    Camera server failing after the update
    • R
      riteshsharma
      Voxl-camera-server is failing after I upgraded the packages on starling drone.
      voxl2:/$ voxl-version
      system-image: 1.7.4-M0054-14.1a-perf
      kernel:       #1 SMP PREEMPT Fri Feb 9 21:59:24 UTC 2024 4.19.125
      hw platform:  M0054
      mach.var:     1.0
      voxl-suite:   1.2.0-202404022201
      Packages:
      Repo:  http://voxl-packages.modalai.com/ ./dists/qrb5165/dev/binary-arm64/
      Last Updated: 2024-04-03 16:41:43
      List:
      libmodal-cv                               0.5.5-202402131035
      libmodal-exposure                         0.1.0-202310231718
      libmodal-journal                          0.2.2-202211021731
      libmodal-json                             0.4.3-202209281920
      libmodal-pipe                             2.10.0-202311162306
      libqrb5165-io                             0.4.4-202401141445
      libvoxl-cci-direct                        0.2.1-202309211746
      libvoxl-cutils                            0.1.1-202210072352
      modalai-slpi                              1.1.12-202312191452
      qrb5165-dfs-server                        0.2.0-202309221318
      qrb5165-imu-server                        1.0.1-202312010251
      qrb5165-rangefinder-server                0.1.1-202312111703
      qrb5165-system-tweaks                     0.2.6-202402151128
      qrb5165-tflite                            2.8.0-2-202210071637
      voxl-bind-spektrum                        0.1.1-202403271220
      voxl-camera-calibration                   0.5.4-202401081655
      voxl-camera-server                        1.9.0-202403211533
      voxl-capture                              0.0.1-202206110121
      voxl-ceres-solver                         2:1.14.0-10-202310130020
      voxl-configurator                         0.5.3-202403121650
      voxl-cpu-monitor                          0.4.8-202402061134
      voxl-docker-support                       1.3.0-202309201525
      voxl-elrs                                 0.2.1-202403141429
      voxl-esc                                  1.4.0-202403251514
      voxl-feature-tracker                      0.3.8-202403261346
      voxl-flow-server                          0.3.6-202403180603
      voxl-gphoto2-server                       0.0.10-202210072352
      voxl-jpeg-turbo                           2.1.3-5-202311071550
      voxl-lepton-server                        1.2.1-202403180611
      voxl-lepton-tracker                       0.0.1-202402261317
      voxl-libgphoto2                           0.0.4-202204111958
      voxl-libuvc                               1.0.7-202210072357
      voxl-logger                               0.3.12-202403261022
      voxl-mapper                               0.2.1-202403201826
      voxl-mavcam-manager                       0.5.4-202401290941
      voxl-mavlink                              0.1.1-202305011701
      voxl-mavlink-server                       1.4.0-202403191520
      voxl-microdds-agent                       2.4.1-0-202311211206
      voxl-modem                                1.0.9-202403121543
      voxl-mongoose                             7.7.0-1-202210072105
      voxl-mpa-to-ros                           0.3.7-202310131817
      voxl-mpa-to-ros2                          0.0.2-202402291159
      voxl-mpa-tools                            1.1.5-202403201735
      voxl-neopixel-manager                     0.0.3-202312061522
      voxl-nlopt                                2.5.0-4-202210072358
      voxl-open-vins                            0.4.10-202403281925
      voxl-open-vins-server                     0.2.46-202403281925
      voxl-opencv                               4.5.5-2-202311071601
      voxl-portal                               0.6.5-202403201802
      voxl-px4                                  1.14.0-2.0.69-202402061301
      voxl-px4-imu-server                       0.1.2-202205131833
      voxl-px4-params                           0.3.6-202403111442
      voxl-qvio-server                          1.0.2-202403151128
      voxl-remote-id                            0.0.9-202309191605
      voxl-ros2-foxy                            0.0.1-202310061042
      voxl-rtp                                  0.0.1-202206101543
      voxl-stitcher                             0.0.2-202206161634
      voxl-streamer                             0.7.4-202309221610
      voxl-suite                                1.2.0-202404022201
      voxl-tag-detector                         0.0.4-202206302112
      voxl-tflite-server                        0.3.2-202401161222
      voxl-utils                                1.3.8-202402131713
      voxl-uvc-server                           0.1.6-202311050848
      voxl-vision-hub                           1.7.4-202401161503
      voxl-voxblox                              1.1.5-202310122350
      voxl-wifi-broadcast                       0.0.10-202206122258
      voxl2-io                                  0.0.1-202401181810
      voxl2-system-image                        1.7.4-r0
      Scanning services...
