  3. OV with External Autopilot
vio
12 Posts 3 Posters 1.9k Views 2 Watching
  • S Offline
    S Offline
    SKA
    Hi! I'm trying to use voxl-vision-hub to send voxl-open-vins position data to an external autopilot (ardupilot). I start by making sure the following services are running:
    • voxl-imu-server
    • voxl-open-vins-server
    • voxl-camera-server
    • voxl-vision-hub
    • voxl-mavlink-server
    I can confirm that the voxl and external autopilot are connected because I see this on Mission Planner MAVLink Inspector:
    and the debug output I see after running voxl-vision-hub -d is:
    voxl2-mini:~$ voxl-vision-hub -d
    Enabling recv debugging for localhost UDP port from ROS
    loading our own config file
    config_file_version:        1
    MAVROS / MAVSDK
    en_localhost_mavlink_udp    1
    localhost_udp_port_number:  14551
    VIO
    en_vio:                     1
    vio_pipe:                   ov
    secondary_vio_pipe:         qvio
    en_reset_vio_if_initialized_inverted: 0
    vio_warmup_s:               0.000000
    send_odom_while_failed:     1
    MISC FEATURES
    horizon_cal_tolerance:      0.500000
    en_hitl:                    0
    OFFBOARD MODE
    offboard_mode:              off
    follow_tag_id:              0
    figure_eight_move_home:     1
    wps_move_home:     1
    wps_timeout:     0.000000
    wps_damp:     1.000000
    robot_radius:               0.300000
    collision_sampling_dt:      0.100000
    max_lookahead_distance:     1.000000
    backtrack_seconds     :     60
    backtrack_rc_chan     :     8
    backtrack_rc_thresh   :     1500
    FIXED FRAME RELOCALIZATION
    en_tag_fixed_frame:         0
    fixed_frame_filter_len:     5
    VOXL FLIGHT CONTROLLER (VFC)
    vfc_rate                    100.000000
    vfc_rc_chan_min             980
    vfc_rc_chan_max             2020
    vfc_thrust_ch               3
    vfc_roll_ch                 1
    vfc_pitch_ch                2
    vfc_yaw_ch                  4
    vfc_submode_ch              6
    vfc_alt_mode_rc_min         0
    vfc_alt_mode_rc_max         0
    vfc_flow_mode_rc_min        0
    vfc_flow_mode_rc_max        0
    vfc_hybrid_flow_mode_rc_min 0
    vfc_hybrid_flow_mode_rc_max 0
    vfc_position_mode_rc_min    0
    vfc_position_mode_rc_max    2100
    vfc_traj_mode_rc_min        0
    vfc_traj_mode_rc_max        0
    vfc_yaw_deadband            30
    vfc_vxy_deadband            50
    vfc_vz_deadband             150
    vfc_min_thrust              0.000000
    vfc_max_thrust              0.800000
    vfc_tilt_max                0.436000
    vfc_yaw_rate_max            3.000000
    vfc_thrust_hover            0.500000
    vfc_vz_max                  1.000000
    vfc_kp_z                    5.290000
    vfc_kd_z                    5.980000
    vfc_vxy_max                 3.000000
    vfc_kp_xy                   0.640000
    vfc_kd_xy                   2.560000
    vfc_kp_z_vio                5.290000
    vfc_kd_z_vio                5.980000
    vfc_kp_xy_vio               3.240000
    vfc_kd_xy_vio               3.960000
    vfc_w_filt_xy_vio           10.000000
    vfc_vel_ff_factor_vio       0.900000
    vfc_xy_acc_limit_vio        2.500000
    vfc_max_z_delta             3.000000
    vfc_att_transition_time     0.500000
    vfc_stick_move_threshold    30.000000
    vfc_flow_transition_time    1.000000
    vfc_q_min                   10
    vfc_points_min              7
    vfc_en_submode_announcement 1
    vfc_disable_fallback        0
    COLLISION PREVENTION (VOA)
    en_voa:                     0
    voa_upper_bound_m:          -0.150000
    voa_lower_bound_m:          0.150000
    voa_memory_s:               1.000000
    voa_max_pc_per_fusion:      100
    voa_pie_min_dist_m:         0.250000
    voa_pie_max_dist_m:         20.000000
    voa_pie_under_trim_m:       1.000000
    voa_pie_threshold:          3
    voa_pie_slices:             36
    voa_pie_bin_depth_m:        0.150000
    voa_send_rate_hz:           20.000000
    voa_input #0
        enabled:            0
        type:               point_cloud
        input_pipe:         dfs_point_cloud
        frame:              stereo_l
        max_depth:          8.000000
        min_depth:          0.300000
        cell_size:          0.080000
        threshold:          4
        x_fov_deg:          68.000000
        y_fov_deg:          56.000000
        conf_cutoff:        0
    voa_input #1
        enabled:            0
        type:               point_cloud
        input_pipe:         stereo_front_pc
        frame:              stereo_front_l
        max_depth:          8.000000
        min_depth:          0.300000
        cell_size:          0.080000
        threshold:          4
        conf_cutoff:        0
    voa_input #2
        enabled:            0
        type:               point_cloud
        input_pipe:         stereo_rear_pc
        frame:              stereo_rear_l
        max_depth:          8.000000
        min_depth:          0.300000
        cell_size:          0.080000
