  3. VOXL 2 M0135 Dual Camera Connections with M0107 and M0149 Cameras
30 Posts 3 Posters 7.8k Views 2 Watching
  • WineVirusW Offline
    WineVirusW Offline
    WineVirus
    I'm pretty new to wiring/connectors/datasheets, so excuse me if my question seems a bit basic;
    I wanted to ask about connections for sensors. I have an M0107 and an M0149 sensor, the M0135 chip, on a VOXL 2 Mini. SDK 1.1.1. From what I've found, the M0107 sensor plugs into the JU port on the Dual Sensor chip, which plugs into the J7 port on the VOXL 2 Mini. Thus, the M0149 sensor plugs into the JL port on the M0135 chip. I have no idea if I'm correct. I'm doing my best to follow docs but I've hit a wall. Can someone confirm what the correct connections are?
    Thanks in advance!
    • WineVirusW WineVirus
      Thanks in advance!
      @WineVirus ,
      Here is one way of connecting these cameras via M0135 adapter:
      • make sure the power to VOXL2 is off before connecting / disconnecting cameras
      • for all connectors, look for pin 1 or white dot and match up the mating connectors so that pin 1 connects to pin 1
      • connect AR0144 (M0149) to M0135 JL (camera slot ID 2)
      • connect IMX412 (M0107) to M0135 JU (camera slot ID 3)
      • connect M0135 with the two cameras to VOXL mini J7
      Software setup:
      • since you are using SDK 1.1.1 and we have updated AR0144 driver since (based on this chanelog ), download the latest driver for camera slot #2 (com.qti.sensormodule.ar0144_2.bin) from here and put it in /usr/lib/camera/
      • copy the IMX412 driver cp /usr/share/modalai/chi-cdk/imx412/com.qti.sensormodule.imx412_3.bin /usr/lib/camera/
      Then if you run voxl-camera-server -l, it should detect two cameras and print our their resolutions. (if needed, stop voxl-camera-server service that may run in the background : systemctl stop voxl-camera-server
      Before you can use the cameras, you need to update /etc/modalai/voxl-camera-server.conf to look something like this:
      	"version":	0.1,
      	"cameras":	[{
      			"type":	"ar0144",
      			"name":	"tracking",
      			"enabled":	true,
      			"camera_id":	0,
      			"fps":	30,
      			"en_rotate":	false,
      			"en_preview":	true,
      			"preview_width":	1280,
      			"preview_height":	800,
      			"ae_mode":	"lme_msv",
      			"ae_desired_msv":	30,
      			"exposure_soft_min_us":	5000,
      			"ae_filter_alpha":	0.6,
      			"ae_ignore_fraction":	0.2,
      			"ae_slope":	0.05,
      			"ae_exposure_period":	1,
      			"ae_gain_period":	1,
      			"en_raw_preview":	true,
      			"type":	"imx412",
      			"name":	"hires",
      			"enabled":	true,
      			"camera_id":	1,
      			"fps":	30,
      			"en_rotate":	false,
      			"en_preview":	false,
      			"preview_width":	640,
      			"preview_height":	480,
      			"en_small_video":	false,
      			"small_video_width":	1280,
      			"small_video_height":	720,
      			"small_venc_mode":	"h265",
      			"small_venc_br_ctrl":	"cqp",
      			"small_venc_Qfixed":	30,
      			"small_venc_Qmin":	15,
      			"small_venc_Qmax":	40,
      			"small_venc_nPframes":	9,
      			"small_venc_mbps":	2,
      			"en_large_video":	true,
      			"large_video_width":	1920,
      			"large_video_height":	1080,
      			"large_venc_mode":	"h265",
      			"large_venc_br_ctrl":	"cqp",
      			"large_venc_Qfixed":	38,
      			"large_venc_Qmin":	15,
      			"large_venc_Qmax":	50,
      			"large_venc_nPframes":	29,
      			"large_venc_mbps":	5,
      			"en_snapshot":	false,
      			"en_snapshot_width":	1280,
      			"en_snapshot_height":	720,
      			"ae_mode":	"isp",
      			"en_raw_preview":	false
      Please follow these steps and let me know if you run into any issues. After the config file update, you should be able to start voxl camera server. You can do it in the foreground (assuming the background service is stopped), just run voxl-camera-server in the voxl2 terminal.
