    connectors for TOF camera on voxl-2
    • voxl-phoenixV
      voxl-phoenix
      Hi, I have recently purchased a TOf camera for mapping, I have tried to connect it with my voxl-2, I belive I'm missing somehting. I have interposers MDK-M0076-1-00, and a dual camera adapter MSU-M0084-1-01.
      I couldn't figure out what I missed for this, please any suggestions?
      Thank you,
      Best.
        Alex Kushleyev ModalAI Team @voxl-phoenix
        @voxl-phoenix , Can you please clarify which TOF camera you purchased and what connectors / cables it came with? There are several versions / options.
        If you can include a photo of the TOF camera and the cables it came with, that would help as well.
        voxl-phoenixV 1 Reply Last reply Reply Quote 0
        • voxl-phoenixV
          voxl-phoenix @Alex Kushleyev
          Thank you for the reply @Alex-Kushleyev, This is the cam Configuration I have got. WhatsApp Image 2025-01-31 at 10.01.22_b2304754.jpg WhatsApp Image 2025-01-31 at 10.01.22_6703ce59.jpg .
          Thanks for help once again.
          • VinnyV
            Vinny ModalAI Team @voxl-phoenix
            Hi @voxl-phoenix
            Please see these notes from here: https://docs.modalai.com/M0178/
            So, you have several options of different HW to buy...
            The easiest which gives you more support of other image sensors is the Starling Front End Imager Unit, M0173: This link is without any extra image sensors ...
            https://www.modalai.com/collections/image-sensors/products/m0173?variant=48528274391344
            Most variants include that exact set of ToF components you have, so you could get the version with tracking/HiRes sensors if you need that capability: 1e33bb80-aacb-4b3e-a55c-afb4262dbf82-image.png
            (note, the $79.99 is just board only and not updated since I did not click through the option).
            Hope this helps!
            • VinnyV
              Vinny ModalAI Team @Vinny
              @voxl-phoenix And I want to add that the two adapters (M0084 and M0135) on the bottom of your image are not used at all in this system.
              • voxl-phoenixV
                voxl-phoenix @Vinny
                @Vinny Thank you so much for the info. I already have tracking and IMX412 cameras. I want to just buy Board. I have a small query, do I need any extra cables or connectors to connect this frontend camera connecter to VOXL 2 or does it come with the board when I order just the board only?
                Thank you.
                • VinnyV
                  Hi @voxl-phoenix
                  Yes, that M0177 flex you have plugs direct into the M0173 board 40-pin connector here: 2a2a4f8f-6b90-4ea5-937e-d0b0426ccf36-image.png
                  Please pay attention to the "+" and "-" notes in silkscreen for proper orientation.
                  Hope this helps!
