  3. Our VOXL2 stopped responding
22 Posts 3 Posters 6.0k Views 2 Watching
  • Matthew WellnerM Offline
    Matthew Wellner
    Our VOXL2 stopped responding over adb after we installed our new 5G carrier board, but we still had access through tailscale. I went to update from 1.1.3 to 1.2.0 and after going through the unbricking procedure and using fastboot to reflash the SDK, I can't get adb to see the VOXL2. I get stuck at the waiting for ADB portion of the flashing sequence.
    Please let me know if there is anything I can try.
    Matt
    ModeratorM 1 Reply Last reply
    • Matthew WellnerM Matthew Wellner
      Matt
      @Matthew-Wellner Hi Matthew, which modem did you install with which 5G carrier board? They do need to be compatible or damage can occur
      Matthew WellnerM 1 Reply Last reply
      • ModeratorM Moderator
        Matthew Wellner
        @Moderator I used the Sierra wireless carrier and modem that came preassembled. Previously we used a Quectel modem in a carrier made by you guys for the Quectel modem and the VOXL 2. Both of those setups worked as expected previously.
        VinnyV 1 Reply Last reply
          VinnyV Offline
          VinnyV Offline
          Vinny
          Hi @Matthew-Wellner
          A failed ADB implies a low level function is busted, possibly HW.
          Can you please send close-up photos of J3 and J5 on your VOXL 2 board and the mating connectors on the M0090 5G Modem board (J1/J2).
          I'm curious if during insertion, maybe some pins got bent and are creating a HW fault.
          • VinnyV Vinny
            Hi @Matthew-Wellner
            Matthew Wellner
            Hi @Vinny
            Here are the close up pics of the connectors - https://photos.app.goo.gl/mU3oUiArJ6j3WisL6
            Matt
              Hi @Vinny
              Matt
              VinnyV Offline
              VinnyV Offline
              Vinny
              Hi @Matthew-Wellner
              Looks like J3 is cracked!!
              That will certainly explain why things are malfunctioning.
              Our RMA process will result in a new board needed as that is not repairable w/o risk of damaging the rest of the board.
              • VinnyV Vinny
                Hi @Matthew-Wellner
                Matthew Wellner
                @Vinny - I definitely didn't see that. Thanks for taking a look. Realizing that it would be impossible for you to really know, is there anything that we could have done to avoid the crack in the connector? We didn't crash / forcefully insert the carrier board into the VOXL2.
                Do you think the cracked connector caused some sort of other HW failure? I'm only asking because I tried getting ADB to come up after I removed the carrier board and I was having the same issue.
                Do we just need to buy a new board or will the RMA process be a less expensive approach?
                Matt
                  Matt
                  VinnyV Offline
                  VinnyV Offline
                  Vinny
                  Hi @Matthew-Wellner
                  To be honest, the outcome will be the same and you'll need a new board. The RMA process will just slow things down and the end cost is the same.
                  The likely cause of your failure is incorrect "zipper angle" during modem board removal. More likely we'd see it on J5, not J3 (to be frank, I have not seen a damaged J3 in many years... )
                  If the mating board is not inserted or removed "true" or "plumb", then you add pressure to the sidewalls of the connectors. So, care must be taken in the future to advise all users in your facility to pay attention to the zipper angle during removal and to be graceful with the mating cycles. Doing so will get you years and years of extended use. I have several products that are over 10 years old still using that 60-pin QSH/QTH series that work perfectly. They are rated for 100 cycles, but we get much much more in practice.
                  Hope this helped.
                  • VinnyV Vinny
                    Hi @Matthew-Wellner
                    Hope this helped.
                    Matthew Wellner
                    Hi @Vinny - We had a new board that we purchased this week to replace the board that wouldn't boot. I tested the board before we added that new board into the rest of the system and I was able to adb to it. After adding the 5G carrier board (Sierra wireless), I went to set the board up and now it won't show up with adb anymore. Any ideas?
                    Matt
                    VinnyV 2 Replies Last reply
                      Matt
                      VinnyV Offline
                      VinnyV Offline
                      Vinny
                      Hi @Matthew-Wellner
                      I may need to call in the big guns here @tom 🙂
                      He is the modem software expert.
                        Matt
                        VinnyV Offline
                        VinnyV Offline
                        Vinny
                        Hi @Matthew-Wellner
                        Hopefully Tom can help too, so I tagged him in the last response, but can you let us know if the failure to ADB happens with and without the modem board plugged into the M0090 board?
                        In other words, can you remove the modem itself from M0090, but leave M0090 plugged in to VOXL 2?
                        Did you get the Modem from us as well, or just M0090-3-02
                        Also, to be sure, did you ever buy any Quectel carrier boards from us? M0090-3-01?
                        If so, please be sure you did not accidentally swap them around since the Sierra modem device will not work properly with the M0090-3-01 board. And, vice versa.
                        (side note: M.2 standard is a very loose standard and many M.2 devices can only work in what they were sold into, especially B-key modems)
                        • VinnyV Vinny
                          Hi @Matthew-Wellner
                          Matthew Wellner
                          @Vinny - Quick update. The old VOXL2 that wasn't working is working when not setup with the Sierra wireless carrier board. It also works when hooked up to the Quectel carrier board. I haven't tried hooking up the Sierra wireless board to it again yet, but I have a feeling something wonky is going on with the Sierra wireless board / modem.
                          Matthew WellnerM VinnyV 2 Replies Last reply
                            Matthew Wellner
                            @Vinny - both carrier board have their respective modems installed.
                              VinnyV Offline
                              VinnyV Offline
                              Vinny
                              Hi @Matthew-Wellner
                              That sure sounds like it to me...
                              Feel free to send in the M0090-03-2 board to us for RMA if you think that is the culprit. I'll get notified when it does and I can inspect it for HW issues and we'll run it through a test routine as well.
                              Please feel free to ping on me when you get an RMA number (and let me know that number) and I'll alert our production team to notify me when it arrives.
                                VinnyV Offline
                                VinnyV Offline
                                Vinny
                                @Matthew-Wellner
                                And, FWIW, your VOXL 2 with the cracked J3 will still work normally in most instances. It is just some plug-in boards may be more sensitive to that, so I'd delegate that specific HW to other purposes if you can.
                                • VinnyV Vinny
                                  Hi @Matthew-Wellner
                                  Matthew Wellner
                                  @Vinny - We have a demo for a government customer next week that I was hoping we didn't have to cancel. Is there anything short of an RMA that we can try? We can't use the Q
                                  Quectel modem since it's not NDAA compliant. Also - how do I get enough reputation points so that I can post faster than every 2 minutes? 🙂
                                    VinnyV Offline
                                    VinnyV Offline
                                    Vinny
                                    Hi @Matthew-Wellner
                                    I alerted our team to see if anyone has any other ideas. I can't promise production items or turn-around times (but some one might be able to 😉 )
                                    • VinnyV Vinny
                                      Hi @Matthew-Wellner
                                      What exactly is needed? A new M0090-3-02?
                                        VinnyV Offline
                                        VinnyV Offline
                                        Vinny
                                        @Moderator That is what the high level failure description seems to imply.
                                        @Matthew-Wellner Are you able to order another one? My team tells me we have them in-stock, and we can ask for expedite (but I can't assure that). Then we can process the RMA later if that works for you.
                                        ModeratorM Matthew WellnerM 2 Replies Last reply
                                        • VinnyV Vinny