      A quick test to see if the cameras are running, you can do:
      voxl-inspect-cam -a
      should print all available camera sterams
      WineVirusW 2 Replies Last reply
        @WineVirus ,
        Software setup:
        	"version":	0.1,
        	"cameras":	[{
        			"type":	"ar0144",
        			"name":	"tracking",
        			"enabled":	true,
        			"camera_id":	0,
        			"fps":	30,
        			"en_rotate":	false,
        			"en_preview":	true,
        			"ae_slope":	0.05,
        			"type":	"imx412",
        			"name":	"hires",
        			"enabled":	true,
        			"camera_id":	1,
        			"fps":	30,
        			"en_rotate":	false,
        			"ae_mode":	"isp",
        voxl-inspect-cam -a
        WineVirusW Offline
        WineVirusW Offline
        WineVirus
          @WineVirus ,
          Software setup:
          	"version":	0.1,
          	"cameras":	[{
          			"type":	"ar0144",
          			"name":	"tracking",
          			"enabled":	true,
          			"camera_id":	0,
          			"fps":	30,
          			"en_rotate":	false,
          			"en_preview":	true,
          			"ae_slope":	0.05,
          			"type":	"imx412",
          			"name":	"hires",
          			"enabled":	true,
          			"camera_id":	1,
          			"fps":	30,
          			"en_rotate":	false,
          			"ae_mode":	"isp",
          voxl-inspect-cam -a
          WineVirusW Offline
          WineVirusW Offline
          WineVirus
          @Alex-Kushleyev voxl-camera-server -l outputs
          voxl2-mini:/$ voxl-camera-server -l
          DEBUG:   ----------- Number of cameras: 0
          DEBUG:   Note: This list comes from the HAL module and may not be indicative
          DEBUG:          of configurations that have full pipelines
          DEBUG:   Number of cameras: 0
          I also tried voxl-camera-server -s which gave me
          voxl2-mini:/$ voxl-camera-server -s
          GPS server Connected
          ERROR:   Did not detect any cameras plugged in
          ERROR:   Failed to get valid debug configuration
          I'm sure my connections are correct as detailed above (pin 1 on pin 1, correct JL/JU, and on the J7 port). Could it be a bad connector?
            @WineVirus , can you please provide a picture of the connected cameras to VOXL2 and contents of /usr/lib/camera on your VOXL2?
            WineVirusW 1 Reply Last reply
              WineVirusW Offline
              WineVirusW Offline
              WineVirus
              wrote on last edited by WineVirus
              @Alex-Kushleyev Here's the output of ./adb shell ls -la /usr/lib/camera . I'll take a picture of the connections when I can. Also, I'm using the VOXL 2 MINI, don't know if that makes any difference.
