    VOXL2 microdds agent namespace
    1329
    • Darshit DesaiD
      Darshit Desai
      Hi @Moderator I am wondering if I can change the namespace as mentioned in the PX4-ROS2 docs here https://docs.px4.io/main/en/ros/ros2_comm.html#customizing-the-topic-namespace . I have 5 starlings in a swarm and I fear that at some point all of them might be subscribing or publishing to the same topic
      • ModeratorM
        Moderator ModalAI Team @Darshit Desai
        @Darshit-Desai it doesn't seem voxl-mpa-to-ros2 supports that today. Have you thought about modifying the code to add that feature?
        Darshit DesaiD 2 Replies Last reply Reply Quote 0
        • Darshit DesaiD
          Darshit Desai @Moderator
          @Moderator Actually this is related to MicroUXRCE Agent for streaming PX4 FMU uORB topics as ROS2 topics, there is a way to rename the namespace for that but in MODAL AI I am not sure. MPATOROS2 is perfectly fine, I can just change the namespace using this command and that is not the issue here: ros2 run voxl_mpa_to_ros2 voxl_mpa_to_ros2_node --ros-args -r __ns:=/drone3. I am talking about when there is no mpatoros2 node running and the Microdds agent streams the PX4 uorb topics as shown below:
            @Moderator THe only way to change microdds namespace is through QGC I tried that and it worked, but the issue is I need to manually type it up on each bootup of the FMU. As shown below:
            Microdds service stopped and started with a namespace
            Topics remapped on VOXL2
            So I thought I could change the voxl-px4.conf to include this as a qshell command but that also didn't work as shown below
            voxl-px4.conf file v1
            voxl-px4.conf file v2
            Both versions resulted in the Error in the restart/power cycle of systemd service
              Eric Katzfey ModalAI Team @Darshit Desai
              @Darshit-Desai Rather than modifying voxl-px4.conf to use EXTRA_STEPS, can you try directly modifying /usr/bin/voxl-px4-start and adding that command?
              Darshit DesaiD 1 Reply Last reply Reply Quote 0
              • Darshit DesaiD
                Darshit Desai @Eric Katzfey
                Hi @Eric-Katzfey that worked, now I actually want to export a variable which states the namespace of the relevant drone and the voxl-px4-start file picks up that variable and assigns the namespace but I am facing some errors because of that, could you have a look
                Here's my bashrc file
                #!/bin/bash
                # ModalAI default bashrc file
                #VERSION 1.2
                # If not running interactively, don't do anything
                case $- in
                    *i*) ;;
                      *) return;;
                esac
                # don't put duplicate lines or lines starting with space in the history.
                # See bash(1) for more options
                HISTCONTROL=ignoreboth
                # append to the history file, don't overwrite it
                shopt -s histappend
                # for setting history length see HISTSIZE and HISTFILESIZE in bash(1)
                HISTSIZE=1000
                HISTFILESIZE=2000
                # check the window size after each command and, if necessary,
                # update the values of LINES and COLUMNS.
                shopt -s checkwinsize
                # ubuntu ssh sets TERM to xterm-256color which screws with ROS
                # change it to linux spec
                export TERM=linux
                if [ -d /home/root/.profile.d/ ]; then
                  for i in /home/root/.profile.d/* ; do
                    if [ -d $i ]; then
                        for j in $i/* ; do
                            if [ -f $j ]; then
                                . $j
                            fi
                        done
                    else
                        . $i
                    fi
                  done
                fi
                # Put user-specific tweaks here or in a file in ~/.profile.d/
                export PX4_NAMESPACE="uav_1"
                Here's my voxl-px4-start file
                #!/bin/sh
                # PX4 commands need the 'px4-' prefix in bash.
                # (px4-alias.sh is expected to be in the PATH)
                . px4-alias.sh
                echo -e "\n*************************"
                echo "GPS: $GPS"
                echo "RC: $RC"
                echo "ESC: $ESC"
                echo "POWER MANAGER: $POWER_MANAGER"
                echo "DISTANCE SENSOR: $DISTANCE_SENSOR"
                echo "OSD: $OSD"
                echo "EXTRA STEPS:"
                for i in "${EXTRA_STEPS[@]}"
                do
                	echo -e "\t$i"
                done
                echo -e "*************************\n"
                # In order to just exit after starting the uorb / muorb modules define
                # the environment variable MINIMAL_PX4. (e.g. export MINIMAL_PX4=1)
                # This is useful for testing / debug where you may want to start drivers
                # and modules manually from the px4 command shell
                if [ ! -z $MINIMAL_PX4 ]; then
                    /bin/echo "Running minimal script"
                    exit 0
                fi
                # Figure out what platform we are running on.
                PLATFORM=`/usr/bin/voxl-platform 2> /dev/null`
                RETURNCODE=$?