        threshold:          4
        conf_cutoff:        0
    voa_input #3
        enabled:            0
        type:               tof
        input_pipe:         tof
        frame:              tof
        max_depth:          6.000000
        min_depth:          0.150000
        cell_size:          0.080000
        threshold:          3
        x_fov_deg:          106.500000
        y_fov_deg:          85.099998
        conf_cutoff:        125
    voa_input #4
        enabled:            0
        type:               rangefinder
        input_pipe:         rangefinders
        frame:              body
        max_depth:          8.000000
        min_depth:          0.300000
        cell_size:          0.080000
        threshold:          4
        conf_cutoff:        0
    loading extrinsics config file
    loading horizon cal file
    starting geometry module
    starting autopilot monitor
    starting mavlink IO
    Waiting to connect to voxl-mavlink-server
    Connected to voxl-mavlink-server
    starting mavlink for ros
    starting fixed pose input
    starting vio manager
    Connected to VIO pipe: ov
    Geometry module updating to use imu: imu_apps for VIO
    new T imu wrt body:
     0.0407  -0.0060  -0.0188
    new R imu to body:
     1.0000  -0.0000   0.0000
     0.0000   1.0000  -0.0000
     0.0000   0.0000   1.0000
    done updating transforms to use imu: imu_apps
    starting tag manager
    starting horizon cal module
    starting imu manager
    starting state manager
    Init complete
    from AP msgid:   0 sysid:  1 compid:  1
    Detected Autopilot Mavlink SYSID 1
    requesting autopilot_version
    from AP msgid:  77 sysid:  1 compid:  1
    from AP msgid: 148 sysid:  1 compid:  1
    Detected autopilot version: 4.5.5
    from AP msgid:  22 sysid:  1 compid:  1
    It seems like other than the heartbeat, no data is being sent to the external autopilot. Thanks in advance for any guidance that can help me sort this out!
    • S SKA
      • voxl-imu-server
      • voxl-vision-hub
      MAVROS / MAVSDK
      VIO
      en_vio:                     1
      vio_pipe:                   ov
      MISC FEATURES
      en_hitl:                    0
      OFFBOARD MODE
      offboard_mode:              off
      follow_tag_id:              0
      wps_move_home:     1
      wps_damp:     1.000000
      vfc_rate                    100.000000
      vfc_rc_chan_min             980
      vfc_thrust_ch               3
      vfc_roll_ch                 1
      vfc_pitch_ch                2
      vfc_yaw_ch                  4
      vfc_submode_ch              6
      vfc_yaw_deadband            30
      vfc_vxy_deadband            50
      vfc_vz_deadband             150
      vfc_vz_max                  1.000000
      vfc_kp_z                    5.290000
      vfc_kd_z                    5.980000
      vfc_kp_xy                   0.640000
      vfc_kd_xy                   2.560000
      vfc_q_min                   10
      vfc_points_min              7
      en_voa:                     0
      voa_pie_slices:             36
      voa_input #0
          enabled:            0
          type:               point_cloud
          frame:              stereo_l
          max_depth:          8.000000
          min_depth:          0.300000
          cell_size:          0.080000
          threshold:          4
          conf_cutoff:        0
      voa_input #1
          enabled:            0
          type:               point_cloud
          max_depth:          8.000000
          min_depth:          0.300000
          cell_size:          0.080000
          threshold:          4
          conf_cutoff:        0
      voa_input #2
          enabled:            0
          type:               point_cloud
          max_depth:          8.000000
          min_depth:          0.300000
          cell_size:          0.080000
          threshold:          4
          conf_cutoff:        0
      voa_input #3
          enabled:            0
          type:               tof
          input_pipe:         tof
          frame:              tof
          max_depth:          6.000000
          min_depth:          0.150000
          cell_size:          0.080000
          threshold:          3
          conf_cutoff:        125
      voa_input #4
          enabled:            0
          type:               rangefinder
          frame:              body
          max_depth:          8.000000
          min_depth:          0.300000
          cell_size:          0.080000
          threshold:          4
          conf_cutoff:        0
      starting mavlink IO
      new T imu wrt body:
      new R imu to body:
      Init complete
      tomT Online
      tomT Online
      @SKA I would review this page if you haven't already: https://docs.modalai.com/voxl2-external-flight-controller/
      S 1 Reply Last reply
        S Offline
        S Offline
        SKA
        wrote on last edited by SKA
        @tom Thanks! I referred to this page in order to set up what I have right now.