              total 4664 drwxr-xr-x 3 root root 4096 Mar 2 13:10 . drwxr-xr-x 69 root root 20480 Mar 2 12:59 .. -rwxr-xr-x 1 root root 9912 Oct 26 2023 com.qti.eeprom.cmk_imx577.so -rwxr-xr-x 1 root root 9904 Oct 26 2023 com.qti.sensor.ar0144.so -rwxr-xr-x 1 root root 5816 Oct 26 2023 com.qti.sensor.cmk_imx577.so -rwxr-xr-x 1 root root 5816 Oct 26 2023 com.qti.sensor.cmk_imx577_flip.so -rwxr-xr-x 1 root root 9904 Oct 26 2023 com.qti.sensor.imx214.so -rwxr-xr-x 1 root root 9912 Oct 26 2023 com.qti.sensor.imx214_flip.so -rwxr-xr-x 1 root root 9904 Oct 26 2023 com.qti.sensor.imx335.so -rwxr-xr-x 1 root root 5808 Oct 26 2023 com.qti.sensor.imx377.so -rwxr-xr-x 1 root root 9904 Oct 26 2023 com.qti.sensor.imx678.so -rwxr-xr-x 1 root root 9912 Oct 26 2023 com.qti.sensor.imx678_flip.so -rwxr-xr-x 1 root root 9912 Oct 26 2023 com.qti.sensor.imx678_mod.so -rwxr-xr-x 1 root root 5808 Oct 26 2023 com.qti.sensor.irs1645.so -rwxr-xr-x 1 root root 9904 Oct 26 2023 com.qti.sensor.ov7251.so -rwxr-xr-x 1 root root 9912 Oct 26 2023 com.qti.sensor.ov7251_front_left.so -rwxr-xr-x 1 root root 9920 Oct 26 2023 com.qti.sensor.ov7251_front_left_flip.so -rwxr-xr-x 1 root root 9920 Oct 26 2023 com.qti.sensor.ov7251_front_right.so -rwxr-xr-x 1 root root 9920 Oct 26 2023 com.qti.sensor.ov7251_front_right_flip.so -rwxr-xr-x 1 root root 9912 Oct 26 2023 com.qti.sensor.ov7251_fsin.so -rwxr-xr-x 1 root root 9912 Oct 26 2023 com.qti.sensor.ov7251_fsout.so -rwxr-xr-x 1 root root 9912 Oct 26 2023 com.qti.sensor.ov7251_rear_left.so -rwxr-xr-x 1 root root 9920 Oct 26 2023 com.qti.sensor.ov7251_rear_left_flip.so -rwxr-xr-x 1 root root 9912 Oct 26 2023 com.qti.sensor.ov7251_rear_right.so -rwxr-xr-x 1 root root 9920 Oct 26 2023 com.qti.sensor.ov7251_rear_right_flip.so -rwxr-xr-x 1 root root 9904 Oct 26 2023 com.qti.sensor.ov9782.so -rwxr-xr-x 1 root root 9912 Oct 26 2023 com.qti.sensor.ov9782_front_left.so -rwxr-xr-x 1 root root 9920 Oct 26 2023 com.qti.sensor.ov9782_front_left_flip.so -rwxr-xr-x 1 root root 9920 Oct 26 2023 com.qti.sensor.ov9782_front_right.so -rwxr-xr-x 1 root root 9920 Oct 26 2023 com.qti.sensor.ov9782_front_right_flip.so -rwxr-xr-x 1 root root 9912 Oct 26 2023 com.qti.sensor.ov9782_rear_left.so -rwxr-xr-x 1 root root 9920 Oct 26 2023 com.qti.sensor.ov9782_rear_left_flip.so -rwxr-xr-x 1 root root 9912 Oct 26 2023 com.qti.sensor.ov9782_rear_right.so -rwxr-xr-x 1 root root 9920 Oct 26 2023 com.qti.sensor.ov9782_rear_right_flip.so -rw-rw-rw- 1 root root 31984 Mar 26 2024 com.qti.sensormodule.ar0144_2.bin -rw-r--r-- 1 root root 578576 Mar 2 13:12 com.qti.sensormodule.imx412_flip_3.bin -rw-r--r-- 1 root root 142472 Mar 2 13:12 com.qti.sensormodule.ov7251_2.bin -rw-r--r-- 1 root root 957344 Oct 26 2023 com.qti.tuned.cmk_imx577.bin -rw-r--r-- 1 root root 835464 Oct 26 2023 com.qti.tuned.cmk_ov9282.bin -rw-r--r-- 1 root root 931864 Oct 26 2023 com.qti.tuned.default.bin -rw-r--r-- 1 root root 882376 Oct 26 2023 com.qti.tuned.sony_imx335.bin drwxr-xr-x 2 root root 4096 Oct 26 2023 components
                @WineVirus
                I will test your camera configuration on voxl2 mini running sdk 1.1.1 and will follow up soon.
                If you have a picture that will be helpful to confirm correct connections.
                  @WineVirus
                  Hi, I just connected the two cameras to voxl-2 mini running SDK 1.1.1.
                  For ar0144, please use the latest sensormodule file from this location . The one that comes with SDK 1.1.1 has stability issues.
