  3. Camera server failing after the update
5 Posts 3 Posters 1.1k Views 2 Watching
  • R Offline
    R Offline
    riteshsharma
    Voxl-camera-server is failing after I upgraded the packages on starling drone.
    voxl2:/$ voxl-version
    system-image: 1.7.4-M0054-14.1a-perf
    kernel:       #1 SMP PREEMPT Fri Feb 9 21:59:24 UTC 2024 4.19.125
    hw platform:  M0054
    mach.var:     1.0
    voxl-suite:   1.2.0-202404022201
    Packages:
    Repo:  http://voxl-packages.modalai.com/ ./dists/qrb5165/dev/binary-arm64/
    Last Updated: 2024-04-03 16:41:43
    List:
    libmodal-cv                               0.5.5-202402131035
    libmodal-exposure                         0.1.0-202310231718
    libmodal-journal                          0.2.2-202211021731
    libmodal-json                             0.4.3-202209281920
    libmodal-pipe                             2.10.0-202311162306
    libqrb5165-io                             0.4.4-202401141445
    libvoxl-cci-direct                        0.2.1-202309211746
    libvoxl-cutils                            0.1.1-202210072352
    modalai-slpi                              1.1.12-202312191452
    qrb5165-dfs-server                        0.2.0-202309221318
    qrb5165-imu-server                        1.0.1-202312010251
    qrb5165-rangefinder-server                0.1.1-202312111703
    qrb5165-system-tweaks                     0.2.6-202402151128
    qrb5165-tflite                            2.8.0-2-202210071637
    voxl-bind-spektrum                        0.1.1-202403271220
    voxl-camera-calibration                   0.5.4-202401081655
    voxl-camera-server                        1.9.0-202403211533
    voxl-capture                              0.0.1-202206110121
    voxl-ceres-solver                         2:1.14.0-10-202310130020
    voxl-configurator                         0.5.3-202403121650
    voxl-cpu-monitor                          0.4.8-202402061134
    voxl-docker-support                       1.3.0-202309201525
    voxl-elrs                                 0.2.1-202403141429
    voxl-esc                                  1.4.0-202403251514
    voxl-feature-tracker                      0.3.8-202403261346
    voxl-flow-server                          0.3.6-202403180603
    voxl-gphoto2-server                       0.0.10-202210072352
    voxl-jpeg-turbo                           2.1.3-5-202311071550
    voxl-lepton-server                        1.2.1-202403180611
    voxl-lepton-tracker                       0.0.1-202402261317
    voxl-libgphoto2                           0.0.4-202204111958
    voxl-libuvc                               1.0.7-202210072357
    voxl-logger                               0.3.12-202403261022
    voxl-mapper                               0.2.1-202403201826
    voxl-mavcam-manager                       0.5.4-202401290941
    voxl-mavlink                              0.1.1-202305011701
    voxl-mavlink-server                       1.4.0-202403191520
    voxl-microdds-agent                       2.4.1-0-202311211206
    voxl-modem                                1.0.9-202403121543
    voxl-mongoose                             7.7.0-1-202210072105
    voxl-mpa-to-ros                           0.3.7-202310131817
    voxl-mpa-to-ros2                          0.0.2-202402291159
    voxl-mpa-tools                            1.1.5-202403201735
    voxl-neopixel-manager                     0.0.3-202312061522
    voxl-nlopt                                2.5.0-4-202210072358
    voxl-open-vins                            0.4.10-202403281925
    voxl-open-vins-server                     0.2.46-202403281925
    voxl-opencv                               4.5.5-2-202311071601
    voxl-portal                               0.6.5-202403201802
    voxl-px4                                  1.14.0-2.0.69-202402061301
    voxl-px4-imu-server                       0.1.2-202205131833
    voxl-px4-params                           0.3.6-202403111442
    voxl-qvio-server                          1.0.2-202403151128
    voxl-remote-id                            0.0.9-202309191605
    voxl-ros2-foxy                            0.0.1-202310061042
    voxl-rtp                                  0.0.1-202206101543
    voxl-stitcher                             0.0.2-202206161634
    voxl-streamer                             0.7.4-202309221610
    voxl-suite                                1.2.0-202404022201
    voxl-tag-detector                         0.0.4-202206302112
    voxl-tflite-server                        0.3.2-202401161222
    voxl-utils                                1.3.8-202402131713
    voxl-uvc-server                           0.1.6-202311050848
    voxl-vision-hub                           1.7.4-202401161503
    voxl-voxblox                              1.1.5-202310122350
    voxl-wifi-broadcast                       0.0.10-202206122258
    voxl2-io                                  0.0.1-202401181810
    voxl2-system-image                        1.7.4-r0
    voxl2:/$ voxl-inspect-services
    Scanning services...
