  3. connectors for TOF camera on voxl-2
7 Posts 3 Posters 989 Views 2 Watching
  • voxl-phoenixV Offline
    voxl-phoenix
    Hi, I have recently purchased a TOf camera for mapping, I have tried to connect it with my voxl-2, I belive I'm missing somehting. I have interposers MDK-M0076-1-00, and a dual camera adapter MSU-M0084-1-01.
    I couldn't figure out what I missed for this, please any suggestions?
    Thank you,
    Best.
    • voxl-phoenixV voxl-phoenix
      Thank you,
      Best.
      @voxl-phoenix , Can you please clarify which TOF camera you purchased and what connectors / cables it came with? There are several versions / options.
      If you can include a photo of the TOF camera and the cables it came with, that would help as well.
      voxl-phoenixV 1 Reply Last reply
        voxl-phoenix
        Thank you for the reply @Alex-Kushleyev, This is the cam Configuration I have got. WhatsApp Image 2025-01-31 at 10.01.22_b2304754.jpg WhatsApp Image 2025-01-31 at 10.01.22_6703ce59.jpg .
        Thanks for help once again.
        VinnyV 1 Reply Last reply
          VinnyV Offline
          VinnyV Offline
          Vinny
          Hi @voxl-phoenix
          Please see these notes from here: https://docs.modalai.com/M0178/
          So, you have several options of different HW to buy...
          The easiest which gives you more support of other image sensors is the Starling Front End Imager Unit, M0173: This link is without any extra image sensors ...
          https://www.modalai.com/collections/image-sensors/products/m0173?variant=48528274391344
          Most variants include that exact set of ToF components you have, so you could get the version with tracking/HiRes sensors if you need that capability: 1e33bb80-aacb-4b3e-a55c-afb4262dbf82-image.png
          (note, the $79.99 is just board only and not updated since I did not click through the option).
          Hope this helps!
          • VinnyV Vinny
            Hi @voxl-phoenix
            Hope this helps!
            VinnyV Offline
            VinnyV Offline
            Vinny
            @voxl-phoenix And I want to add that the two adapters (M0084 and M0135) on the bottom of your image are not used at all in this system.
            • VinnyV Vinny
              voxl-phoenix
              wrote on last edited by voxl-phoenix
              @Vinny Thank you so much for the info. I already have tracking and IMX412 cameras. I want to just buy Board. I have a small query, do I need any extra cables or connectors to connect this frontend camera connecter to VOXL 2 or does it come with the board when I order just the board only?
              Thank you.
                Thank you.
                VinnyV Offline
                VinnyV Offline
                Vinny
                Hi @voxl-phoenix
                Yes, that M0177 flex you have plugs direct into the M0173 board 40-pin connector here: 2a2a4f8f-6b90-4ea5-937e-d0b0426ccf36-image.png
                Please pay attention to the "+" and "-" notes in silkscreen for proper orientation.
                Hope this helps!