                  #from your PC
                  adb push ~/Downloads/com.qti.sensormodule.ar0144_2.bin /usr/lib/camera/
                  #now on VOXL2 mini
                  voxl2-mini:/$ cp /usr/share/modalai/chi-cdk/imx412/com.qti.sensormodule.imx412_3.bin /usr/lib/camera/
                  DEBUG:   ----------- Number of cameras: 2
                  DEBUG:   Cam idx: 0, Cam slot: 2, Slave Address: 0x0030, Sensor Id: 0x0356
                  DEBUG:   Cam idx: 1, Cam slot: 3, Slave Address: 0x0034, Sensor Id: 0x0577
                  DEBUG:   Number of cameras: 2
                  The /etc/modalai/voxl-camera-server.conf should look like this (a good starting point):
                  	"version":	0.1,
                  	"cameras":	[{
                  			"type":	"ar0144",
                  			"name":	"tracking",
                  			"enabled":	true,
                  			"camera_id":	0,
                  			"fps":	30,
                  			"en_rotate":	false,
                  			"en_preview":	true,
                  			"ae_desired_msv":	60,
                  			"exposure_min_us":	20,
                  			"exposure_max_us":	33000,
                  			"gain_min":	54,
                  			"gain_max":	8000,
                  			"ae_gain_period":	1
                  			"type":	"imx412",
                  			"name":	"hires",
                  			"enabled":	true,
                  			"camera_id":	1,
                  			"fps":	30,
                  			"en_raw_preview":	false,
                  			"en_small_video":	true,
                  			"small_video_height":	800,
                  			"large_video_width":	3840,
                  			"large_video_height":	2160,
                  			"large_venc_mbps":	30,
                  			"en_snapshot_width":	4056,
                  			"en_snapshot_height":	3040,
                  			"ae_mode":	"isp"
                  then you can start voxl-camera-server in regular mode (without -l), it should run.
                  use voxl-inspect-cam -a to check video streams:
                  |           Pipe Name |  bytes  | wide |  hgt |exp(ms)| gain | frame id |latency(ms)|  fps |  mbps  | format
                  |   hires_large_color |12441600 | 3840 | 2160 | 33.23 | 1125 |      566 |     78.3  | 29.9 | 2974.3 | NV12
                  | hires_large_encoded |    4893 | 3840 | 2160 | 33.23 | 1125 |      566 |     89.2  | 29.9 |    1.3 | H265 (P)
                  |    hires_large_grey | 8294400 | 3840 | 2160 | 33.23 | 1125 |      567 |     70.6  | 29.9 | 1982.9 | RAW8
                  |   hires_small_color | 1536000 | 1280 |  800 | 33.23 | 1125 |      568 |     57.3  | 29.9 |  367.2 | NV12
                  | hires_small_encoded |    2710 | 1280 |  800 | 33.23 | 1125 |      568 |     60.9  | 29.9 |    1.8 | H265 (P)
                  |    hires_small_grey | 1024000 | 1280 |  800 | 33.23 | 1125 |      568 |     55.5  | 29.9 |  244.8 | RAW8
                  |            tracking | 1024000 | 1280 |  800 |  7.04 |  665 |     8043 |     20.7  | 30.0 |  245.6 | RAW8
                  Then you can use voxl-portal to view images (assuming you have a wired or wifi adapter plugged into your voxl2-mini:
                  (if voxl portal is not enabled, you can enable it):
                  systemctl enable voxl-portal
                  systemctl start voxl-portal
                  Then go to web browser and enter your voxl2-mini's ip to view voxl-portal
                  Alex KushleyevA WineVirusW 3 Replies Last reply
                    #from your PC
                    #now on VOXL2 mini
                    	"version":	0.1,
                    	"cameras":	[{
                    			"type":	"ar0144",
                    			"name":	"tracking",
                    			"enabled":	true,
                    			"camera_id":	0,
                    			"fps":	30,
                    			"en_rotate":	false,
                    			"en_preview":	true,
                    			"gain_min":	54,
                    			"gain_max":	8000,
                    			"ae_gain_period":	1
                    			"type":	"imx412",
                    			"name":	"hires",
                    			"enabled":	true,
                    			"camera_id":	1,
                    			"fps":	30,
                    			"ae_mode":	"isp"
                    images of my setup attached
                      #from your PC
                      #now on VOXL2 mini
                      	"version":	0.1,
                      	"cameras":	[{
                      			"type":	"ar0144",
                      			"name":	"tracking",
                      			"enabled":	true,
                      			"camera_id":	0,
                      			"fps":	30,
                      			"en_rotate":	false,
                      			"en_preview":	true,
                      			"gain_min":	54,
                      			"gain_max":	8000,
                      			"ae_gain_period":	1
                      			"type":	"imx412",
                      			"name":	"hires",
                      			"enabled":	true,
                      			"camera_id":	1,
                      			"fps":	30,
                      			"ae_mode":	"isp"
                      WineVirusW Offline
                      WineVirusW Offline
                      WineVirus
                      #10
                      @Alex-Kushleyev Here's what I'm seeing: bc33809b-869c-4beb-a235-a691d3cde4be-image.png
                      Here's the wiring; It looks the same as yours. IMG_1311 (1).jpg IMG_1312 (1).jpg
                        @WineVirus i believe you have M0135 plugged into J6 instead of J7 like I do. Take a look at my photo again.
