  3. The differences between M0054-1, M0054-2, M0154-1, and M0154-2.
5 Posts 4 Posters 744 Views 3 Watching
  • D Offline
    D Offline
    dongsup.seo
    I'd like to know the differences between M0054-1, M0054-2, M0154-1, and M0154-2.
    VinnyV 1 Reply Last reply
    • D dongsup.seo
      VinnyV Offline
      VinnyV Offline
      Vinny
      Hi @dongsup-seo
      It's a fair question but please provide some context for your concern.
      Aside from the boot image needed (see link below), the design changes are largely transparent to the end user.
      https://docs.modalai.com/m0054-versions/
      Vinny
      D 1 Reply Last reply
      • VinnyV Vinny
        Hi @dongsup-seo
        Vinny
        D Offline
        D Offline
        dongsup.seo
        @Vinny Thank you.
        During the installation of voxl-suite 1.1.3 (on about 20-30 devices), some devices showed slight abnormal symptoms (such as being recognized as KONA-QRD devices),
        So I was wondering if it might be due to device revision differences.
        I would like to know what the difference is between M0054-1 and M0154-1.
        Alex KushleyevA tomT 2 Replies Last reply
        • D dongsup.seo
          @Vinny Thank you.
          @dongsup-seo ,
          We will prepare a better summary of the differences between M0054-1 and M0154, but the main reason for the new board revision was to update some parts that were becoming obsolete. The differences between the two boards are very small.
          When the device appears as KONA-QRD device, this means the VOXL2 was not flashed completely, I think @tom should be able to answer the questions related to that.
          • D dongsup.seo
            @Vinny Thank you.
            @dongsup-seo I would recommend flashing the latest SDK (1.4.1) as that will have much better handling for M0054-1/2, I think a lot of that logic was missing on 1.1.3 as that is very old.
