    Modal M500 Voxl Streamer
    VOXL m500 Reference Drone
    719
    • Samuel BryanS
      Samuel Bryan
      I need to take screenshots off the hires camera feed from the M500 every quarter second and save the screenshots to my computer. Is there a way to modify the voxl streamer script or another script on board the aircraft to do this?
        Eric Katzfey ModalAI Team @Samuel Bryan
        @Samuel-Bryan This command: voxl-send-command hires_snapshot snapshot will take a snapshot and save it to the /data/snapshots directory. You could write a small script to call that every quarter second.
        Samuel BryanS 2 Replies Last reply Reply Quote 0
        • Samuel BryanS
          Samuel Bryan @Eric Katzfey
          @Eric-Katzfey I tried that command, but I got the error "Unable to find valid pipe that accepts control commands at: hires_snapshot". I am using voxl-suite 0.9.4, with system image 4.0.0.
            @Samuel-Bryan Can you update to the latest SDK and try with that? With what you have now what do you see in the /run/mpa directory?
            Samuel BryanS 1 Reply Last reply Reply Quote 0
            • Samuel BryanS
              @Eric-Katzfey I tried update it with the latest SDK but it says it is out of space. I have a Windows machine, are there instructions for installing the latest SDK onto the Modal M500?
                tom admin @Samuel Bryan
                @Samuel-Bryan I would recommend setting up a Linux workstation (ideally Ubuntu) as you'll have an easier time working with that.
                Can you post a screenshot or paste the output of the error you're getting?
                • Samuel BryanS
                  Samuel Bryan
                  I was able to get the SDK upgraded to Voxl 1.2.0. However now it won't communicate with Q Ground Control. When I open it, it shows that it is disconnected despite there being a wifi connection between between the laptop and the M500. It connects to the laptop fine and I can SSH into the aircraft. Is there a setting somewhere on the aircraft that I have to change for it to connect with QGC again?
                  • Samuel BryanS
                    @Eric-Katzfey Do you have a list of voxl-send-command commands, or is it listed in the documentation somewhere?
                      @Samuel-Bryan There are some examples here: https://docs.modalai.com/mpa-camera-interface/#sending-commands-back-to-the-server