      modallink-relink | Disabled | Not Running |
      voxl-camera-server | Enabled | Not Running |
      voxl-cpu-monitor | Enabled | Running | 0.7%
      voxl-feature-tracker | Disabled | Not Running |
      voxl-flow-server | Disabled | Not Running |
      voxl-imu-server | Enabled | Running | 6.0%
      voxl-lepton-server | Disabled | Not Running |
      voxl-lepton-tracker | Disabled | Not Running |
      voxl-mapper | Enabled | Running | 0.4%
      voxl-mavcam-manager | Enabled | Running | 0.0%
      voxl-mavlink-server | Enabled | Running | 4.4%
      voxl-microdds-agent | Disabled | Not Running |
      voxl-modem | Disabled | Not Running |
      voxl-neopixel-manager | Disabled | Not Running |
      voxl-open-vins-server | Disabled | Not Running |
      voxl-portal | Enabled | Running | 0.6%
      voxl-px4 | Enabled | Running | 38.9%
      voxl-qvio-server | Enabled | Running | 5.0%
      voxl-rangefinder-server | Disabled | Not Running |
      voxl-remote-id | Disabled | Not Running |
      voxl-softap | Disabled | Not Running |
      voxl-stitcher | Disabled | Not Running |
      voxl-streamer | Enabled | Running | 0.1%
      voxl-tflite-server | Disabled | Not Running |
      voxl-uvc-server | Disabled | Not Running |
      voxl-vision-hub | Enabled | Running | 1.8%
      voxl-wfb-rx-video | Disabled | Not Running |
      voxl-wfb-rx | Disabled | Not Running |
      voxl-wfb-tx-video | Disabled | Not Running |
      voxl-wfb-tx | Disabled | Not Running |
      voxl2:/$ voxl-camera-server
      voxl-camera-server: symbol lookup error: voxl-camera-server: undefined symbol: _ZTIN6royale3pal13II2cBusAccessE
      T 1 Reply Last reply 3 Apr 2024, 17:09 Reply Quote 0
      • T
        tom admin @riteshsharma
        @riteshsharma The current "dev" repo of voxl-suite isn't expected to work with system image 1.7.4 so there is some software version mismatching going on.
        You'd have to use a newer system image which at this point would only be available in one of our full nightly SDK builds
        R 1 Reply Last reply 3 Apr 2024, 20:01 Reply Quote 0
        • R
          riteshsharma @tom
          @tom In that case, how can I downgrade and go back to initial stage. Do you have any suggestion?
          T A 2 Replies Last reply 3 Apr 2024, 20:07 Reply Quote 0
          • T
            @riteshsharma I would recommend just re-flashing our latest standard SDK (1.1.3) to ensure you're at a clean spot
            https://docs.modalai.com/flash-system-image/#flashing-a-voxl-sdk-release
            • A
              Alex Kushleyev ModalAI Team @riteshsharma
              @riteshsharma , based on changelog (https://gitlab.com/voxl-public/voxl-sdk/services/voxl-camera-server/-/blob/master/CHANGELOG) you can use voxl-camera-server package version 1.8.10 -- dowload it from here http://voxl-packages.modalai.com/dists/qrb5165/dev/binary-arm64/.
              Upgrading your SDK would also work as Tom suggested.
              1 out of 5
