  3. VOXL2 microdds agent namespace
8 Posts 3 Posters 1.9k Views 2 Watching
  • Darshit DesaiD Offline
    Darshit Desai
    Hi @Moderator I am wondering if I can change the namespace as mentioned in the PX4-ROS2 docs here https://docs.px4.io/main/en/ros/ros2_comm.html#customizing-the-topic-namespace . I have 5 starlings in a swarm and I fear that at some point all of them might be subscribing or publishing to the same topic
    ModeratorM 1 Reply Last reply
      @Darshit-Desai it doesn't seem voxl-mpa-to-ros2 supports that today. Have you thought about modifying the code to add that feature?
      Darshit DesaiD 2 Replies Last reply
      • ModeratorM Moderator
        Darshit Desai
        wrote on last edited by Darshit Desai
        @Moderator Actually this is related to MicroUXRCE Agent for streaming PX4 FMU uORB topics as ROS2 topics, there is a way to rename the namespace for that but in MODAL AI I am not sure. MPATOROS2 is perfectly fine, I can just change the namespace using this command and that is not the issue here: ros2 run voxl_mpa_to_ros2 voxl_mpa_to_ros2_node --ros-args -r __ns:=/drone3. I am talking about when there is no mpatoros2 node running and the Microdds agent streams the PX4 uorb topics as shown below:
          Darshit Desai
          @Moderator THe only way to change microdds namespace is through QGC I tried that and it worked, but the issue is I need to manually type it up on each bootup of the FMU. As shown below:
          Microdds service stopped and started with a namespace
          Topics remapped on VOXL2
          So I thought I could change the voxl-px4.conf to include this as a qshell command but that also didn't work as shown below
          voxl-px4.conf file v1
          voxl-px4.conf file v2
          Both versions resulted in the Error in the restart/power cycle of systemd service
            @Darshit-Desai Rather than modifying voxl-px4.conf to use EXTRA_STEPS, can you try directly modifying /usr/bin/voxl-px4-start and adding that command?
            Darshit DesaiD 1 Reply Last reply
              Darshit Desai
              Hi @Eric-Katzfey that worked, now I actually want to export a variable which states the namespace of the relevant drone and the voxl-px4-start file picks up that variable and assigns the namespace but I am facing some errors because of that, could you have a look
              Here's my bashrc file
              #!/bin/bash
              # ModalAI default bashrc file
              #VERSION 1.2
              # If not running interactively, don't do anything
              case $- in
                  *i*) ;;
                    *) return;;
              esac
              # don't put duplicate lines or lines starting with space in the history.
              # See bash(1) for more options
              HISTCONTROL=ignoreboth
              # append to the history file, don't overwrite it
              shopt -s histappend
              # for setting history length see HISTSIZE and HISTFILESIZE in bash(1)
              HISTSIZE=1000
              HISTFILESIZE=2000
              # check the window size after each command and, if necessary,
              # update the values of LINES and COLUMNS.
              shopt -s checkwinsize
              # ubuntu ssh sets TERM to xterm-256color which screws with ROS
              # change it to linux spec
              export TERM=linux
              if [ -d /home/root/.profile.d/ ]; then
                for i in /home/root/.profile.d/* ; do
                  if [ -d $i ]; then
                      for j in $i/* ; do
                          if [ -f $j ]; then
                              . $j
                          fi
                      done
                  else
                      . $i
                  fi
                done
              fi
              # Put user-specific tweaks here or in a file in ~/.profile.d/
              export PX4_NAMESPACE="uav_1"
              Here's my voxl-px4-start file
              #!/bin/sh
              # PX4 commands need the 'px4-' prefix in bash.
              # (px4-alias.sh is expected to be in the PATH)
              . px4-alias.sh
              echo -e "\n*************************"
              echo "GPS: $GPS"
              echo "RC: $RC"
              echo "ESC: $ESC"
              echo "POWER MANAGER: $POWER_MANAGER"
              echo "DISTANCE SENSOR: $DISTANCE_SENSOR"
              echo "OSD: $OSD"
              echo "EXTRA STEPS:"
              for i in "${EXTRA_STEPS[@]}"
              do
              	echo -e "\t$i"
              done
              echo -e "*************************\n"
              # In order to just exit after starting the uorb / muorb modules define
              # the environment variable MINIMAL_PX4. (e.g. export MINIMAL_PX4=1)
              # This is useful for testing / debug where you may want to start drivers
              # and modules manually from the px4 command shell
              if [ ! -z $MINIMAL_PX4 ]; then
                  /bin/echo "Running minimal script"
                  exit 0
              fi
              # Figure out what platform we are running on.
              PLATFORM=`/usr/bin/voxl-platform 2> /dev/null`
              RETURNCODE=$?