                          WineVirusW Offline
                          WineVirusW Offline
                          WineVirus
                          @Alex-Kushleyev Ahh, yeah. My board is upside down, so I got turned around.
                          I'm now detecting one camera, but both are plugged in. I'm not sure which one this is?
                          DEBUG:   ----------- Number of cameras: 1
                          DEBUG:   Number of cameras: 1
                          Also, in terms of updating the config - is it a push command, like the ar0144 driver? Not sure what command to use in ADB.
                            @WineVirus please double check that you have com.qti.sensormodule.imx412_3.bin in /usr/lib/camera/ and also double check the orientation of the flex cable coming out of IMX412 camera inside your 3D printed enclosure. It should come straight away from the camera not towards to center of the camera PCB.
                            for the configuration file, you could edit it right on VOXL (using a command line text editor, like vi), or you can make a new file voxl-camera-server.conf on your PC with the exact contents that i posted and push it to /etc/modalai/
                              WineVirusW Offline
                              WineVirusW Offline
                              WineVirus
                              @Alex-Kushleyev Is there somewhere I can download the imx412_3.bin file? It's not in the output of ./adb shell ls -la /usr/lib/camera
                              The flex connector comes straight away from the camera.
                              I've pushed the server config file.
                                @WineVirus
                                  @WineVirus
                                  WineVirusW Offline
                                  WineVirusW Offline
                                  WineVirus
                                  @Alex-Kushleyev ok, the imx412_3 bin file is in /usr/lib/camera/, but I'm still only sensing 1 camera.
                                  Also, I'll be on spring break, so I apologize for a potential lack of response.
                                    @WineVirus Hmm. please double check to make sure all the connectors are seated properly. They should "snap in" as you insert them.
                                    If that does not work, it could be a bad cable for IMX412 camera, or something else. we can try putting IMX412 on JL, so it would e imx412_2, which you could also copy and try. Then AR0144 could be on JU, so you could download it from here : https://gitlab.com/voxl-public/voxl-sdk/services/voxl-camera-server/-/blob/master/misc_files/usr/share/modalai/voxl-camera-server/drivers/ar0144/com.qti.sensormodule.ar0144_3.bin
                                    Swapping the cameras can help figure out where the issue is. You can leave the existing sensormodules in there (no need to delete them), just add ar0144_3 and imx412_2
                                      #18
                                      If you switch the two cameras around, make sure double check pin 1 on the connector. JL and JU are rotated 180 degrees with respect to each other. You can also just test IMX412 and not connect AR0144 at all, if that is simpler, so that you could test IMX412 only.
                                        WineVirusW Offline
                                        WineVirusW Offline
                                        WineVirus
                                        @Alex-Kushleyev Ran through the troubleshooting steps (swapping both connections), still only getting one camera (same ID, just on the other slot). I think I'll just replace the cable.
                                        Can I work on the setup on only one sensor, with a simple way to add another one? Or will I have to redo the whole setup when I have both?
                                        existing instance of voxl-camera-server found, attempting to stop it
                                        DEBUG:   Cam idx: 0, Cam slot: 3, Slave Address: 0x0030, Sensor Id: 0x0356
                                        VinnyV 1 Reply Last reply
                                          VinnyV Offline
                                          VinnyV Offline
                                          Vinny
                                          wrote on last edited by Vinny
                                          #20
                                          Hi @WineVirus
                                          I think you are also using M0135 wrong.
                                          You can only use 1 of them on each J6 or J7, they cannot be cascaded.
                                          The way I see this here is not the correct usage:
                                          So the hires camera will never work like this.
                                          The one camera you do see is the tracking cam... this one:
                                          You must connect the module into M0135 directly only when plugged into the Voxl 2 Mini.
                                          It is not designed to use the extension flex to mate to another image sensor via M0135.
                                          In summary, remove this second M0135 and the M0036 extension flex:
                                          3347e9d8-6d9e-4071-960f-15feba9d5b92-image.png And plug the M0149 directly into M0135 here to mimic what Alex has demonstrated:
                                          Hope this helps.
                                          If I am mistaken, please let us know but this is what I gather from your photos.