                if [ $RETURNCODE -ne 0 ]; then
                    # If we couldn't get the platform from the voxl-platform utility then check
                    # /etc/version to see if there is an M0052 substring in the version string. If so,
                    # then we assume that we are on M0052.
                    VERSIONSTRING=$(</etc/version)
                    M0052SUBSTRING="M0052"
                    if [[ "$VERSIONSTRING" == *"$M0052SUBSTRING"* ]]; then
                        PLATFORM="M0052"
                    fi
                fi
                # We can only run on M0052, M0054, or M0104 so exit with error if that is not the case
                if [ $PLATFORM = "M0052" ]; then
                    /bin/echo "Running on M0052"
                elif [ $PLATFORM = "M0054" ]; then
                    /bin/echo "Running on M0054"
                elif [ $PLATFORM = "M0104" ]; then
                    /bin/echo "Running on M0104"
                else
                    /bin/echo "Error, cannot determine platform!"
                    exit 0
                fi
                # Sleep a little here. A lot happens when the uorb and muorb start
                # and we need to make sure that it all completes successfully to avoid
                # any possible race conditions.
                /bin/sleep 1
                param select /data/px4/param/parameters
                # Load in all of the parameters that have been saved in the file
                param load
                # Start logging and use timestamps for log files when possible.
                # Add the "-e" option to start logging immediately. Default is
                # to log only when armed. Caution must be used with the "-e" option
                # because if power is removed without stopping the logger gracefully then
                # the log file may be corrupted.
                logger start -t
                # IMU (accelerometer / gyroscope)
                if [ "$PLATFORM" == "M0104" ]; then
                    /bin/echo "Starting IMU driver with rotation 12"
                    qshell icm42688p start -s -R 12
                else
                    /bin/echo "Starting IMU driver with no rotation"
                fi
                # Start Invensense ICP 101xx barometer built on to VOXL 2
                qshell icp101xx start -I -b 5
                # Auto detect the magnetometer. If one or both of these devices
                # are not connected it will fail but not cause any harm.
                /bin/echo "Looking for qmc5883l magnetometer"
                /bin/echo "Looking for ist8310 magnetometer"
                # GPS and magnetometer
                if [ "$GPS" != "NONE" ]; then
                	# On M0052 the GPS driver runs on the apps processor
                	    gps start -d /dev/ttyHS2
                	# On M0054 and M0104 the GPS driver runs on SLPI DSP
                	else
                	    qshell gps start
                	fi
                fi
                # Auto detect an ncp5623c i2c RGB LED. If one isn't connected this will
                # fail but not cause any harm.
                /bin/echo "Looking for ncp5623c RGB LED"
                qshell rgbled_ncp5623c start -X -b 1 -f 400 -a 56
                # We do not change the value of SYS_AUTOCONFIG but if it does not
                # show up as used then it is not reported to QGC and we get a
                # missing parameter error.
                param touch SYS_AUTOCONFIG
                # ESC driver
                if [ "$ESC" == "VOXL_ESC" ]; then
                    /bin/echo "Starting VOXL ESC driver"
                	qshell voxl_esc start
                elif [ "$ESC" == "VOXL2_IO_PWM_ESC" ]; then
                	if [ "$RC" == "M0065_SBUS" ]; then
                		/bin/echo "Starting VOXL IO for PWM ESC with SBUS RC"
                		qshell voxl2_io start
                	else
                		/bin/echo "Starting VOXL IO for PWM ESC without SBUS RC"
                		qshell voxl2_io start -e
                	fi
                else
                	/bin/echo "No ESC type specified, not starting an ESC driver"
                fi
                # RC driver
                if [ "$RC" == "FAKE_RC_INPUT" ]; then
                    /bin/echo "Starting fake RC driver"
                    qshell rc_controller start
                elif [ "$RC" == "CRSF_RAW" ]; then
                    /bin/echo "Starting CRSF RC driver"
                    qshell crsf_rc start -d 7
                elif [ "$RC" == "CRSF_MAV" ]; then
                    /bin/echo "Starting TBS crossfire RC - MAV Mode"
                    qshell mavlink_rc_in start -m -p 7 -b 115200
                elif [ "$RC" == "SPEKTRUM" ]; then
                    /bin/echo "Starting Spektrum RC"
                	# On M0052 the RC driver runs on the apps processor
                        rc_input start -d /dev/ttyHS1
                	# On M0054 and M0104 the RC driver runs on SLPI DSP
                	else
                        qshell spektrum_rc start
                	fi
                elif [ "$RC" == "GHST" ]; then
                    /bin/echo "Starting GHST RC driver"
                    qshell ghst_rc start -d 7
                elif [ "$RC" == "M0065_SBUS" ]; then
                		apps_sbus start
                	elif [ "$ESC" != "VOXL2_IO_PWM_ESC" ]; then
                    	/bin/echo "Attempting to start M0065 SBUS RC driver for original M0065 FW"
                    	qshell dsp_sbus start
                		retVal=$?