              if [ $RETURNCODE -ne 0 ]; then
                  # If we couldn't get the platform from the voxl-platform utility then check
                  # /etc/version to see if there is an M0052 substring in the version string. If so,
                  # then we assume that we are on M0052.
                  VERSIONSTRING=$(</etc/version)
                  M0052SUBSTRING="M0052"
                  if [[ "$VERSIONSTRING" == *"$M0052SUBSTRING"* ]]; then
                      PLATFORM="M0052"
                  fi
              fi
              # We can only run on M0052, M0054, or M0104 so exit with error if that is not the case
              if [ $PLATFORM = "M0052" ]; then
                  /bin/echo "Running on M0052"
              elif [ $PLATFORM = "M0054" ]; then
                  /bin/echo "Running on M0054"
              elif [ $PLATFORM = "M0104" ]; then
                  /bin/echo "Running on M0104"
              else
                  /bin/echo "Error, cannot determine platform!"
                  exit 0
              fi
              # Sleep a little here. A lot happens when the uorb and muorb start
              # and we need to make sure that it all completes successfully to avoid
              # any possible race conditions.
              /bin/sleep 1
              param select /data/px4/param/parameters
              # Load in all of the parameters that have been saved in the file
              param load
              # Start logging and use timestamps for log files when possible.
              # Add the "-e" option to start logging immediately. Default is
              # to log only when armed. Caution must be used with the "-e" option
              # because if power is removed without stopping the logger gracefully then
              # the log file may be corrupted.
              logger start -t
              # IMU (accelerometer / gyroscope)
              if [ "$PLATFORM" == "M0104" ]; then
                  /bin/echo "Starting IMU driver with rotation 12"
                  qshell icm42688p start -s -R 12
              else
                  /bin/echo "Starting IMU driver with no rotation"
              fi
              # Start Invensense ICP 101xx barometer built on to VOXL 2
              qshell icp101xx start -I -b 5
              # Auto detect the magnetometer. If one or both of these devices
              # are not connected it will fail but not cause any harm.
              /bin/echo "Looking for qmc5883l magnetometer"
              qshell qmc5883l start -R 10 -X -b 1
              /bin/echo "Looking for ist8310 magnetometer"
              qshell ist8310 start -R 10 -X -b 1
              # GPS and magnetometer
              if [ "$GPS" != "NONE" ]; then
              	# On M0052 the GPS driver runs on the apps processor
              	    gps start -d /dev/ttyHS2
              	# On M0054 and M0104 the GPS driver runs on SLPI DSP
              	else
              	    qshell gps start
              	fi
              fi
              # Auto detect an ncp5623c i2c RGB LED. If one isn't connected this will
              # fail but not cause any harm.
              /bin/echo "Looking for ncp5623c RGB LED"
              qshell rgbled_ncp5623c start -X -b 1 -f 400 -a 56
              # We do not change the value of SYS_AUTOCONFIG but if it does not
              # show up as used then it is not reported to QGC and we get a
              # missing parameter error.
              param touch SYS_AUTOCONFIG
              # ESC driver
              if [ "$ESC" == "VOXL_ESC" ]; then
                  /bin/echo "Starting VOXL ESC driver"
              	qshell voxl_esc start
              elif [ "$ESC" == "VOXL2_IO_PWM_ESC" ]; then
              	if [ "$RC" == "M0065_SBUS" ]; then
              		/bin/echo "Starting VOXL IO for PWM ESC with SBUS RC"
              		qshell voxl2_io start
              	else
              		/bin/echo "Starting VOXL IO for PWM ESC without SBUS RC"
              		qshell voxl2_io start -e
              	fi
              else
              	/bin/echo "No ESC type specified, not starting an ESC driver"
              fi
              # RC driver
              if [ "$RC" == "FAKE_RC_INPUT" ]; then
                  /bin/echo "Starting fake RC driver"
                  qshell rc_controller start
              elif [ "$RC" == "CRSF_RAW" ]; then
                  /bin/echo "Starting CRSF RC driver"
                  qshell crsf_rc start -d 7
              elif [ "$RC" == "CRSF_MAV" ]; then
                  /bin/echo "Starting TBS crossfire RC - MAV Mode"
                  qshell mavlink_rc_in start -m -p 7 -b 115200
              elif [ "$RC" == "SPEKTRUM" ]; then
                  /bin/echo "Starting Spektrum RC"
              	# On M0052 the RC driver runs on the apps processor
                      rc_input start -d /dev/ttyHS1
              	# On M0054 and M0104 the RC driver runs on SLPI DSP
              	else
                      qshell spektrum_rc start
              	fi
              elif [ "$RC" == "GHST" ]; then
                  /bin/echo "Starting GHST RC driver"
                  qshell ghst_rc start -d 7
              elif [ "$RC" == "M0065_SBUS" ]; then
              		apps_sbus start
              	elif [ "$ESC" != "VOXL2_IO_PWM_ESC" ]; then
                  	/bin/echo "Attempting to start M0065 SBUS RC driver for original M0065 FW"
                  	qshell dsp_sbus start
              		retVal=$?
