  3. Modal M500 Voxl Streamer
m500
9 Posts 3 Posters 2.2k Views 3 Watching
  • Samuel BryanS Offline
    Samuel Bryan
    I need to take screenshots off the hires camera feed from the M500 every quarter second and save the screenshots to my computer. Is there a way to modify the voxl streamer script or another script on board the aircraft to do this?
    • Samuel BryanS Samuel Bryan
      @Samuel-Bryan This command: voxl-send-command hires_snapshot snapshot will take a snapshot and save it to the /data/snapshots directory. You could write a small script to call that every quarter second.
      Samuel BryanS 2 Replies Last reply
        Samuel Bryan
        @Eric-Katzfey I tried that command, but I got the error "Unable to find valid pipe that accepts control commands at: hires_snapshot". I am using voxl-suite 0.9.4, with system image 4.0.0.
          @Samuel-Bryan Can you update to the latest SDK and try with that? With what you have now what do you see in the /run/mpa directory?
          Samuel BryanS 1 Reply Last reply
            Samuel Bryan
            @Eric-Katzfey I tried update it with the latest SDK but it says it is out of space. I have a Windows machine, are there instructions for installing the latest SDK onto the Modal M500?
              @Samuel-Bryan I would recommend setting up a Linux workstation (ideally Ubuntu) as you'll have an easier time working with that.
              Can you post a screenshot or paste the output of the error you're getting?
                Samuel Bryan
                I was able to get the SDK upgraded to Voxl 1.2.0. However now it won't communicate with Q Ground Control. When I open it, it shows that it is disconnected despite there being a wifi connection between between the laptop and the M500. It connects to the laptop fine and I can SSH into the aircraft. Is there a setting somewhere on the aircraft that I have to change for it to connect with QGC again?
                  Samuel Bryan
                  @Eric-Katzfey Do you have a list of voxl-send-command commands, or is it listed in the documentation somewhere?
                    @Samuel-Bryan There are some examples here: https://docs.modalai.com/mpa-camera-interface/#sending-commands-back-to-the-server