        My voxl 2 mini is connected to the external autopilot using the one exposed UART. It seems to be connected fine, since I'm receiving the voxl heartbeat on the autopilot end, and I'm receiving autopilot mavlink messages on the voxl side.
        I wonder if there is anything I might be missing on the voxl-vision-hub side, or elsewhere.
        Thanks for your help!
        • S SKA
          S Offline
          S Offline
          SKA
          @tom I have some updates, and here's more info on my setup!
          voxl-open-vins-server is running and outputting the following:
          voxl-vision-hub and voxl-mavlink-server are running, and the odom messages are being sent. Here's the output from voxl-mavlink-server -l:
          At my external autopilot, the Odometry messages are coming through, but the values are not populating/reading correctly:
          Thanks in advance for any input you may have!
          • S SKA
            @SKA What version of the SDK do you have installed? Can you post the output of voxl-version?
              S Offline
              S Offline
              SKA
              @Eric-Katzfey @tom
              Here's the output of voxl-version:
              voxl2-mini:~$ voxl-version
              system-image: 1.8.02-M0104-14.1a-perf
              kernel:       #1 SMP PREEMPT Mon Nov 11 23:21:25 UTC 2024 4.19.125
              hw platform:  M0104
              mach.var:     2.0.0
              voxl-suite:   1.4.0
              Packages:
              Repo:  http://voxl-packages.modalai.com/ ./dists/qrb5165/sdk-1.4/binary-arm64/
              Last Updated: 2025-03-12 18:51:42
              List:
              libmodal-cv                               0.5.16
              libmodal-exposure                         0.1.3
              libmodal-pipe                             2.10.4
              libqrb5165-io                             0.4.7
              libvoxl-cci-direct                        0.2.3
              modalai-slpi                              1.1.19
              qrb5165-imu-server                        1.1.0
              qrb5165-rangefinder-server                0.1.4
              qrb5165-system-tweaks                     0.3.2
              voxl-camera-calibration                   0.5.9
              voxl-camera-server                        2.0.2
              voxl-configurator                         0.9.4
              voxl-cpu-monitor                          0.5.1
              voxl-elrs                                 0.3.4
              voxl-esc                                  1.4.8
              voxl-feature-tracker                      0.5.2
              voxl-gimbal                               0.0.1
              voxl-io-server                            0.0.4
              voxl-lepton-server                        1.3.3
              voxl-lepton-tracker                       0.0.4
              voxl-logger                               0.4.9
              voxl-mavcam-manager                       0.5.7
              voxl-mavlink-server                       1.4.4
              voxl-modem                                1.1.3
              voxl-mpa-tools                            1.3.4
              voxl-open-vins                            0.4.14
              voxl-open-vins-server                     0.2.83
              voxl-opencv                               4.5.5-2
              voxl-osd                                  0.0.2
              voxl-portal                               0.7.2
              voxl-px4                                  1.14.0-2.0.93
              voxl-px4-params                           0.5.8
              voxl-qvio-server                          1.1.1
              voxl-reset-slpi                           0.0.1
              voxl-state-estimator                      0.0.3
              voxl-streamer                             0.7.5
              voxl-suite                                1.4.0
              voxl-tflite-server                        0.3.7
              voxl-utils                                1.4.4
              voxl-vision-hub                           1.8.18
              voxl-vtx                                  1.1.3
              voxl2-system-image                        1.8.02-r0
              • S SKA
                @Eric-Katzfey @tom
                hw platform:  M0104
                mach.var:     2.0.0
                voxl-suite:   1.4.0
                Packages:
                List:
                libmodal-cv                               0.5.16
                libqrb5165-io                             0.4.7
                modalai-slpi                              1.1.19
                voxl-elrs                                 0.3.4
                voxl-esc                                  1.4.8
                voxl-gimbal                               0.0.1
                voxl-logger                               0.4.9
                voxl-modem                                1.1.3
                voxl-opencv                               4.5.5-2
                voxl-osd                                  0.0.2
                voxl-portal                               0.7.2
                voxl-streamer                             0.7.5
                voxl-suite                                1.4.0
                voxl-utils                                1.4.4
                voxl-vtx                                  1.1.3
                @SKA Okay, great, that's a very recent SDK so that's good. Have you also made sure to disable the voxl-qvio-server service?