              		if [ $retVal -ne 0 ]; then
              	    	/bin/echo "Starting M0065 SBUS RC driver for original M0065 FW failed"
              	    	/bin/echo "Attempting to start M0065 SBUS RC driver for new M0065 FW"
              			qshell voxl2_io start -d -p 7
              		fi
              	else
                  	/bin/echo "M0065 SBUS RC driver already started with PWM ESC start"
              	fi
              fi
              if [ "$DISTANCE_SENSOR" == "LIGHTWARE_SF000" ]; then
              	# Make sure to set the parameter SENS_EN_SF0X to 8 for sf000/b sensor
              	qshell lightware_laser_serial start -d 7
              fi
              if [ "$POWER_MANAGER" == "VOXLPM" ]; then
              	# APM power monitor
              	qshell voxlpm start -X -b 2
              fi
              # Optional distance sensor on spare i2c
              # qshell vl53l0x start -X -b 4
              # qshell vl53l1x start -X -b 4
              # Start all of the processing modules on DSP
              qshell sensors start
              qshell ekf2 start
              qshell mc_pos_control start
              qshell mc_att_control start
              qshell mc_rate_control start
              qshell mc_hover_thrust_estimator start
              qshell mc_autotune_attitude_control start
              qshell land_detector start multicopter
              qshell manual_control start
              qshell control_allocator start
              qshell load_mon start
              # Only start the rc_update module if an actual RC driver
              # is publishing input_rc topics. Otherwise for external RC
              # over Mavlink this isn't needed.
              if [ "$RC" != "EXTERNAL" ]; then
              	qshell rc_update start
              fi
              qshell commander start
              # This is needed for altitude and position hold modes
              qshell flight_mode_manager start
              # Start all of the processing modules on the applications processor
              dataman start
              navigator start
              load_mon start
              # This bridge allows raw data packets to be sent over UART to the ESC
              modal_io_bridge start
              # Start microdds_client for ros2 offboard messages from agent over localhost
              microdds_client start -t udp -h 127.0.0.1 -p 8888 -n $PX4_NAMESPACE
              # On M0052 there is only one IMU. So, PX4 needs to
              # publish IMU samples externally for VIO to use.
              	imu_server start
              fi
              # start the onboard fast link to connect to voxl-mavlink-server
              mavlink start -x -u 14556 -o 14557 -r 100000 -n lo -m onboard
              # slow down some of the fastest streams
              mavlink stream -u 14556 -s HIGHRES_IMU -r 10
              mavlink stream -u 14556 -s ATTITUDE -r 10
              mavlink stream -u 14556 -s ATTITUDE_QUATERNION -r 10
              mavlink stream -u 14556 -s GLOBAL_POSITION_INT -r 30
              mavlink stream -u 14556 -s SCALED_PRESSURE -r 10
              # start the slow normal mode for voxl-mavlink-server to forward to GCS
              mavlink start -x -u 14558 -o 14559 -r 100000 -n lo
              mavlink boot_complete
              # Optional MSP OSD driver for DJI goggles
              # This is only supported on M0054 (with M0125 accessory board)
              if [ "$OSD" == "ENABLE" ]; then
                  /bin/echo "Starting OSD driver"
                  msp_osd start -d /dev/ttyHS1
              fi
              # Start optional EXTRA_STEPS
              do
              	$i
              done
              The errors that I get:
                #!/bin/bash
                #VERSION 1.2
                case $- in
                    *i*) ;;
                      *) return;;
                esac
                shopt -s histappend
                HISTSIZE=1000
                HISTFILESIZE=2000
                export TERM=linux
                    if [ -d $i ]; then
                        for j in $i/* ; do
                            if [ -f $j ]; then
                                . $j
                            fi
                        done
                    else
                        . $i
                    fi
                  done
                fi
                #!/bin/sh
                . px4-alias.sh
                echo "GPS: $GPS"
                echo "RC: $RC"
                echo "ESC: $ESC"
                echo "OSD: $OSD"
                echo "EXTRA STEPS:"
                do
                	echo -e "\t$i"
                done
                    exit 0
                fi
                RETURNCODE=$?
                        PLATFORM="M0052"
                    fi
                fi
                else
                    exit 0
                fi
                /bin/sleep 1
                param load
                logger start -t
                else
                fi
                	else
                	    qshell gps start
                	fi
                fi
                # ESC driver
                	else
                	fi
                else
                fi
                # RC driver
                	else
                	fi
                		apps_sbus start
                		retVal=$?
                		fi
                	else
                	fi
                fi
                fi
                	# APM power monitor
                fi
                qshell ekf2 start
                fi
                dataman start
                navigator start
                load_mon start
                	imu_server start
                fi
                fi
                do
                	$i
                done
                @Darshit-Desai Seems like some bash scripting issues. Perhaps echo $PX4_NAMESPACE before the microdds_client start line to see what is in that variable.
                  Darshit Desai
                  @Eric-Katzfey I know this is a question for the px4 forum, but can you guys help me figure out how to run the https://github.com/PX4/px4_ros_com/blob/main/src/examples/offboard/offboard_control_srv.cpp service server here. I changed the namespace for my microdds client as you know and I am not sure if that service server is running or not, I can't find the server when I do ros2 service list or ros2 service find