                		if [ $retVal -ne 0 ]; then
                	    	/bin/echo "Starting M0065 SBUS RC driver for original M0065 FW failed"
                	    	/bin/echo "Attempting to start M0065 SBUS RC driver for new M0065 FW"
                			qshell voxl2_io start -d -p 7
                		fi
                	else
                    	/bin/echo "M0065 SBUS RC driver already started with PWM ESC start"
                	fi
                fi
                if [ "$DISTANCE_SENSOR" == "LIGHTWARE_SF000" ]; then
                	# Make sure to set the parameter SENS_EN_SF0X to 8 for sf000/b sensor
                	qshell lightware_laser_serial start -d 7
                fi
                if [ "$POWER_MANAGER" == "VOXLPM" ]; then
                	# APM power monitor
                	qshell voxlpm start -X -b 2
                fi
                # Optional distance sensor on spare i2c
                # qshell vl53l0x start -X -b 4
                # qshell vl53l1x start -X -b 4
                # Start all of the processing modules on DSP
                qshell sensors start
                qshell ekf2 start
                qshell mc_pos_control start
                qshell mc_att_control start
                qshell mc_rate_control start
                qshell mc_hover_thrust_estimator start
                qshell mc_autotune_attitude_control start
                qshell land_detector start multicopter
                qshell manual_control start
                qshell control_allocator start
                qshell load_mon start
                # Only start the rc_update module if an actual RC driver
                # is publishing input_rc topics. Otherwise for external RC
                # over Mavlink this isn't needed.
                if [ "$RC" != "EXTERNAL" ]; then
                	qshell rc_update start
                fi
                qshell commander start
                # This is needed for altitude and position hold modes
                qshell flight_mode_manager start
                # Start all of the processing modules on the applications processor
                dataman start
                navigator start
                load_mon start
                # This bridge allows raw data packets to be sent over UART to the ESC
                modal_io_bridge start
                # Start microdds_client for ros2 offboard messages from agent over localhost
                microdds_client start -t udp -h 127.0.0.1 -p 8888 -n $PX4_NAMESPACE
                # On M0052 there is only one IMU. So, PX4 needs to
                # publish IMU samples externally for VIO to use.
                	imu_server start
                fi
                # start the onboard fast link to connect to voxl-mavlink-server
                mavlink start -x -u 14556 -o 14557 -r 100000 -n lo -m onboard
                # slow down some of the fastest streams
                mavlink stream -u 14556 -s HIGHRES_IMU -r 10
                mavlink stream -u 14556 -s ATTITUDE -r 10
                mavlink stream -u 14556 -s ATTITUDE_QUATERNION -r 10
                mavlink stream -u 14556 -s GLOBAL_POSITION_INT -r 30
                mavlink stream -u 14556 -s SCALED_PRESSURE -r 10
                # start the slow normal mode for voxl-mavlink-server to forward to GCS
                mavlink start -x -u 14558 -o 14559 -r 100000 -n lo
                mavlink boot_complete
                # Optional MSP OSD driver for DJI goggles
                # This is only supported on M0054 (with M0125 accessory board)
                if [ "$OSD" == "ENABLE" ]; then
                    /bin/echo "Starting OSD driver"
                    msp_osd start -d /dev/ttyHS1
                fi
                # Start optional EXTRA_STEPS
                do
                	$i
                done
                The errors that I get:
                  @Darshit-Desai Seems like some bash scripting issues. Perhaps echo $PX4_NAMESPACE before the microdds_client start line to see what is in that variable.
                    @Eric-Katzfey I know this is a question for the px4 forum, but can you guys help me figure out how to run the https://github.com/PX4/px4_ros_com/blob/main/src/examples/offboard/offboard_control_srv.cpp service server here. I changed the namespace for my microdds client as you know and I am not sure if that service server is running or not, I can't find the server when I do ros2 service list or ros2 service find