    Service Name | Enabled | Running | CPU Usage
    docker-autorun | Disabled | Not Running |
    modallink-relink | Disabled | Not Running |
    voxl-camera-server | Enabled | Not Running |
    voxl-cpu-monitor | Enabled | Running | 0.7%
    voxl-dfs-server | Disabled | Not Running |
    voxl-feature-tracker | Disabled | Not Running |
    voxl-flow-server | Disabled | Not Running |
    voxl-imu-server | Enabled | Running | 6.0%
    voxl-lepton-server | Disabled | Not Running |
    voxl-lepton-tracker | Disabled | Not Running |
    voxl-mapper | Enabled | Running | 0.4%
    voxl-mavcam-manager | Enabled | Running | 0.0%
    voxl-mavlink-server | Enabled | Running | 4.4%
    voxl-microdds-agent | Disabled | Not Running |
    voxl-modem | Disabled | Not Running |
    voxl-neopixel-manager | Disabled | Not Running |
    voxl-open-vins-server | Disabled | Not Running |
    voxl-portal | Enabled | Running | 0.6%
    voxl-px4-imu-server | Disabled | Not Running |
    voxl-px4 | Enabled | Running | 38.9%
    voxl-qvio-server | Enabled | Running | 5.0%
    voxl-rangefinder-server | Disabled | Not Running |
    voxl-remote-id | Disabled | Not Running |
    voxl-softap | Disabled | Not Running |
    voxl-static-ip | Disabled | Not Running |
    voxl-stitcher | Disabled | Not Running |
    voxl-streamer | Enabled | Running | 0.1%
    voxl-tag-detector | Disabled | Not Running |
    voxl-tflite-server | Disabled | Not Running |
    voxl-time-sync | Disabled | Not Running |
    voxl-uvc-server | Disabled | Not Running |
    voxl-vision-hub | Enabled | Running | 1.8%
    voxl-wait-for-fs | Enabled | Completed |
    voxl-wfb-rx-video | Disabled | Not Running |
    voxl-wfb-rx | Disabled | Not Running |
    voxl-wfb-tx-video | Disabled | Not Running |
    voxl-wfb-tx | Disabled | Not Running |
    voxl2:/$ voxl-camera-server
    voxl-camera-server: symbol lookup error: voxl-camera-server: undefined symbol: _ZTIN6royale3pal13II2cBusAccessE
    • R riteshsharma
      hw platform:  M0054
      mach.var:     1.0
      Packages:
      List:
      @riteshsharma The current "dev" repo of voxl-suite isn't expected to work with system image 1.7.4 so there is some software version mismatching going on.
      You'd have to use a newer system image which at this point would only be available in one of our full nightly SDK builds
      R 1 Reply Last reply
        R Offline
        R Offline
        riteshsharma
        @tom In that case, how can I downgrade and go back to initial stage. Do you have any suggestion?
        tomT Alex KushleyevA 2 Replies Last reply
        • R riteshsharma
          @riteshsharma I would recommend just re-flashing our latest standard SDK (1.1.3) to ensure you're at a clean spot
          https://docs.modalai.com/flash-system-image/#flashing-a-voxl-sdk-release
          • R riteshsharma
            @riteshsharma , based on changelog (https://gitlab.com/voxl-public/voxl-sdk/services/voxl-camera-server/-/blob/master/CHANGELOG) you can use voxl-camera-server package version 1.8.10 -- dowload it from here http://voxl-packages.modalai.com/dists/qrb5165/dev/binary-arm64/.
            Upgrading your SDK would also work as Tom suggested.
