conf.
          More info here :
          https://docs.modalai.com/configure-cameras/#connect-a-new-camera
          If you still need help, please list all the cameras when where exactly they are connected (which camera connector on VOXL2, which interposer flex is used, and which slot ID you think the camera should be recognized as). Also, please list the contents of your /usr/lib/camera/*sensormodule*.
          Thank you
            More info here :
            Thank you
            Jetson Nano
            Veteran
            @Alex-Kushleyev Thank you for reverting, I will check this out and get back to you