                  @Eric-Katzfey Your output shows that it is connecting properly to ov pipe so shouldn't really be necessary to stop voxl-qvio-server but probably a good idea anyways.
                  • S SKA
                    @Eric-Katzfey @tom
                    hw platform:  M0104
                    mach.var:     2.0.0
                    voxl-suite:   1.4.0
                    Packages:
                    List:
                    libmodal-cv                               0.5.16
                    libqrb5165-io                             0.4.7
                    modalai-slpi                              1.1.19
                    voxl-elrs                                 0.3.4
                    voxl-esc                                  1.4.8
                    voxl-gimbal                               0.0.1
                    voxl-logger                               0.4.9
                    voxl-modem                                1.1.3
                    voxl-opencv                               4.5.5-2
                    voxl-osd                                  0.0.2
                    voxl-portal                               0.7.2
                    voxl-streamer                             0.7.5
                    voxl-suite                                1.4.0
                    voxl-utils                                1.4.4
                    voxl-vtx                                  1.1.3
                    @SKA That odometry output results when voxl-vision-hub thinks that vio is in a failed state and sends out that default message. Does the time_usec field increment normally? Do you ever see it populate with good data or is it always showing that? Here is the code where it sends that: https://gitlab.com/voxl-public/voxl-sdk/services/voxl-vision-hub/-/blob/master/src/vio_manager.c?ref_type=heads#L150
                    • S SKA
                      @Eric-Katzfey @tom
                      hw platform:  M0104
                      mach.var:     2.0.0
                      voxl-suite:   1.4.0
                      Packages:
                      List:
                      libmodal-cv                               0.5.16
                      libqrb5165-io                             0.4.7
                      modalai-slpi                              1.1.19
                      voxl-elrs                                 0.3.4
                      voxl-esc                                  1.4.8
                      voxl-gimbal                               0.0.1
                      voxl-logger                               0.4.9
                      voxl-modem                                1.1.3
                      voxl-opencv                               4.5.5-2
                      voxl-osd                                  0.0.2
                      voxl-portal                               0.7.2
                      voxl-streamer                             0.7.5
                      voxl-suite                                1.4.0
                      voxl-utils                                1.4.4
                      voxl-vtx                                  1.1.3
                      @SKA voxl-vision-hub will print out debug messages showing VIO status as it is running. Can you see anything that may indicate why it thinks VIO is failed?
                        S Offline
                        S Offline
                        SKA
                        @Eric-Katzfey Thanks for helping me out with this! I've made some progress at narrowing in on the problem. First to answer your questions:
                        • QVIO: I tried with voxl-qvio-server disabled, this didn't change anything.
                        • VIO failed state: I fixed some other issues leading to the failed state from voxl-open-vins-server. Now the ovins translation and rotation outputs look healthy, and time_usec increments normally, but the external autopilot still does not log the odometry output.
                        • Debug: VIO status debug shows that it isn't failing.
                        I was able to get qvio odometry outputs to log on the external autopilot, but when I switched over to ovins, it fails. With ovins I still see incoming VIO (comp IP 197) heartbeat and timestamp mavlink messages going through, but not the 331 odometry message.
                        Let me know what you think, thanks so much!
                        • S SKA
                          @SKA What pipes do you see listed in /run/mpa? If you run the command voxl-inspect-vio does it show that VIO is running okay?
